Amiga demo wheel
mastermark
  • Replies 59
Has anyone setup Amiga Demos in hyperspin ?? I got the games working great launching through WINUAE Launcher.
Can anyone talk me through just adding the demos too and also doing a .XML
Hi!
I have a guide for running the Amiga system with just WinUAE here: http://www.hyperspin-fe.com/forum/showthread.php?31472-Complete-Guide-for-Commodore-Amiga-in-HS-and-RL-Using-WinUAE-Only
But it works equally as well with floppy images.
There has also been some work done with adding games and demos to the wheel. Take a look at this: http://www.hyperspin-fe.com/forum/showthread.php?27858-*NEW*-Commodore-Amiga-XML-file
Hope this helps.
Thanks,
Ron
Link to comment
Share on other sites
Yes, add it as normal. The only problem I see you having is a default emulator not showing up. To combat that either open the module and add the system name to the MSystem line. So it will read...
MEmu = WinUAE Loader
MEmuV = v1.74
MURL = http://headsoft.com.au/index.php?category=winuaeloader
MAuthor = djvj
MVersion = 2.0
MCRC = 558D1E8B
iCRC = 4E0EC826
MID = 635038268935640326
MSystem = "Commodore Amiga","[b]Commodore Amiga Demos[/b]"
Or uncheck "Valid Module/Emulator only"
Link to comment
I've tried mine again with WinUAE Loader and it just crashes, so I have given up with that for the moment.
As a different approach, I've added then to a genre xml, so they are separate. Works perfectly with Winuae, but I did try adding it to it's own wheel, but some demos don't load, and I'm yet to figure out why.
Link to comment
Right MasterMark, I have this working on a separate wheel using WinUAE, and all the demos I've tried are working, it just needed a tweak to the module.
If you've followed Rons guide to getting Amiga games running with WinUAE then you should be able to use this.
I've called my system Amiga Demos because it fits the wheel better, but if you want it called something else let me know. I will then have to send you the required files, if your interested.
Link to comment
That would be great would I have to change things back what I've messed with. Ie adding Amiga demos to the m/system lines
Don't change anything for the minute, I will change it back and I've knocked up a wheel image. Everything will be drag and drop, I will dropbox you the files.
I will attempt a vid snap.
Link to comment
So backup your original files from the WinUAE Modules folder, then replace them with whats in the Dropbox including the Commodore Amiga Demos.ini
You then need to go here and here. And maybe change your path to your WHD folder.
That should be all thats required, if you already have WinUAE setup.
I did a basic theme also.
Link to comment
Very interested in having this set up but where can I find the WHDLOAD demos?
(Should be fine to ask about this publicly since they aren't commercial and were released for free, etc...)
Demobase is around 11gb and is a real mess, there is also a TOSEC set on PD at 13gb. I think SIC put together a smaller package of the best demos, which he or I could happily share.
If I can clean up my Dropbox I could share the Demobase as well.
Link to comment
