newoski Posted August 5, 2014 Posted August 5, 2014 Hi Guys, I've got all my emulators launching with HLHQ -- using the most up-to-date versions of everything -- but I'm having a terrible time with emulator window pop ups during game launching. At this point, I've tried everything I can possibly think of and am ready to offer up some compensation to someone who really knows HS / HL and is willing to help polish my bartop setup: i5-4670K ASUS GTX660 19" Dell 1908FP monitor 1280x1024 Resolution I'm in the Philadelphia area -- if anyone is relatively local, I'll be happy to drive to you -- or we can do TeamView etc. Shoot me a PM if you're interested. Thanks very much, Owen
rfancella Posted August 5, 2014 Posted August 5, 2014 Hi Guys, I've got all my emulators launching with HLHQ -- using the most up-to-date versions of everything -- but I'm having a terrible time with emulator window pop ups during game launching. At this point, I've tried everything I can possibly think of and am ready to offer up some compensation to someone who really knows HS / HL and is willing to help polish my bartop setup: i5-4670K ASUS GTX660 19" Dell 1908FP monitor 1280x1024 Resolution I'm in the Philadelphia area -- if anyone is relatively local, I'll be happy to drive to you -- or we can do TeamView etc. Shoot me a PM if you're interested. Thanks very much, Owen Owen, I will take no pay, but maybe we can help. What do you mean by emulator window pop ups? Do you have Fade enabled in HyperLaunchHQ? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
newoski Posted August 6, 2014 Author Posted August 6, 2014 Hi Ron, Thanks so much for the offer to help. Here's what I'm dealing with on multiple emulators: https://www.youtube.com/watch?v=6ylJ1HSFT40 You'll see the screen go black, then emulator windows will pop up, then the game will launch. Fade On/Off doesn't fix it.
HazzardActual Posted August 6, 2014 Posted August 6, 2014 I mean.... a lot of my emulators do the same... i dont see it as being much of an issue. Ron might have a trick up his sleeve though
ghutch92 Posted August 6, 2014 Posted August 6, 2014 Is the monitor changing resolution? How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
xHyperSteve Posted August 6, 2014 Posted August 6, 2014 I get little of that with some systems to. Don't let it bug you man! Ron, any ideas? Be sure to like! Also, subscribe to my YouTube Channel for more videos/HyperSteve https://twitter.com/HyperSteveShow
newoski Posted August 6, 2014 Author Posted August 6, 2014 Is the monitor changing resolution? Not that I can tell. There are no indicators on screen that a resolution change is taking place. Any way to monitor and know for sure?
rfancella Posted August 6, 2014 Posted August 6, 2014 Fade is about the only thing I can think of. What is that first screen that pops up? D-Fend Reloaded? Is there any setting in there to not display it? Or launch minimized? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
jamaster14 Posted August 6, 2014 Posted August 6, 2014 Not that I can tell. There are no indicators on screen that a resolution change is taking place. Any way to monitor and know for sure? you can lower your resolution and then launch HS and see if there is a difference to try and see if that is causing the issue or not
wesfranks Posted August 6, 2014 Posted August 6, 2014 Was working on this also. As rfancella mentions, I don't see a fade screen appear, just the emulator loading process. Fade hides this process so the loading process seems seamless. Try HyperlaunchHQ Settings- select system on left pane- Fade General tab (at top)- Fade In. Is this enabled? Enabling this setting turns it on for the selected system. Hyperlaunch, Hyperspin, emulators and other third party software (ex.- xpadder) are doing a lot of different things in the background during this time. If the Fade animation isn't on long enough and you still see loading popups, you may have to change the time in the Exit Delay block in milliseconds- 1000ms = 1 second. You can count how long it takes for the emulated game to fully appear and adjust the delay accordingly. Most of the time the default time "use_global" is long enough once fade is enabled. If not, change it. Warning- only enable fade once the emulator is loading games properly. If any problems arise or popups appear, fade will hide these also and you won't know what problems to fix.
