RELEASE: HyperSpin Checker
I wrote a simple application to help check what is missing in HyperSpin for your systems. I have been using this for a bit now and I think it works ok so I thought I would release it for all.
This application relies on the settings you enter into HyperHQ. You will need to specify your ROM path as well as whether or not to use a subfolder search. It also relies on the extensions in HyperHQ.
You need to unzip the EXE to a new folder of your choice. When you run the application you can choose which system you want to process or you can process all systems. It will create a text file for each system that shows you what you are missing.
Please give it a try if you wish.
Feedback always welcome.
Enjoy :)
HyperSpin Checker 1.0.16
HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer
ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
  • Replies 95
I have updated the app. The link in the first thread is updated.
The reports will now be created in a reports subfolder. It will also store xml files about each system in the data folder.
You can then use the Reports button on my main page to show you what you are missing for each game in each system.
It will highlight a game in red if anything is missing for the game.
Check it out and let me know what you think.
I have updated the app to 1.0.2
I have attempted to check the artwork folder. This is a hit and miss first attempt at this. Please try it out and let me know how it goes.
Thx
I must have telekinetic powers, because I was just thinking how cool it would be to have a program like this. I'm currently using HyperSync for this (which is a great program), but this seems like it simplifies things a lot more. Downloading now and I'll let you know how it goes. Thanks!
There was an issue with the 1.0.2 zip file. I have corrected it so you may need to download the zip again.
I run the check but it never does anything, just says scan is done right away. Then I click on reports and it JIT errors that it can't find the xml file in the data folder, when I click to go to the report I just checked. The data folder is empty as well.
Win 7 x64.
I am using Win7 64bit as well.
Just specify your Hyperspin folder, select the system or ALL and click Check.
Make sure you download the latest zip because if you downloaded it when i first put it up it was missing a file. You should have an exe and a dll in your folder. If not then download the zip again and try it.
Do you have the information in HyperHQ filled out for the 2600?
Does it show any info about the atari 2600?
The database XML is no different than my 5200 database XML.
This is all the XML shows in the checker after doing a scan:
<?xml version="1.0" encoding="utf-8" standalone="yes"?>
<system />
Does the 5200 work when scanned?
The app does not alter the xml at all... only reads it
Send me a PM with your 2600 xml file and I will try it here.
Thx
I replied.
I also updated the zip file to get rid of the message box that pops up. I forgot to remove that :)
I updated the build to 1.0.4
This includes the ability to cancel the check in progress.
It will also dsplay an error message if it has issues with parsing an xml file. It will tell you the line number that gace the issue.
The biggest issue will be the & in the xml file. You must use & for all ampersands.
Enjoy :)
HyperSpin Checker 1.0.4
BladeZX,
First thanks for the application, repairs will be very useful, although I'm using x64 Win7 and gave the error described below.
thanks
Consulte o final desta mensagem para obter detalhes sobre como chamar a
depuração just-in-time (JIT) em vez desta caixa de diálogo.
************** Texto de Exceção **************
System.Xml.XmlException: Caractere inválido na codificação fornecida. Linha 57, posição 27.
  em System.Xml.XmlTextReaderImpl.Throw(Exception e)
  em System.Xml.XmlTextReaderImpl.InvalidCharRecovery(Int32& bytesCount, Int32& charsCount)
  em System.Xml.XmlTextReaderImpl.GetChars(Int32 maxCharsCount)
  em System.Xml.XmlTextReaderImpl.ReadData()
  em System.Xml.XmlTextReaderImpl.ParseAttributeValueSlow(Int32 curPos, Char quoteChar, NodeData attr)
  em System.Xml.XmlTextReaderImpl.ParseAttributes()
  em System.Xml.XmlTextReaderImpl.ParseElement()
  em System.Xml.XmlTextReaderImpl.ParseElementContent()
  em System.Xml.XmlLoader.LoadNode(Boolean skipOverWhitespace)
  em System.Xml.XmlLoader.LoadDocSequence(XmlDocument parentDoc)
  em System.Xml.XmlDocument.Load(XmlReader reader)
  em System.Xml.XmlDocument.Load(String filename)
  em HyperSpin_Checker.frmMain.Get_System_Names()
  em HyperSpin_Checker.frmMain.Load_Systems()
  em HyperSpin_Checker.frmMain.Process_Selected_Folder()
  em HyperSpin_Checker.frmMain.btnBrowse_Click(Object sender, EventArgs e)
  em System.Windows.Forms.Control.OnClick(EventArgs e)
  em System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
  em System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
  em System.Windows.Forms.Control.WndProc(Message& m)
  em System.Windows.Forms.ButtonBase.WndProc(Message& m)
  em System.Windows.Forms.Button.WndProc(Message& m)
  em System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
  em System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Conjuntos de Módulos (Assemblies) Carregados **************
mscorlib
   Versão do Conjunto de Módulos (Assembly): 2.0.0.0
   Versão do Win32: 2.0.50727.5446 (Win7SP1GDR.050727-5400)
   Base de Código: file:///C:/Windows/Microsoft.NET/Framework64/v2.0.50727/mscorlib.dll
HyperSpin Checker
   Versão do Conjunto de Módulos (Assembly): 1.0.4.0
   Versão do Win32: 1.0.4.0
   Base de Código: file:///D:/H%20I%20P%20E%20R%20S%20P%20I%20N/HyperSpin%20Install%201.1%20Final/HSTE/Ferramentas%20Checagem/HyperSpin%20Checker/HyperSpin%20Checker.exe
Microsoft.VisualBasic
   Versão do Conjunto de Módulos (Assembly): 8.0.0.0
   Versão do Win32: 8.0.50727.5420 (Win7SP1.050727-5400)
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
   Versão do Win32: 2.0.50727.5442 (Win7SP1GDR.050727-5400)
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
   Versão do Win32: 2.0.50727.5420 (Win7SP1.050727-5400)
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
System.Xml
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
mscorlib.resources
System.XML.resources
   Versão do Win32: 2.0.50727.4927 (NetFXspW7.050727-4900)
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System.Xml.resources/2.0.0.0_pt-BR_b77a5c561934e089/System.Xml.resources.dll
System.Windows.Forms.resources
   Base de Código: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms.resources/2.0.0.0_pt-BR_b77a5c561934e089/System.Windows.Forms.resources.dll
************** Depuração JIT **************
Para habilitar a depuração just-in-time (JIT), o arquivo .config deste
aplicativo ou computador (machine.config) deve ter o valor
jitDebugging definido na seção system.windows.forms.
O aplicativo também deve ser compilado com a depuração
habilitada.
Por exemplo:
<configuration>
   <system.windows.forms jitDebugging="true" />
</configuration>
Quando a depuração JIT está habilitada, qualquer exceção não tratada
será enviada ao depurador JIT registrado no computador,
em vez de ser tratada nesta caixa de diálogo.
Can you translate this into english for me please
Also... it seems to be an xml error. Can you please send me the xml file for the system it was processing when this happened.
Thx
Updated app.
The app will now report if the system wheel, theme, default theme and video exist on the report text file.
  • 4 months later...
Having an issue with the Sega Model 3 xml on HyperList. Won't process the file and create the file in the data folder for reporting, so it throws a JIT error saying it can't find the xml file in the data directory. Using 1.0.6. Tried changing ' to ' but it didn't fix the issue.
<?xml version="1.0"?>
<menu>
<header>
	<listname>Sega Model 3</listname>
	<lastlistupdate>11/18/2011</lastlistupdate>
	<listversion>1.0</listversion>
	<exporterversion>HyperList XML Exporter Version 1.3 Copywrite (c) 2009-2011 William Strong</exporterversion>
</header>
<game name="von2" index="true" image="c">
	<description>Cyber Troopers Virtual-On Oratorio Tangram</description>
	<cloneof></cloneof>
	<crc></crc>
	<manufacturer>Sega</manufacturer>
	<year>1998</year>
	<genre>Action</genre>
	<rating>AAMA - Yellow (Animated Violence Mild)</rating>
	<enabled>Yes</enabled>
</game>
<game name="von254g" index="" image="">
	<description>Cyber Troopers Virtual-On Oratorio Tangram (Ver. 5.4g) </description>
	<cloneof>von2</cloneof>
	<crc></crc>
	<year>1998</year>
</game>
<game name="daytona2" index="true" image="d">
	<description>Daytona USA 2: Battle on the Edge</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
	<genre>Driving</genre>
	<rating>AAMA - Green (Suitable For All Ages)</rating>
</game>
<game name="dayto2pe" index="" image="">
	<description>Daytona USA 2: Power Edition</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
</game>
<game name="dirtdvls" index="" image="">
	<description>Dirt Devils</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
</game>
<game name="dirtdvlsa" index="" image="">
	<description>Dirt Devils (Alternate)</description>
	<cloneof>dirtdvls</cloneof>
	<crc></crc>
	<year>1998</year>
</game>
<game name="fvipers2" index="true" image="f">
	<description>Fighting Vipers 2</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
	<genre>Fighter</genre>
	<rating>AAMA - Yellow (Life Like Violence Mild)</rating>
</game>
<game name="lemans24" index="true" image="l">
	<description>Le Mans 24</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1997</year>
</game>
<game name="lostwsga" index="" image="">
	<description>Lost World, The: Jurassic Park</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1997</year>
	<genre>Gun</genre>
</game>
<game name="scud" index="true" image="s">
	<description>Scud Race (Australia)</description>
	<cloneof>scudp</cloneof>
	<crc></crc>
	<year>1996</year>
</game>
<game name="scuda" index="" image="">
	<description>Scud Race (Export)</description>
	<crc></crc>
	<year>1996</year>
</game>
<game name="scudj" index="" image="">
	<description>Scud Race (Japan)</description>
	<crc></crc>
	<year>1996</year>
</game>
<game name="scudp" index="" image="">
	<description>Scud Race Plus</description>
	<cloneof>scud</cloneof>
	<crc></crc>
	<year>1997</year>
</game>
<game name="srally2" index="" image="">
	<description>Sega Rally 2</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
</game>
<game name="spikeout" index="" image="">
	<description>Spikeout</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
	<genre>Beat-'Em-Up</genre>
</game>
<game name="spikeofe" index="" image="">
	<description>Spikeout Final Edition</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1999</year>
</game>
<game name="swtrilgy" index="" image="">
	<description>Star Wars Trilogy Arcade (Rev. A)</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
	<genre>Shooter</genre>
</game>
<game name="vf3" index="true" image="v">
	<description>Virtua Fighter 3</description>
	<cloneof>vf3a</cloneof>
	<crc></crc>
	<year>1996</year>
</game>
<game name="vf3a" index="" image="">
	<description>Virtua Fighter 3 (Rev. A)</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1996</year>
</game>
<game name="vs29815" index="" image="">
	<description>Virtua Striker 2 '98 (Step 1.5)</description>
	<cloneof>vs298</cloneof>
	<crc></crc>
	<year>1998</year>
	<genre>Sports/Soccer</genre>
</game>
<game name="vs298" index="" image="">
	<description>Virtua Striker 2 '98 (Step 2.0)</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1998</year>
</game>
<game name="vs215" index="" image="">
	<description>Virtua Striker 2 (Step 1.5)</description>
	<cloneof>vs2</cloneof>
	<crc></crc>
	<year>1997</year>
</game>
<game name="vs2" index="" image="">
	<description>Virtua Striker 2 (Step 2.0)</description>
	<cloneof></cloneof>
	<crc></crc>
	<year>1997</year>
</game>
</menu>
  • 1 month later...
hello,
can you add support for PNG checking as Videos?
Hyperspin also allows static PNG images instead of FLV videos.
all my PNG's are not reported unfortunately.
thanks
alex
hello,
thanks
alex
Try the latest build
All it does is read your console xml files. It uses some settings in the ini files as well.
