Trnzaddict Posted December 23, 2025 Posted December 23, 2025 Hi, Not sure what's going on but I have a curated set of 300 MAME 0.283 non-merged Roms. I did a fresh install of HyperQ & HyperSpin. I select my MAME executable, Rom directory and options etc. Start the install process. HyperQ is importing 14,398 roms. I don't know where it's getting that amount from, but it's like it ignores my curated romset and imports every single arcade game playable in MAME. I've probably tried from scratch about 5 times now and it's always ending up with the 14,398 games. Are there any known bugs right now with the MAME import process? Thanks 1 I am......Machine
dreamw Posted December 24, 2025 Posted December 24, 2025 I have the same problem. I have about 3,000 selected games from the general ROM set, but after adding them to my MAME, it also finds about 14,000 games. It seems to me that after specifying exceptions (casino, mechanical, etc.), it simply takes the game names from ITS GENERAL list and adds them, without taking into account what is actually in the user's games folder. We need an option for it to generate a list of games by scanning ACTUAL ROMs IN THE user's FOLDER. 1
Circo Posted December 25, 2025 Posted December 25, 2025 There is a new release of the mame plugin for the next build. Couple more days, right after Christmas I was told. The testing team had oodles of feedback. 2 ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Trnzaddict Posted December 25, 2025 Author Posted December 25, 2025 Ok great. Just wanted to make sure it’s not user error on my part. I am......Machine
Circo Posted December 25, 2025 Posted December 25, 2025 @TrnzaddictThere are going to be two types of import when it’s final. One that supports a full mame rom set split/merged/non-merged (most common) and a secondary import type for your curated rom set (less common) Talked with frosty, main reason for two types is if your using a full romset but want arcade only, hs will still be able (optionally) to create any available subsystems through the collection system ie game and watch, jakks pacific, etc and you can turn them on to have more wheel systems. (Probably a month out or so) that secondary import hasn’t been added to the plugin yet. 1 ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
fr0stbyt3 Posted December 27, 2025 Posted December 27, 2025 @Trnzaddict can you show me what filters you selected when you added MAME? I want to run a quick test and make sure we have you fixed up! 1
Trnzaddict Posted December 27, 2025 Author Posted December 27, 2025 Hi Frosty - I use my own standalone MAME installation, pick non-merged (which is the format my 300 rom curated set is in), select all filters on the exclusion page to filter out all the crap, keep the trackball, lightgun and spinner games because my cab has all that, and prioritize North America & 2 Players. After scanning it imports 14,398 roms. Just one more thing, I’m confused what changed here. Months ago I was able to import my 300 rom set no problem, but now the MAME plugin doesn’t support it and it needs to be added in? Why was it removed? I am......Machine
Circo Posted December 27, 2025 Posted December 27, 2025 1 hour ago, Trnzaddict said: Hi Frosty - I use my own standalone MAME installation, pick non-merged (which is the format my 300 rom curated set is in), select all filters on the exclusion page to filter out all the crap, keep the trackball, lightgun and spinner games because my cab has all that, and prioritize North America & 2 Players. After scanning it imports 14,398 roms. Just one more thing, I’m confused what changed here. Months ago I was able to import my 300 rom set no problem, but now the MAME plugin doesn’t support it and it needs to be added in? Why was it removed? In the plugin there is this super fancy new mame installer, set to do all kinds of filtering and eventually populating collections and other systems…. BUT…. Support for a custom mame set (non-fancy, just a few roms) isn’t currently there. I’m sure it will be but right now, that’s what’s causing your problem. Probably more of an oversight than anything. 1 ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
fr0stbyt3 Posted December 28, 2025 Posted December 28, 2025 @Trnzaddict Hey! Good question. We redesigned the MAME plugin to use MAME's listxml as the default source for building game lists instead of scanning your ROM folder. This gives us better metadata and parent/clone handling for users with complete sets. Your 300 ROM curated set is still supported - we're adding the User ROMs option back in an upcoming update (should be out within the next month or so). That'll scan your folder directly like the old behavior. We shifted the default because most testers have complete MAME sets, but curated collections will work fine once that option is back. 1 1
davyd Posted January 2 Posted January 2 (edited) Tried to go with MAME and a new 0.284 install, default options "select all" but setup immediately (at 5%) reports "failed, MAME plugin missing" (or similar) and the wizard hangs at "Preparing MAME installation". EDIT: ok found the plugin in main view, and after I installed it, things worked for me - also with apparently 44xxx games I certainly don't have Edited January 2 by davyd Found plugin
Circo Posted January 2 Posted January 2 Import option 1 assumes a full mame rom set of any type. If you have pre filtered or customized your Roms set in any way then use option 2. 2 ___________________________________ HyperSpin Website Admin Team Also Visit EmuMovies.com
Trnzaddict Posted January 9 Author Posted January 9 On 12/27/2025 at 8:19 PM, fr0stbyt3 said: @Trnzaddict Hey! Good question. We redesigned the MAME plugin to use MAME's listxml as the default source for building game lists instead of scanning your ROM folder. This gives us better metadata and parent/clone handling for users with complete sets. Your 300 ROM curated set is still supported - we're adding the User ROMs option back in an upcoming update (should be out within the next month or so). That'll scan your folder directly like the old behavior. We shifted the default because most testers have complete MAME sets, but curated collections will work fine once that option is back. Hi Frosty. So I tried using the new curated set option, and the system now hangs at 5% with "Handing off to MAME Plugin". I've tried a bunch of things to remedy this, including reinstalling HyperQ and deleting and reinstalling the MAME plugin. Any thoughts? 1 I am......Machine
jesfknkrys Posted January 9 Posted January 9 @Trnzaddict You can follow this thread. Hopefully it helps. 1
Trnzaddict Posted January 17 Author Posted January 17 Unfortunately not working. I’ve done everything. Deleted entire install, ran HS Reset script, downloaded and installed latest HyperQ, reinstalled MAME plugin. Still hangs at 10%. Not sure what else to do at this point. I am......Machine
thatman84 Posted January 17 Posted January 17 1 hour ago, Trnzaddict said: Unfortunately not working. I’ve done everything. Deleted entire install, ran HS Reset script, downloaded and installed latest HyperQ, reinstalled MAME plugin. Still hangs at 10%. Not sure what else to do at this point. I think you may be right. I think wait for the next public release. I shouldn’t be to far away. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Trnzaddict Posted yesterday at 05:30 PM Author Posted yesterday at 05:30 PM This is still broke even after with the newest updates. Well, partially broke. The MAME plugin cannot handle a curated set over 270 games it seems. Anything over around 270 roms and it hangs at 10% "Handing off to MAME plugin" Is this working for anyone? I am......Machine
thatman84 Posted 3 hours ago Posted 3 hours ago On 2/2/2026 at 5:30 PM, Trnzaddict said: This is still broke even after with the newest updates. Well, partially broke. The MAME plugin cannot handle a curated set over 270 games it seems. Anything over around 270 roms and it hangs at 10% "Handing off to MAME plugin" Is this working for anyone? Just testing now. 275 rom files imported. 295 sitting at 10%. Should be helpful info for the devs Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
