program to synchronize backup copy of hyperspin on my external hard drive
i was using synctoy but it is crap
with synctoy...if you change something on backup.....it does not replace it next time you sync etc
check out "DSYNCHRONIZE"
this program seems AWESOME so far
keeps an exact copy as far as i can tell
after the initial scan only takes a minute or so to do a backup
100% free
easy to use
on the backup file it will delete files that have been deleted on the original file
on the backup file it will add files that have been added to the original file
on the backup file it will replace files that have been changed in the original file (i.e. if you REPLACE one wheel image with another (with same name))
scroll down for "DSYNCHRONIZE'"
http://dimio.altervista.org/eng/
(i have no financial relationship to this program)
i just did a backup
here is what it looks like
Does it sync to multiple target drives?
Yes Albert
Cool. Because I have a very specific application that I want to use this for :). Mubawahahahaha!
FreeFileSync here also, it does exactly what i want it to do. There are alot of options, from doing a 2 way sync, to doing just a one way (Mirror). For backing up, i just use the Mirror mode, works perfectly :D
Even options on how it will do the comparison, for speed you can do date/size and for those that time doesn't matter you can do a crc comparison. I recommend date/size as the normal for a backup with a crc sync every once in a while.
Another here for FreeFileSync. As long as you are careful when you install, you will not get any of the adware/3rd party crap. FreeFileSync is quite a bit more flexible than dsynchronize, however if it (dsynchronize) does what you need it to do there is no need to switch. I'm just providing info for future reference.
