spudgunjake Posted January 18, 2015 Posted January 18, 2015 I have uploaded the commodore Vic-20 theme and everything to https://mega.co.nz/#F!CNoUEYhB!JC4x_vHHVZzm-eDFTiQ4Wg enjoy any problems please email me.
brolly Posted January 19, 2015 Posted January 19, 2015 Did you make the 3D boxart set yourself? If so where did you manage to find the spine scans for some of those cardboard boxes?
Fromlostdays Posted January 19, 2015 Posted January 19, 2015 Have set this up and everything works. Dude thanks for putting all this together. I'm not too savvy with winvice, though. Do you know how to have it launch fullscreen? Changing the setting in HL doesn't have an effect. Thanks again. Walter:beerglass:
spudgunjake Posted January 19, 2015 Author Posted January 19, 2015 if I can find it ill upload the images for you.
horseyhorsey Posted January 19, 2015 Posted January 19, 2015 Did you make the 3D boxart set yourself? If so where did you manage to find the spine scans for some of those cardboard boxes? I haven't looked, but I'm guessing Vicman, who did the videos on emumovies. Weed Me! HS App: HLM-Check Beta: PinXCheckTunes: http://soundcloud.com/vade/mistys-mind-horse-mix HyperSpin Multiplayer - Take Your Cab online
jcm9800 Posted January 19, 2015 Posted January 19, 2015 thanks that you share this with us spudgun works great add the bezel funktion for myself to the module [sIGPIC][/sIGPIC]
brolly Posted January 19, 2015 Posted January 19, 2015 if I can find it ill upload the images for you. Thanks, that would be great. Or if they are hosted on some site that will do as well and I'll grab them myself. I haven't looked, but I'm guessing Vicman, who did the videos on emumovies. I don't think so, at least last time I checked with him he didn't have that many spine scans for the cardboard boxes.
spudgunjake Posted January 20, 2015 Author Posted January 20, 2015 I did a lot of them and I mean a lot.
potts43 Posted January 20, 2015 Posted January 20, 2015 thanks that you share this with us spudgun works great add the bezel funktion for myself to the module If you have a working bezel module can you share it please?
rfancella Posted January 20, 2015 Posted January 20, 2015 If you have a working bezel module can you share it please? Potts, The most up to date module for WinVICE in the GIT has bezel support. Otherwise, check my signature for the module. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
potts43 Posted January 20, 2015 Posted January 20, 2015 Potts,The most up to date module for WinVICE in the GIT has bezel support. Otherwise, check my signature for the module. Thanks, Ron Oh cheers Ron ;-)
guyverjay Posted January 20, 2015 Posted January 20, 2015 But isn't this set up using a customised module?
rfancella Posted January 20, 2015 Posted January 20, 2015 But isn't this set up using a customised module? Just installed this setup. Thanks to spudgunjake for all this work. It is a modified module of old. I will see what I can do to integrate these changes into the newest module. There have been a ton of changes to this module. Thanks, Ron PS: Looks like most games will run with the official module except the vsd and 8k games. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
craiganderson Posted January 22, 2015 Posted January 22, 2015 awesome setup. thanks a million. even though i have the same emulator the save state files only worked with the one in your download. maybe because yours is the win32 whereas mine was the win64...just fyi either way....working now! awesome job!! thank you very much -craig http://craigandersonthemes.weebly.com/
craiganderson Posted January 22, 2015 Posted January 22, 2015 I added bezel support to the module that was included in the download. I like the fixed res option so that is what i used. The bezel is originally a Grizz bezel. Had to move the bottom border up just a little to cover up emulator. But I like knowing that because i am using the fixed res option that the dimensions of the screen are as the emulator intended....just fyi its not perfect..just fyi MEmu = WinVICE MEmuV = v2.4 MURL = http://vice-emu.sourceforge.net/ MAuthor = djvj,wahoobrian,brolly,Spudgunjake MVersion = 2.0.2 MCRC = BA37ED39 iCRC = DAA4D1EA MID = 635038268966170754 MSystem = "Commodore VIC-20" ;---------------------------------------------------------------------------- ; Notes: ; Roms must be unzipped. ; You can turn off the exit confirmation box by unchecking Settings->Confirm on exit ; Turn on saving settings by checking Settings->Save settings on exit, this will create the vice.ini file this module needs. ; ; If you want to use the StartTape and StopTape hotkeys make sure you edit the files C64\win_shortcuts.vsc or VIC20\win_shortcuts.vsc ; (paths relative to the emulator install folder) and assign Alt+F7 as the StartTape shortcut and Alt+F8 as the StopTape shortcut, like this: ; ALT 0x76 IDM_DATASETTE_CONTROL_START F7 ; ALT 0x77 IDM_DATASETTE_CONTROL_STOP F8 ; ; WinVICE uses different executables for each machine so make sure you setup your emulators properly: ; x64.exe - Commodore 64 ; xplus4.exe - Commodore 16 & Plus/4 ; xvic.exe - Commodore VIC-20 ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() mType := Object("Commodore 64","C64","Commodore 16 & Plus4","PLUS4","Commodore VIC-20","VIC20") ;ident should be the section names used in VICE.ini ident := mType[systemName] ; search object for the systemName identifier IfExist, % modulePath . "\" . systemName . ".ini" ; use a custom systemName ini if it exists settingsFile := modulePath . "\" . systemName . ".ini" Else settingsFile := modulePath . "\" . moduleName . ".ini" ;msgbox 4,,%settingsFile% Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1) ; If true, the module governs if the emulator launches fullscreen or not. Set to false when troubleshooting a module for launching problems. WarpKey := IniReadCheck(settingsFile, "Settings", "WarpKey","F9",,1) ; toggle warp speed JoySwapKey := IniReadCheck(settingsFile, "Settings", "JoySwapKey","F10",,1) ; swap joystick port StartTapeKey := IniReadCheck(settingsFile, "Settings", "StartTapeKey","F7",,1) ; starts tape StopTapeKey := IniReadCheck(settingsFile, "Settings", "StopTapeKey","F8",,1) ; stops tape SelectGameMode := IniReadCheck(settingsFile, "Settings", "SelectGameMode","1",,1) ; 1 = Uses a loop to detect the Edit Box has the romname and path in it. This doesn't work on all PCs, so if you get stuck at the open rom window, use mode 2. 2 = Uses a simple Ctrl+v to paste the romname and path, then press Enter to load the game. ; DiskSwapKey = F11 ; swaps disk or tape - Do not need this key anymore with multigame support UsePaddles := IniReadCheck(settingsFile, romName, "UsePaddles", "false",,1) AutostartPrgMode := IniReadCheck(settingsFile, romName, "AutostartPrgMode", "2",,1) RequiresReset := IniReadCheck(settingsFile, romName, "RequiresReset", "false",,1) BezelStart("fixResMode") 7z(romPath, romName, romExtension, 7zExtractPath) viceINI := CheckFile(emuPath . "\vice.ini") IniRead, currentFullScreen, %viceINI%, %ident%, FullscreenEnabled IniRead, currentAutostartPrgMode, %viceINI%, %ident%, AutostartPrgMode ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = 1 ) IniWrite, 0, %viceINI%, %ident%, FullscreenEnabled Else If ( Fullscreen = "true" And currentFullScreen = 0 ) IniWrite, 1, %viceINI%, %ident%, FullscreenEnabled If ( currentAutostartPrgMode != AutostartPrgMode ) IniWrite, %AutostartPrgMode%, %viceINI%, %ident%, AutostartPrgMode WarpKey := xHotKeyVarEdit(WarpKey,"WarpKey","~","Add") JoySwapKey := xHotKeyVarEdit(JoySwapKey,"JoySwapKey","~","Add") StartTapeKey := xHotKeyVarEdit(StartTapeKey,"StartTapeKey","~","Add") StopTapeKey := xHotKeyVarEdit(StopTapeKey,"StopTapeKey","~","Add") xHotKeywrapper(WarpKey,"Warp") xHotKeywrapper(JoySwapKey,"JoySwap") xHotKeywrapper(StartTapeKey,"StartTape") xHotKeywrapper(StopTapeKey,"StopTape") If romName contains (USA),(Canada) DefaultVideoMode = NTSC Else DefaultVideoMode = PAL VideoMode := IniReadCheck(settingsFile, romName, "VideoMode", DefaultVideoMode,,1) params := "+confirmexit" ; Setting video mode depending on rom, default NTSC if (VideoMode = "NTSC") { params := params . " -ntsc" ;IniWrite, -2, %viceINI%, %ident%, MachineVideoStandard ;NTSC } else { params := params . " -pal" ;IniWrite, -1, %viceINI%, %ident%, MachineVideoStandard ;PAL } ;Enable/Disable paddles as needed, leave these checks in-place because mouse CLI and Ini options aren't supported in VICE 1.22 and this way it will also work with it. IniRead, currentUsePaddles, %viceINI%, %ident%, Mouse If ( UsePaddles = "true" And currentUsePaddles != 1) params := params . " -mouse -mousetype 3" If ( UsePaddles = "false" And currentUsePaddles = 1) params := params . " +mouse" If (ident = "C64") { If romExtension not in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.t64,.tap,.crt ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nd64,d71,d80,d81,d82,g64,g41,x64,t64,tap,crt") If ( romExtension = ".crt" ) { IniWrite, %romPath%\%romName%%romExtension%, %viceINI%, C64, CartridgeFile IniWrite, 0, %viceINI%, C64, CartridgeType } Else { IniWrite, -1, %viceINI%, C64, CartridgeType } ; Hotkey, ~%DiskSwapKey%, MultiGame If romExtension in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.prg Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension in .t64,.tap Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension = .crt Run(executable . " " . params . " -cartcrt """ . romPath . "\" . romName . romExtension . """", emuPath) if (RequiresReset = "true") { WinWaitActive("ahk_class VICE") Sleep, 1000 ; increase if command is not appearing in the emu window or some just some letters Send !r } } Else If (ident = "PLUS4") { If romExtension not in .prg,.d64,.t64,.tap,.crt,.g64 ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,t64,tap,crt,g64") SendCommandDelay := IniReadCheck(settingsFile, "Settings", "SendCommandDelay", "1500",,1) Model := IniReadCheck(settingsFile, romName, "Model", "Commodore Plus/4",,1) ; Setting model If (Model = "Commodore Plus/4") { ;Commodore Plus/4 IniWrite, "3plus1lo", %viceINI%, %ident%, FunctionLowName IniWrite, "3plus1hi", %viceINI%, %ident%, FunctionHighName IniWrite, 64, %viceINI%, %ident%, RamSize IniWrite, 1, %viceINI%, %ident%, Acia1Enable } Else { ;Commodore 16 IniWrite, "", %viceINI%, %ident%, FunctionLowName IniWrite, "", %viceINI%, %ident%, FunctionHighName IniWrite, 16, %viceINI%, %ident%, RamSize IniWrite, 0, %viceINI%, %ident%, Acia1Enable } Command := IniReadCheck(settingsFile, romName, "Command", "",,1) StringLower, Command, Command ;Command MUST be in lower case so let's force it If romExtension in .d64,.g64,.prg Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension in .t64,.tap Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension = .crt Run(executable . " " . params . " -cartcrt """ . romPath . "\" . romName . romExtension . """", emuPath) if (RequiresReset = "true") { WinWaitActive("ahk_class VICE") Sleep, 1000 ; increase if command is not appearing in the emu window or some just some letters Send !r } if %Command% { WinWaitActive("ahk_class VICE") Sleep, %SendCommandDelay% ; increase if command is not appearing in the emu window or some just some letters If romExtension in .t64,.tap { ;Tape loading time will vary greatly so we can't type this automatically, user must do it using a hotkey RunTapeKey := IniReadCheck(settingsFile, romname, "RunTapeKey","Ctrl&F12",,1) ; run tape key RunTapeKey := xHotKeyVarEdit(RunTapeKey,"RunTapeKey","~","Add") xHotKeywrapper(RunTapeKey,"RunTape") } Else { SetKeyDelay, 50 Loop, parse, Command Send, {%A_LoopField% down}{%A_LoopField% up} Send, {ENTER down}{ENTER up} } } } Else If (ident = "VIC20") { If romExtension not in .prg,.d64,.t64,.tap,.crt,.vsf ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,t64,tap,crt,vsf") SendCommandDelay := IniReadCheck(settingsFile, "Settings", "SendCommandDelay", "1500",,1) CartAddress := IniReadCheck(settingsFile, romName, "CartLoadingAddress", "X000",,1) MemoryExpansion := IniReadCheck(settingsFile, romName, "MemoryExpansion", "none",,1) Command := IniReadCheck(settingsFile, romName, "Command", "",,1) RequiresReset := IniReadCheck(settingsFile, romName, "RequiresReset", "false",,1) StringLower, Command, Command ;Command MUST be in lower case so let's force it If ( romExtension = ".crt" ) { ;Sleep, 100 ;Without this romtable comes empty (thread related?) RomTableCheck() ; make sure romTable is created already so the next line can calculate correctly ;MultiPart carts can only be run if the MultiGame feature is enabled If romName contains (Part { If (mgEnabled = "false") ScriptError("You cannot run multipart games with MultiGame disabled") } romCount = % romtable.MaxIndex() If (romCount > 1) { ;multipart carts - need to build custom CLI parameters to invoke multipart cartridges. Multipart cartridges are loaded in more than one ; memory address, so we interrogate each part, and determine its loading address, and build the CLI parameters. ; Once all the cartridge parts have been processed, the emulator with the custom CLI parameters are invoked. ; ; Using Lunaar Leeper as an example, it has two parts, one loaded in $2000, and one in $A000 ; "xvic.exe -cart2 "D:\Games\Commodore VIC-20\Lunar Leeper (USA) (Part 1).crt" -cartA "D:\Games\Commodore VIC-20\Lunar Leeper (USA) (Part 2).crt" multipartCLI = %executable% %params% for index, element in romtable { currentCart := romtable[A_Index,1] SplitPath, currentCart,,,, OutFileName currentCartAddress := IniReadCheck(settingsFile, OutFileName, "CartLoadingAddress", "X000",,1) If (currentCartAddress = "A000") cartSlot := "-cartA" Else If (currentCartAddress = "B000") cartSlot := "-cartB" Else If (currentCartAddress = "2000") cartSlot := "-cart2" Else If (currentCartAddress = "4000") cartSlot := "-cart4" Else If (currentCartAddress = "6000") cartSlot := "-cart6" Else ScriptError("Invalid Cart Address Specified: " . CartAddress) multipartCLI = %multipartCLI% %cartSlot% "%currentCart%" } Run(multipartCLI, emuPath) } Else { ;singlepart carts - unlike multipart carts, we can directly run the emulator with a single CLI parameter If (CartAddress = "A000") cartSlot := "-cartA" Else If (CartAddress = "B000") cartSlot := "-cartB" Else If (CartAddress = "2000") cartSlot := "-cart2" Else If (CartAddress = "4000") cartSlot := "-cart4" Else If (CartAddress = "6000") cartSlot := "-cart6" Else ScriptError("Invalid Cart Address Specified: " . CartAddress) Run(executable . " " . params . " " . cartSlot . " """ . romPath . "\" . romName . romExtension . """", emuPath) } } Else { ;for non cartridges, update the vice.ini with the proper memory expansion values (if needed) prior to calling the emulator. varBlock0 = 0 varBlock1 = 0 varBlock2 = 0 varBlock3 = 0 varBlock5 = 0 If (MemoryExpansion = "3k") { varBlock0 = 1 } Else If (MemoryExpansion = "8k") { varBlock1 = 1 } Else If (MemoryExpansion = "16k") { varBlock1 = 1 varBlock2 = 1 } Else If (MemoryExpansion = "24k") { varBlock1 = 1 varBlock2 = 1 varBlock3 = 1 } Else If (MemoryExpansion = "all") { varBlock0 = 1 varBlock1 = 1 varBlock2 = 1 varBlock3 = 1 varBlock5 = 1 } Else If (MemoryExpansion = "3,5") { varBlock3 = 1 varBlock5 = 1 } Else If (MemoryExpansion = "5") { varBlock5 = 1 } Else If (MemoryExpansion = "1,5") { varBlock1 = 1 varBlock5 = 1 } Else If (MemoryExpansion = "1,2,5") { varBlock1 = 1 varBlock2 = 1 varBlock5 = 1 } IniWrite, %varBlock0%, %viceINI%, VIC20, RAMBlock0 IniWrite, %varBlock1%, %viceINI%, VIC20, RAMBlock1 IniWrite, %varBlock2%, %viceINI%, VIC20, RAMBlock2 IniWrite, %varBlock3%, %viceINI%, VIC20, RAMBlock3 IniWrite, %varBlock5%, %viceINI%, VIC20, RAMBlock5 Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """" , emuPath ) } if (RequiresReset = "true") { WinWaitActive("ahk_class VICE") Sleep, 1000 ; increase if command is not appearing in the emu window or some just some letters Send !r } if %Command% { WinWaitActive("ahk_class VICE") Sleep, %SendCommandDelay% ; increase if command is not appearing in the emu window or some just some letters SetKeyDelay, 450 Loop, parse, Command Send, {%A_LoopField% down}{%A_LoopField% up} Send, {ENTER down}{ENTER up} } } WinWait("ahk_class VICE") WinWaitActive("ahk_class VICE") BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() JoySwap: Send !j Return Warp: Send !w Return StartTape: Send !{F7} Return StopTape: Send !{F8} Return RunTape: SetKeyDelay, 50 Loop, parse, Command Send, {%A_LoopField% down}{%A_LoopField% up} Send, {ENTER down}{ENTER up} Return HaltEmu: If (Fullscreen = "true") Send !{Enter} Return MultiGame: Log("MultiGame Label was run!") If romExtension in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.prg { Send !8 ; swaps a Disk wvTitle:="Attach disk image ahk_class #32770" } Else If romExtension in .t64,.tap { Send !t ; swaps a Tape wvTitle:="Attach tape image ahk_class #32770" } Else { ScriptError(romExtension . " is an invalid multi-game extension") } WinWait(wvTitle) WinWaitActive(wvTitle) If ( SelectGameMode = 1 ) { Loop { ControlGetText, edit1Text, Edit1, %wvTitle% If ( edit1Text = selectedRom ) Break Sleep, 100 ControlSetText, Edit1, %selectedRom%, %wvTitle% } ControlSend, Button1, {Enter}, ahk_class #32770 ; Select Open } Else If ( SelectGameMode = 2 ) { Clipboard := selectedRom Send, ^v{Enter} } Else ScriptError("You did not choose a valid SelectGameMode.`nOpen the module and set the mode at the top.") Log("Module - WinWaitActive`, ahk_class VICE`, `, 5") WinWaitActive("ahk_class VICE",,5) WinActivate, ahk_class VICE Return RestoreEmu: If (Fullscreen = "true") Send !{Enter} Return CloseProcess: FadeOutStart() WinClose("ahk_class VICE") Return http://craigandersonthemes.weebly.com/
potts43 Posted January 22, 2015 Posted January 22, 2015 I added bezel support to the module that was included in the download. I like the fixed res option so that is what i used.The bezel is originally a Grizz bezel. Had to move the bottom border up just a little to cover up emulator. But I like knowing that because i am using the fixed res option that the dimensions of the screen are as the emulator intended....just fyi its not perfect..just fyi MEmu = WinVICE MEmuV = v2.4 MURL = http://vice-emu.sourceforge.net/ MAuthor = djvj,wahoobrian,brolly,Spudgunjake MVersion = 2.0.2 MCRC = BA37ED39 iCRC = DAA4D1EA MID = 635038268966170754 MSystem = "Commodore VIC-20" ;---------------------------------------------------------------------------- ; Notes: ; Roms must be unzipped. ; You can turn off the exit confirmation box by unchecking Settings->Confirm on exit ; Turn on saving settings by checking Settings->Save settings on exit, this will create the vice.ini file this module needs. ; ; If you want to use the StartTape and StopTape hotkeys make sure you edit the files C64\win_shortcuts.vsc or VIC20\win_shortcuts.vsc ; (paths relative to the emulator install folder) and assign Alt+F7 as the StartTape shortcut and Alt+F8 as the StopTape shortcut, like this: ; ALT0x76IDM_DATASETTE_CONTROL_START F7 ; ALT0x77IDM_DATASETTE_CONTROL_STOP F8 ; ; WinVICE uses different executables for each machine so make sure you setup your emulators properly: ; x64.exe - Commodore 64 ; xplus4.exe - Commodore 16 & Plus/4 ; xvic.exe - Commodore VIC-20 ;---------------------------------------------------------------------------- StartModule() BezelGUI() FadeInStart() mType := Object("Commodore 64","C64","Commodore 16 & Plus4","PLUS4","Commodore VIC-20","VIC20") ;ident should be the section names used in VICE.ini ident := mType[systemName]; search object for the systemName identifier IfExist, % modulePath . "\" . systemName . ".ini"; use a custom systemName ini if it exists settingsFile := modulePath . "\" . systemName . ".ini" Else settingsFile := modulePath . "\" . moduleName . ".ini" ;msgbox 4,,%settingsFile% Fullscreen := IniReadCheck(settingsFile, "Settings", "Fullscreen","true",,1); If true, the module governs if the emulator launches fullscreen or not. Set to false when troubleshooting a module for launching problems. WarpKey := IniReadCheck(settingsFile, "Settings", "WarpKey","F9",,1); toggle warp speed JoySwapKey := IniReadCheck(settingsFile, "Settings", "JoySwapKey","F10",,1); swap joystick port StartTapeKey := IniReadCheck(settingsFile, "Settings", "StartTapeKey","F7",,1); starts tape StopTapeKey := IniReadCheck(settingsFile, "Settings", "StopTapeKey","F8",,1); stops tape SelectGameMode := IniReadCheck(settingsFile, "Settings", "SelectGameMode","1",,1);1 = Uses a loop to detect the Edit Box has the romname and path in it. This doesn't work on all PCs, so if you get stuck at the open rom window, use mode 2. 2 = Uses a simple Ctrl+v to paste the romname and path, then press Enter to load the game. ; DiskSwapKey = F11; swaps disk or tape - Do not need this key anymore with multigame support UsePaddles := IniReadCheck(settingsFile, romName, "UsePaddles", "false",,1) AutostartPrgMode := IniReadCheck(settingsFile, romName, "AutostartPrgMode", "2",,1) RequiresReset := IniReadCheck(settingsFile, romName, "RequiresReset", "false",,1) BezelStart("fixResMode") 7z(romPath, romName, romExtension, 7zExtractPath) viceINI := CheckFile(emuPath . "\vice.ini") IniRead, currentFullScreen, %viceINI%, %ident%, FullscreenEnabled IniRead, currentAutostartPrgMode, %viceINI%, %ident%, AutostartPrgMode ; Setting Fullscreen setting in ini if it doesn't match what user wants above If ( Fullscreen != "true" And currentFullScreen = 1 ) IniWrite, 0, %viceINI%, %ident%, FullscreenEnabled Else If ( Fullscreen = "true" And currentFullScreen = 0 ) IniWrite, 1, %viceINI%, %ident%, FullscreenEnabled If ( currentAutostartPrgMode != AutostartPrgMode ) IniWrite, %AutostartPrgMode%, %viceINI%, %ident%, AutostartPrgMode WarpKey := xHotKeyVarEdit(WarpKey,"WarpKey","~","Add") JoySwapKey := xHotKeyVarEdit(JoySwapKey,"JoySwapKey","~","Add") StartTapeKey := xHotKeyVarEdit(StartTapeKey,"StartTapeKey","~","Add") StopTapeKey := xHotKeyVarEdit(StopTapeKey,"StopTapeKey","~","Add") xHotKeywrapper(WarpKey,"Warp") xHotKeywrapper(JoySwapKey,"JoySwap") xHotKeywrapper(StartTapeKey,"StartTape") xHotKeywrapper(StopTapeKey,"StopTape") If romName contains (USA),(Canada) DefaultVideoMode = NTSC Else DefaultVideoMode = PAL VideoMode := IniReadCheck(settingsFile, romName, "VideoMode", DefaultVideoMode,,1) params := "+confirmexit" ; Setting video mode depending on rom, default NTSC if (VideoMode = "NTSC") { params := params . " -ntsc" ;IniWrite, -2, %viceINI%, %ident%, MachineVideoStandard ;NTSC } else { params := params . " -pal" ;IniWrite, -1, %viceINI%, %ident%, MachineVideoStandard ;PAL } ;Enable/Disable paddles as needed, leave these checks in-place because mouse CLI and Ini options aren't supported in VICE 1.22 and this way it will also work with it. IniRead, currentUsePaddles, %viceINI%, %ident%, Mouse If ( UsePaddles = "true" And currentUsePaddles != 1) params := params . " -mouse -mousetype 3" If ( UsePaddles = "false" And currentUsePaddles = 1) params := params . " +mouse" If (ident = "C64") { If romExtension not in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.t64,.tap,.crt ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nd64,d71,d80,d81,d82,g64,g41,x64,t64,tap,crt") If ( romExtension = ".crt" ) { IniWrite, %romPath%\%romName%%romExtension%, %viceINI%, C64, CartridgeFile IniWrite, 0, %viceINI%, C64, CartridgeType } Else { IniWrite, -1, %viceINI%, C64, CartridgeType } ; Hotkey, ~%DiskSwapKey%, MultiGame If romExtension in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.prg Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension in .t64,.tap Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension = .crt Run(executable . " " . params . " -cartcrt """ . romPath . "\" . romName . romExtension . """", emuPath) if (RequiresReset = "true") { WinWaitActive("ahk_class VICE") Sleep, 1000 ; increase if command is not appearing in the emu window or some just some letters Send !r } } Else If (ident = "PLUS4") { If romExtension not in .prg,.d64,.t64,.tap,.crt,.g64 ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,t64,tap,crt,g64") SendCommandDelay := IniReadCheck(settingsFile, "Settings", "SendCommandDelay", "1500",,1) Model := IniReadCheck(settingsFile, romName, "Model", "Commodore Plus/4",,1) ; Setting model If (Model = "Commodore Plus/4") { ;Commodore Plus/4 IniWrite, "3plus1lo", %viceINI%, %ident%, FunctionLowName IniWrite, "3plus1hi", %viceINI%, %ident%, FunctionHighName IniWrite, 64, %viceINI%, %ident%, RamSize IniWrite, 1, %viceINI%, %ident%, Acia1Enable } Else { ;Commodore 16 IniWrite, "", %viceINI%, %ident%, FunctionLowName IniWrite, "", %viceINI%, %ident%, FunctionHighName IniWrite, 16, %viceINI%, %ident%, RamSize IniWrite, 0, %viceINI%, %ident%, Acia1Enable } Command := IniReadCheck(settingsFile, romName, "Command", "",,1) StringLower, Command, Command ;Command MUST be in lower case so let's force it If romExtension in .d64,.g64,.prg Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension in .t64,.tap Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """", emuPath) Else If romExtension = .crt Run(executable . " " . params . " -cartcrt """ . romPath . "\" . romName . romExtension . """", emuPath) if (RequiresReset = "true") { WinWaitActive("ahk_class VICE") Sleep, 1000 ; increase if command is not appearing in the emu window or some just some letters Send !r } if %Command% { WinWaitActive("ahk_class VICE") Sleep, %SendCommandDelay% ; increase if command is not appearing in the emu window or some just some letters If romExtension in .t64,.tap { ;Tape loading time will vary greatly so we can't type this automatically, user must do it using a hotkey RunTapeKey := IniReadCheck(settingsFile, romname, "RunTapeKey","Ctrl&F12",,1); run tape key RunTapeKey := xHotKeyVarEdit(RunTapeKey,"RunTapeKey","~","Add") xHotKeywrapper(RunTapeKey,"RunTape") } Else { SetKeyDelay, 50 Loop, parse, Command Send, {%A_LoopField% down}{%A_LoopField% up} Send, {ENTER down}{ENTER up} } } } Else If (ident = "VIC20") { If romExtension not in .prg,.d64,.t64,.tap,.crt,.vsf ScriptError("Your rom has an extension of " . romExtension . ", only these extensions are supported:`nprg,d64,t64,tap,crt,vsf") SendCommandDelay := IniReadCheck(settingsFile, "Settings", "SendCommandDelay", "1500",,1) CartAddress := IniReadCheck(settingsFile, romName, "CartLoadingAddress", "X000",,1) MemoryExpansion := IniReadCheck(settingsFile, romName, "MemoryExpansion", "none",,1) Command := IniReadCheck(settingsFile, romName, "Command", "",,1) RequiresReset := IniReadCheck(settingsFile, romName, "RequiresReset", "false",,1) StringLower, Command, Command ;Command MUST be in lower case so let's force it If ( romExtension = ".crt" ) { ;Sleep, 100 ;Without this romtable comes empty (thread related?) RomTableCheck(); make sure romTable is created already so the next line can calculate correctly ;MultiPart carts can only be run if the MultiGame feature is enabled If romName contains (Part { If (mgEnabled = "false") ScriptError("You cannot run multipart games with MultiGame disabled") } romCount = % romtable.MaxIndex() If (romCount > 1) { ;multipart carts - need to build custom CLI parameters to invoke multipart cartridges. Multipart cartridges are loaded in more than one ; memory address, so we interrogate each part, and determine its loading address, and build the CLI parameters. ; Once all the cartridge parts have been processed, the emulator with the custom CLI parameters are invoked. ; ; Using Lunaar Leeper as an example, it has two parts, one loaded in $2000, and one in $A000 ; "xvic.exe -cart2 "D:\Games\Commodore VIC-20\Lunar Leeper (USA) (Part 1).crt" -cartA "D:\Games\Commodore VIC-20\Lunar Leeper (USA) (Part 2).crt" multipartCLI = %executable% %params% for index, element in romtable { currentCart := romtable[A_Index,1] SplitPath, currentCart,,,, OutFileName currentCartAddress := IniReadCheck(settingsFile, OutFileName, "CartLoadingAddress", "X000",,1) If (currentCartAddress = "A000") cartSlot := "-cartA" Else If (currentCartAddress = "B000") cartSlot := "-cartB" Else If (currentCartAddress = "2000") cartSlot := "-cart2" Else If (currentCartAddress = "4000") cartSlot := "-cart4" Else If (currentCartAddress = "6000") cartSlot := "-cart6" Else ScriptError("Invalid Cart Address Specified: " . CartAddress) multipartCLI = %multipartCLI% %cartSlot% "%currentCart%" } Run(multipartCLI, emuPath) } Else { ;singlepart carts - unlike multipart carts, we can directly run the emulator with a single CLI parameter If (CartAddress = "A000") cartSlot := "-cartA" Else If (CartAddress = "B000") cartSlot := "-cartB" Else If (CartAddress = "2000") cartSlot := "-cart2" Else If (CartAddress = "4000") cartSlot := "-cart4" Else If (CartAddress = "6000") cartSlot := "-cart6" Else ScriptError("Invalid Cart Address Specified: " . CartAddress) Run(executable . " " . params . " " . cartSlot . " """ . romPath . "\" . romName . romExtension . """", emuPath) } } Else { ;for non cartridges, update the vice.ini with the proper memory expansion values (if needed) prior to calling the emulator. varBlock0 = 0 varBlock1 = 0 varBlock2 = 0 varBlock3 = 0 varBlock5 = 0 If (MemoryExpansion = "3k") { varBlock0 = 1 } Else If (MemoryExpansion = "8k") { varBlock1 = 1 } Else If (MemoryExpansion = "16k") { varBlock1 = 1 varBlock2 = 1 } Else If (MemoryExpansion = "24k") { varBlock1 = 1 varBlock2 = 1 varBlock3 = 1 } Else If (MemoryExpansion = "all") { varBlock0 = 1 varBlock1 = 1 varBlock2 = 1 varBlock3 = 1 varBlock5 = 1 } Else If (MemoryExpansion = "3,5") { varBlock3 = 1 varBlock5 = 1 } Else If (MemoryExpansion = "5") { varBlock5 = 1 } Else If (MemoryExpansion = "1,5") { varBlock1 = 1 varBlock5 = 1 } Else If (MemoryExpansion = "1,2,5") { varBlock1 = 1 varBlock2 = 1 varBlock5 = 1 } IniWrite, %varBlock0%, %viceINI%, VIC20, RAMBlock0 IniWrite, %varBlock1%, %viceINI%, VIC20, RAMBlock1 IniWrite, %varBlock2%, %viceINI%, VIC20, RAMBlock2 IniWrite, %varBlock3%, %viceINI%, VIC20, RAMBlock3 IniWrite, %varBlock5%, %viceINI%, VIC20, RAMBlock5 Run(executable . " " . params . " """ . romPath . "\" . romName . romExtension . """" , emuPath ) } if (RequiresReset = "true") { WinWaitActive("ahk_class VICE") Sleep, 1000 ; increase if command is not appearing in the emu window or some just some letters Send !r } if %Command% { WinWaitActive("ahk_class VICE") Sleep, %SendCommandDelay% ; increase if command is not appearing in the emu window or some just some letters SetKeyDelay, 450 Loop, parse, Command Send, {%A_LoopField% down}{%A_LoopField% up} Send, {ENTER down}{ENTER up} } } WinWait("ahk_class VICE") WinWaitActive("ahk_class VICE") BezelDraw() FadeInExit() Process("WaitClose", executable) 7zCleanUp() BezelExit() FadeOutExit() ExitModule() JoySwap: Send !j Return Warp: Send !w Return StartTape: Send !{F7} Return StopTape: Send !{F8} Return RunTape: SetKeyDelay, 50 Loop, parse, Command Send, {%A_LoopField% down}{%A_LoopField% up} Send, {ENTER down}{ENTER up} Return HaltEmu: If (Fullscreen = "true") Send !{Enter} Return MultiGame: Log("MultiGame Label was run!") If romExtension in .d64,.d71,.d80,.d81,.d82,.g64,.g41,.x64,.prg {Send !8 ; swaps a Disk wvTitle:="Attach disk image ahk_class #32770" } Else If romExtension in .t64,.tap {Send !t ; swaps a Tape wvTitle:="Attach tape image ahk_class #32770" } Else { ScriptError(romExtension . " is an invalid multi-game extension") } WinWait(wvTitle) WinWaitActive(wvTitle) If ( SelectGameMode = 1 ) { Loop { ControlGetText, edit1Text, Edit1, %wvTitle% If ( edit1Text = selectedRom ) Break Sleep, 100 ControlSetText, Edit1, %selectedRom%, %wvTitle% } ControlSend, Button1, {Enter}, ahk_class #32770 ; Select Open } Else If ( SelectGameMode = 2 ) { Clipboard := selectedRom Send, ^v{Enter} } Else ScriptError("You did not choose a valid SelectGameMode.`nOpen the module and set the mode at the top.") Log("Module - WinWaitActive`, ahk_class VICE`, `, 5") WinWaitActive("ahk_class VICE",,5) WinActivate, ahk_class VICE Return RestoreEmu: If (Fullscreen = "true") Send !{Enter} Return CloseProcess: FadeOutStart() WinClose("ahk_class VICE") Return Thanks for sharing Craig!
alexemula Posted October 11, 2017 Posted October 11, 2017 Hi Spudgunjake! The link is not working, please, can you re-upload it? Many thanks! Alex
