cbtegner Posted October 3, 2012 Posted October 3, 2012 How can I configure XBMC to Close when Launching Hyperspin from XBMC? I can launch hyperspin from XBMC and play NES emulation just fine but when I play something like N64 Emulation or even SNES emulation I start to get a sound lag. Is there a way to set up my XBMC / Hyperlaunch so that when I launch Hyperspin: XBMC closes out, and when I exit Hyperspin: XBMC Launches ?? Hyperspin on its own works fine and same thing with XBMC, however when I use Hyperspin through XBMC I get the sound lag. Can somebody help me to understand what step I need to take to acheive this?
dark13 Posted October 3, 2012 Posted October 3, 2012 Instead of launch hyperspin from XBMC launch a .bat from hyperpsin folder Open a new .txt document and write taskkill /F /IM XBMC.exe HyperSpin.exe save it as "HYPERSPIN" and change extension to .bat (must be in the same folder of hyperpsin exe) and set HS to launch XBMC when exiting. Probably you'll see a dos shell, to avoid it open another .txt document and write Set WshShell = CreateObject("WScript.Shell" ) WshShell.Run chr(34) & "FULLPATH/HYPERSPIN.bat" & Chr(34), 0 Set WshShell = Nothing Rename it to HYPERSPIN.vbs and launch it from XBMC (not tested, I use these scripts for slamtilt as you must close explorer.exe to have right colors). Just consider you MUST have no-space folder tree. C:\frontend\HyperSpin = OK C:\front end\HyperSpin = NO Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
newoski Posted October 5, 2012 Posted October 5, 2012 Why do you want to do this? I just use Executor to launch HS. Then, when I exit HS, XBMC is still up in the background Sent from my ADR6425LVW using Tapatalk 2
dark13 Posted October 5, 2012 Posted October 5, 2012 Having another (heavy) program in background is not good if you are using a monocore cpu in the range of p4/atom and 1gb of ram Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin
cbtegner Posted October 28, 2012 Author Posted October 28, 2012 XBMC uses too many resources for me , I have a duel core 1.7 and I get sound lag and slowing. I can run hyperspin alone fine, but always had problems with xbmc running at same time, im going to give the above a shot. My hyperspin folder and everything including executable is on an external drive, I have to modify the above script for G: I hope I don't mess it up
ghutch92 Posted October 28, 2012 Posted October 28, 2012 I use advanced launcher on xbmc frodo. All scripts are written in ahk and compiled to exe's using autohotkey's compiler. Using xbmc point to this to execute Hyperspin and close xbmc #SingleInstance force ;----------SET PATHS----------; XBMC := "C:\Program Files (x86)\XBMC\XBMC.exe" HyperSpin := "C:\HyperSpin\HyperSpin.exe" HS_SettingsINI := "C:\HyperSpin\Settings\Settings.ini" ;-----------------------------; SetTitleMatchMode, 2 Gui, Color, 000000 Gui, -Caption +ToolWindow +AlwaysOnTop Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%, run, TASKKILL /F /IM explorer.exe,,Hide sleep 500 process, close, xbmc.exe run, %HyperSpin%,, UseErrorLevel if ErrorLevel { run, %XBMC%,, UseErrorLevel if Errorlevel = ERROR { gui, destroy msgbox, 0, ERROR, neither %XBMC% or %HyperSpin% was found - Make sure you have correct paths, 4 ExitApp } WinWait, XBMC, , 5 IfWinNotActive, XBMC, , WinActivate, XBMC, WinWaitActive, XBMC, , 5 if ErrorLevel { gui, destroy ExitApp } sleep, 5000 gui, destroy ExitApp } WinWait, HyperSpin, , 3 WinWaitActive, HyperSpin ;add other programs here IniWrite,true,%HS_SettingsINI%,XBMC,Launch sleep, 500 gui, destroy WinActivate, HyperSpin ExitApp If you don't use IdleVolumeAdjuster, or xpadder, delete the first two lines. This script minimizes any background windows. HyperHQ -> Main Settings -> Startup/Exit -> Startup Program. Point to the below script Run,IdleVolumeAdjuster.exe Run,C:\HyperSpin\Keymapper Profiles\Xpadder.exe "HyperSpin.xpadderprofile" "Hyperspin [p2].xpadderprofile" /M WinGet, ID, List, , , Program Manager Loop, %ID% { this_id := id%A_Index% Wingettitle, title, ahk_id %this_id% WinGetClass, class, ahk_id %this_id% If class in Shell_TrayWnd,ThunderRT6FormDC,ThunderRT6Main,CabinetWClass,TXpadderForm,Button,AutoHotkeyGUI,TApplication { ; msgbox match found`n%this_id%`n%title% %class% Continue } WinMinimize, ahk_class %class% ; Sleep, 1000 } ExitApp If you don't use IdleVolumeAdjuster, or xpadder, delete lines 9, and 14. If xbmc was used to launch hyperspin, hyperspin will launch xbmc. if not it will return to the desktop. HyperHQ -> Main Settings -> Startup/Exit -> Exit Program. Point to the below script #SingleInstance force SetWinDelay, -1 ;----------SET PATHS----------; XBMC := "C:\Program Files (x86)\XBMC\XBMC.exe" HS_SettingsINI := "C:\HyperSpin\Settings\Settings.ini" ;-----------------------------; ; add programs to close Process, Close, IdleVolumeAdjuster.exe IniRead,XLaunch,%HS_SettingsINI%,XBMC,Launch If (XLaunch = "true") { IniWrite,false,%HS_SettingsINI%,XBMC,Launch Run,C:\HyperSpin\Keymapper Profiles\Xpadder.exe "C:\HyperSpin\Keymapper Profiles\XBMC\XBMC.xpadderprofile" "C:\HyperSpin\Keymapper Profiles\XBMC\XBMC [p2].xpadderprofile" /M SetTitleMatchMode, 2 ;restarting explorer.exe Gui, Color, 000000 Gui, -Caption +ToolWindow +AlwaysOnTop Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%, run, C:\Windows\explorer.exe,,Hide WinHide ahk_class Shell_TrayWnd WinHide ahk_class Button sleep 1000 Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%, run, %XBMC%,, UseErrorLevel,XBMCpid if ErrorLevel { gui, destroy msgbox, 0, ERROR, %XBMC% was not found - Make sure you have correct paths, 4 ExitApp } WinWait, ahk_pid %XBMCpid%, , 5 WinShow ahk_class Shell_TrayWnd WinShow ahk_class Button WinActivate, ahk_pid %XBMCpid% WinWaitActive, ahk_pid %XBMCpid%, , 5 if ErrorLevel { sleep, 5000 gui, destroy ExitApp } sleep, 500 gui, destroy } ExitApp Add this to the bottom of your "Settings.ini" or whatever ".ini" you want. [XBMC] Launch=false IdleVolumeAdjuster.exe (http://www.hyperspin-fe.com/forum/showthread.php?19692-Idle-Volume-Adjuster) Xpadder (http://xpadder.com/) $10 How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
Scoobysnacks Posted February 4, 2013 Posted February 4, 2013 Hi there, I'm having issues with advanced launcher and hyperspin, not returning to xbmc after I exit HS. I'm going to play round with hyperhq when I get home. These scripts look very helpful thanks! Just curious I'm running a i3 3225k in my htpc do you think I'll run into performance issues once I start getting into dreamcast emulation if xbmc is running in the background? Does the setting to launch a program when exiting HS able to switch focus to an already running process or will it try to launch another instance?
ghutch92 Posted February 4, 2013 Posted February 4, 2013 Scoobysnacks said: Hi there, I'm having issues with advanced launcher and hyperspin, not returning to xbmc after I exit HS. I'm going to play round with hyperhq when I get home. These scripts look very helpful thanks! Just curious I'm running a i3 3225k in my htpc do you think I'll run into performance issues once I start getting into dreamcast emulation if xbmc is running in the background? Does the setting to launch a program when exiting HS able to switch focus to an already running process or will it try to launch another instance? I don't think you will run into performance issues, but remember that HyperLaunch and HyperSpin were coded to expect that there were no background windows open so I feel better about closing xbmc and restarting it than leaving it open in the background. It will try to launch another instance, it's basically using the run command. You could have it run an ahk Script like WinActivate, ahk_class XBMC if you just want it to activate the window. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
NewYears1978 Posted May 14, 2013 Posted May 14, 2013 ghutch92 said: I use advanced launcher on xbmc frodo.All scripts are written in ahk and compiled to exe's using autohotkey's compiler. Using xbmc point to this to execute Hyperspin and close xbmc #SingleInstance force ;----------SET PATHS----------; XBMC := "C:\Program Files (x86)\XBMC\XBMC.exe" HyperSpin := "C:\HyperSpin\HyperSpin.exe" HS_SettingsINI := "C:\HyperSpin\Settings\Settings.ini" ;-----------------------------; SetTitleMatchMode, 2 Gui, Color, 000000 Gui, -Caption +ToolWindow +AlwaysOnTop Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%, run, TASKKILL /F /IM explorer.exe,,Hide sleep 500 process, close, xbmc.exe run, %HyperSpin%,, UseErrorLevel if ErrorLevel { run, %XBMC%,, UseErrorLevel if Errorlevel = ERROR { gui, destroy msgbox, 0, ERROR, neither %XBMC% or %HyperSpin% was found - Make sure you have correct paths, 4 ExitApp } WinWait, XBMC, , 5 IfWinNotActive, XBMC, , WinActivate, XBMC, WinWaitActive, XBMC, , 5 if ErrorLevel { gui, destroy ExitApp } sleep, 5000 gui, destroy ExitApp } WinWait, HyperSpin, , 3 WinWaitActive, HyperSpin ;add other programs here IniWrite,true,%HS_SettingsINI%,XBMC,Launch sleep, 500 gui, destroy WinActivate, HyperSpin ExitApp If you don't use IdleVolumeAdjuster, or xpadder, delete the first two lines. This script minimizes any background windows. HyperHQ -> Main Settings -> Startup/Exit -> Startup Program. Point to the below script Run,IdleVolumeAdjuster.exe Run,C:\HyperSpin\Keymapper Profiles\Xpadder.exe "HyperSpin.xpadderprofile" "Hyperspin [p2].xpadderprofile" /M WinGet, ID, List, , , Program Manager Loop, %ID% { this_id := id%A_Index% Wingettitle, title, ahk_id %this_id% WinGetClass, class, ahk_id %this_id% If class in Shell_TrayWnd,ThunderRT6FormDC,ThunderRT6Main,CabinetWClass,TXpadderForm,Button,AutoHotkeyGUI,TApplication { ; msgbox match found`n%this_id%`n%title% %class% Continue } WinMinimize, ahk_class %class% ; Sleep, 1000 } ExitApp If you don't use IdleVolumeAdjuster, or xpadder, delete lines 9, and 14. If xbmc was used to launch hyperspin, hyperspin will launch xbmc. if not it will return to the desktop. HyperHQ -> Main Settings -> Startup/Exit -> Exit Program. Point to the below script #SingleInstance force SetWinDelay, -1 ;----------SET PATHS----------; XBMC := "C:\Program Files (x86)\XBMC\XBMC.exe" HS_SettingsINI := "C:\HyperSpin\Settings\Settings.ini" ;-----------------------------; ; add programs to close Process, Close, IdleVolumeAdjuster.exe IniRead,XLaunch,%HS_SettingsINI%,XBMC,Launch If (XLaunch = "true") { IniWrite,false,%HS_SettingsINI%,XBMC,Launch Run,C:\HyperSpin\Keymapper Profiles\Xpadder.exe "C:\HyperSpin\Keymapper Profiles\XBMC\XBMC.xpadderprofile" "C:\HyperSpin\Keymapper Profiles\XBMC\XBMC [p2].xpadderprofile" /M SetTitleMatchMode, 2 ;restarting explorer.exe Gui, Color, 000000 Gui, -Caption +ToolWindow +AlwaysOnTop Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%, run, C:\Windows\explorer.exe,,Hide WinHide ahk_class Shell_TrayWnd WinHide ahk_class Button sleep 1000 Gui, Show, x0 y0 w%A_ScreenWidth% h%A_ScreenHeight%, run, %XBMC%,, UseErrorLevel,XBMCpid if ErrorLevel { gui, destroy msgbox, 0, ERROR, %XBMC% was not found - Make sure you have correct paths, 4 ExitApp } WinWait, ahk_pid %XBMCpid%, , 5 WinShow ahk_class Shell_TrayWnd WinShow ahk_class Button WinActivate, ahk_pid %XBMCpid% WinWaitActive, ahk_pid %XBMCpid%, , 5 if ErrorLevel { sleep, 5000 gui, destroy ExitApp } sleep, 500 gui, destroy } ExitApp Add this to the bottom of your "Settings.ini" or whatever ".ini" you want. [XBMC] Launch=false IdleVolumeAdjuster.exe (http://www.hyperspin-fe.com/forum/showthread.php?19692-Idle-Volume-Adjuster) Xpadder (http://xpadder.com/) $10 I know this post is old but I have been searching all day and this finally did what I needed with almost no hitches! Thank you! My only issues are these, a) it didn't minimize windows when it quit XBMC...now normally I don't have any open anyways but when I did they were all open. when I exit Hyperspin my taskbar pops up before it goes back into launching XBMC..not a huge deal..but might be a simple fix. Are you an HTPC user? Do you like Kodi/XBMC?If so, check out these Kodi Style Themes!-----------------------------------------------------------------------------------------------------Aeon Nox 13 by @dark13Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress-----------------------------------------------------------------------------------------------------If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
frankhs Posted February 25, 2014 Posted February 25, 2014 ghutch92, Thank you very much for these scripts!!! I know this is an old thread but I just setup launching Hyperspin from XBMC and returning to XBMC using them. All I changed was the paths, removed the IdleVolumeAdjuster, adjusted the Xpadder Hyperspin profile and set to kill the Xpadder.exe process on return to XBMC as I don't use Xpadder to control XBMC. Launching Hyperspin and coming back to XBMC works great! I'm not sure if this is related to your scripts but now it looks like it takes a few seconds (maybe 5 seconds) for Xpadder to switch profile everytime a switch is needed. For example: Start Hyperspin : Hyperspin profile works immediately Start MAME (Xpadder switches to default profile) : I don't notice any problem here Go to Hyperpause (Xpadder switches to Hyperlaunch profile) : Takes 5 seconds to get control Stop Hyperpause (Xpadder switches to default profile) : I don't notice a problem Stop MAME : (Xpadder switches to Hyperspin profile) : Takes 5 seconds to get control Edit: The slow xpadder profile changes only happen while using these scripts. I think the slow xpadder profile changes occur because explorer.exe is not running. If I comment out the run, TASKKILL /F /IM explorer.exe,,Hide line from the launch hyperspin script, everything seems to work fine.
Iggy Posted May 5, 2014 Posted May 5, 2014 Ghutch...thank you for this autohotkey script.....followed your directions and works like a charm Bro! [sIGPIC][/sIGPIC]Sega Saturn Japanese Wheel Project: COMPLETE!! If you have FTP access, find my name and grab the set now!!!
marxkemp Posted December 26, 2014 Posted December 26, 2014 +1 Ghutch. Old Thread but still works like a charm. I'm not a coder, but hoping for a HL plugin for XBMC so I can use RCB / AdvLauncher, but in the meanwhile I use this. I even added a line with nomousy.exe so it hides the windows cursor while loading hyperspin.exe
Bootleg Posted March 31, 2015 Posted March 31, 2015 how do i name these scripts do i just make an ahk file and put it in the directory i really need this but i am at lost lol im just getting into hyperspin everything works great as far as runing within xbmc just want to set mines up like this
