New Wheel style: Horizontal Wide (HS1.4)
On the latest 1.4beta BBB added a new feature: horizontal wide wheel. This new wheel style shows 7 wheelart instead of 5 and it looks much better when using boxarts as wheel image
[wheel]
alpha=1
small_alpha=1
style=horizontal wide
speed=high
pin_center_width=500
horz_wheel_y=597
vert_wheel_position=right
y_rotation=center
norm_large=175
norm_small=160
vert_large=400
vert_small=240
pin_large=500
pin_small=200
horz_large=175
horz_small=175
letter_wheel_x=220
letter_wheel_y=384
text_width=700
text_font=Style4
small_text_width=260
large_text_width=400
text_stroke_size=6
text_stroke_color=0x000000
text_color1=0x00BFFD
text_color2=0xFFFFFF
text_color3=0x00BFFD
color_ratio=139
shadow_distance=0
shadow_angle=45
shadow_color=0x000000
shadow_alpha=1
shadow_blur=0
Just open the .ini in settings of the system you want to be horizontal wide and set style=horizontal to style=horizontal wide
If you have access to 1.4beta please test the new style and report any problem. Thank you :)
Cool, GJ BBB
The main menu is on the FTP in upload here/dark13/Aeon nox XIII release, go also to the first page of Aeon Nox thread (follow mi signature) and download main menu wheelart v2.0 set.
System's menus are WIP, probably I'll start releasing stuff when 1.4 will be released (I may release some system menus right now but BBB is adding features on HS :P )
When using HS 1.4beta you can use a mix horizontal and vertical wheels as input problems has been addressed, so you can use Aeon Nox XIII as main menu and Azurica or Unified Megatheme as system menus :)
