HLM - Minter Helper Checker Whatever 2.0.2
horseyhorsey
  • Replies 290
The settings menu doesn't show up for me, i want to change the directory it scans as its not picking up anything. any idea what could be wrong? im guessing im missing something?
Delete the config file
doesnt work, i deleted HLM-Check.exe.config and its still picking up my systems but not picking up videos etc.
within that config file it hasnt got the directories i picked at initial launch so im guessing the settings are kept somewhere else or within the app.
yep all the ini files have the video settings. "hyperspin checker" the other minting app i use picks up the videos fine.
It reads your hyperspin databases to scan the hyperlaunch media folders. Don't expect it to show videos from your hyperspin folder.
Hyperlaunch\Media\Videos\SystemName
What is the video column for then? Confused about that.
Cool, remember if you spot any errors or something could be better let us know.
Absolutely ! The only thing I have found is when I rename a bezel and then try to bezel edit I sometimes get a jit error as if it's looking for the original named png.
Thanks, maybe it didn't refresh the new filename properly.
You had probably worked out that after you drag a new bezel in, if you change the name Bezel in textbox to (for example) Main they come out like:
I personally would like it to default to:
Etc
Mine most certainly do. The Bezel name or background etc has to begin with that. It is what HL looks for. If there is more than one in the folder it selects one at random and if you have a key set up you can change them on the fly and go through them sequentially.
In HL media/mame/bezel/
in a game named folder "pacman"
You could have...
Instruction cards are fixed but HL would randomly select the above on each launch! Nice feature but would be better if you could still select a default for that game rom but don't have this option. Just random
Tip
One plus is if you create a Full screen res transparent Bezel you can use this to have your game as big as it will go without turning off bezel first. Just press the swap bezel button during the game and it goes through each one until it gets this one - resizing the game for each one automatically.
Tip
Thanks for sorting that out, it's a great feature. :cheers:
Ok, they work with an underscore. They didn't with a straight digit after the bezel name.
I'll leave it as it is , sorry, but to me makes more sense with naming like this:
Bezel - SP - Samus Red & Orange - manson976
Bezel - CPCMonitor - Horse
Bezel - full handheld
I think that leaves a good starting prefix, bezel info & the author.
With the specific game bezels however that could be changed to underscore. And let this way fill out the romname for you.
