Virtual Jaguar 2.1 released
mesk
  • Replies 64
I can't seem to hide the toolbar. I'm using Hyperlaunch 2.25 and Virtual Jaguar 2.1 on Windows XP. I tried copying your code into a fresh "Atari Jaguar.ahk" file in the modules folder but it doesn't work. Any advice?
Try using the version listed in the module I made
In the Module Replace
If (A_OSVersion = "WIN_7"){
with
If (A_OSVersion = "WIN_7" || A_OSVersion = "WIN_XP"){
let me know
I don't see any reference to OSVersion.
Are you sure you are using the module I posted?
Try both versions I post here and let me know which one works for you
1
; Atari Jaguar
; Virtual Jaguar Git - 02/09/2013 - http://www.emucr.com/2013/02/virtual...=1360460895285
; 1.0
; Notes:
; Set Virtual Jaguar to start full screen.
GUI_ID := FadeInStart()
7z1 := 7z(romPath, romName, romExtension, 7zExtractDir)
Run %executable% "%romPath%%romName%%romExtension%", %emuPath%,, VJ_PID
WinWait ahk_pid %VJ_PID%
WinWaitActive ahk_pid %VJ_PID%
If A_OSVersion in WIN_7,WIN_XP
{	MouseClick Right, 1, 1
MouseClick Left, 5, 5
ControlMove QGLWidget1, 0, 0, %A_ScreenWidth%, %A_ScreenHeight%, ahk_pid %VJ_PID%
GUI_ID2 := FadeInExit()
Process, WaitClose, %VJ_PID%
7z2 := 7zCleanUp()
GUI_ID4 := FadeOutExit()
WinActivate, HyperSpin
ExitApp
CloseProcess:
GUI_ID3 := FadeOutStart()
WinClose ahk_pid %VJ_PID%
Return
2
; Atari Jaguar
; 1.0
; Notes:
7z2 := 7zCleanUp()
ExitApp
CloseProcess:
Return
BTW, this is slightly cleaner:
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
If you're using loading screens the mouse click part must be done after FadeInExit and not before otherwise you'll be clicking the fade GUI. Mouse click is also needed for XP btw.
Brolly, you are right. I moved the code after the FadeInExit and it worked. Now how do I remove the gray bar at the bottom of the screen?
Here's my code:
; Atari Jaguar
; 1.0
; Notes:
7z2 := 7zCleanUp()
ExitApp
CloseProcess:
Return
Must be moved as well, thats what hides the control... so just put it after the if condition.
Seems removing the toolbar isn't an easy fix after all, Shamus will try to address it at a later version, but it probably will take a while so for now we'll have to stick to doing it on the module.
New Module... MouseClicks are not needed for Windows 7 anymore. Need someone with XP to verify this is working.
; Atari Jaguar
; Virtual Jaguar Git - 02/14/2013 - [url="http://www.emucr.com/2013/02/virtual-jaguar-git-20130214.html"]http://www.emucr.com/2013/02/virtual-jaguar-git-20130214.html[/url]
;For use with HyperLaunch v2.25c
; 1.1
; Notes:
; Fullscreen works but is not perfect until the emu dev allows hiding of the toolbar
; The emu stores its config in the registry @ HKEY_CURRENT_USER\Software\Underground Software\Virtual Jaguar
Fullscreen = true
currentFullScreen := ReadReg("fullscreen")
If (Fullscreen = "true" && currentFullScreen = "false")
WriteReg("fullscreen", "true")
Else If (Fullscreen != "true" && currentFullScreen = "true")
WriteReg("fullscreen", "false")
If Fullscreen != true
Center(ahk_class QWidget)
If Fullscreen = true	; if windowed mode, moving the control causes the game to never show
ControlMove QWidget2, 0, 0, 0, 0, ahk_pid %VJ_PID%
Process WaitClose, %VJ_PID%
7z2 := 7zCleanUp()
WinActivate HyperSpin
ExitApp
CloseProcess:
Return
ReadReg(var1){
RegRead regValue, HKEY_CURRENT_USER, Software\Underground Software\Virtual Jaguar, %var1%
Return %regValue%
WriteReg(var1, var2){
RegWrite REG_SZ, HKEY_CURRENT_USER, Software\Underground Software\Virtual Jaguar, %var1%, %var2%
Center(title){
WinGetPos X, Y, width, height, %title%
x := ( A_ScreenWidth / 2 ) - ( width / 2 )
y := ( A_ScreenHeight / 2 ) - ( height / 2 )
WinMove %title%, , x, y
Stole some of your code djvj :eviltongue:
Some? Looks like you added a link... :congrats:
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Nobody adds links like I do. I could have changed the variable names and then you never would have known. :rofl:
JK...
For real though, there wasn't anything I could have done differently anyway. Maybe I could of left out the functions and put all the code in the autoexecute section, but that would have looked ugly.
  • 3 weeks later...
Hi guys, any way to remove the grey bar at the bottom?
Are you using the module that is three posts above yours?
If thats not working, try this one.
; Atari Jaguar
; Virtual Jaguar Git - 02/14/2013 - [url]http://www.emucr.com/2013/02/virtual...-20130214.html[/url]
; 1.1
; Notes:
Fullscreen = true
MouseClicks = true
If (MouseClicks = true){
If (MouseClicks != true)
7z2 := 7zCleanUp()
ExitApp
CloseProcess:
Return
ReadReg(var1){
Return %regValue%
Center(title){
I'm using the first module you posted on post 32. These last two modules make it worse, adding a thin line on the right side of the screen plus the one at the bottom. I'm on windows 7 x64.
The one in post 42 should be the one you want then. Use the emu version that is linked in the module.
The module in post 42 was tested and confirmed working on Windows 7 x64 and Windows 8 x64.
Downloaded emu linked in module and used module in post 42. Got the side and bottom bars, see picture. When I go to about in emu it says git 20130213 even though download links are labeled 20130214.
Set the mouse cursor to hidden in Atari Jaguar.ini
I just want to make it clear that the Module works on Windows 7 & 8. I just need someone with XP to test it.
Module and setup went great but I'm still stuck on how to hide the mouse cursor. Where is Atari Jaguar.ini located?
