56
Everything posted by jesfknkrys
Snail paced loading times - potential reason ?
jesfknkrys commented on Creezz67's record in HyperSpin 2 - Development Questions
In HypeHQ, could a button be added to manually check for ROM and media files on a per-system basis? We’d like to have Hyperspin load as quickly as possible, and performing file checks every time it starts isn’t ideal. If no media changes or updates have been made, there’s really no need to verify everything each time. In my opinion, the settings and updates should be done in HyperHQ so Hyperspin loading times are minimally affected. -
Same happened to me. I had to quit and restart HyperHQ, then I was able to update.
Unfortunately, Hyper-Sync service is no longer available. You would need to download each theme manually. Andyman posted 10+ gigs worth of themes you can start with . You can also follow floatingyeti's MAME updates.
Yes, I just updated the latest Windows updates, which it reinstalled KB5055523. I will need to uninstall and block it. Keep in mind, Microsoft is rolling out updates in certain areas. For example, Dime333 has updates available for a later Windows11 build which is currently not available here in southern California.
@jh79 Try checking for Windows corrupted files first. In an elevated command type the below from line 1 and wait for it to complete. Then try uninstalling the update using the command on line 2. If it doesn’t work we can try repairing your Windows files using DISM commands. Let us know your result. 1. sfc /scannow 2. wusa /uninstall /kb:5055523
It could be that you selected to downloaded the updates when you initially installed a Fresh copy of Windows. I installed the updates one at a time inside Windows. Try this in Command Line as an administrator: Replace "5055523" with the update you would like removed. The example below is to remove "KB5055523" wusa /uninstall /kb:5055523
