jesfknkrys
    409
    56
Everything posted by jesfknkrys
  1. HyperHQ was freezing up on me today, so I did a fresh install. Now, when selecting systems in HyperHQ, there seems to be lag when switching between them. Not stuck on "Processing Preparing to start matching process".
  2. That is strange. I wonder if there is a mininimum software requirement. Are you on Windows 10 or above with latest updates?
  3. Are you on Hyperspin v2.0.36.0? Did you also, remove the 2 folders under the user profile?
  4. Atari 2600, 5200, and 7800 themes worked fine for me on HyperHq v2.0.54 . I installed Retroarch through HyperHQ. Try deleting your Hyperspin and HyperHQ files inside your user AppData folders.
  5. HyperSpin v2.0.36.0 now loads significantly faster. It now takes 21 seconds to load MAME(Complete Set); it was taking approximately 1.5 minutes to load MAME on Hyperspin v2.0.34.0.
  6. Seem like the issues has been fixed on HyperHQ v2.0.54.
  7. The issue seems so be fixed for me on HyperHQ v2.0.54. It seems to be very responsive and much quicker.
  8. Issue is fixed in HyperHQ v2.0.54.
  9. This is now working on HyperSpin v2.0.36.0
  10. The Themes are now loading on HyperHQ v2.0.54 and HyperSpin v2.0.36.0
  11. Here you go. I'm not sure if it's supposed to be allowed to open more than one instance.
  12. It's working now on HyperHQ 2.0.53.
  13. @Redman805 I myself haven’t confirmed it it’s working on windows 11 with the latest updates. Are you up to date Windows 11 updates?
  14. The Hyperspin default theme "Update" button located in the Media section in HyperHQ, stays on after applying the update. Also, get a status showing that it updates every time I restart HyperHQ.
  15. I have the complete MAME media, but when creating collection wheels used from MAME, there's no media showing inside the wheel. Are there additional steps I need to take to have the media show up?
  16. HyperHQ allows multiple instances of Hyperspin to open when opening from HyperHQ. If you try try to close an instance before completely loading, you receive a persistent popup "A Javascript error occurred in the main process", which you can only close using task manager.
  17. After a fresh install, Hyperspin loading times are taking too long. Takes approximately a minute and a half to load.
  18. Hyperspin.exe - No themes populate after a fresh install. It works after I deleting Hyperspin and HyperHQ files from the users\AppData folders, but prefer not to have to update after fresh install.
  19. Issue: On a Fresh Install, HyperSpin.exe would not open after pressing the Icon located on the lower left corner in HyperHQ. Fix: Had to reinstall the HyperSpinCore and restart HyperHQ, but hopefully can get installed and working during a fresh install or updates.
  20. Try deleting the plugins manually. They would be located in your installation folder under plugins. then start HyperHQ to rebuild.
  21. Have you tried checking for system corruption just to narrow down your issue? sfc /scannow
  22. MAME 274 is working fine on HyperHQ v2.049, Hyperspin v2.0.34.0.
  23. HyperspinCoreEssentials updater not working. It gets stuck on "Installing..."
  24. Which core is stuck HyperspinCore 2.0.34 or HyperspinCoreEssentials 1.1.0 ?
  25. I was also having issues on the previous version. I would download the lastest HyperHQ release from the websitem instead of updating, if you haven't done so? Also, I HyperspinCore 1.1.0 might take a while to download and install. I clicked on update, and it's been stuck on "Installing" for the past 7 minutes. Besides that, Hyperspin is working fine so far.
