gunit Posted June 26, 2015 Author Posted June 26, 2015 Working now as removed that .key file budget is tight due to the bartop coming in at £900 all in. Also I just ordered another 2tb harddrive plus paid out on hyperpsin membership and emumoves. The bank is officially closed on this project.
gigapig Posted June 27, 2015 Posted June 27, 2015 Clucking bell, that £900 bartop must have some serious bling on it. Can't they throw in WhdLoad key @ only £15. Do you a free key ring
nimpa Posted June 27, 2015 Posted June 27, 2015 Downloaded a fake whdload key maybe?? hehe.. thats why... or wrong kickstart roms....
gunit Posted June 27, 2015 Author Posted June 27, 2015 Not really that great (i5 processor etc), but all bought new as I wanted to see if it was viable to build more in the future ( the foamex board is not cheap either!). I think it will be a one off for me and the Son to play
bigfraz5 Posted March 5, 2017 Posted March 5, 2017 How do you map game pad to the amiga emulator to make it work, ? tried stand alone and through hyperspin, can someone send a screenshot of there layout or point in right direction!?? thanks.
gigapig Posted March 5, 2017 Posted March 5, 2017 3 hours ago, bigfraz5 said: How do you map game pad to the amiga emulator to make it work, ? tried stand alone and through hyperspin, can someone send a screenshot of there layout or point in right direction!?? thanks. Try this. Start WinUAE, then load your config. Select Game Ports in the left pane and then look for Port 2. From the drop down choose your game pad, then under that you should see three smaller boxes then left two having drop downs as well. From the middle one you can choose "Game Pad" or "JoyStick or even the CD32 pad if you set CD32 also. Those are the original controllers your Game Pad will be emulating. Edit: Save your config.
BoOgieman Posted January 17, 2018 Posted January 17, 2018 On 27-6-2015 at 2:31 PM, gigapig said: Clucking bell, that £900 bartop must have some serious bling on it. Can't they throw in WhdLoad key @ only £15. Do you a free key ring Guys... Perhaps you already heard about it, but I just found out that WHDLoad is now free for use since version 18.2. Registration Starting with WHDLoad release 18.2 a registration is neither required nor possible. Please update to the latest available WHDLoad version." Source:http://www.whdload.de/reg.html HyperSpeech - Text-To-Speech Voice Addon for HyperSpin
tmart1234 Posted October 28, 2019 Posted October 28, 2019 I know this post is old, but if anyone is out there... I'm a newbie trying to follow the tutorial for setting up the Amiga in Hyperspin. According to the video I just watched (and a few other posts), the Rom.Key file is required for a successful install. I'm confused as to whether I need the file or not. The Amiga Forever technical help guy told me it hasn't been used since 1997. The post above says it isn't needed. I feel like a cat chasing its tale. I'd really appreciate it if someone could explain what is going on. The video i'm following is the simplest set of instructions I"ve found yet, so I was hoping to stick to the instructions.
gigapig Posted October 28, 2019 Posted October 28, 2019 44 minutes ago, tmart1234 said: I know this post is old, but if anyone is out there... I'm a newbie trying to follow the tutorial for setting up the Amiga in Hyperspin. According to the video I just watched (and a few other posts), the Rom.Key file is required for a successful install. I'm confused as to whether I need the file or not. The Amiga Forever technical help guy told me it hasn't been used since 1997. The post above says it isn't needed. I feel like a cat chasing its tale. I'd really appreciate it if someone could explain what is going on. The video i'm following is the simplest set of instructions I"ve found yet, so I was hoping to stick to the instructions. The post above refers to WHDLoad which is like a ROM set (best way I can describe it) which until a few years ago required a registration key that you purchased from the site. That key and purchase is no longer required. What you do need though is the Kickstart ROMs (Amiga bios files) which the emulator will use to emulate the various versions of the Amiga. I hope that clears things up a little.
tmart1234 Posted October 29, 2019 Posted October 29, 2019 Thank you for the reply! I believe I have the Kickstart Roms from AF. It seems like as long as I don't screw up the install, I should be all set.
tmart1234 Posted November 2, 2019 Posted November 2, 2019 Arghh! So... Is there something I'm missing for multi-disk games? My first priority is to get the TV Sports games working. I can't get anything to run that has two adf's in the zip file. If I'm supposed to separate the disks into separate zip files, I don't know how I'd match them to the xml database. If I'm supposed to leave them in the zip file is there a naming convention for the compressed files? Or are there other settings in WINUAE that I'm missing?
rocktofakie Posted November 4, 2019 Posted November 4, 2019 Hi. For my old setup I used winUAE Loader. With this loader the CLI Windows showing the WHDLoad informations were suppressed. With avar’s setup everything works fine but I see the CLI Windows while booting. Is there a way to hide these? If I use fade in, it stops when the CLI Window appears. Any suggestions? Thanks.
