Arcade Classics xml without any of the other "classics" games included?
rich2k4
Since the "classics" collection is broken out by manufacturer, is there an xml of the Arcade Classics section that removes everything from the other classics wheels and leaves everything that is left over?
In other words, an xml with Capcom classics, Konami classics, etc removed?  To me it seems dumb for the arcade classics/mame wheel to lump everything together, when most of the games are in the other "classic" wheels.
I think rich2k4 is requesting a MAME.xml file, with all the overlapping games from the Classics XMLs removed
That way, the games only appear on one wheel.
To my knowledge, no XMLs like this have been shared and they would need to be updated each time a new MAME release came out, making them unlikely to be up-to-date often
My mame has everything removed.  That's what was leftover after taking out all the "classics" from it.
Really?  Nothing at all?  I figured there had to be at least a hundred or so games that weren't in the classics xmls
I was looking for such a database as well.  There does not appear to be an easy way to make it.  I thought about removing the wheels with Hyperspin Rom Manager and then setting the Arcade Classics wheel to 'Wheels Only', but it did not work for me.  Displays all the wheels anyways.  Other methods involve too much editing or database building.  There are other wheels in addition to the classics that can be removed to which makes the whole thing relative to the user.  I think some have AAE to use MAME, so do you remove those? etc.
put the ROMs that you need, then use HyperROM2XML  http://www.hyperspin-fe.com/files/file/7383-hyperrom2xml/   it works on many emulators.
That's the fastest if you only have certain games.
Noooo. My MAME xml has everything removed from it. Taito, Konami, Midway, etc. etc.  Leaving whatever leftover.
It's tedious, but just going through an XML and deleting irrelevant data is by far the most efficient. It's definitely do-able. I have done it to every one of my systems except for the TurboGrafx and the 3DO (I just haven't gotten to them yet.)
don's hyperspin tools.  just filter out all of the main manufacturers, and you are left with a cleared out mame xml.  Took like 10 minutes to make the manufacturer xml files and the leftover file.  I wouldn't even think of trying to sift through the thousands of games and make my own mame database manually.
This is what I was thinking. Just use that to pull out the ones you don't want.
