4 Player arcade with 30" monitor, RGB LED buttons (full build album)
scoodidabop
Top notch, I like the design... I have plans on doing full size cab, any chance of sharing cab plans even though you are clearly selling these?
I'd love an answer to this as well. Might be interested in a 4 Player cabinet + CP
It varies. This one had dual light guns, spinner, trackball RGB LEDs and this few additions alone were around $700 in parts alone.
Amazing work brother. ...love everything about it.... also see you made more than 1.... you selling those other ones?
Great job and one of the nicest and cleanest cabs I've seen in a long time.
Alex
Alex
Thanks! All of these builds were commissioned by friends.  I'm working on one for myself now that's NASA themed and should be pretty cool. I'll post that one up soon!
Your cp is almost identical to the lay out in using. would you be interested in selling one of your control panel overlays?
Without doubt the sexiest cabinet I've ever seen.  If I ever have the time, this will be the cabinet I build.
Btw, do you have a parts list for the LED buttons and necessary components?
I only have a spare from the NASA cab I just did.  If you have a graphic I can refer to you my vinyl guy.
Thanks!  PacLED64s are from Ultimarc and the buttons and LEDs are Paradise Arcade Shop.
Is there a hinge on the CP? Do you screw on the bottom part do the CP to the cab?
Single long, black piano hinge yeah.  Screwed to the control panel box.
