demonseed Posted October 20, 2015 Posted October 20, 2015 I was finally able to get MUGEN games to run in HS via PClauncher. I have them setup in my PC Games section. The thing I do not understand is sometimes I run HS and they work fine, then other times, when I click a MUGEN game it loads in the taskbar? I pasted my log... maybe someone can help me? I can not figure out the issue as it is hit and miss . 22:18:35:426 | RL | INFO | +N/A | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com) 22:18:35:426 | RL | WARNING | +0 | Main - You have "Logging_Log_Command_Window" enabled. This is only for logging errors being dumped to the command window from an executable. This may cause issues with running some executables and needs to be turned off when you are done. 22:18:35:516 | RL | INFO | +78 | Main - System Specs: RocketLauncher Dir: E:\Rocketlauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Professional SKU: Professional Total Memory: 8016.31 MB Free Memory: 6108.07 MB Used Memory: 1908.242 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 4 GPU 1 Name: Intel(R) HD Graphics GPU 1 RAM: -1924.00 MB GPU 1 Driver Version: 9.17.10.3347 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: High Definition Audio Device Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: Yes Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1440x900 (1440x860 work) [Landscape] (Primary) Current AHK Desktop Width: 1440 Current AHK Desktop Height: 900 AutoHotkey Path: C:\Program Files\AutoHotkey\AutoHotkey.exe AHK Version: 1.1.09.04 Unicode: No 22:18:35:516 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\RocketLauncher.exe exists 22:18:35:526 | RL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription RocketLauncher FileVersion 1.0.1.3 LegalCopyright ©2015 RocketLauncher ProductName djvj's one swell guy! ProductVersion 1.1.9.4 CompanyName Your favorite Front End companion! Visit us @ www.rlauncher.com File Size: 2061824 bytes Created: 5/23/2015 - 11:53:13 PM Modified: 9/6/2015 - 9:32:08 PM 22:18:35:536 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BinHexRW.ahk exists 22:18:35:546 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:546 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 4961 bytes Created: 5/24/2015 - 9:27:48 AM Modified: 6/4/2014 - 11:48:13 PM 22:18:35:546 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\BlockInput.exe exists 22:18:35:556 | RL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription FileVersion 1.1.09.04 InternalName OriginalFilename ProductName ProductVersion 1.1.09.04 File Size: 657920 bytes Created: 5/24/2015 - 9:26:42 AM Modified: 1/2/2014 - 11:27:34 PM 22:18:35:556 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\CLR_L.ahk exists 22:18:35:566 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:566 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5474 bytes Created: 9/6/2015 - 9:32:14 PM Modified: 9/6/2015 - 9:32:14 PM 22:18:35:566 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Control_AniGif.ahk exists 22:18:35:586 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:586 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5716 bytes Created: 5/24/2015 - 9:26:30 AM Modified: 4/29/2013 - 2:56:02 PM 22:18:35:586 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip.ahk exists 22:18:35:596 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:606 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 88789 bytes Created: 5/24/2015 - 8:02:39 AM Modified: 1/13/2013 - 6:07:30 PM 22:18:35:606 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gdip_alt.ahk exists 22:18:35:616 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:616 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5895 bytes Created: 5/24/2015 - 9:25:59 AM Modified: 6/28/2015 - 7:41:33 AM 22:18:35:616 | RL | DEBUG1 | +0 | gdip_alt.ahk Version: 1.0.2 22:18:35:626 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\gsdll32.dll exists 22:18:35:626 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 13090816 bytes Created: 5/24/2015 - 9:25:19 AM Modified: 1/6/2015 - 10:20:42 PM 22:18:35:626 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\itextsharp.dll exists 22:18:35:636 | RL | DEBUG1 | +16 | CheckFile - Attributes: FileDescription iTextSharp FileVersion 5.4.2.0 InternalName itextsharp.dll LegalCopyright Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved. OriginalFilename itextsharp.dll ProductName iTextSharp ProductVersion 5.4.2.0 CompanyName 1T3XT BVBA File Size: 3743744 bytes Created: 5/24/2015 - 9:24:07 AM Modified: 6/14/2013 - 3:06:21 PM 22:18:35:636 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Java.ahk exists 22:18:35:656 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:666 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 7841 bytes Created: 5/24/2015 - 9:27:37 AM Modified: 12/24/2014 - 12:02:37 AM 22:18:35:666 | RL | DEBUG1 | +0 | Java.ahk Version: 1.0.0 22:18:35:676 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\JSON.ahk exists 22:18:35:676 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:686 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 9203 bytes Created: 5/24/2015 - 9:26:08 AM Modified: 5/5/2013 - 3:22:25 PM 22:18:35:686 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Origin.ahk exists 22:18:35:686 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:696 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 4904 bytes Created: 5/24/2015 - 9:26:27 AM Modified: 3/22/2015 - 3:51:41 PM 22:18:35:696 | RL | DEBUG1 | +0 | Origin.ahk Version: 1.0.2 22:18:35:706 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RegRW64.ahk exists 22:18:35:706 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:716 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6915 bytes Created: 5/24/2015 - 9:28:09 AM Modified: 5/8/2014 - 4:06:39 AM 22:18:35:716 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\RIni.ahk exists 22:18:35:726 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:726 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 67561 bytes Created: 5/24/2015 - 9:28:04 AM Modified: 6/5/2013 - 7:56:23 PM 22:18:35:736 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\SevenZipSharp.dll exists 22:18:35:736 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription SevenZipSharp FileVersion 0.64.4841.31212 InternalName SevenZipSharp.dll LegalCopyright Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3 OriginalFilename SevenZipSharp.dll ProductName SevenZipSharp ProductVersion 0.64.4841.31212 CompanyName Markovtsev Vadim File Size: 165888 bytes Created: 5/24/2015 - 9:27:30 AM Modified: 4/21/2013 - 12:08:10 AM 22:18:35:736 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\Steam.ahk exists 22:18:35:746 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:746 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 5347 bytes Created: 5/24/2015 - 9:28:20 AM Modified: 3/22/2015 - 3:52:25 PM 22:18:35:746 | RL | DEBUG1 | +0 | Steam.ahk Version: 1.0.2 22:18:35:756 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA.ahk exists 22:18:35:756 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Extension. 22:18:35:766 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 34688 bytes Created: 5/24/2015 - 9:26:53 AM Modified: 3/1/2013 - 10:05:47 PM 22:18:35:766 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\VA_Extension.ahk exists 22:18:35:766 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:776 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 3833 bytes Created: 5/24/2015 - 9:28:38 AM Modified: 1/13/2015 - 9:16:56 PM 22:18:35:776 | RL | DEBUG1 | +0 | VA_Extension.ahk Version: 1.0.1 22:18:35:776 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\7z.ahk exists 22:18:35:796 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:796 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 29013 bytes Created: 5/30/2015 - 12:47:30 AM Modified: 9/6/2015 - 9:32:05 PM 22:18:35:796 | RL | DEBUG1 | +0 | 7z.ahk Version: 1.0.1 22:18:35:796 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Bezel.ahk exists 22:18:35:816 | RL | DEBUG1 | +31 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:816 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 102587 bytes Created: 5/24/2015 - 9:28:01 AM Modified: 6/28/2015 - 7:41:34 AM 22:18:35:826 | RL | DEBUG1 | +0 | Bezel.ahk Version: 1.1.2 22:18:35:826 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade.ahk exists 22:18:35:826 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:846 | RL | DEBUG1 | +31 | CheckFile - Attributes: File Size: 37849 bytes Created: 5/24/2015 - 9:26:50 AM Modified: 9/6/2015 - 9:31:56 PM 22:18:35:846 | RL | DEBUG1 | +0 | Fade.ahk Version: 1.1.1 22:18:35:846 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Init.ahk exists 22:18:35:856 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:856 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 999 bytes Created: 5/24/2015 - 9:27:38 AM Modified: 12/24/2014 - 12:21:02 AM 22:18:35:856 | RL | DEBUG1 | +0 | Fade Init.ahk Version: 1.0.1 22:18:35:866 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Fade Animations.ahk exists 22:18:35:876 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:876 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 79882 bytes Created: 5/24/2015 - 9:27:41 AM Modified: 9/6/2015 - 9:31:50 PM 22:18:35:886 | RL | DEBUG1 | +16 | Fade Animations.ahk Version: 1.1.8 22:18:35:886 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause.ahk exists 22:18:35:896 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:906 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 392698 bytes Created: 5/24/2015 - 9:26:19 AM Modified: 9/6/2015 - 9:31:52 PM 22:18:35:906 | RL | DEBUG1 | +0 | Pause.ahk Version: 1.1.4 22:18:35:906 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Pause Init.ahk exists 22:18:35:916 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:916 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 553 bytes Created: 5/24/2015 - 9:24:21 AM Modified: 9/6/2015 - 9:31:51 PM 22:18:35:916 | RL | DEBUG1 | +0 | Pause Init.ahk Version: 1.0.3 22:18:35:926 | RL | INFO | +15 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper.ahk exists 22:18:35:926 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:926 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33453 bytes Created: 5/24/2015 - 9:28:11 AM Modified: 5/30/2015 - 10:18:27 PM 22:18:35:936 | RL | DEBUG1 | +0 | Keymapper.ahk Version: 1.1.2 22:18:35:936 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Keymapper Init.ahk exists 22:18:35:956 | RL | DEBUG1 | +32 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:966 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 3461 bytes Created: 5/24/2015 - 9:26:35 AM Modified: 5/30/2015 - 10:18:57 PM 22:18:35:966 | RL | DEBUG1 | +0 | Keymapper Init.ahk Version: 1.0.4 22:18:35:966 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame.ahk exists 22:18:35:976 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:976 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 40753 bytes Created: 5/24/2015 - 9:24:03 AM Modified: 9/6/2015 - 9:32:13 PM 22:18:35:986 | RL | DEBUG1 | +16 | MultiGame.ahk Version: 1.0.8 22:18:35:986 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiGame Init.ahk exists 22:18:35:996 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:35:006 | RL | DEBUG1 | +15 | CheckFile - Attributes: File Size: 161 bytes Created: 5/24/2015 - 9:28:32 AM Modified: 4/14/2013 - 2:33:19 PM 22:18:36:006 | RL | DEBUG1 | +0 | MultiGame Init.ahk Version: 1.0.0 22:18:36:006 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\MultiPlayer.ahk exists 22:18:36:016 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:016 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 58770 bytes Created: 5/24/2015 - 9:23:41 AM Modified: 7/16/2015 - 11:34:20 PM 22:18:36:016 | RL | DEBUG1 | +0 | MultiPlayer.ahk Version: 1.0.6 22:18:36:026 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Password.ahk exists 22:18:36:036 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:036 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 10025 bytes Created: 5/24/2015 - 9:24:18 AM Modified: 9/6/2015 - 9:31:55 PM 22:18:36:036 | RL | DEBUG1 | +0 | Password.ahk Version: 1.0.2 22:18:36:036 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Rom Mapping Launch Menu.ahk exists 22:18:36:056 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:056 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 73772 bytes Created: 5/24/2015 - 9:23:41 AM Modified: 7/16/2015 - 11:34:23 PM 22:18:36:066 | RL | DEBUG1 | +16 | Rom Mapping Launch Menu.ahk Version: 1.0.5 22:18:36:066 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Shared.ahk exists 22:18:36:076 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:076 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 116503 bytes Created: 5/24/2015 - 9:26:27 AM Modified: 9/6/2015 - 9:31:56 PM 22:18:36:086 | RL | DEBUG1 | +15 | Shared.ahk Version: 1.3.2 22:18:36:086 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics.ahk exists 22:18:36:086 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:096 | RL | DEBUG1 | +16 | CheckFile - Attributes: File Size: 26143 bytes Created: 5/24/2015 - 9:26:45 AM Modified: 4/9/2015 - 5:16:56 AM 22:18:36:096 | RL | DEBUG1 | +0 | Statistics.ahk Version: 1.0.3 22:18:36:096 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\Statistics Init.ahk exists 22:18:36:106 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:106 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 33 bytes Created: 5/24/2015 - 9:28:01 AM Modified: 12/24/2014 - 12:23:48 AM 22:18:36:106 | RL | DEBUG1 | +0 | Statistics Init.ahk Version: 1.0.1 22:18:36:116 | RL | INFO | +16 | CheckFile - Checking if E:\Rocketlauncher\Lib\Virtual Drive.ahk exists 22:18:36:116 | RL | DEBUG1 | +0 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:126 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 17070 bytes Created: 5/30/2015 - 12:47:33 AM Modified: 9/6/2015 - 9:32:09 PM 22:18:36:126 | RL | DEBUG1 | +0 | Virtual Drive.ahk Version: 1.0.1 22:18:36:126 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey.ahk exists 22:18:36:136 | RL | DEBUG1 | +15 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:136 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 26540 bytes Created: 5/24/2015 - 9:28:26 AM Modified: 9/6/2015 - 9:32:04 PM 22:18:36:136 | RL | DEBUG1 | +0 | XHotkey.ahk Version: 1.0.4 22:18:36:136 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Lib\XHotkey Init.ahk exists 22:18:36:146 | RL | DEBUG1 | +16 | CRC Check - CRC matches, this is an official unedited Library. 22:18:36:146 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1063 bytes Created: 5/24/2015 - 9:26:46 AM Modified: 9/6/2015 - 9:31:50 PM 22:18:36:156 | RL | DEBUG1 | +0 | XHotkey Init.ahk Version: 1.0.2 22:18:36:156 | RL | DEBUG1 | +0 | Main - Raw CLI received: "PC Games MUGEN Superheroes" 22:18:36:156 | RL | DEBUG1 | +0 | Main - Received this dbName with no path via CLI: "MUGEN Superheroes" 22:18:36:156 | RL | DEBUG1 | +0 | Main - dbName: MUGEN Superheroes 22:18:36:166 | RL | WARNING | +15 | Main - Front End plugin was not sent via CLI. Defaulting to the "HyperSpin" Plugin. If you want to load a different Front End Plugin, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-p <PLUGINTYPE>" 22:18:36:166 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Plugins\HyperSpin.plugin exists 22:18:36:166 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 8969 bytes Created: 5/24/2015 - 9:28:44 AM Modified: 5/30/2015 - 10:18:21 PM 22:18:36:166 | RL | WARNING | +0 | Main - No frontendPath was sent via CLI. Defaulting to use HyperSpin in "..\HyperSpin\HyperSpin.exe". If you want to use a different FE Path, please make sure you set up your Front End so it sends this parameter to RocketLauncher: "-f <PATH_TO_MY_FE\FRONTEND.exe>" 22:18:36:176 | RL | INFO | +16 | Main - HyperSpin.exe coordinates are x0 y0 w1440 h900 22:18:36:186 | RL | INFO | +0 | Main - RocketLauncher received "PC Games" and "MUGEN Superheroes" 22:18:36:196 | RL | INFO | +16 | Main - Found a "Games Options.ini" file, loading it into memory. 22:18:36:206 | RL | INFO | +15 | Main - MUGEN Superheroes is using the default emulator: PCLauncher 22:18:36:206 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in E:\Rocketlauncher\Settings\PC Games\Emulators.ini 22:18:36:206 | RL | INFO | +0 | Main - Checking for a [PCLauncher] section in E:\Rocketlauncher\Settings\Global Emulators.ini 22:18:36:206 | RL | INFO | +0 | Main - Found [PCLauncher] in E:\Rocketlauncher\Settings\Global Emulators.ini 22:18:36:206 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Modules\PCLauncher\PCLauncher.ahk exists 22:18:36:216 | RL | DEBUG1 | +0 | CheckFile - Attributes: File Size: 16076 bytes Created: 5/24/2015 - 9:27:46 AM Modified: 9/6/2015 - 9:32:06 PM 22:18:36:216 | RL | INFO | +0 | Main - CRC Check - CRC matches, this is an official unedited module. 22:18:36:216 | RL | INFO | +0 | Main - MUGEN Superheroes will use module: E:\Rocketlauncher\Modules\PCLauncher\PCLauncher.ahk 22:18:36:236 | RL | INFO | +31 | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher". 22:18:36:236 | RL | INFO | +0 | Main - INI Keys read 22:18:36:236 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.exe exists 22:18:36:236 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7-Zip Console FileVersion 9.20 InternalName 7z LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7z.exe ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 163840 bytes Created: 5/24/2015 - 9:26:40 AM Modified: 3/5/2013 - 10:21:50 PM 22:18:36:236 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\7z.dll exists 22:18:36:246 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription 7z Standalone Plugin FileVersion 9.20 InternalName 7za LegalCopyright Copyright (c) 1999-2010 Igor Pavlov OriginalFilename 7za.dll ProductName 7-Zip ProductVersion 9.20 CompanyName Igor Pavlov File Size: 914432 bytes Created: 5/24/2015 - 9:28:28 AM Modified: 3/5/2013 - 10:21:49 PM 22:18:36:246 | RL | INFO | +0 | Main - "MUGEN Superheroes" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 22:18:36:246 | RL | INFO | +0 | CheckPaths - Started 22:18:36:246 | RL | DEBUG1 | +0 | CheckPaths - Current romName: 22:18:36:256 | RL | DEBUG1 | +16 | CheckPaths - Current romPath: 22:18:36:256 | RL | DEBUG1 | +0 | CheckPaths - Current romExtension: 22:18:36:256 | RL | INFO | +0 | CheckPaths - Ended 22:18:36:266 | RL | INFO | +0 | BuildScript - User Variables: ;---------------------------------------------------------------------------- ; INJECTED VARIABLES ;---------------------------------------------------------------------------- #NoTrayIcon #InstallKeybdHook DetectHiddenWindows, ON SetTitleMatchMode, 2 SendMode, Event 0 = 2 pluginPath = E:\Rocketlauncher\Plugins pluginName = HyperSpin pluginExt = .plugin contextOnExit = rlMode = rlTitle = RocketLauncher rlVersion = 1.0.1.3 rlAuthor = djvj rlURL = www.rlauncher.com langFile = E:\Rocketlauncher\Data\Language\Localization.ini primMonitor = 1 frontendPID = 1656 frontendPath = E:\HyperSpin frontendExe = HyperSpin.exe frontendExt = exe frontendName = HyperSpin frontendDrive = E: exitEmulatorKey = ~Esc|H3:1joy6 restoreFE = false exitScriptKey = ~q & ~s toggleCursorKey = ~e & ~t emuFullPath = emuPath = emuName = PCLauncher emuExt = romPath = romPathFromIni = romExtension = romExtensionOrig = romExtensions = executable = systemDbName = PC Games systemName = PC Games dbPath = dbName = MUGEN Superheroes dbExt = romName = romMapPath = romMappingEnabled = false romMappingLaunchMenuEnabled = false romMappingFirstMatchingExt = false romMappingShowAllRomsInArchive = true romMappingNumberOfGamesByScreen = 7 romMappingMenuWidth = 400 romMappingMenuMargin = 65 romMappingTextFont = Bebas Neue romMappingTextOptions = cFFFFFFFF r4 s60 Bold romMappingDisabledTextColor = ff888888 romMappingTextSizeDifference = 7 romMappingTextMargin = 15 romMappingTitleTextFont = Bebas Neue romMappingTitleTextOptions = cFFFFFFFF r4 s90 Bold romMappingTitle2TextFont = Bebas Neue romMappingTitle2TextOptions = cFFFFFFFF r4 s22 Bold romMappingGameInfoTextFont = Bebas Neue romMappingGameInfoTextOptions = cFFFFFFFF r4 s22 Regular romMappingBackgroundBrush = aa000000 romMappingColumnBrush = 33000000 romMappingButtonBrush1 = 6f000000 romMappingButtonBrush2 = 33000000 romMappingBackgroundAlign = Stretch and Lose Aspect romMappingMenuFlagWidth = 55 romMappingMenuFlagSeparation = 7 romMappingDefaultMenuList = FullList romMappingSingleFilteredRomAutomaticLaunch = false altArchiveNameOnly = altRomNameOnly = altArchiveAndRomName = altArchiveAndManyRomNames = altRomNamesOnly = romMapScenario = skipchecks = false romMatchExt = false blockInputTime = 0 blockInputFile = E:\Rocketlauncher\Module Extensions\BlockInput.exe errorLevelReporting = false lockLaunch = false lockLaunchGame = screenRotationAngle = 0 screenRotationAngleGame = logFile = E:\Rocketlauncher\RocketLauncher.log logLabel := [" INFO"," WARNING"," ERROR"," DEBUG1"," DEBUG2"] logLevel = 10 logShowDebugConsole = true logIncludeModule = true logIncludeFileProperties = true logShowCommandWindow = false logCommandWindow = true rlDebugConsoleStdout = 7 sysLang = English_United_States sysType = 64-bit broadcastWindowTitle = navUpKey = Up navDownKey = Down navLeftKey = Left navRightKey = Right navSelectKey = 1 navP2UpKey = Numpad8 navP2DownKey = Numpad2 navP2LeftKey = Numpad4 navP2RightKey = Numpad6 navP2SelectKey = NumpadEnter originalWidth = 1440 originalHeight = 900 vdEnabled = false vdFullPath = vdUseSCSI = true vdDriveLetter = vdAddDrive = true servoStikEnabled = false servoStikExitMode = false ledblinkyEnabled = false ledblinkyFullPath = ledblinkyProfilePath = E:\Rocketlauncher\Profiles\LEDBlinky ledblinkyRLProfile = E:\Rocketlauncher\Profiles\LEDBlinky\RocketLauncher emuIdleShutdown = 0 launchPasswordHash = UpUpDownDownLeftRightLeftRight hideCursor = true hideEmu = false hideFE = false fadeIn = false fadeInDuration = 500 fadeInTransitionAnimation = DefaultAnimateFadeIn fadeInDelay = 0 fadeInExitDelay = 0 fadeOutExitDelay = 0 fadeOut = false fadeOutExtraScreen = false fadeOutDuration = 500 fadeOutTransitionAnimation = LegacyFadeOutTransition fadeOutDelay = 0 fadeLyrInterpolation = 7 fadeMuteEmulator = false fadeUseBackgrounds = false fadeWidthBaseRes = 1920 fadeHeightBaseRes = 1080 fadeLyr1Color = FF000000 fadeLyr1AlignImage = Stretch and Lose Aspect fadeLyr2Pos = Stretch and Lose Aspect fadeLyr2X = 0 fadeLyr2Y = 0 fadeLyr2W = fadeLyr2H = fadeLyr2Adjust = 1 fadeLyr2PicPad = 0 fadeLyr2Prefix = Extra Layer 1 - Console fadeLyr3Pos = Center fadeLyr3X = 450 fadeLyr3Y = 5 fadeLyr3W = fadeLyr3H = fadeLyr3Adjust = 1 fadeLyr3PicPad = 0 fadeLyr3Speed = 750 fadeLyr3Animation = DefaultFadeAnimation fadeLyr37zAnimation = DefaultFadeAnimation fadeLyr3Type = imageandbar fadeLyr3ImgFollow7zProgress = true fadeLyr3Repeat = 1 fadeLyr3BackImageTransparency = 30 fadeLyr3StaticPos = No Alignment fadeLyr3StaticX = 0 fadeLyr3StaticY = 870|1575 fadeLyr3StaticW = fadeLyr3StaticH = fadeLyr3StaticAdjust = 1 fadeLyr3StaticPicPad = 0 fadeLyr3StaticPrefix = Info Bar fadeLyr4Adjust = 1 fadeLyr4X = 1792|952 fadeLyr4Y = 891|1596 fadeLyr4W = 128 fadeLyr4H = fadeLyr4Pos = No Alignment fadeLyr4FPS = 50 fadeLyr4PicPad = 0 fadeTranspGifColor = FFFFFF fadeBarWindow = Image fadeBarWindowX = fadeBarWindowY = fadeBarWindowW = 900 fadeBarWindowH = fadeBarWindowR = 30 fadeBarWindowM = 30 fadeBarWindowHatchStyle = 8 fadeBar = true fadeBarNon7zProgressTime = 0 fadeBarBack = true fadeBarBackColor = FF555555 fadeBarH = 30 fadeBarR = 10 fadeBarColor = DD00BFFF fadeBarHatchStyle = 8 fadeBarPercentageText = true fadeBarInfoText = true fadeBarXOffset = 0 fadeBarYOffset = 150 fadeRomInfoDescription = filtered text fadeRomInfoSystemName = image fadeRomInfoYear = text with label fadeRomInfoManufacturer = text with label fadeRomInfoGenre = disabled fadeRomInfoRating = image fadeRomInfoOrder = Description|SystemName|Year|Manufacturer|Genre|Rating fadeRomInfoTextPlacement = User Defined fadeRomInfoTextMargin = 7 fadeRomInfoText1Options = w1600|787 h90 x165 y870|1575 cFFE1E1E1 r4 s90 Left Regular fadeRomInfoText2Options = w400 x8 y15 cFF555555 r4 s60 Bold fadeRomInfoText3Options = w310 x165 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText4Options = w1305|492 h66 x460 y960|1665 cFFE1E1E1 r4 s66 Left Regular fadeRomInfoText5Options = cFF555555 r4 s42 Bold fadeRomInfoText6Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular fadeStats_Number_of_Times_Played = text with label fadeStats_Last_Time_Played = text with label fadeStats_Average_Time_Played = text with label fadeStats_Total_Time_Played = text with label fadeStats_System_Total_Played_Time = text with label fadeStats_Total_Global_Played_Time = text with label fadeStatsInfoOrder = Number_of_Times_Played|Last_Time_Played|Average_Time_Played|Total_Time_Played|System_Total_Played_Time|Total_Global_Played_Time fadeStatsInfoTextPlacement = topRight fadeStatsInfoTextMargin = 7 fadeStatsInfoText1Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText2Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText3Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText4Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText5Options = cFFB4B4B4 r4 s22 Bold fadeStatsInfoText6Options = cFFB4B4B4 r4 s22 Bold fadeText1X = 0 fadeText1Y = 0 fadeText1Options = cFFB4B4B4 r4 s30 Right Bold fadeText1 = Loading Game fadeText2X = 0 fadeText2Y = 0 fadeText2Options = cFFB4B4B4 r4 s30 Right Bold fadeText2 = Extraction Complete, Ready fadeText3 = Loading Game fadeText4 = Loading Complete fadeFont = Bebas Neue fadeSystemAndRomLayersOnly = false fadeExtractionTime = disabled fadeExtractionTimeTextX = 0 fadeExtractionTimeTextY = 0 fadeExtractionTimeTextOptions = cFF555555 r4 s20 Bold fadeInterruptKey = detectFadeErrorEnabled = false fadeImgPath = E:\Rocketlauncher\Media\Fade RLDataPath = E:\Rocketlauncher\Data RLMediaPath = E:\Rocketlauncher\Media RLErrSoundPath = E:\Rocketlauncher\Media\Sounds\Error modulesPath = E:\Rocketlauncher\Modules moduleFullName = E:\Rocketlauncher\Modules\PCLauncher\PCLauncher.ahk moduleName = PCLauncher modulePath = E:\Rocketlauncher\Modules\PCLauncher moduleExtension = ahk moduleExtensionsPath = E:\Rocketlauncher\Module Extensions libPath = E:\Rocketlauncher\Lib 7zEnabled = true 7zPath = E:\Rocketlauncher\Module Extensions\7z.exe 7zDllPath = E:\Rocketlauncher\Module Extensions\7z.dll 7zExtractPath = C:\Users\Lenovo\AppData\Local\Temp\HS 7zExtractPathOrig = 7zAttachSystemName = false 7zDelTemp = true 7zSounds = true 7zFormats = .zip,.rar,.7z,.lzh,.gzip,.tar 7zFormatsNoP = zip,rar,7z,lzh,gzip,tar mgEnabled = false mgKey = ~NumpadSub mgBackgroundColor = FF000000 mgSidePadding = 0.2 mgWidthBaseRes = 1920 mgHeightBaseRes = 1080 mgYOffset = 500|800 mgFont = Arial mgText1Options = x10p y250|500 w80p Center cBBFFFFFF r4 s100 BoldItalic mgText1Text = Please select a game mgText2Options = w96p cFFFFFFFF r4 s50 Center BoldItalic mgText2Offset = 100 mgUseSound = true mgSoundfreq = 300 mgExitEffect = none mgSelectedEffect = rotate mgUseGameArt = false mgCandidate = mgValidTypes = (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side mgOnLaunch = false pauseEnabled = false pauseKey = m pauseBackToMenuBarKey = n pauseZoomInKey = C pauseZoomOutKey = V pauseScreenshotKey = ~PrintScreen pauseHiToTextPath = E:\Rocketlauncher\Module Extensions\HiToText.exe pauseSaveStateKeyCodes = pauseLoadStateKeyCodes = keymapperEnabled = true keymapperAHKMethod = External keymapper = xpadder xpadderFullPath = E:\Hyperspin\Utilities\Xpadder\Xpadder.exe joyToKeyFullPath = E:\Utilities\JoyToKey\JoyToKey.exe keymapperProfilePath = E:\Rocketlauncher\Profiles\xpadder keymapperFrontEndProfileName = RocketLauncherUI keymapperFrontEndProfile = xpadder keymapperRocketLauncherProfileEnabled = true joyIDsEnabled = true joyIDsPreferredControllersGlobal = Controller (Xbox 360 Wireless Receiver for Windows) joyIDsPreferredControllersSystem = use_global joyIDsPreferredControllersOnExit = CustomJoyNamesEnabled = false CustomJoyNames = rotateMethod = false FEProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI defaultProfile = E:\Rocketlauncher\Profiles\xpadder\_Default systemProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games xPadderSystemProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default emuProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher romProfile = E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes RocketLauncherProfile = E:\Rocketlauncher\Profiles\xpadder\RocketLauncher blankProfile = E:\Rocketlauncher\Profiles\xpadder\_Default\blank ahkFEProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncherUI ahkDefaultProfile = E:\Rocketlauncher\Profiles\AHK\_Default ahkSystemProfile = E:\Rocketlauncher\Profiles\AHK\PC Games ahkEmuProfile = E:\Rocketlauncher\Profiles\AHK\PC Games\PCLauncher ahkRomProfile = E:\Rocketlauncher\Profiles\AHK\PC Games\MUGEN Superheroes ahkRocketLauncherProfile = E:\Rocketlauncher\Profiles\AHK\RocketLauncher bezelEnabled = false bezelICEnabled = false statisticsEnabled = true pressDuration = -1 emuVolume = 1 dxwndIni = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.ini dxwndFullPath = E:\Rocketlauncher\Module Extensions\dxwnd\dxwnd.exe mon1O = pacDrivedllFile = E:\Rocketlauncher\Module Extensions\PacDrive32.dll userFadeAnimIniFile = E:\Rocketlauncher\Lib\User Fade Animations.ini 22:18:36:266 | RL | INFO | +0 | BuildScript - Loaded XHotkey Init.ahk scripts 22:18:36:276 | RL | INFO | +16 | BuildScript - Loaded Keymapper Init.ahk scripts 22:18:36:276 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 22:18:36:276 | RL | WARNING | +0 | BuildScript - "E:\Rocketlauncher\Lib\User Functions Init.ahk" not found 22:18:36:276 | RL | DEBUG1 | +0 | BuildScript - Module starts on line: 2 22:18:36:276 | RL | INFO | +0 | BuildScript - Validating module 22:18:36:286 | RL | INFO | +15 | BuildScript - Validation complete 22:18:36:286 | RL | INFO | +0 | BuildScript - Module: MEmu = PCLauncher MEmuV = N/A MURL = http://www.rlauncher.com/wiki/index.php?title=PCLauncher MAuthor = djvj MVersion = 2.1.7 MCRC = D8BCAECA iCRC = A79D31F9 mId = 635243126483565041 MSystem = "Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project" ;---------------------------------------------------------------------------- ; Notes: ; Use the examples in the ini, in your Modules\PCLauncher\ folder, to add more applications. ; PCLauncher supports per-System inis. Copy your PCLauncher ini in the same folder and rename it to match the System's Name. Use this if you have games with the same name across multiple systems. ; Read the comments at the top of ini for the definitions of each key. ; For informaion on how to use this module and what all the settings do, please see https://sites.google.com/site/RocketLauncher2/additional-features/pclauncher ;---------------------------------------------------------------------------- StartModule() If (romExtensions != "") ScriptError("PCLauncher does not use extensions, but you have them set to: """ . romExtensions . """. Please remove all extensions from the PCLauncher emulator in RocketLauncherUI to continue using it.") IfExist, % modulePath . "\" . systemName . ".ini" ; use a custom systemName ini if it exists settingsFile := modulePath . "\" . systemName . ".ini" Else settingsFile := CheckFile(modulePath . "\" . moduleName . ".ini", "Could not find """ . modulePath . "\" . moduleName . ".ini"". RocketLauncherUI will create this file when you configure your first game to be used with this " . MEmu . " module.") iniLookup = SteamID|Application|AppWaitExe|DiscImage|Parameters|OriginGame|DXWndGame|WorkingFolder|PreLaunch|PreLaunchParameters|PreLaunchMode|PreLaunchSleep|PostLaunch|PostLaunchParameters|PostLaunchSleep|PostExit|PostExitParameters|PostExitSleep|ExitMethod|FadeTitle|FadeInExitSleep|BezelEnabled Loop, Parse, iniLookup, | { %A_LoopField% := IniReadCheck(settingsFile, dbName, A_LoopField, A_Space,,1) If A_LoopField in Application If (!Application && !SteamID) { ; Create keys if they do not exist in the ini and this is not a steam game IniWrite, %A_Space%, %SettingsFile%, %dbName%, %A_LoopField% missingKeys = 1 } } ; These settings enable them to be customized per-game in this module bezelEnabled := IniReadCheck(settingsFile, "Settings|" . dbName, "BezelEnabled",,,1) If bezelEnabled = true BezelGUI() FadeInStart() If bezelEnabled = true BezelStart() If (missingKeys && !SteamID) ScriptError("You have not set up " . dbName . " in RocketLauncherUI yet, so PCLauncher does not know what exe, FadeTitle, and/or SteamID to watch for.") ; If Application needs a cd/dvd image in the drive, mount it in DT first If DiscImage { Log("PCLauncher - Application is a Disc Image, mounting it in DT") appIsImage=1 DiscImage := GetFullName(DiscImage) ; convert a relative path defined in the PCLauncher ini to absolute CheckFile(DiscImage,"Cannot find this DiscImage for " . dbName . ":`n" . DiscImage) SplitPath,DiscImage,,ImagePath,ImageExt,ImageName If ImageExt in mds,mdx,b5t,b6t,bwt,ccd,cue,isz,nrg,cdi,iso,ape,flac { VirtualDrive("get") ; get the vdDriveLetter VirtualDrive("mount",ImagePath . "\" . ImageName . "." . ImageExt) } Else ScriptError("You defined a DiscImage, but it is not a supported format for this module and/or DT:`nccd,cdi,cue,iso,isz,nrg") } ; Verify module's settings are set CheckSettings() If PreLaunch { Log("PCLauncher - PreLaunch set by user, running: " . PreLaunch) PreLaunchParameters := If (!PreLaunchParameters or PreLaunchParameters="ERROR" ) ? "" : PreLaunchParameters If (preLaunchMode = "run") { errLevel := Run(If preLSkip ? PreLaunch : """" . PreLaunchName . """ " . PreLaunchParameters, PreLaunchPath) If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") Sleep, %PreLaunchSleep% } Else { errLevel := RunWait(If preLSkip ? PreLaunch : """" . PreLaunchName . """ " . PreLaunchParameters, PreLaunchPath) If errLevel ScriptError("There was a problem launching your PreLaunch application. Please check it is a valid executable.") } } If DXWndGame = true ; start dxwnd if needed DxwndRun() If mode in steam,steambp ; steam launch Steam(SteamID, Application, Parameters) Else If mode = origin ; origin launch Origin(ApplicationName, ApplicationPath, Parameters) Else { If mode = url { Log("PCLauncher - Launching URL.") errLevel := Run(Application) } Else { ; standard launch Log("PCLauncher - Launching a standard application.") errLevel := Run("""" . (If WorkingFolder ? ApplicationPath . "\" : "") . ApplicationName . """ " . Parameters, If WorkingFolder ? WorkingFolder : ApplicationPath,, AppPID) } If errLevel ScriptError("There was a problem launching your " . (If appIsImage ? "ImageExe" : "Application") . ". Please check it is a valid executable.") } If PostLaunch { Log("PCLauncher - PostLaunch set by user, running: " . PostLaunch) PostLaunchParameters := If (!PostLaunchParameters or PostLaunchParameters="ERROR" ) ? "" : PostLaunchParameters errLevel := Run(If postLSkip ? PostLaunch : """" . PostLaunchName . """ " . PostLaunchParameters, PostLaunchPath) If errLevel ScriptError("There was a problem launching your PostLaunch application. Please check it is a valid executable.") Sleep, %PostLaunchSleep% } If FadeTitle { Log("PCLauncher - FadeTitle set by user, waiting for """ . FadeTitle . """") WinWait(FadeTitle) WinWaitActive(FadeTitle) } Else If AppWaitExe { Log("PCLauncher - FadeTitle not set by user, but AppWaitExe is. Waiting for AppWaitExe: " . AppWaitExe) AppWaitPID := Process("Wait", AppWaitExe, 15) If AppWaitPID = 0 ScriptError("PCLauncher - There was an error getting the Process ID from your AppWaitExe for """ . dbName . """. Please try setting a FadeTitle instead.") } Else If SteamIDExe { Log("PCLauncher - FadeTitle and AppWaitExe not set by user, but SteamIDExe was found. Waiting for SteamIDExe: " . SteamIDExe) SteamIDPID := Process("Wait", SteamIDExe, 15) If SteamIDPID = 0 ScriptError("PCLauncher - There was an error getting the Process ID from your SteamIDExe for """ . dbName . """. Please try setting a FadeTitle instead.") } Else If AppPID { Log("PCLauncher - FadeTitle and AppWaitExe not set by user, but an AppPID was found. Waiting for AppPID: " . AppPID) WinWait("ahk_pid " . AppPID) WinWaitActive("ahk_pid " . AppPID) } Else Log("PCLauncher - FadeTitle and AppWaitExe not set by user and no AppPID found from an Application, PCLauncher has nothing to wait for",3) If bezelEnabled = true BezelDraw() Sleep, %FadeInExitSleep% ; PCLauncher setting for some stubborn games that keeps the fadeIn screen up a little longer FadeInExit() If AppWaitExe { SplitPath,AppWaitExe,AppWaitExe ; In case someone set this as a path accidentally, only want the filename from this key Log("PCLauncher - Waiting for AppWaitExe """ . AppWaitExe . """ to close.") Process("WaitClose", AppWaitExe) } Else If FadeTitle { ; If fadeTitle is set and no appPID was created. Log("PCLauncher - Waiting for FadeTitle """ . FadeTitle . """ to close.") WinWaitClose(FadeTitle) } Else If SteamIDExe { Log("PCLauncher - Waiting for SteamIDExe """ . SteamIDExe . """ to close.") Process("WaitClose", SteamIDExe) } Else If AppPID { Log("PCLauncher - Waiting for AppPID """ . AppPID . """ to close.") Process("WaitClose", AppPID) } Else ScriptError("Could not find a proper AppWaitExe`, FadeTitle`, or AppPID (from the launched Application). Try setting either an AppWaitExe or FadeTitle so the module has something to look for.") If PostExit { Log("PCLauncher - PostExit set by user, running: " . PostExit) PostExitParameters := If (!PostExitParameters or PostExitParameters="ERROR" ) ? "" : PostExitParameters errLevel := Run(If postESkip ? PostExit : """" . PostExitName . """ " . PostExitParameters, PostExitPath) If errLevel ScriptError("There was a problem launching your PostExit application. Please check it is a valid executable.") Sleep, %PostExitSleep% } ; If Application is a cd/dvd image, unmount it in DT If appIsImage VirtualDrive("unmount") ; Close steam if it was not open prior to launch, not really needed anymore because module knows how to launch if steam already running now ; If AppPID = 0 ; Run, Steam.exe -shutdown, %SteamPath% ; close steam If DXWndGame = true DxwndClose() If bezelEnabled = true BezelExit() FadeOutExit() ExitModule() CheckSettings() { Global Application,ApplicationPath,ApplicationName,ApplicationExt Global PreLaunch,PreLaunchPath,PreLaunchName,PreLaunchExt Global PostLaunch,PostLaunchPath,PostLaunchName,PostLaunchExt Global PostExit,PostExitPath,PostExitName,PostExitExt Global moduleName,appIsImage,vdDriveLetter,SteamID,OriginGame,DXWndGame,mode,preLSkip,postLSkip,postESkip,AppWaitExe,SteamIDExe,FadeTitle Global modulePath,fadeIn Log("CheckSettings - Started") ; These checks allow you to run URL and Steam browser protocol commands. Without them ahk would error out that it can't find the file. This is different than setting a SteamID but either work If (SteamID) { mode = steam ; setting module to use steam mode Log("PCLauncher - SteamID is set, setting mode to: """ . mode . """") } Else If (SubStr(Application,1,3) = "ste") { mode = steambp ; setting module to use Steam Browser Protocol mode Log("PCLauncher - Application is a Steam Browser Protocol, setting mode to: """ . mode . """") } Else If (SubStr(Application,1,4) = "http") { mode = url ; setting module to use url mode Log("PCLauncher - Application is a URL, setting mode to: """ . mode . """") } Else If OriginGame { mode = origin ; setting module to use Origin mode Application := GetFullName(Application) ; convert a relative path defined in the PCLauncher ini to absolute SplitPath,Application,ApplicationName,ApplicationPath,ApplicationExt StringRight, ApplicationBackSlash, Application, 1 Log("PCLauncher - Origin mode enabled. Will log in to Origin if required.") } Else If Application { mode = standard ; for standard launching Application := GetFullName(Application) ; convert a relative path defined in the PCLauncher ini to absolute SplitPath,Application,ApplicationName,ApplicationPath,ApplicationExt StringRight, ApplicationBackSlash, Application, 1 Log("PCLauncher - Setting mode to: """ . mode . """") } Else ; error if no modes are used ScriptError("Please set an Application, SteamID, Steam Browser Protocol, or URL in " moduleName . ".ini for """ . dbName . """") If (SteamID && Application) ; do not allow 2 launching methods ScriptError("You are trying to use Steam and Application, you must choose one or the other.") If ((mode = "steam" || mode = "steambp") && !AppWaitExe && !FadeTitle) { ; && fadeIn = "true") { ; If AppWaitExe or FadeTitle are defined, that will take precedence over the automatic method using the SteamIDs.ini SteamIDFile := CheckFile(modulePath . "\SteamIDs.ini") If !SteamID SplitPath, Application,SteamID ; grab the SteamIDExe := IniReadCheck(SteamIDFile, SteamID, "exe","",,1) If !SteamIDExe ScriptError("You are using launching a Steam game but no way for the module to know what window to wait for after launching. Please set a AppWaitExe, FadeTitle, or make sure your SteamID and the correct exe is defined in the SteamIDs.ini",10) Else Log("PCLauncher - Found an exe in the SteamIDs.ini for this game: """ . SteamIDExe . """") } Else If (mode = "url" && !AppWaitExe && !FadeTitle) ScriptError("You are using launching a URL but no way for the module to know what to window to wait for after launching. Please set a AppWaitExe or FadeTitle to your default application that gets launched when opening URLs.",10) preLSkip := If (SubStr(PreLaunch,1,4)="http" || SubStr(PreLaunch,1,3)="ste") ? 1:"" If preLSkip Log("PCLauncher - PreLaunch is a URL or Steam Browser Protocol: " . PreLaunch) postLSkip := If (SubStr(PostLaunch,1,4)="http" || SubStr(PostLaunch,1,3)="ste") ? 1:"" If postLSkip Log("PCLauncher - PostLaunch is a URL or Steam Browser Protocol: " . PostLaunch) postESkip := If (SubStr(PostExit,1,4)="http" || SubStr(PostExit,1,3)="ste") ? 1:"" If postESkip Log("PCLauncher - PostExit is a URL or Steam Browser Protocol: " . PostExit) If (ApplicationBackSlash = "\") ScriptError("Please make sure your Application does not contain a backslash on the end:`n" . Application) If (appIsImage && !ApplicationPath) ; if user only defined an exe for Application with no path, assume it will be found on the root dir of the image when mounted ApplicationPath := vdDriveLetter . ":\" If (!ApplicationName && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing filename on the end of your Application in " . moduleName . ".ini:`n" . Application) If (!ApplicationExt && mode = "standard" && (mode != "steam" || mode != "steambp")) ScriptError("Missing extension on your Application in " . moduleName . ".ini:`n" . Application) If (PreLaunch && !preLSkip) { PreLaunch := GetFullName(PreLaunch) SplitPath,PreLaunch,PreLaunchName,PreLaunchPath,PreLaunchExt StringRight, PreLaunchBackSlash, PreLaunch, 1 CheckFile(PreLaunch,"Cannot find this PreLaunch application:`n" . PreLaunch) If (PreLaunchBackSlash = "\") ScriptError("Please make sure your PreLaunch does not contain a backslash on the end:`n" . PreLaunch) } If (PostLaunch && !postLSkip) { PostLaunch := GetFullName(PostLaunch) SplitPath,PostLaunch,PostLaunchName,PostLaunchPath,PostLaunchExt StringRight, PostLaunchBackSlash, PostLaunch, 1 CheckFile(PostLaunch,"Cannot find this PostLaunch application:`n" . PostLaunch) If (PostLaunchBackSlash = "\") ScriptError("Please make sure your PostLaunch does not contain a backslash on the end:`n" . PostLaunch) } If (PostExit && !postESkip) { PostExit := GetFullName(PostExit) SplitPath,PostExit,PostExitName,PostExitPath,PostExitExt StringRight, PostExitBackSlash, PostExit, 1 CheckFile(PostExit,"Cannot find this PostExit application:`n" . PostExit) If (PostExitBackSlash = "\") ScriptError("Please make sure your PostExit does not contain a backslash on the end:`n" . PostExit) } If mode = standard CheckFile(ApplicationPath . "\" . ApplicationName,"Cannot find this Application:`n" . ApplicationPath . "\" . ApplicationName) ; keeping this last so more descriptive errors will trigger first Log("CheckSettings - Ended") } CloseProcess: If ExitMethod ; fadeout will only take effect if an ExitMethod method was set, otherwise fade will occur and application will not close FadeOutStart() If ( ExitMethod = "Process Close AppWaitExe" && AppWaitExe) { Log("CloseProcess - ExitMethod is ""Process Close AppWaitExe""") Process("Close", AppWaitExe) } Else If ( ExitMethod = "WinClose AppWaitExe" && AppWaitExe) { Log("CloseProcess - ExitMethod is ""WinClose AppWaitExe""") AppWaitExePID := Process("Exist", AppWaitExe) WinClose("ahk_pid " . AppWaitExePID) } Else If ( ExitMethod = "Process Close Application" ) { Log("CloseProcess - ExitMethod is ""Process Close Application""") Process("Close", ApplicationName) } Else If ( ExitMethod = "WinClose Application" && FadeTitle ) { Log("CloseProcess - ExitMethod is ""WinClose Close Application""") WinClose(FadeTitle) } Else If ( ExitMethod = "Send Alt+F4" ) { Log("CloseProcess - ExitMethod is ""Send Alt+F4""") Send, !{F4} } Else { Log("CloseProcess - Default ExitMethod`, using ""WinClose""") WinClose(ApplicationName) } Return 22:18:36:296 | RL | INFO | +0 | BuildScript - Loaded Multi-Player scripts 22:18:36:296 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 22:18:36:306 | RL | WARNING | +16 | BuildScript - "E:\Rocketlauncher\Lib\User Functions.ahk" not found 22:18:36:306 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 22:18:36:306 | RL | INFO | +0 | Main - Module is built 22:18:36:306 | RL | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\AutoHotkey.dll exists 22:18:36:306 | RL | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AutoHotkey_H ANSI 32-bit FileVersion 1.1.09.04 InternalName AutoHotkey_H LegalCopyright Copyright (C) 2012 OriginalFilename AutoHotkey.exe ProductName AutoHotkey_H ProductVersion 1.1.09.04 File Size: 785408 bytes Created: 5/24/2015 - 9:28:11 AM Modified: 4/19/2013 - 7:16:32 PM 22:18:36:316 | RL | INFO | +15 | Main - Running module 22:18:36:316 | RL | INFO | +0 | Main - Starting timer to watch if Front End gets displaced and restore it if it does. 22:18:36:406 | MD | INFO | +N/A | Module initialized 22:18:36:406 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:18:36:406 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups 22:18:36:406 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:18:36:426 | MD | DEBUG2 | +32 | XHotkeyTableCreation - Post loop 2 check 22:18:36:426 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess" 22:18:36:426 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:18:36:426 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:18:36:436 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~1joy6 not in TableKeyGroups ~Esc, 22:18:36:436 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:18:36:436 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 2 check 22:18:36:436 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using extended Hotkey method for key(s): "~1joy6" to call a group label 22:18:36:436 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Ended 22:18:36:476 | MD | DEBUG2 | +46 | Keymapper - Checking for the JoyIDs_Preferred_Controllers key in E:\Rocketlauncher\Settings\PC Games\Games JoyIDs.ini under section [MUGEN Superheroes] 22:18:36:476 | MD | INFO | +0 | LoadPreferredControllers - Started 22:18:36:506 | MD | DEBUG2 | +32 | LoadPreferredControllers - JoyIDsPreferredControllers = Controller (Xbox 360 Wireless Receiver for Windows) 22:18:36:536 | MD | DEBUG2 | +31 | LoadPreferredControllers - Creating a list of currently connected joysticks 22:18:36:546 | MD | INFO | +0 | GetJoystickArray - Started 22:18:36:566 | MD | DEBUG2 | +31 | GetJoystickArray - Joysticks Detected: 1000000000000000 22:18:36:596 | MD | INFO | +31 | GetJoystickGUID - Started 22:18:36:596 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 22:18:36:596 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 22:18:36:596 | MD | INFO | +0 | GetJoystickArray - Ended 22:18:36:606 | MD | DEBUG2 | +0 | LoadPreferredControllers - Preferred Order Sorting List -> 1.01|045e|02a1|5041DB96E6EDE4118001444553540000 22:18:36:606 | MD | INFO | +0 | LoadPreferredControllers - Sorting Currently Connected joysticks List to match the order of the Preferred Controller List 22:18:36:606 | MD | INFO | +0 | LoadPreferredControllers - Assigning the New Joystick IDs according to the preferred list for the active controllers 22:18:36:606 | MD | INFO | +0 | ChangeJoystickID - Started 22:18:36:606 | MD | DEBUG2 | +0 | ChangeJoystickID - Swapping Joystick ID: 00000000 to the New Joystick ID: 00000000, for the Joystick VID_045e&PID_02a1&GUID_5041DB96E6EDE4118001444553540000 22:18:36:626 | MD | INFO | +31 | ChangeJoystickID - Ended 22:18:36:626 | MD | INFO | +0 | LoadPreferredControllers - Ended 22:18:36:626 | MD | INFO | +0 | CheckFile - Checking if E:\Hyperspin\Utilities\Xpadder\Xpadder.exe exists 22:18:36:636 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 1178624 bytes Created: 6/16/2015 - 12:46:34 PM Modified: 2/2/2014 - 4:10:38 PM 22:18:36:636 | MD | INFO | +0 | Keymapper - Loading xpadder 22:18:36:636 | MD | INFO | +0 | RunKeymapper - Started, using method "load" 22:18:36:636 | MD | INFO | +0 | GetJoystickArray - Started 22:18:36:666 | MD | DEBUG2 | +32 | GetJoystickArray - Joysticks Detected: 1000000000000000 22:18:36:666 | MD | INFO | +0 | GetJoystickGUID - Started 22:18:36:666 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 22:18:36:696 | MD | DEBUG2 | +31 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 22:18:36:696 | MD | INFO | +0 | GetJoystickArray - Ended 22:18:36:696 | MD | DEBUG2 | +0 | RunKeymapper - Found your keymapper application here: "E:\Hyperspin\Utilities\Xpadder\Xpadder.exe" 22:18:36:696 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 22:18:36:726 | MD | DEBUG2 | +31 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)" 22:18:36:726 | MD | DEBUG2 | +0 | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes|E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher|E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default|E:\Rocketlauncher\Profiles\xpadder\_Default\blank 22:18:36:726 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:18:36:726 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\MUGEN Superheroes\p1.xpadderprofile 22:18:36:726 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:18:36:756 | MD | DEBUG2 | +31 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\PCLauncher\p1.xpadderprofile 22:18:36:786 | MD | DEBUG2 | +31 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:18:36:786 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\PC Games\_Default\p1.xpadderprofile 22:18:36:786 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:18:36:786 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile 22:18:36:796 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile 22:18:36:796 | MD | INFO | +0 | RunXpadder - Started 22:18:36:796 | MD | INFO | +0 | Process - Exist JoyToKey.exe 22:18:36:796 | MD | DEBUG2 | +0 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 22:18:36:796 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 22:18:36:846 | MD | DEBUG1 | +63 | Run - "Xpadder.exe /C" Process ID: 3672 22:18:36:846 | MD | DEBUG2 | +0 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 22:18:36:846 | MD | INFO | +0 | Process - WaitClose Xpadder.exe 2 22:18:37:066 | MD | DEBUG2 | +218 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 22:18:37:066 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 22:18:37:076 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M 22:18:37:126 | MD | DEBUG1 | +63 | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\_Default\p1.xpadderprofile" /M" Process ID: 2756 22:18:37:126 | MD | INFO | +0 | RunXpadder - Ended 22:18:37:126 | MD | INFO | +0 | RunKeymapper - Ended 22:18:37:126 | MD | INFO | +0 | Keymapper - Loading External AHK Keymapping 22:18:37:126 | MD | INFO | +0 | CheckFile - Checking if E:\Rocketlauncher\Module Extensions\AhkLauncher.exe exists 22:18:37:136 | MD | DEBUG1 | +0 | CheckFile - Attributes: FileDescription AhkLauncher FileVersion 1.0.0.0 InternalName AhkLauncher.exe LegalCopyright Copyright © 2013 OriginalFilename AhkLauncher.exe ProductName AhkLauncher ProductVersion 1.0.0.0 File Size: 11264 bytes Created: 5/24/2015 - 9:28:06 AM Modified: 9/4/2013 - 7:30:52 PM 22:18:37:136 | MD | INFO | +0 | RunAHKKeymapper - Started 22:18:37:136 | MD | DEBUG1 | +0 | RunAHKKeymapper - Loading MUGEN Superheroes, PCLauncher, PC Games, or _Default AHK Keymapper profile 22:18:37:136 | MD | INFO | +0 | GetAHKProfile - Started 22:18:37:136 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\PC Games\MUGEN Superheroes.ahk 22:18:37:136 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\PC Games\PCLauncher.ahk 22:18:37:156 | MD | DEBUG2 | +31 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\PC Games.ahk 22:18:37:156 | MD | DEBUG2 | +0 | GetAHKProfile - Searching for: E:\Rocketlauncher\Profiles\AHK\_Default.ahk 22:18:37:156 | MD | INFO | +0 | GetAHKProfile - Ended and no profile found 22:18:37:166 | MD | DEBUG1 | +0 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 22:18:37:166 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 22:18:37:166 | MD | INFO | +0 | RunAHKKeymapper - Ended 22:18:37:166 | MD | INFO | +0 | StartModule - Started 22:18:37:166 | MD | INFO | +0 | StartModule - MEmu: PCLauncher MEmuV: N/A MURL: http://www.rlauncher.com/wiki/index.php?title=PCLauncher MAuthor: djvj MVersion: 2.1.7 MCRC: D8BCAECA iCRC: A79D31F9 MID: MSystem: "Arcade PC","Doujin Soft","Examu eX-BOARD","Fan Remakes","Games for Windows","Konami e-Amusement","Konami Bemani","Microsoft Windows","PCLauncher","PC Games","Steam","Steam Big Picture","Taito Type X","Taito Type X2","Touhou","Touhou Project" 22:18:37:196 | MD | INFO | +31 | StartModule - You have a supported System Name for this module: "PC Games" 22:18:37:196 | MD | INFO | +0 | PluginInit - Started 22:18:37:196 | MD | DEBUG1 | +0 | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Manufacturer|Year|Genre|Rating 22:18:37:196 | MD | INFO | +0 | CheckFile - Checking if E:\HyperSpin\Databases\PC Games\PC Games.xml exists 22:18:37:196 | MD | DEBUG1 | +0 | CheckFile - Attributes: File Size: 6859 bytes Created: 10/16/2015 - 8:59:23 PM Modified: 10/19/2015 - 9:57:52 PM 22:18:37:226 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching for a "Game Name" in the database 22:18:37:226 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Game Name" in the database! 22:18:37:226 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Name 22:18:37:226 | MD | DEBUG1 | +0 | BuildDatabaseTable - Found "Name" with a value: "MUGEN Superheroes" 22:18:37:256 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching database for: Cloneof 22:18:37:256 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Cloneof 22:18:37:256 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Manufacturer 22:18:37:296 | MD | DEBUG1 | +32 | BuildDatabaseTable - Could not find: Manufacturer 22:18:37:296 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Year 22:18:37:296 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Year 22:18:37:316 | MD | DEBUG1 | +31 | BuildDatabaseTable - Searching database for: Genre 22:18:37:316 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Genre 22:18:37:316 | MD | DEBUG1 | +0 | BuildDatabaseTable - Searching database for: Rating 22:18:37:326 | MD | DEBUG1 | +0 | BuildDatabaseTable - Could not find: Rating 22:18:37:326 | MD | DEBUG2 | +0 | PluginInit - GameInfo: GameInfo Label: Name | GameInfo Value: 22:18:37:326 | MD | DEBUG1 | +0 | BuildDatabaseTable - Ended 22:18:37:326 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo 22:18:37:326 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Logo: E:\HyperSpin\Media\PC Games\Images\Wheel\MUGEN Superheroes.png 22:18:37:346 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a System Logo: E:\HyperSpin\Media\Main Menu\Images\Wheel\PC Games.png 22:18:37:346 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Game Logo | Asset Path1: E:\HyperSpin\Media\PC Games\Images\Wheel\MUGEN Superheroes.png | Asset Extension1: png | Asset Type1: game Asset Label: System Logo | Asset Path1: E:\HyperSpin\Media\Main Menu\Images\Wheel\PC Games.png | Asset Extension1: png | Asset Type1: system 22:18:37:346 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:18:37:356 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other 22:18:37:356 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Artwork1: E:\HyperSpin\Media\PC Games\Images\Artwork1\MUGEN Superheroes.png 22:18:37:356 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Box Art: E:\HyperSpin\Media\PC Games\Images\Artwork2\MUGEN Superheroes.png 22:18:37:356 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Cartridge: E:\HyperSpin\Media\PC Games\Images\Artwork3\MUGEN Superheroes.png 22:18:37:376 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Flyers: E:\HyperSpin\Media\PC Games\Images\Artwork4\MUGEN Superheroes.png 22:18:37:376 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Letters: E:\HyperSpin\Media\PC Games\Images\Letters 22:18:37:406 | MD | DEBUG1 | +31 | BuildAssetsTable - Searching for a Other: E:\HyperSpin\Media\PC Games\Images\Other 22:18:37:416 | MD | DEBUG2 | +0 | BuildAssetsTable - Media assets found: Asset Label: Letters | Asset Path1: E:\Hyperspin\Media\PC Games\Images\Letters\!.png | Asset Extension1: png | Asset Type1: system Asset Label: Letters | Asset Path2: E:\Hyperspin\Media\PC Games\Images\Letters\'.png | Asset Extension2: png | Asset Type2: system Asset Label: Letters | Asset Path3: E:\Hyperspin\Media\PC Games\Images\Letters\(.png | Asset Extension3: png | Asset Type3: system Asset Label: Letters | Asset Path4: E:\Hyperspin\Media\PC Games\Images\Letters\0.png | Asset Extension4: png | Asset Type4: system Asset Label: Letters | Asset Path5: E:\Hyperspin\Media\PC Games\Images\Letters\1.png | Asset Extension5: png | Asset Type5: system Asset Label: Letters | Asset Path6: E:\Hyperspin\Media\PC Games\Images\Letters\2.png | Asset Extension6: png | Asset Type6: system Asset Label: Letters | Asset Path7: E:\Hyperspin\Media\PC Games\Images\Letters\3.png | Asset Extension7: png | Asset Type7: system Asset Label: Letters | Asset Path8: E:\Hyperspin\Media\PC Games\Images\Letters\4.png | Asset Extension8: png | Asset Type8: system Asset Label: Letters | Asset Path9: E:\Hyperspin\Media\PC Games\Images\Letters\5.png | Asset Extension9: png | Asset Type9: system Asset Label: Letters | Asset Path10: E:\Hyperspin\Media\PC Games\Images\Letters\6.png | Asset Extension10: png | Asset Type10: system Asset Label: Letters | Asset Path11: E:\Hyperspin\Media\PC Games\Images\Letters\7.png | Asset Extension11: png | Asset Type11: system Asset Label: Letters | Asset Path12: E:\Hyperspin\Media\PC Games\Images\Letters\8.png | Asset Extension12: png | Asset Type12: system Asset Label: Letters | Asset Path13: E:\Hyperspin\Media\PC Games\Images\Letters\9.png | Asset Extension13: png | Asset Type13: system Asset Label: Letters | Asset Path14: E:\Hyperspin\Media\PC Games\Images\Letters\a.png | Asset Extension14: png | Asset Type14: system Asset Label: Letters | Asset Path15: E:\Hyperspin\Media\PC Games\Images\Letters\b.png | Asset Extension15: png | Asset Type15: system Asset Label: Letters | Asset Path16: E:\Hyperspin\Media\PC Games\Images\Letters\c.png | Asset Extension16: png | Asset Type16: system Asset Label: Letters | Asset Path17: E:\Hyperspin\Media\PC Games\Images\Letters\d.png | Asset Extension17: png | Asset Type17: system Asset Label: Letters | Asset Path18: E:\Hyperspin\Media\PC Games\Images\Letters\e.png | Asset Extension18: png | Asset Type18: system Asset Label: Letters | Asset Path19: E:\Hyperspin\Media\PC Games\Images\Letters\f.png | Asset Extension19: png | Asset Type19: system Asset Label: Letters | Asset Path20: E:\Hyperspin\Media\PC Games\Images\Letters\g.png | Asset Extension20: png | Asset Type20: system Asset Label: Letters | Asset Path21: E:\Hyperspin\Media\PC Games\Images\Letters\h.png | Asset Extension21: png | Asset Type21: system Asset Label: Letters | Asset Path22: E:\Hyperspin\Media\PC Games\Images\Letters\i.png | Asset Extension22: png | Asset Type22: system Asset Label: Letters | Asset Path23: E:\Hyperspin\Media\PC Games\Images\Letters\j.png | Asset Extension23: png | Asset Type23: system Asset Label: Letters | Asset Path24: E:\Hyperspin\Media\PC Games\Images\Letters\k.png | Asset Extension24: png | Asset Type24: system Asset Label: Letters | Asset Path25: E:\Hyperspin\Media\PC Games\Images\Letters\l.png | Asset Extension25: png | Asset Type25: system Asset Label: Letters | Asset Path26: E:\Hyperspin\Media\PC Games\Images\Letters\m.png | Asset Extension26: png | Asset Type26: system Asset Label: Letters | Asset Path27: E:\Hyperspin\Media\PC Games\Images\Letters\n.png | Asset Extension27: png | Asset Type27: system Asset Label: Letters | Asset Path28: E:\Hyperspin\Media\PC Games\Images\Letters\o.png | Asset Extension28: png | Asset Type28: system Asset Label: Letters | Asset Path29: E:\Hyperspin\Media\PC Games\Images\Letters\p.png | Asset Extension29: png | Asset Type29: system Asset Label: Letters | Asset Path30: E:\Hyperspin\Media\PC Games\Images\Letters\q.png | Asset Extension30: png | Asset Type30: system Asset Label: Letters | Asset Path31: E:\Hyperspin\Media\PC Games\Images\Letters\r.png | Asset Extension31: png | Asset Type31: system Asset Label: Letters | Asset Path32: E:\Hyperspin\Media\PC Games\Images\Letters\s.png | Asset Extension32: png | Asset Type32: system Asset Label: Letters | Asset Path33: E:\Hyperspin\Media\PC Games\Images\Letters\t.png | Asset Extension33: png | Asset Type33: system Asset Label: Letters | Asset Path34: E:\Hyperspin\Media\PC Games\Images\Letters\u.png | Asset Extension34: png | Asset Type34: system Asset Label: Letters | Asset Path35: E:\Hyperspin\Media\PC Games\Images\Letters\v.png | Asset Extension35: png | Asset Type35: system Asset Label: Letters | Asset Path36: E:\Hyperspin\Media\PC Games\Images\Letters\w.png | Asset Extension36: png | Asset Type36: system Asset Label: Letters | Asset Path37: E:\Hyperspin\Media\PC Games\Images\Letters\x.png | Asset Extension37: png | Asset Type37: system Asset Label: Letters | Asset Path38: E:\Hyperspin\Media\PC Games\Images\Letters\y.png | Asset Extension38: png | Asset Type38: system Asset Label: Letters | Asset Path39: E:\Hyperspin\Media\PC Games\Images\Letters\z.png | Asset Extension39: png | Asset Type39: system Asset Label: Other | Asset Path1: E:\Hyperspin\Media\PC Games\Images\Other\Pointer.png | Asset Extension1: png | Asset Type1: system 22:18:37:446 | MD | DEBUG1 | +32 | BuildAssetsTable - Ended 22:18:37:446 | MD | DEBUG1 | +0 | BuildAssetsTable - Started - Building Table for: Game Video|System Video 22:18:37:446 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a Game Video: E:\HyperSpin\Media\PC Games\Video\MUGEN Superheroes.* 22:18:37:446 | MD | DEBUG1 | +0 | BuildAssetsTable - Searching for a System Video: E:\HyperSpin\Media\Main Menu\Video\PC Games.* 22:18:37:506 | MD | DEBUG2 | +62 | BuildAssetsTable - Media assets found: Asset Label: Game Video | Asset Path1: E:\HyperSpin\Media\PC Games\Video\MUGEN Superheroes.mp4 | Asset Extension1: mp4 | Asset Type1: game Asset Label: System Video | Asset Path1: E:\HyperSpin\Media\Main Menu\Video\PC Games.mp4 | Asset Extension1: mp4 | Asset Type1: system 22:18:37:506 | MD | DEBUG1 | +0 | BuildAssetsTable - Ended 22:18:37:536 | MD | INFO | +31 | PluginInit - Ended 22:18:37:566 | MD | DEBUG1 | +31 | StartModule - Setting romName to the dbName sent to RocketLauncher: MUGEN Superheroes 22:18:37:566 | MD | INFO | +0 | Hiding mouse cursor 22:18:37:576 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Started 22:18:37:576 | MD | DEBUG2 | +0 | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~1joy6, 22:18:37:576 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 1 check 22:18:37:576 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Post loop 2 check 22:18:37:576 | MD | DEBUG2 | +0 | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor" 22:18:37:596 | MD | DEBUG2 | +32 | XHotkeyTableCreation - Ended 22:18:37:596 | MD | INFO | +0 | StartModule - Ended 22:18:37:606 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - SteamID: 22:18:37:606 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - Application: H:\PC Games\MUGEN Superheroes\MUGEN Superheroes.exe 22:18:37:606 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - AppWaitExe: 22:18:37:606 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - DiscImage: 22:18:37:606 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - Parameters: 22:18:37:626 | MD | INFO | +31 | Module Setting - [MUGEN Superheroes] - OriginGame: 22:18:37:636 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - DXWndGame: 22:18:37:636 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - WorkingFolder: 22:18:37:636 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PreLaunch: 22:18:37:636 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PreLaunchParameters: 22:18:37:636 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PreLaunchMode: 22:18:37:656 | MD | INFO | +31 | Module Setting - [MUGEN Superheroes] - PreLaunchSleep: 22:18:37:656 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PostLaunch: 22:18:37:656 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PostLaunchParameters: 22:18:37:666 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PostLaunchSleep: 22:18:37:666 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PostExit: 22:18:37:666 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PostExitParameters: 22:18:37:666 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - PostExitSleep: 22:18:37:696 | MD | INFO | +31 | Module Setting - [MUGEN Superheroes] - ExitMethod: Send Alt+F4 22:18:37:726 | MD | INFO | +31 | Module Setting - [MUGEN Superheroes] - FadeTitle: 22:18:37:756 | MD | INFO | +32 | Module Setting - [MUGEN Superheroes] - FadeInExitSleep: 22:18:37:756 | MD | INFO | +0 | Module Setting - [MUGEN Superheroes] - BezelEnabled: 22:18:37:786 | MD | INFO | +31 | Module Setting - [Settings] - BezelEnabled: 22:18:37:816 | MD | INFO | +31 | Module Setting - [MUGEN Superheroes] - BezelEnabled: 22:18:37:826 | MD | INFO | +0 | CheckSettings - Started 22:18:37:826 | MD | INFO | +0 | PCLauncher - Setting mode to: "standard" 22:18:37:846 | MD | INFO | +31 | CheckFile - Checking if H:\PC Games\MUGEN Superheroes\MUGEN Superheroes.exe exists 22:18:37:846 | MD | DEBUG1 | +0 | CheckFile - Attributes: FileDescription M.U.G.E.N Engine FileVersion 1.0.0 InternalName mugen LegalCopyright Copyright 1999-2010 Elecbyte OriginalFilename mugen.exe ProductName M.U.G.E.N ProductVersion 1.0.0 CompanyName Elecbyte LegalTrademarks Elecbyte, M.U.G.E.N File Size: 697344 bytes Created: 10/3/2015 - 9:52:14 PM Modified: 9/7/2013 - 5:28:12 AM 22:18:37:856 | MD | INFO | +0 | CheckSettings - Ended 22:18:37:856 | MD | INFO | +0 | PCLauncher - Launching a standard application. 22:18:37:876 | MD | INFO | +32 | Run - Running: H:\PC Games\MUGEN Superheroes\"MUGEN Superheroes.exe" 22:18:37:886 | MD | DEBUG1 | +0 | Run - ""MUGEN Superheroes.exe" " Process ID: 4400 22:18:37:906 | MD | INFO | +31 | PCLauncher - FadeTitle and AppWaitExe not set by user, but an AppPID was found. Waiting for AppPID: 4400 22:18:37:916 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x134029e | Process ID: 1656 | Process Path: E:\Hyperspin\HyperSpin.exe 22:18:37:916 | MD | INFO | +0 | WinWait - Waiting for "ahk_pid 4400" 22:18:38:676 | MD | DEBUG1 | +764 | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x134029e | Process ID: 1656 | Process Path: E:\Hyperspin\HyperSpin.exe 22:18:38:678 | MD | DEBUG1 | +0 | GetActiveWindowStatus - Title: HyperSpin | Class: ThunderRT6FormDC | State: 0 | X: 0 | Y: 0 | Width: 1440 | Height: 900 | Window HWND: 0x134029e | Process ID: 1656 | Process Path: E:\Hyperspin\HyperSpin.exe 22:18:38:679 | MD | INFO | +0 | WinWaitActive - Waiting for "ahk_pid 4400" 22:18:39:044 | MD | DEBUG1 | +375 | GetActiveWindowStatus - Title: M.U.G.E.N | Class: SDL_app | State: 0 | X: 0 | Y: 0 | Width: 640 | Height: 480 | Window HWND: 0xae0234 | Process ID: 4400 | Process Path: H:\PC Games\MUGEN Superheroes\MUGEN Superheroes.exe 22:18:39:111 | MD | INFO | +62 | PCLauncher - Waiting for AppPID "4400" to close. 22:18:39:113 | MD | INFO | +0 | Process - WaitClose 4400 22:18:39:434 | RL | WARNING | +3121 | HyperSpin.exe was displaced to x0 y0 w640 h480 by PCLauncher. It is probably running in true fullscreen mode. 22:18:49:734 | MD | DEBUG1 | +10624 | CloseProcess - Started, user requested to end launched application 22:18:49:736 | MD | INFO | +0 | CloseProcess - ExitMethod is "Send Alt+F4" 22:18:49:892 | MD | DEBUG1 | +156 | CloseProcess - Ended 22:19:10:031 | MD | INFO | +20139 | ExitModule - Started 22:19:10:034 | MD | INFO | +0 | Starting Updating Statistics: 22:19:10:034 | MD | DEBUG2 | +0 | Total Elapsed Time in Pause in seconds: 0 22:19:10:034 | MD | DEBUG2 | +0 | gameSectionStartTime:37072795 22:19:10:034 | MD | DEBUG2 | +0 | ElapsedTime:32 22:19:10:065 | MD | DEBUG2 | +32 | Statistics cleared game name: MUGEN Superheroes 22:19:10:096 | MD | DEBUG2 | +31 | Loaded game statistics from ini files: Number_of_Times_Played: 1 Last_Time_Played: Monday October 19, 2015 09:15:45 PM Average_Time_Played: 61 Total_Time_Played: 61 System_Total_Played_Time: 4071 Total_Global_Played_Time: 95777 22:19:10:096 | MD | DEBUG2 | +0 | Updated Statistics: Number_of_Times_Played: 2 Last_Time_Played: Monday October 19, 2015 10:18:37 PM Average_Time_Played: 47 Total_Time_Played: 93 System_Total_Played_Time: 4103 Total_Global_Played_Time: 95809 22:19:10:159 | MD | INFO | +62 | Game section statistics updated. 22:19:10:159 | MD | INFO | +0 | RunKeymapper - Started, using method "unload" 22:19:10:159 | MD | INFO | +0 | GetJoystickArray - Started 22:19:10:190 | MD | DEBUG2 | +31 | GetJoystickArray - Joysticks Detected: 1000000000000000 22:19:10:190 | MD | INFO | +0 | GetJoystickGUID - Started 22:19:10:190 | MD | INFO | +0 | GetJoystickGUID - Ended and found GUID: 5041DB96E6EDE4118001444553540000 22:19:10:190 | MD | DEBUG2 | +0 | GetJoystickArray - ID: 1 | Port: 0 | Name: Controller (Xbox 360 Wireless Receiver for Windows) | MID: 045e | PID: 02a1 | GUID: 5041DB96E6EDE4118001444553540000 22:19:10:190 | MD | INFO | +0 | GetJoystickArray - Ended 22:19:10:190 | MD | DEBUG2 | +0 | RunKeymapper - Looping through controllers to find xpadder profiles for each one 22:19:10:190 | MD | DEBUG2 | +0 | RunKeymapper - ID: 1 Now searching for a matching profile for this controller: "Controller (Xbox 360 Wireless Receiver for Windows)" 22:19:10:221 | MD | DEBUG2 | +32 | GetProfile - Searching for these profiles (| delimited): E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI|E:\Rocketlauncher\Profiles\xpadder\_Default\blank 22:19:10:221 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\Controller (Xbox 360 Wireless Receiver for Windows)\p1.xpadderprofile 22:19:10:221 | MD | DEBUG2 | +0 | GetProfile - Searching for a Player 1 profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile 22:19:10:221 | MD | INFO | +0 | GetProfile - Loading Player 1 Profile -> E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile 22:19:10:221 | MD | INFO | +0 | RunXpadder - Started 22:19:10:221 | MD | INFO | +0 | Process - Exist JoyToKey.exe 22:19:10:252 | MD | DEBUG2 | +31 | RunXpadder - Closing xpadder to refresh controllers seen by xpadder 22:19:10:252 | MD | INFO | +0 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe /C 22:19:10:299 | MD | DEBUG1 | +47 | Run - "Xpadder.exe /C" Process ID: 1008 22:19:10:330 | MD | DEBUG2 | +31 | RunXpadder - Creating an array of connected controllers and profiles to arrange according to the order found in E:\Hyperspin\Utilities\Xpadder\xpadder.ini 22:19:10:362 | MD | INFO | +31 | Process - WaitClose Xpadder.exe 2 22:19:10:580 | MD | DEBUG2 | +218 | RunXpadder - Reading the order in E:\Hyperspin\Utilities\Xpadder\xpadder.ini and arranging profiles found to match that order 22:19:10:580 | MD | DEBUG2 | +0 | RunXpadder - No more controllers to be found 22:19:10:611 | MD | INFO | +32 | Run - Running: E:\Hyperspin\Utilities\Xpadder\Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M 22:19:10:642 | MD | DEBUG1 | +31 | Run - "Xpadder.exe "E:\Rocketlauncher\Profiles\xpadder\RocketLauncherUI\p1.xpadderprofile" /M" Process ID: 3032 22:19:10:642 | MD | INFO | +0 | RunXpadder - Ended 22:19:10:642 | MD | INFO | +0 | RunKeymapper - Ended 22:19:10:642 | MD | INFO | +0 | RunAHKKeymapper - Started 22:19:10:642 | MD | DEBUG1 | +0 | RunAHKKeymapper - Unloading AhkLauncher 22:19:10:642 | MD | DEBUG1 | +0 | RunAHKKeymapper - If AhkLauncher.exe is running, need to close it first before a new profile can be loaded 22:19:10:642 | MD | INFO | +0 | Process - Exist AhkLauncher.exe 22:19:10:674 | MD | INFO | +31 | RunAHKKeymapper - Ended 22:19:10:674 | MD | INFO | +0 | Restoring mouse cursor 22:19:10:674 | MD | INFO | +0 | ExitModule - Ended 22:19:10:674 | MD | INFO | +0 | End of Module Logs 22:19:10:798 | RL | INFO | +31356 | Main - Module ended, exiting RocketLauncher normally 22:19:10:798 | RL | INFO | +0 | ExitScript - Started 22:19:10:798 | RL | DEBUG1 | +0 | ExitScript - Checking what application is currently in focus. 22:19:10:814 | RL | DEBUG1 | +15 | ExitScript - Control Panel\Appearance and Personalization\Display\Screen Resolution is currently active. Putting focus back on HyperSpin.exe 22:19:16:274 | RL | ERROR | +5460 | ExitScript - Timed out trying to put HyperSpin.exe back in focus. 22:19:16:274 | RL | INFO | +0 | SystemCursor - Restoring mouse cursor 22:19:16:305 | RL | INFO | +32 | ExitScript - Ended
Metalzoic Posted October 20, 2015 Posted October 20, 2015 It looks like you don't have your FadeTitle set in the module settings. Not sure if that's your problem, but I'd start there since so many games don't load/close right without it. Also it looks like you had the PC control panel opened in the background and it timed out trying to get HS back into focus. Your problem might simply be trying to run it without first closing your other windows. Just a couple ideas.
demonseed Posted October 20, 2015 Author Posted October 20, 2015 For some reason when I used mugen module games would not exit. I tried setting Mugabe games up as a pc game and they exit fine...the issue is sometimes they load in background ? I just tested it now and it is all working? I don't understand why it would suddenly stop? Maybe I should try mugen module again? Can someone explain the fade title?
Metalzoic Posted October 20, 2015 Posted October 20, 2015 On 10/20/2015 at 1:58 PM, demonseed said: I just tested it now and it is all working? I don't understand why it would suddenly stop? Maybe I should try mugen module again? Can someone explain the fade title? No idea, maybe it was caused by having something open in the background like I mentioned? FadeTitle gives an explanation right by the option. Just put your cursor over the ?. I believe it's explained in the module notes/instructions as well.
demonseed Posted October 20, 2015 Author Posted October 20, 2015 Hey Ok so I redid the mugen model and still has issues exiting the games..... no matter what setting. The games load but then gives some error. See video.,. https://www.youtube.com/watch?v=D4dcgJXUlaI I am not understanding it.. I followed it and pointed it to my EXE.
32assassin Posted October 20, 2015 Posted October 20, 2015 correct me if I'm wrong but, the exit key does not work with Mugen. you have to exit the game by using the exit menu in the game. that's what I do when I play a game in Mugen.
demonseed Posted October 20, 2015 Author Posted October 20, 2015 I tried using another key other than esc and it does the same thing. Can someone confirm if the exit key wont work?
demonseed Posted October 20, 2015 Author Posted October 20, 2015 I did try the resolution change that's how I got it to open sometimes setup thru pc launcher method... But it's finicky as heck
gigapig Posted October 20, 2015 Posted October 20, 2015 I just watched my own Mugen set up video from a few years ago and I told myself to use the in game menu to exit. Apparently tis the only way.
ninja2bceen Posted October 20, 2015 Posted October 20, 2015 Yes I also have to exit via in game Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Metalzoic Posted October 21, 2015 Posted October 21, 2015 So basically it's just like PC games then. You use the in-game exit to exit.
demonseed Posted October 21, 2015 Author Posted October 21, 2015 So the exit works via the emulator. But through the mugen module I still can not get it to load a game full screen in HS. It always loads it minimized. I tired changing settings in mugen to WINDOW and it works. but If I go full screen or stretch it does not. Any suggestions? I have tried hiding front end on load but that did not work. Is it something in the module itself? I noticed this line about minimizing mugen? I am not a coder so not sure. FadeInExit() If (exitHack = 1) ; Sometimes mugen crashes during exit and doesn't close, so we need to do a workaround to detect it, this doesn't seem to happen on MUGEN 1.0{ If (gameTitle != frontendWinTitle) ; If the user exited mugen in under 1500ms then we don't need to do this otherwise the script would hang IfWinExist, %gameTitle% Loop { Sleep, 1000 WinGet, gameState, MinMax, %gameTitle% If ( gameState != 1 ) ; Mugen window minimized or closed Break }
demonseed Posted October 21, 2015 Author Posted October 21, 2015 Hmmm I have no idea why it does not load full screen and does not get focus. Is there a windows setting?
ninja2bceen Posted October 21, 2015 Posted October 21, 2015 Can u use hide emulator in rl? Tapatalk signature Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
demonseed Posted October 22, 2015 Author Posted October 22, 2015 So I changed the setting hide emulator which seems to work... Also some games i had to re point exe to proper game directory... Seems to work well now. You do have to use in game exit too if you don't it causes issues. Also when I started I re did everything from scratch ... Final testing tonite.
demonseed Posted October 23, 2015 Author Posted October 23, 2015 Well I went through every game and it all seems to work! I did have two minor issues with biohazard demo and a dragon ball vs street fighter as they would not go full screen.. All others are working. I want to thank everyone for helping!
