Creezz67 Posted December 11, 2015 Posted December 11, 2015 Hi, I have all system name wheels showing e.g. AAE, NINTENDO WII etc when loading Fade in loading screen in Rocket Launcher, but in Hyperspin they are not showing up in the top left hand corner. Any ideas ? Thanks in advance
Creezz67 Posted December 11, 2015 Author Posted December 11, 2015 Its the loading screen for a particular system. Usually the systems wheelart shows on the top left hand side while loading screen is in progress (unzipping) but they have all disappeared. Now just blank (EXAMPLE BELOW (Nintendo Entertainment SYSTEM image and all other system images that should show in top left corner are missing on my setup) though its set to image on Rocketlauncher. It worked before but since I moved Hyperspin and rocketlauncher to different drive it not showing now Thanks
Styphelus Posted December 11, 2015 Posted December 11, 2015 There's a folder in Rocketluncher that has the system wheels. It does not read the system wheels from hyperspin. I'm at work right now so I can't tell you exactly which folder it is. If you don't have a system wheel for that particular is not there, it won't show.
Creezz67 Posted December 11, 2015 Author Posted December 11, 2015 Thanks for info, I have this folder with all the wheels, but for some reason it just is not pointing to them to show it As I say it was working until i moved system to different hard drive. All paths should still be the same thats why i dont understand. If I launch from Rocketlauncher system wheel shows in left corner like it should, but when i launch through Hyperspin there is nothing.
SeanDyer87 Posted December 11, 2015 Posted December 11, 2015 Thanks for info, I have this folder with all the wheels, but for some reason it just is not pointing to them to show it As I say it was working until i moved system to different hard drive. All paths should still be the same thats why i dont understand. If I launch from Rocketlauncher system wheel shows in left corner like it should, but when i launch through Hyperspin there is nothing. i believe rocketlauncher changed its location it looks for in a recent update i believe to fix your issue you have to rename the "Wheels" folder in the rocketlancher media folder to "Logos" hopefully that fixes your issue mate
Creezz67 Posted December 11, 2015 Author Posted December 11, 2015 At last Thanks mate, much appreciated, that worked perfectly. I should have mentioned I also did an update yesterday which i completely forgot about till i seen you mention it. Thanks again, that was doing my head in.
SeanDyer87 Posted December 11, 2015 Posted December 11, 2015 At last Thanks mate, much appreciated, that worked perfectly. I should have mentioned I also did an update yesterday which i completely forgot about till i seen you mention it. Thanks again, that was doing my head in. your welcome mate glad i could help out
Metalzoic Posted December 11, 2015 Posted December 11, 2015 Yup, that is why you should always read the thread on their forum for what the new updates change. Changing that folder name was highlight in it. You had me confuses though, the way you worded your question it was as if the logo was supposed to be in HS itself in the corner. Agree on both points. Always check the update notes first thing. I also didn't know what he meant since he said the trouble was in HS when it was actually in RL.
NewYears1978 Posted January 11, 2016 Posted January 11, 2016 Sorry to semi necro this, but did I installed just recently and I installed update 1.4 and all by default..but my fades do not work. I had to change Wheel to Logos like mentioned above, but nothing else works either, fade text is not shown, Genre, rating images are not shown..did they change ALL of these folder names??? (Mind you I instlaled RL directly..not upgraded from HL) Are you an HTPC user? Do you like Kodi/XBMC?If so, check out these Kodi Style Themes!-----------------------------------------------------------------------------------------------------Aeon Nox 13 by @dark13Aeon MQ6 by @NewYears1978 >> Click here to see Current Progress-----------------------------------------------------------------------------------------------------If you're new and going for your first install, I HIGHLY recommend Simply Austin's Tutorials.
bcterp Posted March 11, 2016 Posted March 11, 2016 Sorry to semi necro this, but did I installed just recently and I installed update 1.4 and all by default..but my fades do not work. I had to change Wheel to Logos like mentioned above, but nothing else works either, fade text is not shown, Genre, rating images are not shown..did they change ALL of these folder names??? (Mind you I instlaled RL directly..not upgraded from HL) Same issue here. Fade shows everything when launching a game from within rocket launcher. When launching from hyperspin the genre and system images are missing as is the game name and year text.
