jhabers Posted May 18, 2017 Share Posted May 18, 2017 4 minutes ago, wesfranks said: Will the disregard/removal of metadata in parenthesis also be applied to say, the MAME system category? Rather than building an xml based on the roms present in the MAME roms folder, I think many of us keep full romsets to make updating/seeding easier. We then pare down the xml, using the metadata in that xml to identify and exclude/include certain roms to be available to HyperSpin, rather than 20 or 30,000 games. It also helps to see the naming info in parenthesis when you prefer say a Midway version of the game vs Taito, etc, while spinning through the wheel. For console or disc sets, the region info gives hints to where to hunt for certain games (ex., PAL or Asian sets). This is also true (as previously stated) with translated games. I do not hunt for a translation to apply to a rom unless I see that there is one available as listed in the xml. Unless there is something I am not understanding (very possible), I for one would prefer the info in parenthesis remains in the xml. Good points. Fr0stbyt3 we are going to need an option to keep bracketed data Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 should I be mentioning problems with media? I'm noticing some extra spaces in some of the themes for snes just extra spaces before the extensionNoted, I'll get those taken care of tomorrowSent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
wesfranks Posted May 18, 2017 Share Posted May 18, 2017 Crap. I was hoping this was something I didn't understand, as usual. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 Good points. Fr0stbyt3 we are going to need an option to keep bracketed data I can just save the original file name as a property. When I export I'll use the file name. However, in our master database, we're going to drop it in favor of proper metadata. We need a more reliable way to express what each region actually is. Right now it's a little haphazard. For instance, a ROM can have multiple regions. Those regions can be the same for two different games but in a different order. Some are abbreviated. Some aren't. This makes matching and adding metadata much more difficult. Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 Also, down the road, the collections tab should give you what you need to create custom XML files (Including genres and favorites).So I could give you an option to see the full file name there. You can set up your xml file in the UI. Then I can export with or without the extra parenthesis. All without 'losing' your information.Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
KlopjerO Posted May 18, 2017 Share Posted May 18, 2017 Praise the sun! Link to comment Share on other sites More sharing options...
shitoken Posted May 18, 2017 Share Posted May 18, 2017 Keep testing bros, rock it , hey try not to be too complicated. Link to comment Share on other sites More sharing options...
thatman84 Posted May 18, 2017 Share Posted May 18, 2017 This may be a big task but i notice on scanning my mame version romset of Atari 5200 i got no matches. Would it be possible to add software list naming to the DB? For Android reasons and for ease of access to some romsets I have held off adding many systems i can run through mame to avoid renaming everything. Low priority as doubt many people do the same Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 This may be a big task but i notice on scanning my mame version romset of Atari 5200 i got no matches. Would it be possible to add software list naming to the DB? For Android reasons and for ease of access to some romsets I have held off adding many systems i can run through mame to avoid renaming everything. Low priority as doubt many people do the sameI haven't had any coffee yet, so I may just be out of it; but what are you saying here?Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 For all those who are worried about the original file name and parenthesis, here is how I will be handling it for now. I'll create a toggle where users can say they want all media to export as the file name rather than the game name. This should clear up any issues. Moving forward, we're going to come up with a better solution for housing this data. Link to comment Share on other sites More sharing options...
Avar Posted May 18, 2017 Share Posted May 18, 2017 2 hours ago, thatman84 said: This may be a big task but i notice on scanning my mame version romset of Atari 5200 i got no matches. Would it be possible to add software list naming to the DB? For Android reasons and for ease of access to some romsets I have held off adding many systems i can run through mame to avoid renaming everything. Low priority as doubt many people do the same Could also ClrMamePro it to the proper names. I've been in the arctic for a few years so haven't had the data available to do a full mame update in a while but if it's using the same garbage minimalist nomenclature as MAME you should be able to use the provided DATs to fix it locally. Likely much faster/easier. Also, unless the Software List went a different rom format direction, your normal Atari 5200 roms oughta work. Link to comment Share on other sites More sharing options...
wallmachine Posted May 18, 2017 Share Posted May 18, 2017 1 hour ago, fr0stbyt3 said: For all those who are worried about the original file name and parenthesis, here is how I will be handling it for now. I'll create a toggle where users can say they want all media to export as the file name rather than the game name. This should clear up any issues. Moving forward, we're going to come up with a better solution for housing this data. Just curious you aren't manually entering everything are you? Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 Depends on what you mean by that. The server database or the local database? Link to comment Share on other sites More sharing options...
wallmachine Posted May 18, 2017 Share Posted May 18, 2017 Just now, fr0stbyt3 said: Depends on what you mean by that. The server database or the local database? local database. Are you pulling this information from dats? Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 So some of the data is from the server side database. Some of the data is calculated from the file system. Some of it is a direct read of information in the file system. The above is a picture of my local application database. Link to comment Share on other sites More sharing options...
thatman84 Posted May 18, 2017 Share Posted May 18, 2017 8 hours ago, fr0stbyt3 said: I haven't had any coffee yet, so I may just be out of it; but what are you saying Your gonna need more than coffee to understand my rambles! 7 hours ago, Avar said: Could also ClrMamePro it to the proper names. I've been in the arctic for a few years so haven't had the data available to do a full mame update in a while but if it's using the same garbage minimalist nomenclature as MAME you should be able to use the provided DATs to fix it locally. Likely much faster/easier. Also, unless the Software List went a different rom format direction, your normal Atari 5200 roms oughta work. Not really sure what you mean about the fixes, clrmamepro is lost on my little brain . Android mame can only use software list roms by default unless you use a text file to point all the normal cmd line switches at it ( which i dot think many people can get working bar me ) What im geting at is this for A5200 as an easy example applied to the tens of other software list romsets. My xml lists beamridr and my mame rom is beamridr.zip for the game Beamrider (USA) Will HBL be able to match beamridr to Beamrider and download the media named as beamridr. You have to forgive me as im a little slow! When something clicks im all over it but HBL has not clicked with me yet which is totally fine as its not finished yet. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 18, 2017 Author Share Posted May 18, 2017 Not really sure what you mean about the fixes, clrmamepro is lost on my little brain [emoji4]. Android mame can only use software list roms by default unless you use a text file to point all the normal cmd line switches at it ( which i dot think many people can get working bar me [emoji20] ) What im geting at is this for A5200 as an easy example applied to the tens of other software list romsets. My xml lists beamridr and my mame rom is beamridr.zip for the game Beamrider (USA) Will HBL be able to match beamridr to Beamrider and download the media named as beamridr. You have to forgive me as im a little slow! When something clicks im all over it but HBL has not clicked with me yet which is totally fine as its not finished yet. The short answer is not yet. The longer answer is the database supports alternate names. So a ROM could have an alt name that is the silly mame name. I really want to know why people would mangle the names like that...So, down the road, yes I'll support that.Sent from my SM-G955U using Tapatalk Link to comment Share on other sites More sharing options...
thatman84 Posted May 18, 2017 Share Posted May 18, 2017 perfect I really have no clue why they do it but they do a fantastic job. Link to comment Share on other sites More sharing options...
Avar Posted May 18, 2017 Share Posted May 18, 2017 @thatman84 I do believe so! The singularity is upon us. Link to comment Share on other sites More sharing options...
KlopjerO Posted May 19, 2017 Share Posted May 19, 2017 Noobish question... am I supposed to download the 0.42 version and have it update to 53 ? Link to comment Share on other sites More sharing options...
Avar Posted May 19, 2017 Share Posted May 19, 2017 @KlopjerO AFAIK it will always update to the latest version automatically regardless and I believe the only download link's the one on the OP. Link to comment Share on other sites More sharing options...
JoeC3109 Posted May 19, 2017 Share Posted May 19, 2017 Hey guys, great continued work on this. General question, to help me understand how this will work moving forward. I just set up SNES, and it changed the names of each wheel art for each game to remove the region (which makes sense, as was mentioned earlier). However, now none of my wheel art is showing up in HS, presumably because the database name is different than the newly named files - ie database still has regions. How is this going to work in the future? The idea is that databases themselves will be phased out? I'm just wondering how I should maintain the naming for my files in the interim, because now my SNES wheel looks a little bare. Thanks again for all you guys have been doing. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 19, 2017 Author Share Posted May 19, 2017 5 minutes ago, JoeC3109 said: Hey guys, great continued work on this. General question, to help me understand how this will work moving forward. I just set up SNES, and it changed the names of each wheel art for each game to remove the region (which makes sense, as was mentioned earlier). However, now none of my wheel art is showing up in HS, presumably because the database name is different than the newly named files - ie database still has regions. How is this going to work in the future? The idea is that databases themselves will be phased out? I'm just wondering how I should maintain the naming for my files in the interim, because now my SNES wheel looks a little bare. Thanks again for all you guys have been doing. Back up your databases first. Then go to General Settings > Database > Enable 'XML Database Export'. Then delete and re-add SNES. Magic will happen. Link to comment Share on other sites More sharing options...
fr0stbyt3 Posted May 19, 2017 Author Share Posted May 19, 2017 @Avar Feel free to take over the op and do whatever you want for updates. the link is exactly the same every time. I upload and installer and an update file for every build. You just need to change the number in the link. Also you should not use the installer every time . Doing so can delete your configuration database for HBL. Causing you to have to start over. Link to comment Share on other sites More sharing options...
elements604 Posted May 19, 2017 Share Posted May 19, 2017 Hi sorry if this has been asked before. I just want to know before testing if there is media currently on hyperbase that is not available on the FTP server as I have most stuff on the ftp. Link to comment Share on other sites More sharing options...
