Fyrecrypts Posted June 7, 2010 Author Posted June 7, 2010 Well for me...Though I now have a playable (minus hi scores) via hyperspin. I seriously doubt i wiill be using it much without getting hiscores to show up. Since they do when running stuff direct, Im likley to dump hyperspin even with the success of getting stuff setup. And no, I wont bother with the external option, I only care about the games itself doing save state or simlar... as they already do when run direct. THis is a hyperspin issue so I will be looking for another alternative to hyperspin. Bummer Hyperspin is the coolest one, and in fact is the only one I would pay retail $$ for and more... My alternative to hyperspin will be a dos run menu that I dont particular like but its mine based on rubyonrails and webbased so time will tell. Two things for you. HiToText does not support save states (yet), so you kinda have the wrong thread for that. Secondly, I see you've plastered your question in multiple locations and in doing so repeatedly bash this FE for not working correctly with what you want as opposed to asking in the appropriate location for help setting HyperSpin up. Numerous people have HyperSpin with Hyperlaunch working correctly with MAME and save states. The HyperSpin community is very helpful, so long as you're nice about it. Good luck! Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
killars Posted June 7, 2010 Posted June 7, 2010 The HyperSpin community is very helpful, so long as you're nice about it. Good luck! For anyone experiencing problems who can`t be bothered to recompile or are unsure what they are doing and just want to `play it safe` just do a search for mameuifx and a search for hiscore.dat and voila! (this is confirmed working within hyperspin with highscore support). Compiling your own though really is the best way to do it. Im seeing multiple threads concerning highscore support etc and fyrecrypts is perfectly right, we all will help when we can. Just because you havent received a quick or immediate response it does`nt mean your being ignored. In a majority of cases peoples questions are answered within minutes - the key = patience.
Tulsaboyw Posted June 7, 2010 Posted June 7, 2010 True enough, appologies to all for that.. .I was in a bit of mood and it was uncalled for in a lot of the 'bashing' except for the the fact that the hiscore which works outside HS but doesnt work via Hs when HS is just a FE. In that I consider the bashing valid... but the scope and multiple posts is definately uncalled for.
killars Posted June 7, 2010 Posted June 7, 2010 earlier i installed multiple versions of mame testing the `hiscore` problem. I found that without compiling my own then using any of the UI versions (such as Mameui32 etc) i ran into no highscore saving. I did however find Mameuifx32 which when coupled with a hiscore.dat in the mame folder worked fine inside of hyperspin. I had been looking into your problem for you Personally i`d take an alternative mame to an alternative Hyperspin ANYDAY. Sorry to interrupt your thread Fyrecrypts.
Tulsaboyw Posted June 8, 2010 Posted June 8, 2010 Thnanks killars your help has been stellar amongst it all. I dont see why in my case mame need be compiled when all the mames I have do hiscore just fine (its only via HS that it doesnt, unless i hit f7,alt-f7 to load em). Agreed, as noted before I guess I had a bit of a fit and got carried away. but will check into uifx also. makes sense on alternatives, i guess it depends on approach.
Fyrecrypts Posted June 8, 2010 Author Posted June 8, 2010 Sorry to interrupt your thread Fyrecrypts. No worries, I only brought it up because he was less likely to get help in this thread than elsewhere. Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
DynamiteSJ Posted June 8, 2010 Posted June 8, 2010 mame compiler 64... http://headsoft.com.au/index.php?category=mame&page=mc64 Easiest way to compile your own build with highscore support
Tulsaboyw Posted June 9, 2010 Posted June 9, 2010 not needed, there were other mame's (unofficial or not) that had hiscore built in but where not necessarily HS doable without the usual stuff on configs. no matter using something else anyway now. Thanks all anyway for the help. Maybe one day, back to HS, its still the best visual out there though with a bit too much on some of the cool stuff though fortunately most of that is editable anyway.
Fyrecrypts Posted August 9, 2010 Author Posted August 9, 2010 Made an update (finally, I know). With about 15 new games' support added, big thanks to bLAZER for 10 of them (and 2 ports from the old format to the XML format). Additionally, some minor bug fixes, and some additions/fixes to the hiscore.dat. ------------------- Version 2010.8.9 ------------------- New Games: Alien3: The Gun, Aliens, Alien Sector, The Alphax Z, Alpine Ski, Soldier Girl Amazon (Fyrecrypts) Bio Attack, Dommy, M-79 Ambush, Monte Carlo, Qwak, King & Balloon, Mermaid, The End, Snow Bros. 2 - With New Elves / Otenki Paradise (bLAZER) Bug Fixes: Fixed duplication of special mapping in Argus. hiscore.dat modified to have m660 clones of alphaxz hiscore.dat modified to fix amazon. Issue with relative path to file not working correctly. It is now. New features: Clone added to alphaxz (m660j). Long name clones added to altbeast. Clone changes and additions to invaders. Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
Firebat138 Posted August 9, 2010 Posted August 9, 2010 Nice... never used this, but I assume you need this to make the Hi score work in HS. Where do I get this great little app and is there a tutorial to make it work... thanx Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0 Click below to see my PinCab - PinWARS http://forum.arcadecontrols.com/index.php/topic,164660.0.html Wouldn't you prefer a nice game of chess?
Fyrecrypts Posted August 9, 2010 Author Posted August 9, 2010 The first post should have all you need to get started. Nice... never used this, but I assume you need this to make the Hi score work in HS. Where do I get this great little app and is there a tutorial to make it work... thanx Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
bLAZER Posted August 9, 2010 Posted August 9, 2010 Nice... never used this, but I assume you need this to make the Hi score work in HS. Where do I get this great little app and is there a tutorial to make it work... thanx No, this is for showing the highscores directly in Hyperspin without loading the game.
Firebat138 Posted August 10, 2010 Posted August 10, 2010 yeah.... that's what i meant... i suck at typing out my thoughts... downloading now... Click below to see my Metal Gear/Splinter Cell Machine... http://forum.arcadecontrols.com/index.php?topic=108360.0 Click below to see my PinCab - PinWARS http://forum.arcadecontrols.com/index.php/topic,164660.0.html Wouldn't you prefer a nice game of chess?
chillinwater Posted August 10, 2010 Posted August 10, 2010 There is a HiToText.xml 2010.08.09 Parents\Clones up on Hyperlist. (for easy testing, shows all HiToText Supported games) You gotta play 'em to display 'em You can use hyperlaunch but dont exit with your Hyperlaunch "exit key" or the highscores wont save and HiToText wont display. Still couldnt get the Parents only text output option to work. So for now if you want to use Parents only, use Romlister. I may post it later today. FireCrypts your link to the source file .zip seems dead. Thanks again for this app! Game\Theme\Favorites\Genre - List Creation * FatMatch File Renaming for HyperNewbies. Like Me! https://hyperspin-fe.com/forums/topic/259-setting-up-un-official-systems-with-hyperspin/?do=findComment&comment=31034
Fyrecrypts Posted August 10, 2010 Author Posted August 10, 2010 Sorry about that, I've fixed the links, some minor FTP issues. =) There is a HiToText.xml 2010.08.09 Parents\Clones up on Hyperlist.(for easy testing, shows all HiToText Supported games) You gotta play 'em to display 'em You can use hyperlaunch but dont exit with your Hyperlaunch "exit key" or the highscores wont save and HiToText wont display. Still couldnt get the Parents only text output option to work. So for now if you want to use Parents only, use Romlister. I may post it later today. FireCrypts your link to the source file .zip seems dead. Thanks again for this app! Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
Fyrecrypts Posted August 16, 2010 Author Posted August 16, 2010 Big-ish update this time around. 21 new games thanks to bLAZER, and massive speed increases which reduce the HyperSpin hang-up, but don't remove it. As I mentioned earlier, without some changes to how HyperSpin access HiToText these hangups will certainly always be there. At the very least it's a "little less" jarring seeing the hi scores pop up with this new version. Additionally, as I can't figure out why chillinwater is having issues with the -lp command, I've put up a file: http://hitotext.com/HiToText/parents.txt that actually lists the parents for him to use for his HyperList lists. ------------------- Version 2010.8.16 ------------------- New Games: Crash, Orbitron, Sheriff, Water Ski, Logic Pro, The Tin Star, Enigma II, Hexa, Gee Bee, Paradise, Indian Battle, Red Clash, Super Bug, Targ, Spectar, Sasuke vs. Commander, Pisces, Killer Comet, Tank Battalion, Levers, Navarone (bLAZER) Bug Fixes: Fixed issue with alien3, rank display was incorrectly read as int instead of a hex int. tinstar2 added to hiscore.dat (clone of tinstar). enigma2a, and enigma2b added to hiscore.dat (clones of enigma2). geebeeb added to hiscore.dat (clone of geebee). targ and spectar split into separate parents. targc added to hiscore.dat (clone of targ). panzer, phantom, phantoma, and rallys added to hiscore.dat (clones of spectar). piscesb added to hiscore.dat (clone of pisces). New features: Massive speed increases for legacy calls using the command line. It's not quite as fast as legacy drivers were, but the difference is only about 10-50 ms. at most which is usually negligible. Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
Fyrecrypts Posted August 24, 2010 Author Posted August 24, 2010 Small update to increase speeds, reduce confusion, and fix a bug with -lp (again). ------------------- Version 2010.8.24 ------------------- Bug Fixes: Fix to -lp command, it actually works in all known circumstances (so far). Fix to version checking of MAME, only used when necessary (so far just Track and Field). Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
chillinwater Posted August 25, 2010 Posted August 25, 2010 Hey Hey -Lp is working. I noticed a signaficant speed increase in the previous version. only a very slight hiccup. (havent tested this one yet). And here is the benefit of -Lp. As usual feed these txt files into Hyperlist to make your databases. Then add these lines to your: \hyperspin\databases\mame\Genre.xml to quickly see which games are popping up with the "High Scores" in HS. You gotta play 'em to display 'em <game name="HiToTxt-Parents v2010.8.24" /> <game name="HiToTxt-Parents-Clones v2010.8.24" /> [HiToTxt-Parents v2010.8.24.txt] 005 10yard 1941 1942 1943 1943kai 1944 19xx 4dwarrio 8ballact actionhw ad2083 afighter agress airattck airbustr airduel airwolf ajax alexkidd alibaba alien3 aliens aliensec aliensyn alpine altbeast amazon amidar animaljr anteater apb aquajack arabfgt argus arkanoid arkarea arknoid2 arkretrn armedf armora armorcar assault astdelux asterix asteroid astyanax athena atlantis atomicp aurail baddudes bagman balonfgt bankp barrier barrier batsugun battlcry berzerk bioatack bjtwin blktiger blockout bloodbro blueprnt bnzabros bombjack boomrang boxingb brkthru brubber btime bublbobl bullfgt bzone cabal captaven carnival cburnrub ccastles cclimber centiped chasehq circusc ckong cleopatr columns columns2 commando contra crash crush crzrally daioh dariusg dazzler ddonpach ddragon ddribble deadeye defender demon digdug digdug2 dino djboy dkong dkong3 dkongjr domino dommy dorunrun dotron dowild dragnblz dynagear elevator enigma2 esprade evilston exerion exprraid extrmatn eyes frogger frogs fshark galaga galaxian gaunt2 gauntlet gberet geebee gigawing gijoe gng gunsmoke gyruss headon headon2 headoni hexa hvysmsh hyperpac hyperspt hyprduel imgfight indianbt invaders jackal jjack jjsquawk journey joust joust2 junglek jungler junofrst kamikcab kangaroo kchamp kickridr killcom kingball klax knights kungfum ladybug levers logicpro lrescue m660 m79amb madalien mappy marble mario matmania megadon mermaid metrocrs mhavoc milliped mimonkey missile mk mk2 montecar mooncrst mpatrol mrdo mrdrillr mrgoemon ms5pcb mslug mslug2 mslug3 mslug4 mslug5 mslugx mspacman msword mtlchamp mwalk narc naughtyb navarone nemesis nitd nmouse nova2001 olibochu omegaf orbitron outzone pacland pacmania pacplus paperboy paradise pbaction pengo phoenix pirates pisces pleiads pooyan popeye puckman pulstar punchout qb3 qbert qbertqub qwak raiden rastan redbaron redclash redufo ripoff roadrunn robocop robotron rpatrol rthunder rtype rtype2 rygar s1945ii sasuke sbagman sci scramble sdtennis seawolf seawolf2 sf2 shadoww sheriff silkworm simpsons slapfigh snowbro2 solarq spdodgeb spectar speedfrk spf2t spnchout sprint1 srumbler starcas starwars steelwkr streakng subroc3d sundance superbug suprmrio swimmer szaxxon tailg tankbatt tapper targ tempest terracre tetris theend timber timeplt tinstar tmnt tmnt2 toki trackfld trackfld troangel tron turfmast twincobr uniwars unsquad upndown vendetta videopin vigilant viofight waterski wb3 wboy woodpeck wotw wrally xmen xmvsf yiear zaxxon zookeep [HiToTxt-Parents-Clones v2010.8.24.txt] 005 10yard 10yardj 1941 1941j 1942 1942a 1942b 1942w 1943 1943j 1943kai 1944 1944d 1944j 19xx 19xxa 19xxb 19xxd 19xxh 19xxj 19xxjr1 4dwarrio 8ballact 8ballact2 8ballat2 8bpm abscam actionhw ad2083 afighter agress agressb airattca airattck airattcka airbusb airbustj airbustr airbustrb airbustrj airduel airwolf airwolfa ajax ajaxj alexkid1 alexkida alexkidd alexkidd1 alibaba alien3 alien3u alieninv aliens aliens2 aliens3 aliensa aliensec aliensj aliensj2 aliensu aliensy1 aliensy2 aliensy3 aliensy5 aliensyn alphaxz alpine alpinea altbeaj1 altbeaj3 altbeas2 altbeas4 altbeas5 altbeasj altbeast altbeast2 altbeast4 altbeast5 altbeastj altbeastj1 altbeastj3 amatelas amazon amidar amidarb amidaro amidars amidaru amigo animaljr anteater anteatg anteatgb apb apb1 apb2 apb3 apb4 apb5 apbf apbg aquajack aquajckj arabfgt arabfgtj arabfgtu area88 argus ark1ball arkangc arkangc2 arkanoid arkarea arkatayt arkatour arkbloc2 arkblock arkgcbl arkmcubl arknid2j arknid2u arknoid2 arknoidj arknoidu arknoiuo arkretrn arktayt2 armedf armora armorap armorar armorca2 armorcar armorcar2 assault assaultj assaultp astdelu1 astdelu2 astdelux astdelux1 astdelux2 asterix asterixj asterock asteroi1 asteroi2 asteroib asteroid astrxeaa astrxeac astyanax athena atlantis atlantis2 atlantol atlantol atlants2 atomicp aurail aurail1 auraila aurailj baby2 baby3 baddudes bagman bagmanmc bagmans bagmans2 bagnard bagnarda balonfgt bankp baraduke barrier barrier batman2 batsugna batsugun battlcry batugnsp berzerk berzerk1 bioatack bjtwin bjtwina bktigrb1 bktigrb2 blktiger blockout blockout2 blockoutj bloodbra bloodbro blueprnj blueprnt bnj bnzabros bnzabrsj boblbobl bombjac2 bombjack boomrana boomrang boomranga boxingb brkthru brkthruj brubber btime btime2 btimem bub68705 bubbobr1 bublbob1 bublbobl bublbobr bullfgt bzone bzone2 bzonec cabal cabala cabalbl cabalus cabalus2 captaven captavna captavne captavnj captavnu captavua captavuu car2 caractn carnival carnvckt caterpil cbnj cburnrb2 cburnrub cburnrub2 ccastle1 ccastle2 ccastle3 ccastlef ccastleg ccastlej ccastlep ccastles ccboot ccboot2 cclimber cclimbrj centipb2 centipd2 centipdd centiped centtime chasehq chasehqj chasehqu chthang chtmsatk chtmspa circusc circusc2 circusc3 circuscc circusce ckong ckonga ckongalc ckongb ckongg ckongjeu ckongo ckongs cleopatr column2j columns columns2 columnsj commandb commandj commando commandu condor contra contrab contraj contrajb cosmicm2 cosmicmo crash crazypac croquis crush crzralla crzrallg crzrally ctrpllrp daioh dariusg dariusgx darthvdr dazzler ddonpach ddragnba ddragnw1 ddragob2 ddragon ddragonb ddragonu ddragonw ddragoua ddribble deadeye defcmnd defence defendb defender defendg defendw defndjeu demon desterth digdug digdug2 digdug2a digdug2o digduga1 digdugat digdugb dino dinoj dinou dizzy djboy djboya djboyj dkngjnrb dkngjnrj dkong dkong3 dkong3b dkong3j dkongf dkongjo dkongjo1 dkongjp dkongjpo dkongjr dkongjre dkongo domino dommy dorunrca dorunruc dorunrun dotron dotrone dowild dragnblz drgninja dynagear dzigzag eagle eagle2 eagle3 earthinv elevatob elevator elevatorb eltonpac enigma2 enigma2a enigma2b esprade espradej espradeo evilston excthour exerion exerionb exeriont explorer exprrada exprraid extrmatj extrmatn extrmatu eyes eyes2 eyeszac falcon falconz fantazia fasthang fasthear fastmspa fastplus faststrm forcebrk frogger froggrmc frogs frogseg1 frogseg2 fshark fsharkbt fstmsatk gaiden galaga galaga84 galagab2 galagads galagamf galagamk galagamw galagao galap1 galap4 galapx galaxb galaxbsf galaxiaj galaxian gallag galmidw galmidwo galtaito galturbo gaunt2 gaunt2p gauntir1 gauntir2 gauntlet gberet gberetb geebee geebeeb geebeeg gigawing gijoe gng gnga gngbl gngblita gngt gradius grescue griffon gryzor gteikoku gunsmoka gunsmoke gunsmoku gunsmrom gwinga gwingb gwingj gwingjd gyruss gyrussce hangly hangly2 hangly2x hangly3 hanglyad hanglyx headon headon2 headonb headoni headons heartbrn hexa hpolym84 hvysmsh hvysmsha hvysmshj hyperpac hyperspt hyprdelj hyprduel hyprolyb hyprolyb hyprolym hyprolym imgfigho imgfight indianbt invader4 invaders invadrmr jackal jackalj jjack jjsquawb jjsquawk journey joust joust2 joustr joustwr joyman juju jujub jungleh junglek jungler junglers junofrst junofstg kamikcab kangaroa kangarob kangaroo karatedo karatevs kchamp kchampvs kickridr killcom kingbalj kingball kkgalax klax klax2 klax3 klaxd klaxj klaxp1 klaxp2 knights knightsj knightsu korosuke ktiger kungfub kungfub2 kungfud kungfum ladybgb2 ladybug ladybugb levers logicpro lordofk lrescue lrescuem m660 m660b m660j m79amb madalien madaliena madalina makaimuc makaimug makaimur maketrax maketrxb mappy mappyj marble marble2 marble3 marble4 marble5 marblea mario marioe marioj mariojp marioo masao matmania mazeman mcombat mcombata megadon mermaid meteorho meteorts metrocra metrocrs mhavoc millipdd milliped mimonkey mimonsco mimonscr missile missile2 mk mk2 mk2chal mk2r14 mk2r21 mk2r32 mk2r42 mk2r91 mkla1 mkla2 mkla3 mkla4 mkprot8 mkprot9 mkr4 mkyawdim mlander monkeyd montecar mooncmw mooncrgx mooncrs2 mooncrs3 mooncrsa mooncrsb mooncrsg mooncrst mooncrsu mpatrol mpatrolw mranger mrdo mrdofix mrdot mrdoy mrdrillr mrdu mrgoemon mrlo mrpacman ms4plus ms5pcb ms5plus msatk2ad msatkad msbaby msbaby1 mschamp msdstorm mselton msf1pac mshangly mshearts msindy mslug mslug2 mslug3 mslug3b6 mslug3h mslug4 mslug5 mslug5h mslugx msmini msminia mspac6m mspacat2 mspacatb mspacatk mspacman mspacmat mspacmbe mspacmnf mspacpls mspacx mspatkx msrumble mssilad msword mswordj mswordr1 mswordu mtlchamp mtlchamp1 mtlchampa mtlchampj mtlchampu mtlchmp1 mtlchmpa mtlchmpj mtlchmpu mwalk mwalkbl mwalkj mwalku myqbert narc narc3 naughtya naughtyb naughtyba naughtybc naughtyc navarone nemesis nemesisuk nemesuk newpuc2 newpuc2b newpuckx newtangl nextfase nitd nkdodge nkdodgeb nmouse nmouseb nov2001u nova2001 nova2001u npacmod olibochu omegaf omegafs orbitron outzone outzonea outzoneb outzonec outzonep pacgal pacland pacland2 pacland3 paclandm pacman pacmanf pacmania pacmanjp pacmanm pacmini pacmini2 pacmod pacplus pacstrm paddle2 panzer paperboy paradise pbactio2 pbactio3 pbaction pengo pengo2 pengo2u pengo3u pengo4 pengob penta pestplce phantom phantoma phoenix phoenix3 phoenixa phoenixb phoenixc phoenixj phoenixt piranha piranhah pirates pisces piscesb pleiadbl pleiadce pleiads pootan pooyan pooyans popeye popeyebl popeyef popeyeu puckman puckmana puckmanf puckmanh puckmod pulstar punchita punchout qb3 qbert qberta qbertjp qbertqub qberttst qwak raiden rallys rastan rastanu rastanu2 rastsaga rbtapper redbaron redclash redclsha redclshk redufo ripoff roadrunn robocop robocopb robocopj robocopu robocopw robocpu0 robotron robotryo rpatrol rpatrolb rpatrolo rthunder rthundro rtype rtype2 rtype2j rtypeb rtypej rtypejp rtypeu rushatck rushcrsh rygar rygar2 rygar3 rygarj ryukenda ryukendn s1945ii sasuke sbagman sbagmans sci scia scij sciu scramb2 scramblb scramble scrambls sdtennis searthia searthin seawolf seawolf2 sf2 sf2a sf2b sf2e sf2j sf2ja sf2jb sf2ua sf2ub sf2ue shadoww shadowwa sheriff sicv silkworm silkwrm2 silvland simps2pa simps2pj simps4pa simpsn2p simpsons sinvasn sinvasnb sinvemag sisv sisv2 sitv skyshark skywolf skywolf2 slapbtjp slapbtuk slapfgtr slapfiga slapfigh smooncrs snowbro2 solarq spacbatt spaceatt spaceftr spaceplt spacewr3 spartanx spcdrag spcdraga spceking spcewars spctbird spdodgeb spectar spectar1 speedfrk spf2t spf2ta spf2xj spf2xjd spnchotj spnchout sprint1 sprmatkd srumbler srumblr2 starcas starcas1 starcase starcasp startrkd starwar1 starwars starwars1 steelwkr stellcas streakng strfbomb subroc3d sundance supcrash superbug superg suprmatk suprmatkd suprmrio sutapper swarm swimmer swimmera swimmerb szaxxon tailg tankbatt tapper tappera targ targc tempest tempest1 tempest2 tempest3 temptube terracra terracrb terracre tetris tetrisaa theend theends thetogyu timber timeplt timeplta timepltc tinstar tinstar2 tmht tmht2p tmnt tmnt2 tmnt2a tmnt2pj tmnt2po tmntj tmntu tmntua toki tokia tokib tokiu topgunbl topgunr tornado1 tornado2 trackflc trackflc trackfld trackfld troangel tron tron2 tron3 tron4 turfmast twincobr twincobu typhoon uniwars unsquad upndown vautour vautourz vendetta vendetta2p vendetta2pd vendetta2pu vendettaj vendettar videopin vigilant vigilntj vigilntu viofighj viofight viofighu vs10yard vs10yarj waterski wb3 wb31 wb34 wb3a wb3b wbdeluxe wboy wboy2 wboy2u wboy3 wboy4 wboy4u wboyo wboyu weststry wexpresb wexpresc wexpress woodpeca woodpeck wotw wotwc wrally wrallya wrallyb xmen xmen2p xmen2pj xmen6p xmen6pu xmenj xmvsf xmvsfa xmvsfar1 xmvsfb xmvsfh xmvsfj xmvsfjr1 xmvsfjr2 xmvsfr1 xmvsfu xmvsfu1d xmvsfur1 yachtmn yankeedo yellowcb yellowcj yiear yiear2 zaxxon zaxxon2 zaxxonb zero zero2 zolamaze zookeep Game\Theme\Favorites\Genre - List Creation * FatMatch File Renaming for HyperNewbies. Like Me! https://hyperspin-fe.com/forums/topic/259-setting-up-un-official-systems-with-hyperspin/?do=findComment&comment=31034
Fyrecrypts Posted September 1, 2010 Author Posted September 1, 2010 Not a big update or anything huge, but I've put HiToText up on Sourceforge: https://sourceforge.net/projects/hitotext/ I figured this might be an easier way to update the project than my current method. In the future, expect updates to be found there instead of linked off of my FTP. Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
Lid Posted October 8, 2010 Posted October 8, 2010 Awesome work I have just got HiToText working and I love it. Now it's time to set some highscores so I can see my name popping up in hyperspin One quick question I know its not quite relating to HiToText but maybe someone can help. I notice that in the list by chillinwater it mentions Bubble Bobble but for some reason whenever I run Bubble Bubble in mame it won't create a .hi file. I know this isn't a HiToText problem as it can't find the .hi file because mame hasn't created it but does anyone else get this problem. It works fine for all of the other games I have tested but I love Bubble Bobble and that was the main reason I wanted Hi score support in HS. I made a post about it here if anyone can help http://www.hyperspin-fe.com/forum/showthread.php?t=9901 Thanks Bubble Bobble Themed Arcade Project - http://bubbob.retro.me.uk/
Dna Disturber Posted October 10, 2010 Posted October 10, 2010 One quick question I know its not quite relating to HiToText but maybe someone can help. I notice that in the list by chillinwater it mentions Bubble Bobble but for some reason whenever I run Bubble Bubble in mame it won't create a .hi file. I know this isn't a HiToText problem as it can't find the .hi file because mame hasn't created it but does anyone else get this problem. It works fine for all of the other games I have tested but I love Bubble Bobble and that was the main reason I wanted Hi score support in HS. I made a post about it here if anyone can help http://www.hyperspin-fe.com/forum/showthread.php?t=9901 Thanks I posted a quick fix for you (see other post)... It's a hiscore.dat issue dna disturber:beer: Author of PINemHi............................ Decipher-dude for the HiToText project.......... http://www.youtube.com/watch?v=HxMx90ARGik HiToText 2010.11.4 Vs. Mame 0.140 ------------------------------------------------------ Percentage of original games in HiToText :8.09 % Percentage of original+clone games in HiToText:10.57 % ------------------------------------------------------
Fyrecrypts Posted October 10, 2010 Author Posted October 10, 2010 I posted a quick fix for you (see other post)... It's a hiscore.dat issuedna disturber:beer: Resolved, at least for end-users. Help us crack more .hi files here: http://forum.arcadecontrols.com/index.php?topic=83614.0 HiToText on Sourceforge: https://sourceforge.net/projects/hitotext/
Lid Posted October 11, 2010 Posted October 11, 2010 Excellent work guys. Thank you for such a quick response. Bubble Bobble Themed Arcade Project - http://bubbob.retro.me.uk/
snatex Posted November 23, 2010 Posted November 23, 2010 I was hoping someone could help me out with Hitotext. This is what I have done: 1 - Compiled MAME 0.140u1 with latest hiscore diff 2 - Downloaded latest hitotext w xml and put in hyperspin folder with hyperspin.exe 3 - Downloaded latest hiscore.dat and put in MAME folder with MAME.exe 4 - Edited Hyperlaunch MAME portion with Autohotkey to remove "Hotkey, %exitEmulatorKey%, CloseProcess" then recompiled. 5 - Made sure that hyperpin's setting.ini had HiScore section, Active = true After editing hyperlaunch I am now getting .hi files to generate but when I achieve an actual hiscore it is crashing MAME. I played Donkey Kong and got a hiscore. When I exited I got a crash error box from MAME. Next time I tried to play Donkey Kong it was all messed up and DK was invisible, etc. So I deleted the .hi file and played again. It was now fine but when I got another hiscore and tried to exit it crashed again. Can you help me get this setup properly? Thanks.
snatex Posted November 24, 2010 Posted November 24, 2010 I've now tested this without hyperspin and it works fine. I tried exiting with and without hyperlaunch but every time it crashes when writing a high score. Any ideas?
