drewjbx1 Posted October 6, 2015 Posted October 6, 2015 I am stumped... I can launch hayate, time gal, and time traveler just fine from my american laser games wheel which uses the singe emulator as default with batch files.... (along with all the gun games) I added timegal, hayate, and time traveler to my daphne wheel.. they just fit better there, then I set them up in rocketlauncher to launch with alternative emulator (american laser system and daphne singe emulator) but when I try to launch from the daphne wheel i get bad command line error. Dont see why this is as I am pointing to launch the game from the american laser game wheel and singe emulator. When i go back into AML wheel it launches fine from there. Am I missing something?
rfancella Posted October 6, 2015 Author Posted October 6, 2015 Hi Drew, Hard to tell. Please post your RocketLauncher log with the Logging Level set to Troubleshooting. Thanks, Ron I am stumped... I can launch hayate, time gal, and time traveler just fine from my american laser games wheel which uses the singe emulator as default with batch files.... (along with all the gun games) I added timegal, hayate, and time traveler to my daphne wheel.. they just fit better there, then I set them up in rocketlauncher to launch with alternative emulator (american laser system and daphne singe emulator) but when I try to launch from the daphne wheel i get bad command line error. Dont see why this is as I am pointing to launch the game from the american laser game wheel and singe emulator. When i go back into AML wheel it launches fine from there. Am I missing something? Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
drewjbx1 Posted October 6, 2015 Posted October 6, 2015 Ok problem solved. A post by 32assissin in another AML thread worked, thanks! I just chose PCLauncher to run the 3 games as well as added the batch files paths to PClauncher.ini. Works great now
gooch Posted October 9, 2015 Posted October 9, 2015 I can't launch WoW Action Max, it crashes with the log below complaining about fonts. I went through all the Singe directories and installed every .TTF I could find, but it still complains. Has anyone seen this before? American Laser Games works great. Thanks for the write up Ron! --DAPHNE version 1.0.10 --Command line is: C:\Arcade\Emulators\Daphne Singe 1.14\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile C:\Arcade\Emulators\Daphne Singe 1.14\singe/ActionMax/frame_38AmbushAlley.txt -script C:\Arcade\Emulators\Daphne Singe 1.14\singe/ActionMax/38AmbushAlley.singe --CPU : GenuineIntel 3550 MHz || Mem : 4096 megs --OS : Windows XP/.NET || Video : NVIDIA GeForce GT 635 --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting screen width to 800 Setting screen height to 600 Set 1920x1080 at 32 bpp with flags: 20 Initializing sound system ... Joystick #0 was successfully opened Framefile parse succeeded. Video/Audio directory is: C:/Arcade/Emulators/Daphne Singe 1.14/singe/ActionMax/./ YUV overlay is done in software (ie unaccelerated). Booting ROM ... Starting Singe version 1.14 Search to 1 received [blocking] SINGE: Unable to load font. SINGE: Unable to load font. SINGE: Unable to load font. SINGE: Unable to load font. SINGE: Unable to load font.
rfancella Posted October 9, 2015 Author Posted October 9, 2015 Hi gooch! Those are not system fonts. They should be in your game directory and are being called by the emulator. Be sure these module settings for WoW Action Max are set to false: SingePathUpdate & ForcePathUpdate (Unless your using the bat files to launch the game) Also, your ActionMax directory should have all these files: Volume in drive G is Games Volume Serial Number is F0F3-FC54 Directory of G:\Emulators\Daphne Singe\singe\ActionMax 10/09/2015 05:55 PM <DIR> . 10/09/2015 05:55 PM <DIR> .. 02/10/2015 10:44 AM 307 38AmbushAlley.singe 01/01/2007 04:12 PM 92 38AmbushAlley.txt 12/16/2014 04:36 PM 303 BlueThunder.singe 01/01/2007 04:12 PM 90 BlueThunder.txt 03/19/2015 05:55 PM 14,151 Emulator.singe 07/07/2000 11:09 AM 66,788 font_BlueStone.ttf 04/03/2002 11:29 AM 33,324 font_chemrea.ttf 05/14/1998 06:55 PM 4,708 font_LED_Real.ttf 01/01/2007 04:12 PM 92 frame_38AmbushAlley.txt 01/01/2007 04:12 PM 90 frame_BlueThunder.txt 01/01/2007 04:12 PM 91 frame_Hydrosub2021.txt 01/01/2007 04:12 PM 90 frame_PopsGhostly.txt 12/31/2006 08:54 PM 88 frame_SonicFury.txt 01/01/2007 04:02 PM 296 Hydrosub2021.singe 01/01/2007 04:12 PM 91 Hydrosub2021.txt 01/01/2007 03:56 PM 295 PopsGhostly.singe 01/01/2007 04:12 PM 90 PopsGhostly.txt 06/06/2007 11:55 AM 1,288 README.wpd 01/01/2007 03:39 PM 293 SonicFury.singe 12/31/2006 08:54 PM 88 SonicFury.txt 08/16/2014 05:41 PM 141,424 sound_ActionMax.wav 08/16/2014 05:41 PM 401,484 sound_ASteadyAimIsCritical.wav 12/15/2006 12:31 PM 71,384 sound_BadHit.wav 01/01/2007 07:32 PM 375,280 sound_GameOver.wav 08/16/2014 05:42 PM 263,348 sound_GetReadyForAction.wav 12/15/2006 12:30 PM 40,280 sound_GoodHit.wav 12/15/2006 12:26 PM 190,400 sound_Gunshot.wav 12/23/2006 10:27 PM 12,030 sprite_38AmbushAlley.png 11/09/2006 10:29 AM 1,573 sprite_ActionMax.png 12/23/2006 10:32 PM 21,665 sprite_BlueThunder.png 12/26/2006 10:25 AM 928 sprite_Bullet.png 11/06/2006 09:32 PM 2,942 sprite_Crosshair.png 12/23/2006 10:34 PM 19,488 sprite_Hydrosub2021.png 12/08/2006 03:25 PM 13,745 sprite_LightOff.png 12/08/2006 03:26 PM 15,881 sprite_LightOn.png 12/23/2006 10:31 PM 17,181 sprite_PopsGhostly.png 12/23/2006 10:29 PM 16,134 sprite_SonicFury.png 09/25/2013 11:27 AM 111,292 video_38AmbushAlley.dat 08/16/2014 12:56 PM 733,184,761 video_38AmbushAlley.m2v 09/25/2013 11:15 AM 9,467,184 video_38AmbushAlley.ogg 09/25/2013 11:27 AM 1,432 video_ActionMaxIntro.dat 08/16/2014 12:56 PM 12,781,051 video_ActionMaxIntro.m2v 09/25/2013 09:27 AM 141,514 video_ActionMaxIntro.ogg 09/25/2013 03:42 PM 110,392 video_BlueThunder.dat 08/16/2014 12:57 PM 733,080,602 video_BlueThunder.m2v 09/25/2013 03:24 PM 12,288,195 video_BlueThunder.ogg 09/25/2013 04:20 PM 113,872 video_Hydrosub2021.dat 08/16/2014 12:57 PM 732,798,526 video_Hydrosub2021.m2v 09/25/2013 04:12 PM 9,704,476 video_Hydrosub2021.ogg 09/25/2013 11:27 AM 404 video_Menu.dat 09/25/2013 09:36 AM 800,953 video_Menu.m2v 12/26/2006 09:30 PM 0 video_Menu.ogg 09/25/2013 04:45 PM 125,932 video_PopsGhostly.dat 08/16/2014 12:57 PM 732,802,686 video_PopsGhostly.m2v 09/25/2013 04:10 PM 10,815,788 video_PopsGhostly.ogg 09/25/2013 04:53 PM 105,172 video_SonicFury.dat 08/16/2014 12:57 PM 732,805,551 video_SonicFury.m2v 09/25/2013 04:08 PM 8,929,163 video_SonicFury.ogg 59 File(s) 3,731,896,768 bytes 2 Dir(s) 2,915,573,760 bytes free Thanks, Ron I can't launch WoW Action Max, it crashes with the log below complaining about fonts. I went through all the Singe directories and installed every .TTF I could find, but it still complains. Has anyone seen this before? American Laser Games works great. Thanks for the write up Ron! --DAPHNE version 1.0.10 --Command line is: C:\Arcade\Emulators\Daphne Singe 1.14\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile C:\Arcade\Emulators\Daphne Singe 1.14\singe/ActionMax/frame_38AmbushAlley.txt -script C:\Arcade\Emulators\Daphne Singe 1.14\singe/ActionMax/38AmbushAlley.singe --CPU : GenuineIntel 3550 MHz || Mem : 4096 megs --OS : Windows XP/.NET || Video : NVIDIA GeForce GT 635 --OpenGL: Compiled In --RGB2YUV Function: MMX --Line Blending Function: MMX --Audio Mixing Function: MMX Setting screen width to 800 Setting screen height to 600 Set 1920x1080 at 32 bpp with flags: 20 Initializing sound system ... Joystick #0 was successfully opened Framefile parse succeeded. Video/Audio directory is: C:/Arcade/Emulators/Daphne Singe 1.14/singe/ActionMax/./ YUV overlay is done in software (ie unaccelerated). Booting ROM ... Starting Singe version 1.14 Search to 1 received [blocking] SINGE: Unable to load font. SINGE: Unable to load font. SINGE: Unable to load font. SINGE: Unable to load font. SINGE: Unable to load font. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
gooch Posted October 9, 2015 Posted October 9, 2015 Holy faster-than-an-autoreply Batman! Let me get back to my cab and check this out! Thanks! Sent from my iPhone using Tapatalk
gooch Posted October 9, 2015 Posted October 9, 2015 OK, that did it, the fonts were in the wrong folder. Thanks Ron!
rfancella Posted October 10, 2015 Author Posted October 10, 2015 OK, that did it, the fonts were in the wrong folder. Thanks Ron!Lol. I just happened to be wrapping up my day and saw your post. Glad it's all sorted.Thanks, Ron Sent from my VS980 4G using Tapatalk Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Kwestone Posted October 12, 2015 Posted October 12, 2015 Is there anyway to change the controls in the daphne singe? I have the batch installations installed.
rfancella Posted October 12, 2015 Author Posted October 12, 2015 Not that I know of. You might try using Keymapper in RLUI. Thanks, Ron Is there anyway to change the controls in the daphne singe? I have the batch installations installed. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Kwestone Posted October 16, 2015 Posted October 16, 2015 Thanks for the response. What if I changed over to the daphne singe method? And where can I find the guides to set it up. Thanks Chris
Metalzoic Posted October 16, 2015 Posted October 16, 2015 Thanks for the response. What if I changed over to the daphne singe method? And where can I find the guides to set it up. Thanks Chris I'm not sure what you're asking? What do you mean change to the Daphne Singe method? And this topic is the guide to set it up.
Kwestone Posted October 16, 2015 Posted October 16, 2015 I got it. I created custom xpadder profiles and just moved around the buttons. Seems to work great.
shitoken Posted October 21, 2015 Posted October 21, 2015 HI Ron, thank you for your Action max guide. I am having some issue to set this up. First of all do I need to rename the files from video_38AmbushAlley.m2v to 38AmbushAlley.m2v ?I have created bat file with below details if is correct?H:\HyperSpin\Emulators\WoW Action Max\WoWActionMax\DaphneSinge32v1.14\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe/ActionMax/frame_38AmbushAlley.txt -script H:\HyperSpin\Emulators\WoW Action Max\WoW Action Max\Daphne Singe Win 32v1.14\singe/ActionMax/38AmbushAlley.singe Please find the log details -DAPHNE version 1.0.10--Command line is: H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\daphne.exe singe vldp -x 1920 -y 1080 -ignore_aspect_ratio -framefile H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe\ActionMax\38AmbushAlley.txt -script H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe\ActionMax\38AmbushAlley.singe--CPU : GenuineIntel 3400 MHz || Mem : 4096 megs--OS : Windows NT Derivative || Video : AMD Radeon HD 6700 Series--OpenGL: Compiled In--RGB2YUV Function: MMX--Line Blending Function: MMX--Audio Mixing Function: MMXSetting screen width to 1920Setting screen height to 1080Script H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe\Action does not exist.Unknown command line parameter or parameter value:-scriptBad command line or initialization problem (see daphne_log.txt for details).To run DAPHNE, you must specify which game to run and which laserdisc player you are using.For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode. thank you
rfancella Posted October 21, 2015 Author Posted October 21, 2015 Hi, Looks like you need to shorten your paths. If I remember right, 80 characters are the max. The length you have is 113 characters "H:\HyperSpin\Emulators\WoW Action Max\WoW Action Max\Daphne Singe Win 32v1.14\singe/ActionMax/38AmbushAlley.singe" Thanks, Ron HI Ron, thank you for your Action max guide. I am having some issue to set this up. First of all do I need to rename the files from video_38AmbushAlley.m2v to 38AmbushAlley.m2v ?I have created bat file with below details if is correct?H:\HyperSpin\Emulators\WoW Action Max\WoWActionMax\DaphneSinge32v1.14\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe/ActionMax/frame_38AmbushAlley.txt -script H:\HyperSpin\Emulators\WoW Action Max\WoW Action Max\Daphne Singe Win 32v1.14\singe/ActionMax/38AmbushAlley.singe Please find the log details -DAPHNE version 1.0.10--Command line is: H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\daphne.exe singe vldp -x 1920 -y 1080 -ignore_aspect_ratio -framefile H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe\ActionMax\38AmbushAlley.txt -script H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe\ActionMax\38AmbushAlley.singe--CPU : GenuineIntel 3400 MHz || Mem : 4096 megs--OS : Windows NT Derivative || Video : AMD Radeon HD 6700 Series--OpenGL: Compiled In--RGB2YUV Function: MMX--Line Blending Function: MMX--Audio Mixing Function: MMXSetting screen width to 1920Setting screen height to 1080Script H:\HyperSpin\Emulators\WoWActionMax\WoWActionMax\DaphneSinge32v1.14\singe\Action does not exist.Unknown command line parameter or parameter value:-scriptBad command line or initialization problem (see daphne_log.txt for details).To run DAPHNE, you must specify which game to run and which laserdisc player you are using.For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode. thank you Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Styphelus Posted October 21, 2015 Posted October 21, 2015 Is there a way to change the mouse sensitivity. I don't have a gun and I've been using the mouse but it's sluggish and slow.
rfancella Posted October 21, 2015 Author Posted October 21, 2015 Hey, The only way I know of doing that is to change your mouse speed. You might try changing it to fullscreen or fullscreen_windowed first. Other than that, not that I know of. There might be some variable in the singe file, but I'll have to look into that. Thanks, Ron Is there a way to change the mouse sensitivity. I don't have a gun and I've been using the mouse but it's sluggish and slow. Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
shitoken Posted October 25, 2015 Posted October 25, 2015 Hi, Looks like you need to shorten your paths. If I remember right, 80 characters are the max. The length you have is 113 characters "H:\HyperSpin\Emulators\WoW Action Max\WoW Action Max\Daphne Singe Win 32v1.14\singe/ActionMax/38AmbushAlley.singe" Thanks, Ron Hi Ron Thank you for your reply I have shorten the path now as below H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\singe/ActionMax/frame_38AmbushAlley.txt -script H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\singe/ActionMax/38AmbushAlley.singe Received below error please help me thanks Script H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\singe/ActionMax/38AmbushAlley.si does not exist. Unknown command line parameter or parameter value: -script Bad command line or initialization problem (see daphne_log.txt for details). To run DAPHNE, you must specify which game to run and which laserdisc player you are using. For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode.
rfancella Posted October 25, 2015 Author Posted October 25, 2015 Hi Ron Thank you for your reply I have shorten the path now as below H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\daphne.exe singe vldp -x 800 -y 600 -fullscreen_window -noserversend -framefile H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\singe/ActionMax/frame_38AmbushAlley.txt -script H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\singe/ActionMax/38AmbushAlley.singe Received below error please help me thanks Script H:\HyperSpin\Emulators\WoWActionMax\DaphneSinge\singe/ActionMax/38AmbushAlley.si does not exist. Unknown command line parameter or parameter value: -script Bad command line or initialization problem (see daphne_log.txt for details). To run DAPHNE, you must specify which game to run and which laserdisc player you are using. For example, try 'daphne lair noldp' to run Dragon's Lair in testing mode. Hi,Your path is still too long. Change WoWActionMax to WoWAM and thaat should work. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
shitoken Posted October 28, 2015 Posted October 28, 2015 Hi RonFinally something start up on the screen but with message of lady Oh Oh introduction file is missing..... Hmm cant seems to find this file
shitoken Posted November 11, 2015 Posted November 11, 2015 appreciate if any help on this introduction file which I am missing
Metalzoic Posted November 11, 2015 Posted November 11, 2015 appreciate if any help on this introduction file which I am missing You haven't told us which file it says is missing.
wesfranks Posted November 12, 2015 Posted November 12, 2015 Not at my computer but off the top of my head there is a common intro video (intro.m2v, maybe) listed in the framefile for each game. It is the video with the scrolling film strip and says, "ActionMax, (blah, blah) takes a steady hand." The scripting of each game requires this video to play prior to switching to the game.m2v. If it is not there, the game errors out. The last time I checked the site that file was not there anymore. Maybe someone with that file can help you out.
wesfranks Posted November 12, 2015 Posted November 12, 2015 Ok, checked the site http://www.jaegertech.com/software/singe At the bottom of the page is a link for "ActioMax Intro (for emulator)". This is the file you need. Download it and place it in the common ActionMax folder. All else being correct, this should fix your problem.
shitoken Posted November 12, 2015 Posted November 12, 2015 Weskfranks and metalzoic thank so much , will check this tonight. Tapatalk を使用して私の A0001 から送信
