Acorn BBC XML
SamC
Acorn BBC.ahk for HLHQ
MEmu = Acorn BBC
MEmuV = 20/11/13
MURL = http://www.hyperspin-fe.com/
MAuthor = SamC (butchered from a djvj's Kat5200.ahk)
MVersion = 1.0
MCRC =
iCRC =
MID =
MSystem = "Acorn BBC"
; Notes:
StartModule()
FadeInStart()
Run(executable . " """ . romPath . "\" . romName . romExtension . """", emuPath)
FadeOutExit()
ExitModule()
CloseProcess:
FadeOutStart()
WinClose("Acorn BBC ahk_class phoenix_window")
Return
Has anyone figured out an escape sequence for BeebEm yet?
I was looking at the keymap file (\UserData\DefaultUser.kmap) and tried changing line 22 from:
-2 -2 0 -2 -2 1
to:
-9 -9 -9 -9 -9 -9 ***[Pause-Break]***
But all it seems to do is to disable the key in emulation.
N.B.
I use Pause/Break as my exit key.
EDIT:
\UserData\DefaultUser.kmap NOT \UserData\Default.kmap as shown in \UserData\Preferences.cfg, line 91
  • 5 months later...
here is mine
workin pretty good
works with .uef and .ssd files
removed the .img part cuz all of them were getting an error WITHIN the emulator
if this doesnt work please let me know and ill try to fix it
MEmu = BeebEm
MEmuV =
MURL =
MAuthor = craiganderson
MVersion = 1.0
MCRC =
iCRC =
MID =
MSystem = "Acorn BBC Micro"
; Notes:
;The vast majority of images within the archive contain a BASIC loader file, so the following should suffice:
;*TAPE
;PAGE=&E00
;CHAIN ""
;However, if the first file in an image is machine code (indicated by a _RUN in the long filename e.g. Islandia_RUN_B.uef) then you will need to ;enter this instead:
;*TAPE
;*RUN
StartModule()
BezelGUI()
FadeInStart()
BlockInput, On
screensize := ""
disableHideTitleBar := true
disableHideToggleMenu := true
disableHideBorder := true
BezelStart("fixResMode")
screensize := If Fullscreen = "true" ? "-fullscreen " : ""
If romExtension = .ssd
Run(executable . " """ . romPath . "\" . romName . romExtension . """  " . screensize, emuPath)
If romExtension = .dsd
If romExtension = .rom
If romExtension = .uef
Sleep,1250
SetKeyDelay, 50
Send, {~ down}{~ up}{t down}{t up}{a down}{a up}{p down}{p up}{e down}{e up}{ENTER down}{ENTER up}
Sleep,100
Send, {p down}{p up}{a down}{a up}{g down}{g up}{e down}{e up}{_ down}{_ up}{^ down}{^ up}{e down}{e up}{0 down}{0 up}{0 down}{0 up}{ENTER down}{ENTER up}
Sleep,100
Send, {c down}{c up}{h down}{h up}{a down}{a up}{i down}{i up}{n down}{n up}{@ down}{@ up}
Sleep,100
Send, {@ down}{@ up}{ENTER down}{ENTER up}
WinWait("ahk_class BEEBWIN")
WinWaitActive("ahk_class BEEBWIN")
Sleep, 2500
BlockInput, OFF
BezelDraw()
FadeInExit()
7zCleanUp()
BezelExit()
FadeOutExit()
ExitModule()
CloseProcess:
FadeOutStart()
  	Process, Close, BeebEm.exe
; WinClose("ahk_class BEEBWIN")
Return
  • 3 months later...
Nice one. I've updated my files.
Going to start the laborious task of recording video clips.
I've managed to source the a boat load of box scans which I'll try and 3Derise one day.
Think I'll use your theme in the meantime - it's got all the classics on there. Thanx again.
  • 4 weeks later...
Thanks Craig for the module.
[EDIT]
Wow, I did not see page two. My bad Craig and I appologize!!
The Changes you made look great!
[/EDIT]
I modified it to allow for bezels and added an isd for selecting fullscreen.
Here is the ahk: http://pastebin.com/w4458vUG
Here is the ahk: http://pastebin.com/kmjczayx
Here is the isd: http://pastebin.com/brMDE5ad
You will have to create a new directory in ...\HyperLaunch\Modules and call it BeebEM and put these two files in there.
Then Launch HyperHQ.exe and add the Acorn BBC Micro wheel.
Launch HyperLaunchHQ.
Create a new Global Emulator.
Name it BeebEm.
Set the path for the emulator.
Enter 7z|zip|ssd|uef for the Rom Extensions
Pick the BeebEm.ahk for the module.
You should be set. :D
Thanks,
Ron
[EDIT]
[/EDIT]
Name it BeebEm.
Thanks,
Ron
You should put your name in the module as well!!
And also please note that the module uses a BlockInput command to prevent keyboard/mouse from interfering with loading a game.
On my system HYPERSPIN and xpadder (if using) both need to be run as an administrator when using BlockInput command ...dont know why...just FYI.
The user could always get rid of the BlockInput,On and BlockInput,Off commands if the User doesnt want them in there....but then just dont mess with keyboard or mouse as game is loading!
Let us know how the video clips are coming along when you get a chance. Thanks.
  • 3 weeks later...
Made a couple more radical changes and waiting to find out how to finish it.
It will enter the correct tape and run commands for .uef files and if the file name has "start)" in it, it will run the correct commands to start.
If it's an .ssd file, it will start the command for you. Hope to figure out how to extract the command from the file name.
BeebEM.ahk:
Craig,
Does using the ~ work for you in your original module? Mine requires the * key.
Thanks,
Ron
i just tried it and the ~ worked for me
weird
Try my updated module above and let me know if it works.
Using the ~ I got Bad Command... etc.
Thanks,
Ron
weird
Craig,
Over at the HyperLaunch site, I have a post with a much updated module.
Can you test it and let me know if it works for you??
http://www.hyperlaunch.net/forum/showthread.php?231-BeebEm-module&p=2609&viewfull=1#post2609
Thanks,
Ron
.ssd file loaded
unofortunately the .uef file did not load
must be the problem brolly mentioned
see video
n8qh3P9ippI
(the final "f" u see at the end of the video is me exiting (my exit keys are combo of F and V)
just fyhi
same game loading with my module (which works on my system at least....dont know about others BUT i think some people are using it)
59YaeRE50_k
thanks
Different keyboard layouts mean different keycodes, you should never use characters such as ~ with Send commands, you need to use the vk codes instead to make it compatible across different keyboard layouts:
http://www.autohotkey.com/docs/KeyList.htm#SpecialKeys
I am not sure how to use VK codes in the module as brolly mentioned above.
If anybody can help me ...thanks ahead of time
craig
