46" / 30" / 19" widebody cabinet
chriz99
haha! It never stops! :proud:
Virtual pinball =no maintenance needed my ass! :thefinger:
  • Replies 1.5k
Chris, good luck with the motors. You are killing us! :)
Okay, so i did a bit of work on the LEDs.
This is the wood that I have as the trim on either side of the pinball
CIMG1958.JPG?psid=1
CIMG1959.JPG?psid=1
I routed a groove down the middle (it had snowed and was cold here so I did that in the garage... very noisy and dusty :)
CIMG1960.JPG?psid=1
I drilled 3 holes in the wood for the LEDs but did not take a picture of it. The LEDs where about 1/4, 1/2, and 3/4 from the top of the LCD, starting near the backbox.
I then removed the LED from the heatsink:
CIMG1963.JPG?psid=1
And wired up the connections:
CIMG1965.JPG?psid=1
Here are the LEDs installed temporarily:
CIMG1967.JPG?psid=1
From the front:
CIMG1968.JPG?psid=1
And a couple more:
CIMG1969.JPG?psid=1
CIMG1970.JPG?psid=1
Videos coming shortly...
With 5v no glass:
kkcHt9_C1eE
With 12v no glass:
JsPx3nR-c1c
With 12v & glass:
ngDe22c48pk
Hard to tell, but the 12v & under glass makes a difference. Wont know for sure until I have the software to really test with.
Great work shilmover!! it's amazing!!! I love this, but i can't put it in my 46" :(
but It's fantastic!
don't you have a 1 - 1.5cm foam on top of the lcd-rails? you could install some leds in there, or simply split the foam and add a wooden led housing?
cheers
chris
[sIGPIC][/sIGPIC]
Thats looks good!!!!
Are these LED able to recreate the flash effect you get from flashers, for instance destroying the UFO on AFM??
nice work!... that looks awesome. too bad the last video doesnt work
Thanks. It does not work? Works for me?
I am going to try to see if flaring the LED hole will make a difference. Will report back.
That's the idea. I am hoping to control 6 LEDs on the playfield and 3 on the backbox (plus some extras, but I am keeping that secret for now... :))
So does the color reflect on to the play field?
Somewhat, yes...
Hey Chris and all others! Took a break from my project but am now ready to resume by getting the 46 inch lcd for the pf. Wanted to see what everyone thought of this one on sale this weekend at Best Buy for $700...
Sony - BRAVIA 46" Class / 1080p / 60Hz / LCD HDTV
Model: KDL46EX400 | SKU: 9763694
It's only a 60hrz lcd, but that's what Chris' Sharp is in his game, so I'm thinking it's ok.
Any suggestions? What brand are other 46 inch VP people using?
Thanks!
Thanks!
sounds good so far.
I would suggest you to check the inputlag (ms) of the sony. you have to search the web (forums, like avs) for that info.
my sharp has nearly no inputlag, which is necessary (especially) for playing pinball games.
cheers
chris
[sIGPIC][/sIGPIC]
here is an "easy schematic ;) " to install the industry relay:
ps: its better to use an extern 12V-DC poweradapter (I use an old solid 10amps 12V-DC poweradapter) instead the pc-powersupply. its just saver.
ps2: there is electricity. do it only if you know what you do. I will take no responsibility for this.
Hey chris i got everything so far except the diodes, Would you happen to have a live picture of your flipper setup?
My Cabs
My Pin Cab Attack of the PINZ cab
My Racing Cab OutRun Racing
check out ext2k thread for a live pic
http://www.hyperspin-fe.com/forum/showpost.php?p=96804&postcount=78
if you use ledwiz, you need only a positive and negative wire at a1+ / a2- and a diode (like in4007, silver side goes to a1+ and black side to a2-).
without ledwiz you have to use the "easy schematic"
cheers
chris
[sIGPIC][/sIGPIC]
hey Chris on your diagram is that dio positioned the right way? Just wanted to double check
Also i noticed you and E2K have fuse boxes installed just wondering what there wired to.
My Cabs
diode is positioned right. the fuse is installed in the positive wire (ledwiz manual recommends to use a fuse).
cheers
chris
[sIGPIC][/sIGPIC]
Did you put in a complete diahatsu in your pinball ?? ;)
[TABLE=width: 500]
[TR]
[TD][/TD]
[TD=align: center]New project homepage: http://blog.pixelmagic.nl/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]LED-Wiz utility: http://pinball.pixelmagic.nl/ledwiz/[/TD]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[TD=align: center]Anyone want to buy my LEDwiz ??
[/TD]
[TD][/TD]
[/TR]
[/TABLE]
Nice!
How does it sound? feel?
It sounds and feels like a gear motor :D
If you play for example the "real" addams family pinball you can hear the gear motor when the bookshelf is moving.
most pinball games use a gear motor, so it's a nice add-on when everything else is emulated.
cheers
chris
[sIGPIC][/sIGPIC]
