qwerty89 Posted April 16, 2016 Posted April 16, 2016 Hello everyone, this is my first post. My goal is to emulate N64 on myShield TV device, nothing else. So, I've been trying for 5h to make HyperSpin work on my Nvidia Shield TV, and I'm about to give up. To start, I'm going to list all what I did so that we can eliminate a few error factors from me: -I first tried to run Retroarch (nightly build from their website) with my N64 roms (I didn't forget to download N64 core, etc.), only to have the games start and start with a black screen and a few bit of game sound sometime. I later learned in the forums that the N64 core from Retroarch is down for now. -Then I went for HyperSpin. I watched Simply Austin videos on how to setup HyperSpin with Rocketlauncher, how to upgrade HyperSpin 1.3.3 to 1.4, his Setup video to run N64. So I had HyperSpin working perfectly on my computer with N64 games. -From that I changed the ini.files in the Settings for the ones of Android. I installed Retroarch and HyperSpin on my shield from Google Play store. -I followed this guide (http://www.hyperspin-fe.com/topic/9226-how-to-set-up-hyperspin-on-the-nvidia-shield-beginners-guide/), copied the HyperSpin folder on my shield. It didn't work (roms not found) -The N64 roms are not zipped, then I read about changing the path of the roms in the N64.ini files so that they match And then I see that in the download section of this website there is 2 patches for android, and I'm getting really confused as to what I'm supposed to do because I see about 25 different things I'm supposed to change in a certain order to make it work. So my question would be: how do I make N64 roms run on my Nvidia shield TV? Thank you (a guy getting confused by the amount of information to make it run) EDIT*** N64 roms are now working with Mupen64AE, you should use this until the core for the N64 is fixed for Hyperspin***
thatman84 Posted April 16, 2016 Posted April 16, 2016 Sorry I can't help more but You need the mupen64 emulator for your shield. Unzipped roms and get them to work with the my pen emulator before moving on to hyperspin. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Sting Posted April 16, 2016 Posted April 16, 2016 Watch this http://www.hyperspin-fe.com/topic/15200-mupen64plusmupen64ae-setup-tutorial/
badhemi Posted April 17, 2016 Posted April 17, 2016 I try both nightly and regular and they both load in menu. This crap is getting old.it also says can't load iso
BiZzAr721 Posted April 17, 2016 Posted April 17, 2016 Not sure I understand about "can not load iso" N64 doesn't use disk images. [sIGPIC][/sIGPIC]
badhemi Posted April 17, 2016 Posted April 17, 2016 Not sure I understand about "can not load iso" N64 doesn't use disk images.I'm getting same error
JoyStickKilla Posted April 17, 2016 Posted April 17, 2016 That'e why you find a version that works and don't update!
BiZzAr721 Posted April 17, 2016 Posted April 17, 2016 I'm using mupen64 alpha from a few months ago, and it's working well. I haven't used the newest, but I'll check it out to see if I get the same error since I know everything else is setup correctly. You should definitely make the developer aware of the issue - they can't fix what they don't know is broken [sIGPIC][/sIGPIC]
thatman84 Posted April 17, 2016 Posted April 17, 2016 Is mupen in the App Store or sideload ? Couldn't find it. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
reznnate Posted April 17, 2016 Posted April 17, 2016 It would be best if retroarch would fix N64 core but it is broken right now. In the meantime, you can use Paul's mupen64 emu but then you'll need to unzip roms (and change file extension in the .ini.
badhemi Posted April 17, 2016 Posted April 17, 2016 It would be best if retroarch would fix N64 core but it is broken right now. In the meantime, you can use Paul's mupen64 emu but then you'll need to unzip roms (and change file extension in the .ini. now wonder I had mine zipped. Sting has his zipped though
reznnate Posted April 17, 2016 Posted April 17, 2016 My ROMS are zipped and unzipping them isn't worth it to me RIGHT NOW. I'm waiting for mupen64 to add .zip support OR for retroarch to fix their bug.
badhemi Posted April 18, 2016 Posted April 18, 2016 I tried a few unzipped and it loaded. I just don't like the loading in menu and exiting in menu.
BiZzAr721 Posted April 18, 2016 Posted April 18, 2016 I tested the latest mupen nightly and all is wel (noticed the addition of being able to add hi-res pack zips from within app) [sIGPIC][/sIGPIC]
qwerty89 Posted April 19, 2016 Author Posted April 19, 2016 Hello guys and thanks for the replies. So to recapitulate: - The N64 core from Retroarch is down, so we cannot use it right now -I'm told to use Mupen64 (from the Google play store), however I cannot find it in the shield TV Google play store (is it available?). I can find it on my computer, but it doesn't appear with the Shield TV (same for Thatman84 apparently). Is it possible to copy the app on a usb key and transfert that to the Shield? -If I install Mupen64, I need to change the ini files so it point to the correct location of the ROMs (thanks to Sting for the lines of codes and the video, but I need Mupen64 before) and unzip the ROMs (which I already did). So if someone who has Mupen64 running on a Shield TV (very important here, not the tablet or gamepad), could someone write the general lines of what he did (copied Mupen64 from the computer to the Shield TV, changed this line, etc). Thank you! EDIT: Oh wait, I can install Mupen64 on my shield from my computer. My bad. So I will install it and try your settings from your video, will give news!
qwerty89 Posted April 19, 2016 Author Posted April 19, 2016 Watch this http://www.hyperspin-fe.com/topic/15200-mupen64plusmupen64ae-setup-tutorial/ So Sting, did you find the Mupen64 on the Google play store? I cannot find it. Thank you EDIT: Oh wait, I can install Mupen64 on my shield from my computer. My bad. So I will install it and try your settings from your video, will give news!
qwerty89 Posted April 25, 2016 Author Posted April 25, 2016 Good news, Mupen64AE build from the 17/04 worked perfectly, no change needed. Just installed the apk and copied my ROMs unzipped on my shield, made Mupen64 scan the right folder and it was working.
thatman84 Posted April 25, 2016 Posted April 25, 2016 Where did you get the nightly from? Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Henderson33 Posted April 25, 2016 Posted April 25, 2016 Where did you get the nightly from? http://www.paulscode.com/source/Mupen64Plus-AE/AutoBuilds/
thatman84 Posted April 27, 2016 Posted April 27, 2016 Thanks I'll give that a go some time Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
thatman84 Posted May 10, 2016 Posted May 10, 2016 Looks like the retroarch mupen64 core is back working again. Haven't tested it yet. Video needs to be set to dynamic recompiler Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Sting Posted May 11, 2016 Posted May 11, 2016 Tested and it works finally If anyone hasn't already, I'd update your Mupen 64 core, and then Never update it again
