Mame 64bit + NoNag - Hi-score - Raw-input
sevenseal
have i missed something, can't get it work with dual guns ...
tried messing with mame.ini.
anyone else try this version with dual guns ?
at least i still got mame 171.
there are the other normal things you have to enable.
i would explain but getting ready for work, maybe someone will chime in?
i've already enabled lightgun input, dual lightguns, changed controller mapping settings, etc ...
setting exactly the same as previous mame versions that worked with dual lightguns.
just thought i may have missed something simple.
Did you get this to work with dual lightguns...I'm stuck at the moment with 171 also and hoped this version would sort this issue too....
Sevenseal mentioned in another thread that you can enable it in the ini now.
I'm not sure as I didn't need to mess with it. Check his 175 Mameuifx thread. It's probably in there.
Cheers....been away and came back to see 175.1 was required but can't find the raw version of the 175.1. After trying every version from 171 I hoped to get confirmation that it worked before wasting pointless hours when someone had already done that[emoji20]
Just wanted to chime in and direct everyone to the thread where we are trying to work through the dual lightgun bug. I am the submitter of the bug to mame and Pitou has submitted a patch for testing. Its not fully working but its almost there. At this moment it appears that 0173, 0174 and 0175 still have the bug that prevents gun2 from being recognized and added. 0172 as described and provided in the below thread is still the latest working version with dual lightgun support, at least for Aimtrak guns. I do not know how the other mfg's compare.
I did test this build posted here on HS with various lightgun/mouseprovider options with no success at getting mame to recognize both gun1 and gun2. At least the Pitou patch gets mame to recognize both guns. There is a precompiled version with the patch available at my thread here -
http://forum.arcadecontrols.com/index.php?topic=150393.msg1579910
It would be great if everyone with dual lightgun setup could try that 0175 patched mame64 with the updated 0175 mame.ini options set to auto, specifically lightgunprovider and mouseprovider.
Have tried various options of the mame builds posted here. Nothing after 171 works with dual light guns. I'm currently testing different options for mame dev. Yes the above patch does work to an extent. Im still curious as to how others have got dual guns working on mame versions after 171. Any input would be valuable to all.
quick update raw input values for dual guns should be released next mame version 177 (hopefully).
there is this page http://mametesters.org/view.php?id=6185 to check out.
still no word on how others have made dual guns work on 175. sevenseal?
Are you saying the MAMEdevs have actually said they'll have it fixed in 177?
This is good news. Looks like it will be worth me buying a second Aimtrak at some point and building a gun games bartop. Nice to see Andy offering free guns to the devs.
your guess is as good as mine, but talking to people and reading the posts from mamedevs,
it looks promising. issue has been noted and is being worked on. i wish i could tell you either way.
