ePSXe 1.9 Long rom loading
voyagerxp
I've just setup ePSXe 1.9 and its running fine outside HyperSpin but my problem is when i load a game in Hyperspin it takes 30 seconds to load the game. Anyone know why this could be happening?.
17:58:32:282 | HL |     INFO  | +N/A   | Main - HyperLaunch v3.0.1.1c
17:58:32:414 | HL |     INFO  | +125   | Main - System Specs:
				HyperLaunch Dir: D:\Hyperspin\RocketLauncher
				OS: Microsoft Windows 8.1 Pro
				SKU: Professional
				Total Memory: 8116.55 MB
				Free Memory: 5054.98 MB
				Used Memory: 3061.570 MB
				SystemType: x64-based PC
				Physical Processors: 1
				Logical Processors: 8
				GPU 1 Name: ATI Mobility Radeon HD 5800 Series
				GPU 1 RAM: 1024.00 MB
				GPU 1 Driver Version: 13.251.0.0
				Sound 1 Device: AMD High Definition Audio Device
				Sound 1 Status: Enabled
				Sound 2 Device: Realtek High Definition Audio
				Sound 2 Status: Enabled
				OS Language: English_United_Kingdom
				OS Admin Status: No
				Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1032 work)
				AutoHotkey Path:
				AHK Version: 1.1.09.04
				Unicode: No
17:58:32:414 | HL |     INFO  | +0     | Main - HyperSpin.exe coordinates are x y w h
17:58:32:415 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\HyperLaunch.exe exists
17:58:32:416 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	3.0.1.1
				File Size:			910336 bytes
				Created:			2/10/2014 - 9:41:49 PM
				Modified:			2/10/2014 - 9:38:57 PM
17:58:32:416 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\itextsharp.dll exists
17:58:32:418 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	iTextSharp
				FileVersion             	5.4.2.0
				InternalName            	itextsharp.dll
				LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
				OriginalFilename        	itextsharp.dll
				ProductName             	iTextSharp
				ProductVersion          	5.4.2.0
				CompanyName             	1T3XT BVBA
				File Size:			3743744 bytes
				Created:			2/10/2014 - 9:41:50 PM
				Modified:			2/10/2014 - 9:38:58 PM
17:58:32:418 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
17:58:32:419 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileDescription         	SevenZipSharp
				FileVersion             	0.64.4841.31212
				InternalName            	SevenZipSharp.dll
				LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
				OriginalFilename        	SevenZipSharp.dll
				ProductName             	SevenZipSharp
				ProductVersion          	0.64.4841.31212
				CompanyName             	Markovtsev Vadim
				File Size:			165888 bytes
17:58:32:419 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gsdll32.dll exists
17:58:32:421 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			8818688 bytes
17:58:32:421 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe exists
17:58:32:423 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription
				InternalName
				OriginalFilename
				ProductName
				File Size:			657920 bytes
17:58:32:424 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\gdip.ahk exists
17:58:32:436 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Extension.
17:58:32:437 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			88789 bytes
17:58:32:438 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\RIni.ahk exists
17:58:32:444 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
17:58:32:445 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			67561 bytes
17:58:32:446 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\CLR.ahk exists
17:58:32:447 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
17:58:32:449 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			10586 bytes
17:58:32:449 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\COM.ahk exists
17:58:32:452 | HL |   DEBUG1  | +15    | CRC Check - CRC matches, this is an official unedited Extension.
17:58:32:453 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26342 bytes
17:58:32:454 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\JSON.ahk exists
17:58:32:456 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Extension.
17:58:32:457 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			9203 bytes
17:58:32:457 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Init.ahk exists
17:58:32:459 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:460 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			1145 bytes
17:58:32:461 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\HyperPause Init.ahk exists
17:58:32:462 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:464 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			691 bytes
17:58:32:465 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper Init.ahk exists
17:58:32:467 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:468 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			3435 bytes
17:58:32:469 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame Init.ahk exists
17:58:32:470 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:472 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			161 bytes
17:58:32:472 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics Init.ahk exists
17:58:32:473 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:474 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			167 bytes
17:58:32:475 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade.ahk exists
17:58:32:477 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:479 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			25516 bytes
17:58:32:479 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\HyperPause.ahk exists
17:58:32:499 | HL |   DEBUG1  | +31    | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:500 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			360180 bytes
17:58:32:501 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Keymapper.ahk exists
17:58:32:504 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:506 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			30775 bytes
17:58:32:506 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\MultiGame.ahk exists
17:58:32:510 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:512 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			36816 bytes
17:58:32:512 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Bezel.ahk exists
17:58:32:522 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:523 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			83008 bytes
17:58:32:523 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Statistics.ahk exists
17:58:32:526 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:527 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			26153 bytes
17:58:32:527 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk exists
17:58:32:532 | HL |   DEBUG1  | +16    | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:533 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			63798 bytes
17:58:32:534 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Shared.ahk exists
17:58:32:539 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:540 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			80791 bytes
17:58:32:540 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\XHotkey.ahk exists
17:58:32:543 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:544 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				File Size:			28374 bytes
17:58:32:544 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Lib\Fade Animations.ahk exists
17:58:32:549 | HL |   DEBUG1  | +0     | CRC Check - CRC matches, this is an official unedited Library.
17:58:32:550 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			49050 bytes
17:58:32:551 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Databases\Main Menu\Main Menu.xml exists
17:58:32:552 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			952 bytes
				Modified:			2/22/2014 - 8:54:04 PM
17:58:32:638 | HL |     INFO  | +94    | Main - HyperLaunch launched directly
17:58:41:748 | HL |     INFO  | +9109  | Main - HyperLaunch received "Sony PlayStation" and "Crash Bandicoot - Warped (USA)"
17:58:41:759 | HL |     INFO  | +0     | Main - Crash Bandicoot - Warped (USA) is using the default emulator: ePSXe
17:58:41:760 | HL |     INFO  | +0     | Main - Checking for a [ePSXe] section in D:\Hyperspin\RocketLauncher\Settings\Sony PlayStation\Emulators.ini
17:58:41:761 | HL |     INFO  | +0     | Main - Found [ePSXe] in D:\Hyperspin\RocketLauncher\Settings\Sony PlayStation\Emulators.ini
17:58:41:761 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Modules\ePSXe\ePSXe.ahk exists
17:58:41:763 | HL |   DEBUG1  | +16    | CheckFile - Attributes:
				File Size:			12272 bytes
				Modified:			2/10/2014 - 9:39:02 PM
17:58:41:766 | HL |     INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
17:58:41:766 | HL |     INFO  | +0     | Main - Crash Bandicoot - Warped (USA) will use module: D:\Hyperspin\RocketLauncher\Modules\ePSXe\ePSXe.ahk
17:58:41:781 | HL |     INFO  | +16    | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks.
17:58:41:791 | HL |     INFO  | +0     | Main - INI Keys read
17:58:41:792 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe exists
17:58:41:793 | HL |   DEBUG1  | +15    | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7z
				ProductVersion          	9.20
				File Size:			163840 bytes
17:58:41:794 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll exists
17:58:41:795 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileVersion             	9.20
				InternalName            	7za
				ProductVersion          	9.20
				File Size:			914432 bytes
17:58:41:795 | HL |     INFO  | +0     | CheckPaths - Started
17:58:41:796 | HL |   DEBUG1  | +0     | CheckPaths - Looking for rom: D:\Hyperspin\Games\Sony Playstation\Crash Bandicoot - Warped (USA).7z
17:58:41:796 | HL |     INFO  | +0     | CheckPaths - Found rom: D:\Hyperspin\Games\Sony Playstation\Crash Bandicoot - Warped (USA).7z
17:58:41:797 | HL |   DEBUG1  | +0     | CheckPaths - Current romName: Crash Bandicoot - Warped (USA)
17:58:41:797 | HL |   DEBUG1  | +0     | CheckPaths - Current romPath: D:\Hyperspin\Games\Sony Playstation
17:58:41:798 | HL |   DEBUG1  | +0     | CheckPaths - Current romExtension: .7z
17:58:41:798 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Emulators\ePSXe\ePSXe190\ePSXe.exe exists
17:58:41:799 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			384000 bytes
				Created:			2/23/2014 - 5:30:49 PM
				Modified:			8/3/2013 - 8:50:48 AM
17:58:41:799 | HL |     INFO  | +0     | CheckPaths - Ended
17:58:41:800 | HL |     INFO  | +0     | BuildScript - User Variables:
				; INJECTED VARIABLES
				#NoTrayIcon
				#InstallKeybdHook
				DetectHiddenWindows, ON
				SetTitleMatchMode, 2
				SendMode, Event
				0 = 0
				hlMode =
				frontendPID = 0
				frontendPath = D:\Hyperspin
				frontendExe = HyperSpin.exe
				frontendExt = exe
				frontendName = HyperSpin
				frontendDrive = D:
				exitEmulatorKey = ~Esc
				exitEmulatorKeyWait = 0
				forceHoldKey = ~Esc
				restoreFE = false
				exitScriptKey = ~q & ~s
				toggleCursorKey = ~e & ~t
				emuFullPath = D:\Hyperspin\Emulators\ePSXe\ePSXe190\ePSXe.exe
				emuPath = D:\Hyperspin\Emulators\ePSXe\ePSXe190
				emuName = ePSXe
				emuExt = exe
				romPath = D:\Hyperspin\Games\Sony Playstation
				romPathFromIni = D:\Hyperspin\Games\Sony Playstation
				romExtension = .7z
				romExtensionOrig = .7z
				romExtensions = 7z|zip|cue|bin
				executable = ePSXe.exe
				systemName = Sony PlayStation
				dbName = Crash Bandicoot - Warped (USA)
				romName = Crash Bandicoot - Warped (USA)
				romMapPath =
				romMappingEnabled = false
				romMappingMenuWidth = 300
				romMappingMenuMargin = 50
				romMappingTextMargin = 10
				romMappingMenuFlagWidth = 40
				skipchecks = false
				romMatchExt = true
				blockInputTime = 0
				blockInputFile = D:\Hyperspin\RocketLauncher\Module Extensions\BlockInput.exe
				errorLevelReporting = false
				logFile = D:\Hyperspin\RocketLauncher\HyperLaunch.log
				logLevel = 10
				logIncludeModule = true
				logShowCommandWindow = false
				logCommandWindow = false
				sysLang = English_United_Kingdom
				navUpKey = Up
				navDownKey = Down
				navLeftKey = Left
				navRightKey = Right
				navSelectKey = Enter
				navP2UpKey = Numpad8
				navP2DownKey = Numpad2
				navP2LeftKey = Numpad4
				navP2RightKey = Numpad6
				navP2SelectKey = NumpadEnter
				originalWidth = 1920
				originalHeight = 1080
				dtEnabled = true
				dtPath = C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe
				dtUseSCSI = true
				dtAddDrive = true
				emuIdleShutdown = 0
				hideCursor = false
				hideEmu = false
				hideFE = false
				fadeIn = false
				fadeInDuration = 500
				fadeInDelay = 0
				fadeInExitDelay = 0
				fadeOutExitDelay = 0
				fadeOut = false
				fadeOutExtraScreen = false
				fadeOutDuration = 500
				fadeOutDelay = 0
				fadeLyrInterpolation = 7
				fadeLyr1Color = FF000000
				fadeLyr2X = 300
				fadeLyr2Y = 300
				fadeLyr2Adjust = 1
				fadeLyr2PicPad = 0
				fadeLyr3Pos = Center
				fadeLyr3X = 300
				fadeLyr3Y = 300
				fadeLyr3Adjust = 0.75
				fadeLyr3Speed = 750
				fadeLyr3Type = imageandbar
				fadeLyr3Repeat = 1
				fadeLyr3PicPad = 0
				fadeLyr4Adjust = 0.75
				fadeLyr4X = 100
				fadeLyr4Y = 100
				fadeLyr4FPS = 10
				fadeLyr4PicPad = 0
				fadeTranspGifColor = FFFFFF
				fadeBarWindow = false
				fadeBarWindowX =
				fadeBarWindowY =
				fadeBarWindowW = 600
				fadeBarWindowH = 120
				fadeBarWindowR = 20
				fadeBarWindowM = 20
				fadeBarWindowHatchStyle = 8
				fadeBarBack = true
				fadeBarBackColor = FF555555
				fadeBarH = 20
				fadeBarR = 5
				fadeBarColor = DD00BFFF
				fadeBarHatchStyle = 3
				fadeBarPercentageText = true
				fadeBarInfoText = true
				fadeBarXOffset = 0
				fadeBarYOffset = 100
				fadeRomInfoDescription = text
				fadeRomInfoSystemName = text
				fadeRomInfoYear = text
				fadeRomInfoGenre = text
				fadeRomInfoRating = text
				fadeRomInfoTextMargin = 5
				fadeStatsInfoTextMargin = 5
				fadeText1X = 0
				fadeText1Y = 0
				fadeText1 = Loading Game
				fadeText2X = 0
				fadeText2Y = 0
				fadeFont = Arial
				fadeInterruptKey =
				detectFadeErrorEnabled = true
				fadeImgPath = D:\Hyperspin\RocketLauncher\Media\Fade
				HLDataPath = D:\Hyperspin\RocketLauncher\Data
				HLMediaPath = D:\Hyperspin\RocketLauncher\Media
				HLErrSoundPath = D:\Hyperspin\RocketLauncher\Media\Sounds\Error
				modulesPath = D:\Hyperspin\RocketLauncher\Modules
				moduleFullName = D:\Hyperspin\RocketLauncher\Modules\ePSXe\ePSXe.ahk
				moduleName = ePSXe
				modulePath = D:\Hyperspin\RocketLauncher\Modules\ePSXe
				moduleExtension = ahk
				moduleExtensionsPath = D:\Hyperspin\RocketLauncher\Module Extensions
				libPath = D:\Hyperspin\RocketLauncher\Lib
				7zEnabled = true
				7zPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.exe
				7zDllPath = D:\Hyperspin\RocketLauncher\Module Extensions\7z.dll
				7zExtractPath = C:\Users\steven\AppData\Local\Temp\HS
				7zExtractPathOrig =
				7zAttachSystemName = false
				7zDelTemp = true
				7zSounds = true
				mgEnabled = false
				mgKey = ~NumpadSub
				mgBackgroundColor = FF000000
				mgSidePadding = 0.2
				mgYOffset = 500
				mgImageAdjust = 0
				mgFont = Arial
				mgText2Offset = 70
				mgUseSound = true
				mgSoundfreq = 300
				mgExitEffect = none
				mgSelectedEffect = rotate
				mgUseGameArt = false
				mgArtworkDir = Artwork1
				hpEnabled = false
				hpKey = ~NumpadAdd
				hpBackToMenuBarKey = X
				hpZoomInKey = C
				hpZoomOutKey = V
				hpHiToTextPath = D:\Hyperspin\RocketLauncher\Module Extensions\HiToText.exe
				hpSaveStateKeyCodes =
				hpLoadStateKeyCodes =
				keymapperEnabled = false
				keymapperAHKMethod = false
				keymapper =
				xpadderFullPath = D:\Hyperspin\Utilities\Xpadder\xpadder.exe
				joyToKeyFullPath = D:\Hyperspin\Utilities\JoyToKey\JoyToKey.exe
				keymapperProfilePath = D:\Hyperspin\RocketLauncher\Profiles\
				JoyIDsEnabled = false
				JoyIDsPreferredControllersSystem = use_global
				CustomJoyNamesEnabled = false
				CustomJoyNames =
				FEProfile = D:\Hyperspin\RocketLauncher\Profiles\\HyperSpin
				defaultProfile = D:\Hyperspin\RocketLauncher\Profiles\\_Default
				systemProfile = D:\Hyperspin\RocketLauncher\Profiles\\Sony PlayStation
				xPadderSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\\Sony PlayStation\_Default
				emuProfile = D:\Hyperspin\RocketLauncher\Profiles\\Sony PlayStation\ePSXe
				romProfile = D:\Hyperspin\RocketLauncher\Profiles\\Sony PlayStation\Crash Bandicoot - Warped (USA)
				HyperLaunchProfile = D:\Hyperspin\RocketLauncher\Profiles\\HyperLaunch
				blankProfile = D:\Hyperspin\RocketLauncher\Profiles\\blank
				ahkFEProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\HyperSpin
				ahkDefaultProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\_Default
				ahkSystemProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Sony PlayStation
				ahkEmuProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Sony PlayStation\ePSXe
				ahkRomProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\Sony PlayStation\Crash Bandicoot - Warped (USA)
				ahkHyperLaunchProfile = D:\Hyperspin\RocketLauncher\Profiles\AHK\HyperLaunch
				bezelEnabled = false
				statisticsEnabled = true
17:58:41:801 | HL |     INFO  | +0     | BuildScript - Loaded XHotkey Init.ahk scripts
17:58:41:802 | HL |     INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
17:58:41:802 | HL |     INFO  | +0     | BuildScript - Loaded User Functions Init.ahk script
17:58:41:802 | HL |   DEBUG1  | +0     | BuildScript - Module starts on line: 2
17:58:41:805 | HL |     INFO  | +0     | BuildScript - Module:
				MEmu = ePSXe
				MEmuV =  v1.9.0
				MURL = http://www.epsxe.com/
				MAuthor = djvj & Shateredsoul & brolly
				MVersion = 2.0.7
				MCRC = A47833DF
				iCRC = AFD664B0
				MID = 635038268888210842
				MSystem = "Sony PlayStation"
				; Notes:
				; epsxe can't deal with bin/cue dumps with more than one audio track if you load the cue file directly.
				; For these to work you must mount the cue on daemon tools and let epsxe boot the game from there.
				; You need to make sure you have a SCSI virtual drive on Daemon Tools, NOT a DT one.
				; On first time use, 2 default memory card files will be created called _default_001.mcr and _default_002.mcr in emuPath\memcards
				; Extract all your BIOS files to the bios subfolder. Then goto Config->Bios and select the bios you wish to use.
				; Go to Config->Video then choose a plugin. Pete's OpenGL line is preffered
				; Click Configure (under video plugin) and choose fullscreen and set your desired resolution. Video options/results will vary based on the plugin you choose.
				; If you are using images with multiple tracks, set your extension to cue (make sure all your cues are correctly pointing to their tracks).
				; Go to Config->Cdrom->Configure button and select the drive letter associated with your daemon tools virtual drive.
				; ePSXe will ONLY close via Escape, it will bug out with all other forms of closing a normal program. Do not edit CloseProcess!
				; TurboButton will only work with DX7 video plugin. Turbo key by Hypnoziz
				; Requires at least Libs\Shared.ahk v1.1.3
				; epsxe stores its settings in the registry @ HKEY_CURRENT_USER\Software\epsxe\config
				; plugins store their settings in the registry @ HKEY_CURRENT_USER\Software\Vision Thing\PSEmu Pro
				StartModule()
				BezelGUI()
				FadeInStart()
				turboButton := IniReadCheck(settingsFile, "Settings", "turboButton","F12",,1)		; Key mapping for turbo button assignment
				slowBoot := IniReadCheck(settingsFile, "Settings", "slowBoot","false",,1)			; If true, force emulator to show bios screen at boot
				enableAnalog := IniReadCheck(settingsFile, "Settings", "enableAnalog","true",,1)	; If true, enables analog controls at start of game for you, so you don't have to press F5
				hideEpsxeGUIs := IniReadCheck(settingsFile, "Settings", "HideePSXeGUIs","true",,1)
				MLanguage := IniReadCheck(settingsFile, "Settings", "MLanguage","English",,1)		; If English, dialog boxes look for the word "Open" and if Spanish/Portuguese, looks for "Abrir"
				perGameMemCards := IniReadCheck(settingsFile, "Settings", "PerGameMemoryCards","true",,1)
				disableMemoryCard1 := IniReadCheck(settingsFile, romName, "DisableMemoryCard1","false",,1)	; If true, disables memory card 1 for this game. Some games may not boot if both memory cards are inserted.
				disableMemoryCard2 := IniReadCheck(settingsFile, romName, "DisableMemoryCard2","false",,1)	; If true, disables memory card 2 for this game. Some games may not boot if both memory cards are inserted.
				mLang := Object("English","Open","Spanish/Portuguese","Abrir")
				winLang := mLang[MLanguage]	; search object for the MLanguage associated to the user's language
				If !winLang
					ScriptError("Your chosen language is: """ . MLanguage . """. It is not one of the known supported languages for this module: " . moduleName)
				BezelStart()
				If (Fullscreen = "true") {
					WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\PeteOpenGL2", "WindowMode", 0)	; changes fullscreen setting for all 3 gpu plugins
					WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\PeteTNT", "WindowMode", 0)
					WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\DFXVideo", "WindowMode", 0)
				} Else {
					WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\PeteOpenGL2", "WindowMode", 1)
					WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\PeteTNT", "WindowMode", 1)
					WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\DFXVideo", "WindowMode", 1)
					If (bezelEnabled = "true") {
						winSize := bezelScreenHeight * 65536 + bezelScreenWidth	; convert desired windowed resolution to Decimal
						WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\PeteOpenGL2", "WinSize", winSize)
						WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\PeteTNT", "WinSize", winSize)
						WriteReg("DWORD", "Vision Thing\PSEmu Pro\GPU\DFXVideo", "WinSize", winSize)
				; Memory Cards
				memCardPath := emuPath . "\memcards"
				defaultMemCard1 := memCardPath . "\_default_001.mcr"	; defining default blank memory card for slot 1
				defaultMemCard2 := memCardPath . "\_default_002.mcr"	; defining default blank memory card for slot 2
				romMemCard1 := memCardPath . "\" . romName . "_001.mcr"		; defining name for rom's memory card for slot 1
				romMemCard2 := memCardPath . "\" . romName . "_002.mcr"		; defining name for rom's memory card for slot 2
				memcardType := If perGameMemCards = "true" ? "rom" : "default"	; define the type of memory card we will create in the below loop
				IfNotExist, %memCardPath%
					FileCreateDir, %memCardPath%	; create memcard folder if it doesn't exist
				Loop 2
				{	IfNotExist, % %memcardType%MemCard%A_Index%
					{	FileAppend,, % %memcardType%MemCard%A_Index%		; create a new blank memory card if one does not exist
						Log("Module - Created a new blank memory card in Slot " . A_Index . ":" . %memcardType%MemCard%A_Index%)
					WriteReg("SZ", "epsxe\config", "Memcard" . A_Index, %memcardType%MemCard%A_Index%)
					; Now disable a memory card if required for the game to boot properly
					memcard%A_Index%Enable := ReadReg("epsxe\config", "Memcard" . A_Index . "Enable")
					If (disableMemoryCard%A_Index% = "true")
						WriteReg("SZ", "epsxe\config", "Memcard" . A_Index . "Enable", 0)
					Else
						WriteReg("SZ", "epsxe\config", "Memcard" . A_Index . "Enable", 1)
				epsxeExtension := InStr(".ccd|.cue|.img|.iso|.mdf",romExtension)	; the psx extensions supported by the emu
				SetKeyDelay, 50
				; turboButton := xHotKeyVarEdit(turboButton,"turboButton","~","Add")
				xHotKeywrapper(turboButton,"TurboProcess")
				turboEnabled = 0				; Initialize turbo state
				RomTableCheck()	; make sure romTable is created already so the next line can calculate correctly
				noGUI := If romTable.MaxIndex() ? "" : " -nogui" ; multidisc games will not use nogui because we need to select an option in epsxe's gui to swap discs
				slowBoot := If slowBoot = "true" ? " -slowboot" : ""
				If (noGUI = "" && hideEpsxeGUIs = "true") {	; for multi disc games only
					Log("Module - Starting the HideGUIWindow timer to prevent them from showing")
					SetTimer, HideGUIWindow, 10	; start watching for gui window so it can be completely hidden
				; Mount the CD using DaemonTools
				If (epsxeExtension && dtEnabled = "true" ) {
					Log("Module - Daemon Tools is enabled and " . romExtension . " is a supported DT extension.")
					DaemonTools("mount",romPath . "\" . romName . romExtension)
					errorLvl := Run(executable . noGUI . slowBoot, emuPath)
					usedDT := 1
				} Else {
					Log("Module - Sending rom to emu directly as Daemon Tools is not enabled or " . romExtension . " is not a supported DT extension.")
					errorLvl := Run(executable . noGUI . slowBoot . " -loadiso """ . romPath . "\" . romName . romExtension . """", emuPath)
				If errorLvl
					ScriptError("Error launching " . executable . "`, closing module.")
				epsxeLaunchType := If usedDT ? "CDROM" : "ISO"	; determines which command gets sent to epsxe
				If (noGUI = "") {	; for multi disc games only
					Log("Module - " . romName . " is a multi-disc game, so launching " . MEmu . " with GUI enabled so swapping can occur.")
					WinWait("ePSXe ahk_class EPSXGUI")
					If (epsxeLaunchType = "CDROM") {
						Log("Module - Telling ePSXe to run a CDROM")
						PostMessage, 0x111, 40001,,,ahk_class EPSXGUI	; Run CDROM
					} Else {
						Log("Module - Telling ePSXe to run an ISO")
						PostMessage, 0x111, 40003,,,ahk_class EPSXGUI	; Run ISO
				} Else
					Log("Module - " . romName . " is not a multi-disc game, so launching " . MEmu . " with GUI disabled.")
				epsxeOpenWindow := winLang . " PSX ISO ahk_class #32770"
				If (!usedDT && noGUI = "") {		; for some reason, epsxe still shows an open psx iso box even though it was provided on the run command when we don't also send -nogui. This handles loading the rom.
					Log("Module - " . MEmu . " GUI and DT support are both disabled. Loading rom via the Open PSX ISO window.")
					WinWait(epsxeOpenWindow)
					Loop {
						ControlGetText, edit1Text, Edit1, %epsxeOpenWindow%
						If (edit1Text = romPath . "\" . romName . romExtension)
							Break
						Sleep, 100
						ControlSetText, Edit1, %romPath%\%romName%%romExtension%, %epsxeOpenWindow%
					ControlSend, Button1, {Enter}, %epsxeOpenWindow% ; Select Open
				WinWait("ePSXe ahk_class EPSX")
				WinWaitActive("ePSXe ahk_class EPSX")
					Log("Module - Stopping the HideGUIWindow timer")
					SetTimer, HideGUIWindow, Off
				BezelDraw()
				FadeInExit()
				If enableAnalog = true
				{	Sleep, 1500	; necessary otherwise epsxe doesn't register the key
					Send, {F5 down}{F5 up}
				If usedDT
					DaemonTools("unmount")
				7zCleanUp()
				BezelExit()
				FadeOutExit()
				ExitModule()
				ReadReg(var1, var2) {
					RegRead, regValue, HKEY_CURRENT_USER, Software\%var1%, %var2%
					Return %regValue%
				WriteReg(type, var1, var2, var3) {
					RegWrite, REG_%type%, HKEY_CURRENT_USER, Software\%var1%, %var2%, %var3%
				TurboProcess:
				    If (turboEnabled = 0) {
						Send, {Delete}{End}{End}{Delete}
						turboEnabled = 1
				    } Else {
						Send, {Delete}{End}{Delete}
						turboEnabled = 0
				Return
				HaltEmu:
					SetKeyDelay, 50
					If Fullscreen = true
					{	PostMessage, 0x111, 40001,,,ahk_class EPSXGUI	; Go fullscreen, same as alt+enter
						Sleep, 200
				Return
				MultiGame:
					; msgbox % "selectedRom = " . selectedRom . "`nselected game = " . currentButton . "`nmgRomPath = " . mgRomPath . "`nmgRomExt = " . mgRomExt . "`nmgRomName = "  . mgRomName
					SetKeyDelay, 50
					If usedDT
					{	DaemonTools("unmount")	; Unmount the CD from DaemonTools
						Sleep, 500	; Required to prevent  DT from bugging
						DaemonTools("mount",selectedRom)	; Mount the CD using DaemonTools
					ControlSend,, {ESC down}{ESC Up}, ahk_class EPSX	; this exits the game window and brings back ePSXe's gui menu window
					If hideEpsxeGUIs = true
					{	Log("Module - Starting the HideGUIWindow timer to prevent them from showing")
						Log("Module - Telling ePSXe to swap to another CDROM")
						PostMessage, 0x111, 40005,,,ahk_class EPSXGUI	; Change Disc CDROM
					} Else {
						Log("Module - Telling ePSXe to swap to another ISO")
						PostMessage, 0x111, 40006,,,ahk_class EPSXGUI	; Change Disc ISO
					If usedDT
					{	WinWait("Change Disc Option ahk_class #32770")
						ControlSend,Button1,{Enter},Change Disc Option ahk_class #32770
					} Else {
						Loop {
							If (edit1Text = selectedRom)
								Break
							Sleep, 100
							ControlSetText, Edit1, %selectedRom%, %epsxeOpenWindow%
					{	Log("Module - Stopping the HideGUIWindow timer")
						SetTimer, HideGUIWindow, off
				Return
				RestoreEmu:
					SetKeyDelay, 50
					WinActivate, ahk_id  %emulatorID%
				Return
				HideGUIWindow:
					WinSet, Transparent, On, ePSXe ahk_class EPSXGUI
					WinSet, Transparent, On, Open PSX ISO ahk_class #32770	; when not using DT
					WinSet, Transparent, On, Change Disc Option ahk_class #32770	; when using DT
				Return
				CloseProcess:
					FadeOutStart()
					SetWinDelay, 50
					Log("Module - Sending Escape to close emulator")
					; ControlSend,, {Esc down}{Esc up}, ePSXe ahk_class EPSX ; DO NOT CHANGE
					PostMessage, 0x111, 40007,,,ahk_class EPSX	; Go fullscreen, same as alt+enter
						WinClose("ePSXe ahk_class EPSXGUI")
				Return
17:58:41:806 | HL |     INFO  | +0     | CheckFile - Checking if C:\Program Files (x86)\DAEMON Tools Lite\DTLite.exe exists
17:58:41:808 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				FileDescription         	DAEMON Tools Lite
				FileVersion             	4.48.1.0347
				InternalName            	DTLite.exe
				LegalCopyright          	© 2000-2013 Disc Soft Ltd.
				OriginalFilename        	DTLite.exe
				ProductName             	DAEMON Tools Lite
				ProductVersion          	4.48.1.0347
				CompanyName             	Disc Soft Ltd
				File Size:			3675352 bytes
				Created:			10/28/2013 - 8:29:38 AM
				Modified:			10/28/2013 - 8:29:38 AM
17:58:41:808 | HL |     INFO  | +0     | BuildScript - Loaded Statistics.ahk script
17:58:41:809 | HL |     INFO  | +16    | BuildScript - Loaded User Functions.ahk script
17:58:41:809 | HL |     INFO  | +0     | BuildScript - Finished injecting functions into module
17:58:41:809 | HL |     INFO  | +0     | Main - Module is built
17:58:41:810 | HL |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\RocketLauncher\AutoHotkey.dll exists
17:58:41:811 | HL |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			785408 bytes
17:58:41:813 | HL |     INFO  | +0     | Main - Running module
17:58:41:813 | HL |     INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
17:58:41:959 | MD |     INFO  | +N/A   | Module initialized
17:58:41:963 | MD |     INFO  | +0     | StartModule - Started
17:58:41:964 | MD |     INFO  | +0     | StartModule - MEmu: ePSXe
				MEmuV: v1.9.0
				MURL: http://www.epsxe.com/
				MAuthor: djvj & Shateredsoul & brolly
				MVersion: 2.0.7
				MCRC: A47833DF
				iCRC: AFD664B0
				MID:
				MSystem: "Sony PlayStation"
17:58:41:964 | MD |     INFO  | +0     | StartModule - You have a supported System Name for this module: "Sony PlayStation"
17:58:41:965 | MD |   DEBUG1  | +16    | StartModule - Leaving romName as is because Rom Mapping filled it with an Alternate_Rom_Name: Crash Bandicoot - Warped (USA)
17:58:41:966 | MD |     INFO  | +0     | StartModule - Ended
17:58:41:966 | MD |     INFO  | +0     | StartGlobalUserFeatures - Starting
17:58:41:967 | MD |     INFO  | +0     | StartGlobalUserFeatures - Ending
17:58:41:967 | MD |     INFO  | +0     | Module Setting - [settings] - Fullscreen: true
17:58:41:968 | MD |     INFO  | +0     | Module Setting - [settings] - turboButton: F12
17:58:41:968 | MD |     INFO  | +0     | Module Setting - [settings] - slowBoot: false
17:58:41:969 | MD |     INFO  | +0     | Module Setting - [settings] - enableAnalog: true
17:58:41:969 | MD |     INFO  | +0     | Module Setting - [settings] - HideePSXeGUIs: true
17:58:41:970 | MD |     INFO  | +0     | Module Setting - [settings] - MLanguage: English
17:58:41:970 | MD |     INFO  | +0     | Module Setting - [settings] - PerGameMemoryCards: true
17:58:41:971 | MD |     INFO  | +0     | Module Setting - [Crash Bandicoot - Warped (USA)] - DisableMemoryCard1: false
17:58:41:971 | MD |     INFO  | +0     | Module Setting - [Crash Bandicoot - Warped (USA)] - DisableMemoryCard2: false
17:58:41:972 | MD |     INFO  | +0     | 7z - Started, received D:\Hyperspin\Games\Sony Playstation\Crash Bandicoot - Warped (USA).7z. If rom is an archive, it will extract to C:\Users\steven\AppData\Local\Temp\HS
17:58:41:972 | MD |   DEBUG1  | +0     | 7z - Using Standard method to extract this rom
17:58:41:973 | MD |   DEBUG1  | +0     | 7z - ".7z" found in .zip,.rar,.7z,.lzh,.gzip,.tar
17:58:41:973 | MD |     INFO  | +0     | CheckFile - Checking if D:\Hyperspin\Games\Sony Playstation\Crash Bandicoot - Warped (USA).7z exists
17:58:41:975 | MD |   DEBUG1  | +0     | CheckFile - Attributes:
				File Size:			108635485 bytes
				Created:			2/23/2014 - 5:42:26 PM
				Modified:			2/23/2014 - 5:44:21 PM
17:58:42:078 | MD |     INFO  | +109   | 7z - Archive name matches rom name; DLL found rom inside archive using "findFileInZip": "Crash Bandicoot - Warped (USA).bin"
17:58:42:080 | MD |   DEBUG1  | +0     | 7z - Invoked COM Object, ROM extracted size: 344713824 bytes
17:58:42:081 | MD |   DEBUG1  | +0     | 7z - File does not already exist in 7z_Extract_Path, proceeding to extract it.
17:58:42:081 | MD |   DEBUG1  | +0     | 7z - File found in archive
17:58:42:081 | MD |     INFO  | +0     | 7z - Extracted path of rom will be 103 in length and within the 255 character limit.
17:58:42:082 | MD |     INFO  | +0     | 7z - The 7zExtractPath has 28827 MB of free space which is enough to extract this game: 344 MB
17:58:42:082 | MD |   DEBUG1  | +0     | 7z - Starting 7z extraction of D:\Hyperspin\Games\Sony Playstation\Crash Bandicoot - Warped (USA).7z  to C:\Users\steven\AppData\Local\Temp\HS\Crash Bandicoot - Warped (USA)
17:58:57:052 | MD |   DEBUG1  | +14969 | 7z - Finished 7z extraction
17:58:57:053 | MD |   DEBUG1  | +0     | 7z - Found file in C:\Users\steven\AppData\Local\Temp\HS\Crash Bandicoot - Warped (USA)\Crash Bandicoot - Warped (USA).bin
17:58:57:053 | MD |     INFO  | +0     | 7z - Ended
17:58:57:054 | MD |     INFO  | +0     | RomTableCheck - Started
17:58:57:055 | MD |   DEBUG1  | +0     | RomTableCheck - MultiGame and/or HyperPause's Change DIsc Menu is enabled so checking if romTable exists yet.
17:58:57:056 | MD |   DEBUG1  | +0     | RomTableCheck - romTable does not exist yet, waiting until it does to continue loading the module.
17:59:18:929 | MD |    ERROR  | +21875 | RomTableCheck - Creating the romTable took longer than 20 seconds. Continuing with module thread without waiting for the table's creation.
17:59:18:929 | MD |     INFO  | +0     | RomTableCheck - Ended
17:59:18:930 | MD |     INFO  | +0     | Module - Sending rom to emu directly as Daemon Tools is not enabled or .bin is not a supported DT extension.
17:59:18:930 | MD |     INFO  | +0     | Run - Running: D:\Hyperspin\Emulators\ePSXe\ePSXe190\ePSXe.exe -nogui -loadiso "C:\Users\steven\AppData\Local\Temp\HS\Crash Bandicoot - Warped (USA)\Crash Bandicoot - Warped (USA).bin"
17:59:18:960 | MD |   DEBUG1  | +31    | Run - "ePSXe.exe -nogui -loadiso "C:\Users\steven\AppData\Local\Temp\HS\Crash Bandicoot - Warped (USA)\Crash Bandicoot - Warped (USA).bin"" Process ID: 8920
17:59:18:960 | MD |     INFO  | +0     | Module - Crash Bandicoot - Warped (USA) is not a multi-disc game, so launching ePSXe with GUI disabled.
17:59:18:961 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: RocketLauncher | Class: CabinetWClass | State: 0 | X: 480 | Y: 124 | Width: 966 | Height: 833 | Window HWND: 0xb00690 | Process ID: 2032 | Process Path: C:\Windows\explorer.exe
17:59:18:962 | MD |     INFO  | +0     | WinWait - Waiting for "ePSXe ahk_class EPSX"
17:59:19:138 | MD |   DEBUG1  | +188   | GetActiveWindowStatus - Title: ePSXe - Enhanced PSX emulator | Class: EPSX | State: 1 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xe504bc | Process ID: 8920 | Process Path: D:\Hyperspin\Emulators\ePSXe\ePSXe190\ePSXe.exe
17:59:19:139 | MD |   DEBUG1  | +0     | GetActiveWindowStatus - Title: ePSXe - Enhanced PSX emulator | Class: EPSX | State: 1 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xe504bc | Process ID: 8920 | Process Path: D:\Hyperspin\Emulators\ePSXe\ePSXe190\ePSXe.exe
17:59:19:139 | MD |     INFO  | +0     | WinWaitActive - Waiting for "ePSXe ahk_class EPSX"
17:59:19:255 | MD |   DEBUG1  | +109   | GetActiveWindowStatus - Title: ePSXe - Enhanced PSX emulator | Class: EPSX | State: 1 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0xe504bc | Process ID: 8920 | Process Path: D:\Hyperspin\Emulators\ePSXe\ePSXe190\ePSXe.exe
17:59:20:849 | MD |     INFO  | +1594  | Process - WaitClose ePSXe.exe
17:59:30:211 | MD |   DEBUG1  | +9359  | CloseProcess - Started, user requested to end launched application
17:59:30:212 | MD |     INFO  | +0     | Module - Sending Escape to close emulator
17:59:30:213 | MD |   DEBUG1  | +0     | CloseProcess - Ended
17:59:30:418 | MD |     INFO  | +219   | 7zCleanUp - Started
17:59:30:475 | MD |   DEBUG1  | +47    | 7zCleanUp - Deleted C:\Users\steven\AppData\Local\Temp\HS\Crash Bandicoot - Warped (USA)
17:59:30:476 | MD |     INFO  | +0     | 7zCleanUp - Ended
17:59:30:476 | MD |     INFO  | +0     | StopGlobalUserFeatures - Starting
17:59:30:477 | MD |     INFO  | +0     | StopGlobalUserFeatures - Ending
17:59:30:477 | MD |     INFO  | +0     | ExitModule - Started
17:59:30:477 | MD |     INFO  | +0     | Starting Updating Statistics:
17:59:30:478 | MD |   DEBUG2  | +0     | Total Elapsed Time in Pause in seconds: 0
17:59:30:478 | MD |   DEBUG2  | +0     | gameSectionStartTime:176001937
17:59:30:479 | MD |   DEBUG2  | +0     | ElapsedTime:48
17:59:30:479 | MD |     INFO  | +0     | CreateRomTable - Started
17:59:30:479 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Disc"
17:59:30:480 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Disk"
17:59:30:480 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Cart"
17:59:30:481 | MD |   DEBUG1  | +16    | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Tape"
17:59:30:481 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Cassette"
17:59:30:481 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Part"
17:59:30:482 | MD |   DEBUG1  | +0     | CreateRomTable - Checking for match: "Crash Bandicoot - Warped (USA)" and "(Side"
17:59:30:482 | MD |     INFO  | +0     | CreateRomTable - Ended, 7 Loops to create table.
17:59:30:483 | MD |   DEBUG2  | +0     | Statistics cleared game name: Crash Bandicoot - Warped
17:59:30:521 | MD |   DEBUG2  | +31    | Loaded game statistics from ini files:
				Number_of_Times_Played: 5
				Last_Time_Played: Sunday February 23, 2014 05:50:57 PM
				Average_Time_Played: 36
				Total_Time_Played: 180
				System_Total_Played_Time: 180
				Total_Global_Played_Time: 11906
17:59:30:522 | MD |   DEBUG2  | +0     | Updated Statistics: Number_of_Times_Played: 6
				Last_Time_Played: Sunday February 23, 2014 05:58:41 PM
				Average_Time_Played: 38
				Total_Time_Played: 228
				System_Total_Played_Time: 228
				Total_Global_Played_Time: 11954
17:59:30:557 | MD |     INFO  | +31    | Game section statistics updated.
17:59:30:558 | MD |     INFO  | +0     | ExitModule - Ended
17:59:30:559 | MD |     INFO  | +16    | End of Module Logs
17:59:30:624 | HL |     INFO  | +48812 | Main - Module ended, exiting HyperLaunch normally
17:59:30:624 | HL |     INFO  | +0     | ExitScript - Started
17:59:30:646 | HL |     INFO  | +16    | SystemCursor - Restoring mouse cursor
17:59:30:713 | HL |     INFO  | +62    | ExitScript - Ended
Voyagerxp your running it on a laptop is that right?
I will have to test it also but I think 30 seconds is about right seeing as the game is being extracted then mounted in DT.
The speed at which the game starts will also depend on your PC, if you have a fast processor and an SSD or fast hard drive then it will be extracted quicker.
I found this post amusing. With all the thing hyperspin/hyperlaunch does loading a game in 30 seconds is a long time? It would take you longer to locate the actually CD itself and put it in a playstation and fire it up. All kidding aside...I use to run some of my games over wireless on a network drive to a NAS and larger games would take 60 or more seconds (I use to change the timeout in the modules because it would take so long). 30 seconds on a laptop to extract, mount, launch a emulator seems more than reasonable. Not sure how much faster you need it to be. Are you switching to a different frequently so it seems like a long time to load? Maybe you need more intro vids for your games so you can see what they are about vs loading them up to view them.
30 seconds.......... Seems fast to me.. If you need it faster I would look at your D:\ and see how fast that disk is. IS it a hybrid SSHD? Is it a SSD? Is it a regular 7200RPM drive? Is it not any of these 3 then maybe upgrade that? Get a larger disk so you do not need to compress your games? You can get 4tb for not a lot of money. How fast is it if you do not have it zipped? I would look there too.
Good luck
Ya i'm using a laptop, Asus G73JH gaming laptop with Intel Core i7, 8gb ddr3, ssd C:drive, hybrid ssd D:drive & Radeon® HD 5870. The hyperspin i'm using is a test setup as my main hyperspin is still on 1.0 and wanted to get used to the new features and setup before i change my old setup. ePSXe 1.9 on my main setup does not take this long.
That makes sense. Is it faster without having them compressed? Mine loads in 5 to 10 seconds with no compression. Could save you 20 or so seconds.
Your D:\ is a hybrid drive though based on the specs for the system it doesn't come stock with 2 hard drives. So I am guessing you added one, specifically the hybrid SSD. Is that connected to the computer via a eSata or onboard Sata connection, like inplace of the BDRom? Or are you running that over USB2/3?
Nope, my Asus G73 Came with two sata 500gb 7200rpm hard drives but i swapped them with a 80GB SSD for C and 500GB SSD Hybrid for D. My main HyperSpin setup on my HTPC has a SSD for C with my windows operating system & XBMC and a Seagate Barracuda 4TB 5900RPM SATA 6Gb/s 64MB Cache which as my Hyperspin & roms.
Today updated my main Hyerspin system from 1.0 to latest and my psx roms were still as slow as they were on my laptop but i've found out that it loads quicker with Fade in set to true.
Is fade in just tricking your brain into thinking it's quicker because you've got something pretty to look at? Change the pic to this and see how long it takes.
And then swap it out for this one and see if your game loads quicker.
Saved to camera roll. Will take these to work and see staring at these change my perception of time.
Hold on. Forgot I was typing. Did I say something? I want to tap her on the shoulder so she turns around. Or maybe not the shoulder.
  • 4 months later...
I am having the same problem since updating to RL. Outside of hyperlaunch the games load instantly within epsxe, but for some reason it takes about 45 seconds to even get to the start credits screen of the game when hyperlaunch is used. My games are unzipped to so no time needed for that process. But oh well. After spending a few days just trying to figure this out, doing the git update, then doing some shared.ahk stuff that some other thread suggested, then having hyperspin not launch at all, then having to do a system restore to before I installed git - I'm happy to just have hyperspin working again lol! I can wait the 45 seconds for now. But there is definitely something going on.
i have also the same problem. something in the ahk file ? i think. works quick outside HS but takes 30 to 45 seconds to start from within HS
It is getting hung on on rom map creation. Just FYI, this is fixed in the next HL update. Nothing I can do for you now except try toggling rom mapping to see if it helps.
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • 4 weeks later...
Good luck
No need to be an asshole about it.
Same thing happens to me. The proof in the pudding that it's something to do with Hyperlaunch is that if you launch a rom directly from the emulator it launches instantly.
Yes and it's fixed in the beta.
Sent from my Samsung S3 using Tapatalk
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Will the shark enhanced patch be implemented into the new module release?
Don't know what that is.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
  • 1 month later...
Hi guys, setting Multigame / General options to TRUE didnt fix it here for me, its still around 20-30 seconds to startup from HS. Outside HS it starts imidiately.
Meanwhile, until its fixed, is it possible to add a loadscreen instead activated imidiately after pressing the enter key ?
