badhemi Posted October 31, 2016 Posted October 31, 2016 On 10/31/2016 at 10:21 PM, retrogriff said: Thanks thatman84 i have that pack but some ini files are missing and these are the ones i need like GOG,Popcap,Bigfish Games.I have fifty systems set up with media.Forty seven systems working so far and counting thanks to this forumI don't have those inis because there not currently able to be emulated by android
JoyStickKilla Posted November 1, 2016 Posted November 1, 2016 Dont work as in not all hyperspin themes work in the Android version. Especially ones using swf to get clean(er) 1080 resolution
badhemi Posted November 1, 2016 Posted November 1, 2016 On 11/1/2016 at 12:24 AM, JoyStickKilla said: Dont work as in not all hyperspin themes work in the Android version. Especially ones using swf to get clean(er) 1080 resolutiondid you try mine?
cowgod Posted November 14, 2016 Posted November 14, 2016 I tried the Main Menu.ini from both @thatman84 and @badhemi and they both just show a blank screen. Could this possibly be a media issue and not an ini issue? Does anyone have a working main menu for HyperSpin on Android? 1
thatman84 Posted November 14, 2016 Author Posted November 14, 2016 Sound like a media issue, are you getting the intro video? for main menu you need main menu.xml in Hyperspin/databases/main menu (lists all your systems, case sensitive, matching all your system folders, xml's and settings) images for your main menu system list in hyperspin/media/main menu/images/wheel themes and videos for your main menu go in Hyperspin/media/main menu/themes (& videos) Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
cowgod Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 8:53 AM, thatman84 said: Sound like a media issue, are you getting the intro video? for main menu you need main menu.xml in Hyperspin/databases/main menu (lists all your systems, case sensitive, matching all your system folders, xml's and settings) images for your main menu system list in hyperspin/media/main menu/images/wheel themes and videos for your main menu go in Hyperspin/media/main menu/themes (& videos) Expand Thanks for the reply. Yes, I do get the intro video, and the system menus work fine, just not the main menu. Your zip file does not contain a Main Menu folder in the Media folder, so that must be the issue. Any reason you didn't include it?
badhemi Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 2:46 PM, cowgod said: Thanks for the reply. Yes, I do get the intro video, and the system menus work fine, just not the main menu. Your zip file does not contain a Main Menu folder in the Media folder, so that must be the issue. Any reason you didn't include it?I did not post a main menu ini. What exactly do you need. A main menu theme? Expand
thatman84 Posted November 14, 2016 Author Posted November 14, 2016 Strange I will take a look at the uploaded file Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted November 14, 2016 Posted November 14, 2016 On 10/31/2016 at 10:17 PM, thatman84 said: Are these your Main Menu Themes? the ones I checked looked that way and they are all named as per the system so guessing they are Expand What main menu themes do you need
thatman84 Posted November 14, 2016 Author Posted November 14, 2016 On 10/31/2016 at 1:22 AM, badhemi said: Here is all my system themes see if you need the ones that don't work https://mega.nz/#!HZMmhKAS!em43BHENgJHM--OWbtILIP7DzwckbvKF2UK1KB_iU40 Expand im correct in saying this is your main menu themes @badhemi? I grabbed it and fixed your turbografx 16 one to display the background correctly im good for main menus. I have not really started on default themes for calling in the boxart and stuff. Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 4:56 PM, thatman84 said: im correct in saying this is your main menu themes @badhemi? I grabbed it and fixed your turbografx 16 one to display the background correctly im good for main menus. I have not really started on default themes for calling in the boxart and stuff. Expand Those are my main themes I was confused for a minute. Can you send me the turbo grafx one back as corrected.
badhemi Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 4:56 PM, thatman84 said: im correct in saying this is your main menu themes @badhemi? I grabbed it and fixed your turbografx 16 one to display the background correctly im good for main menus. I have not really started on default themes for calling in the boxart and stuff. Expand Do you need system themes?
thatman84 Posted November 14, 2016 Author Posted November 14, 2016 When my little one is in bed I will try get on the PC, i will probably grab default themes as a project but I setup a universal one for my own system to get me by until I take on that full set project. if you fancy extracting your default themes I won't say no! But for the project I will have to try and keep track to give credits for them as much as possible Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
cowgod Posted November 14, 2016 Posted November 14, 2016 It would be great if we could all work together to make an Android download starter pack that worked perfectly on the first try, and got it sanctioned as an official tutorial. As someone fairly new to HyperSpin, I spent literally all weekend learning about it and setting it all up. I have it all working on PC, but Android is a whole different ballgame and it's not clear at all why some stuff works and some doesn't.
badhemi Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 5:45 PM, thatman84 said: When my little one is in bed I will try get on the PC, i will probably grab default themes as a project but I setup a universal one for my own system to get me by until I take on that full set project. if you fancy extracting your default themes I won't say no! But for the project I will have to try and keep track to give credits for them as much as possible Expand I'll grab them later
badhemi Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 5:49 PM, cowgod said: It would be great if we could all work together to make an Android download starter pack that worked perfectly on the first try, and got it sanctioned as an official tutorial. As someone fairly new to HyperSpin, I spent literally all weekend learning about it and setting it all up. I have it all working on PC, but Android is a whole different ballgame and it's not clear at all why some stuff works and some doesn't. Expand I think it is do to the fact of incompatibility of Windows based items
thatman84 Posted November 14, 2016 Author Posted November 14, 2016 On 11/14/2016 at 5:49 PM, cowgod said: It would be great if we could all work together to make an Android download starter pack that worked perfectly on the first try, and got it sanctioned as an official tutorial. As someone fairly new to HyperSpin, I spent literally all weekend learning about it and setting it all up. I have it all working on PC, but Android is a whole different ballgame and it's not clear at all why some stuff works and some doesn't. Expand That was my attempt with the base pack. Problem is you should really treat Android as a stanalone setup because there is way more stuff you can do with a windows setup. Just keep all the ROM's in one place for both and have 2 sets of media/settings Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
cowgod Posted November 14, 2016 Posted November 14, 2016 On 11/14/2016 at 6:51 PM, thatman84 said: I Think the reason you didnt have the Main Menu was because you did not download all parts! You need to download all the parts of the Base Pack I created and Combine them. There are file size limits on the site so it had to be split. Main Menu media is in the Media.zip Expand Oh! You're right, I never saw a Media.zip file. Where is that one located? I don't see it linked anywhere.
thatman84 Posted November 14, 2016 Author Posted November 14, 2016 Click the Hyperspin Android Base Pack link in the 1st post tutorial. Give that a read and click on Donload. You will have a list of all the files including the help text files and settings folder 1 Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
cowgod Posted November 15, 2016 Posted November 15, 2016 I found the Media.zip file and was able to successfully get the main menu to load with the folder in place. Thank you! I am getting very close to a fully working system now--I just have to figure out why the RetroArch configs don't always save properly.
thatman84 Posted November 15, 2016 Author Posted November 15, 2016 Cool don't lose hope man! retroarch configs are a real pain unless you root your device ( I didn't want to) Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
badhemi Posted November 16, 2016 Posted November 16, 2016 On 11/15/2016 at 8:31 AM, thatman84 said: Cool don't lose hope man! retroarch configs are a real pain unless you root your device ( I didn't want to) Expand https://mega.nz/#F!2VklEYqT!GyVFnCdgM6c_RgfItDCevQ 1
butagaz Posted November 18, 2016 Posted November 18, 2016 NEED HELP hello I've specially baught a Tegra 4i android 4.4 smartphone called Wiko Highway 4g, who is technicaly compatible with hyperspin android like required specifications says. I follow your installation guide, but unfortunatly it doesn't work : at starting application I've a message saying that application closed. So i've still the hope to run HSandroid on my Tegra smartphone... There is some 3rd party software to install or something else ? Or there is some settings to configure ? Thanks for your returns
Pouteur Posted November 18, 2016 Posted November 18, 2016 Salut Butagaz, en fait je pense qu'il faut que ton téléphone soit compatible avec opengl3 aussi.
badhemi Posted November 18, 2016 Posted November 18, 2016 On 11/18/2016 at 7:32 AM, reznnate said: Sounds awesome. Will it require a bunch of individiual batch/text files PER game that point to specific files on storage? This was the only way I found and I didn't want to bother with creating a bunch of files that had fixed paths. Expand On 11/18/2016 at 7:36 AM, gigapig said: Well done. I spent the evening trying to get the controls working for Amiga using the Ultrastiks. The directions were fine it was the save/load buttons etc that I had trouble with. But after enough clicking it worked. Expand Wonder why atari 5200 doesn't like alternate method in mame option settings
Create an account
Register a new accountSign in
Sign In Now
