VanZan Posted April 7, 2020 Posted April 7, 2020 Thanks for the replies. Ok so I need either the latest 64 bit of RetroArch OR an older, pre 64 bit, version of the 32bit? Most bizarre since I have things working fine on my old Shield Portable with 32 bit RetroArch. Perhaps because that's ARM whilst the Shield TV is ARM64? I'll have to experiment some more later today.
thatman84 Posted April 7, 2020 Author Posted April 7, 2020 Android OS forced apps to only release to play store in 64bit. RetroArch doesn't have as many or as good 64bit cores. Official Hyperspin Tutorials Playlist HS Android Overview & Install HS Android Base Pack Download My Tutorials
sfanetti Posted April 7, 2020 Posted April 7, 2020 I have THE SOLUTION for retroarch issue. I had tested a while ago. If you have installed any version after the 1.7.7 (32 bit), you have to RESET completely your Shield Tv for fix. I tried now and the fix is ok. You are not able to install a newer version in 32 bit or to downgrade to 32 bit. probably remain certain files that are unable to config correctly retroarch. I repeat, the ONLY solution is to reset completely tour shield tested now for me and I'm very happy.
VanZan Posted April 7, 2020 Posted April 7, 2020 Thanks for that. I've been trying 1.7.7 without success. There's no way I'm resetting though. I do have root so maybe I can still delete what needs removing without resetting? Otherwise I just can't get HyperSpin to work with RetroArch on the Nvidia Shield at all. Have tried 64bit and 32bit versions. Like I said tried the 32 bit 1.7.7. Gonna give up and hope there's an easier fix down the road.
sfanetti Posted April 8, 2020 Posted April 8, 2020 Probably yes, but I don't know where are the files to delete. If you are able, tell me where and how. Thank you
kimondevil Posted December 29, 2020 Posted December 29, 2020 Hi Everyone, Can someone please help me with how to setup Final Burn Alpha on the Nvidia Shield? I have been looking at this and just cant find an answer. I have MAME working fine and the setup I am using is Bandits No Clutter. The wheel has MAME and this is further sub categorised with other aspects like shootem ups, fighting etc. However, although my FBA folder has a test rom in in it does not show up in the wheel. Do I need to use Rocket Launcher? I also have the Database file in there and also the XML file and ini file. Is there something simple I am missing? Thanks for any guidance.
Create an account
Register a new accountSign in
Sign In Now
