I need help installing hyperpin
supercomputertyler
Hello I am new to hyperpin so I am sorry if these questions have been answered but I cant seem to find any thing on this
I am trying to set up hyperpin so I can build a cab, I want to configure it with visual pinball, I dumped all my directb2s and jpg back glass files in the media folder, all my play field jpgs in the table images folder in media and all the wheel images in the folder and I configured the settings ini file with those folders and with my install of visual pinball and and the tables, I made sure that the table name matched that in the database xml and with all the images and back glass files, but when I try running hyperpin the images do not show up on either screen, When I try opening a table it gives me an error noise and error message but it disappears so quickly its impossible to read.
this is what it put in the log file
12:47:32 PM |  HyperSpin Started
12:47:32 PM |  Setting up monitors
12:47:32 PM |  Starting Backglass
12:47:32 PM |  Startup Program Unvavailable
12:47:32 PM |  Visual Pinball.xml found
12:47:32 PM |  Dual monitor found
12:47:46 PM |  xml loaded
12:47:46 PM |  Visual Pinball.xml found
12:47:46 PM |  Loading wheel images
12:47:46 PM |  Entering  Menu
12:47:50 PM |  Pausing Animations
12:47:50 PM |  Running FPLaunch.exe
12:47:51 PM |  Command Line is: FPLaunch.exe "Visual Pinball" "Apollo 13"
12:47:59 PM |  Pausing Animations
12:47:59 PM |  Running FPLaunch.exe
12:47:59 PM |  Command Line is: FPLaunch.exe "Visual Pinball" "Apollo 13"
12:48:09 PM |  Pausing Animations
12:48:09 PM |  Running FPLaunch.exe
12:48:09 PM |  Command Line is: FPLaunch.exe "Visual Pinball" "Apollo 13"
12:48:32 PM |  Pausing Animations
12:48:32 PM |  Running FPLaunch.exe
12:48:32 PM |  Command Line is: FPLaunch.exe "Visual Pinball" "Apollo 13"
12:48:48 PM |  Quiting program
12:48:48 PM |  Exit Program Unvavailable
12:48:48 PM |  Bye!
Any help at all would be very nice, Thank you in advance
I'm not familiar with Hyperpin but I know some members of this forum have set it up on their end. I'm sure someone will post a reply but right now the traffic on the site is kinda low.
29 minutes ago, supercomputertyler said:
thanks, I just figured out the artwork but I have no idea how to get them to launch
How to get VP tables to launch? I don't know but did you already check the RocketLauncher module instructions?
I tried downgrading fp launch to 1.29 and now the tables boot however when i boot a table it makes an obnoxious nocking sound every second or so, and it doesn't stop until I close fp launcher in the task manager does anyone know how to fix this
you should forget about HyperPin and use PinballX
HyperPin can only launch Future Pinball and ONE version of Visual Pinball.
if you like to run FX2 you will have to launch the tables as a Future pinball table,  I'm not sure you can use the command version of FX2.
whats worse, is that you cannot launch VPX tables directly,  you have to change the extension of the tables to VPT or you will not be able to use them.
It would be nice if you could use RL with HyperPin,  but you cannot add more systems to HyperPin.  It's Future Pinball and Visual Pinball and that's it!!!!
this is why you have to add FX2 to your Future Pinball XML.
  • 3 weeks later...
i have installed
AutoHotkey
B2S Backglass Server 1.3.0.1
Direct X 9.0c
B2S_ScreenResEditor.exe
Net Framework 3.5 includes 2.0 and 3.0
NET Framework 4
for XML i use   Hyperpin Editor.exe
Compatibility mode for hp same as for vp
i dont use uvp
only b2s with 2 monitors
settings for 2 monitors
1680
1050
1680
1050
2
200
