IPAC or USB interface ?
smoothop
it depends on your needs and on the emulators you are using because their are pros and cons to both devices
Ipac
an ipac is a keyboard encoder, meaning every time you press a button,;   the assigned character in a keyboard will be triggered.
although their are multiple fixes,  you will encounter a few problems with this set up.
the main one is when you are playing 2 player fighter games and you press multiple buttons causing your MAME emulator to close.
or
a few Taito Type X games that don't like keyboard keys.
USB interface =  aka  Joystick Encoder
windows will see this device as a generic joystick
you will find this in your devices window
most emulators support joysticks now
the only problem with a joystick encoder is that Hyperspin joystick support is flaky at best.  but their is a work round.
 You disable "Joystick support"  in Hyperspin  and launch this plugin when you launch Hyperspin.  It will map your joystick to control Hyperspin without any problems.
