How do you remove games in a wheel so they don’t display?
mamemaniac
Either edit the database and remove games not required, or set wheels only in hyperhq and remove the wheelart.
probably other ways but these 2 are easy.
If I remember right you can also just filter it to show Roms only right in the Hyperspin/HyperHQ settings.
Just remember that to use filters you need to add the path to your roms into HyperHQ as well
  • 1 month later...
I'm trying to do this in HS now to only display ROMs that are available and am having issues. Under the MAME wheel settings in HQ I set the path to the ROMs and Executable and then, under wheel filters I have it set to "ROMs Only". When I pull HS and select the MAME system it just bounces back to the main menu without showing any games at all.
I ran an audit to confirm the system identifies the ROMs but no luck. Any thoughts?
Put the rom path and extensions.... not the executable!
This
