Avenger Posted June 25, 2018 Posted June 25, 2018 Does Hyperspin support the categories in catver.ini or is there something equivalent available? I like to keep a full .198 Rom set on my PC and be able to select a list of baseball games or wrestling games for example. Does Hyperspin provide that degree of filtering? Thanks.
Avenger Posted June 26, 2018 Author Posted June 26, 2018 16 hours ago, Avenger said: Does Hyperspin support the categories in catver.ini or is there something equivalent available? I like to keep a full .198 Rom set on my PC and be able to select a list of baseball games or wrestling games for example. Does Hyperspin provide that degree of filtering? Thanks. Search deeper, I see there were some tutorials to create a genre wheel which should work also for mame. The posts/tutorials are a few years old. Are they still valid? They involve using a tool (Don's tool?) to create the list.
thatman84 Posted June 26, 2018 Posted June 26, 2018 Don's filter list and other tools in the 3rd party apps section can export xml lists based on the filters you select. Genre xmls are created based on the tags in your main mame.xml which could be outdated. Try the official mame xml thread. Phulshof creates bundles of mame xmls of all flavours every release. The guides are still valid as HS has not changed much for years. Hyperspin 2.0 Latest Download Hyperspin 2.0 Documentation -------Pre Hyperspin 2.0 Below---------- HS Android Overview & Install HS Android Base Pack Download My Tutorials
Rowr14 Posted June 26, 2018 Posted June 26, 2018 There might be other ways out there but I found romlister works well. It supports catver and you can output for Hyperspin friendly xml. Then run it through dons tools with mamelist to add the metadata. This tutorial for separating for genres for Retroarch has some pretty good info on how to use it and they have done a lot of the hardwork in tidying up and working out what to filter. I've been through on my own terms gone through and created many custom genres with this program. Edit - +1 for phulsofs lists if the above is a bit more than what you are looking for.
gigapig Posted June 26, 2018 Posted June 26, 2018 Like ThatMan said, I use Phulshofs xmls from RetroFE.com
phulshof Posted June 26, 2018 Posted June 26, 2018 54 minutes ago, gigapig said: Like ThatMan said, I use Phulshofs xmls from RetroFE.com That would be retrofe.nl
