Jedediah79 Posted July 18, 2018 Posted July 18, 2018 I have watched 6 videos and read countless pages and I just cant launch a game in HyperSpin can someone help me please log.txt
Jedediah79 Posted July 19, 2018 Author Posted July 19, 2018 sorry i put this in the wrong spot i dont know how to delete it
Aorin Posted July 19, 2018 Posted July 19, 2018 1 hour ago, Jedediah79 said: I have watched 6 videos and read countless pages and I just cant launch a game in HyperSpin can someone help me please log.txt You can try this video. Remember that the Frontend usually provides you the interface basically, most, I mean 99% of the configuration that will actually launch the emulators, PC games and such are set in RocketLauncher. The more information, the better for us to help. Feel free to post your difficulties here. Aorin
ninja2bceen Posted July 19, 2018 Posted July 19, 2018 Ive created a channel on YouTube to dedicate to tutorials. I’m busting out videos like crazy. Grant it they are all the add ons so I assume you have a basic set up going Check out the channel, plenty more to come. Please subscribehttps://www.youtube.com/user/mjustin9Sent from my iPhone using Tapatalk Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
Jedediah79 Posted July 19, 2018 Author Posted July 19, 2018 I have RocketLauncher setup and I have the setings.ini set to the RocketLauncer location Settings.ini [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=Nintendo Entertainment System Hyperlaunch_Path=F:\RocketLauncher\RocketLauncher.exe HyperSpin Log 07:46:44 PM | HyperSpin Started 07:46:44 PM | Going windowed mode 07:46:45 PM | Checking for updates 07:46:45 PM | Update Check Complete 07:46:45 PM | Startup program unavailable 07:46:45 PM | Playing intro video 07:47:03 PM | Error intializing joysticks 07:47:03 PM | Menu Mode is multi 07:47:03 PM | Loading Main Menu.xml 07:47:03 PM | Main Menu.xml successfully loaded 07:47:04 PM | Main Menu wheel loaded successfully 07:47:05 PM | Loading Nintendo Entertainment System.xml 07:47:05 PM | Main Menu.xml successfully loaded 07:47:05 PM | Nintendo Entertainment System wheel loaded successfully 07:47:11 PM | Launching Game 07:47:11 PM | Using HyperLaunch 07:47:11 PM | Getting Launcher path 07:47:11 PM | Launcher located at F:\RocketLauncher\RocketLauncher.exe 07:47:11 PM | Running Launcher 07:47:11 PM | Launcher Command Line is: F:\RocketLauncher\RocketLauncher.exe "Nintendo Entertainment System" "3-D WorldRunner (USA)" 07:47:57 PM | Loading Main Menu.xml 07:47:57 PM | Main Menu.xml successfully loaded 07:47:57 PM | Main Menu wheel loaded successfully 07:47:59 PM | Exit program unavailable 07:47:59 PM | Quiting Hyperspin 07:47:59 PM | Bye! And this is what i get
Spawk Posted July 20, 2018 Posted July 20, 2018 HS log is of no use in this case. You would need to post an RL log (set to troubleshooting). And it's probably better to post it over on the RL forums (use pastebin) although there may be someone here who can help. I can say that the general workflow is: 1. make sure game loads in emu itself (or it will never run through HS/RL) 2. make sure game loads through RL (or it will never run through HS) 3. then try game in HS If you are only stuck on #3, then there is a really high chance it's a setting in HQ. Do you use any filters? Do you have rompath and extensions set (but NOT emu path!)?
Jedediah79 Posted July 20, 2018 Author Posted July 20, 2018 8 minutes ago, Spawk said: HS log is of no use in this case. You would need to post an RL log (set to troubleshooting). And it's probably better to post it over on the RL forums (use pastebin) although there may be someone here who can help. I can say that the general workflow is: 1. make sure game loads in emu itself (or it will never run through HS/RL) 2. make sure game loads through RL (or it will never run through HS) 3. then try game in HS If you are only stuck on #3, then there is a really high chance it's a setting in HQ. Do you use any filters? Do you have rompath and extensions set (but NOT emu path!)? It loads in the emu it loads in RL I have the emulator path set and the rom path set HS just doesn't do anything when I try and open a game
Jedediah79 Posted July 20, 2018 Author Posted July 20, 2018 Ok so i gave RL administrative rights and it launches the emulator for a second the game starts but it then just kicks me back to the whell.
Jedediah79 Posted July 20, 2018 Author Posted July 20, 2018 I have set the emu path in HQ and the rom path in HQ that didn't help the emu launches I see the game start to run and then I'm back in HS
Spawk Posted July 20, 2018 Posted July 20, 2018 Maybe I could have been clearer, do NOT set an emu path in HQ! Settings in here are just to populate the wheel (rompath and extension). I am not sure why it messes things up since RL is doing the launching but it just does.
Jedediah79 Posted July 20, 2018 Author Posted July 20, 2018 1 hour ago, Spawk said: Maybe I could have been clearer, do NOT set an emu path in HQ! Settings in here are just to populate the wheel (rompath and extension). I am not sure why it messes things up since RL is doing the launching but it just does. Ok I took them out of HQ but its still the same, I appreciate the help, I tried another game and it gave me the start up screen but then kicked me back to HS
32assassin Posted July 20, 2018 Posted July 20, 2018 why exactly do you need to give any program administrative rights if your emulator is staring to the point where you can see a start up screen then You should launch HS and your emulator in window mode to see if you have any pop up windows that kill your emulator when loading. and you should consider reducing your user account control settings on your windows environment so that you do not need to give permissions to programs you have installed
Spawk Posted July 20, 2018 Posted July 20, 2018 I hate to be nit picky, but not sure what you mean by "them". I only wanted you to take out the emulator path, the other two are needed if you plan to use any filters. Anyway, I am not that good with the logs so hopefully someone will look at the one you posted on the RL forums. It sounds like the emulator is in fact loading though, just behind HS???? I also notice that you are running things from ../user/desktop/ I am sure you will have to run as admin for anything in any "system" folder. I would recommend staying away from any directory made by windows.
Jedediah79 Posted July 21, 2018 Author Posted July 21, 2018 Thank you all for the help the guys over at rocketlauncher said everything on there end looked good and that I hit the button to exit the emulator although the only button i pressed was the one to launch the game. This is not the final setup I'm going to run this on so I think I'll set up the computer I'm going to run it on and see if I can get it working on that computer.
xinside Posted July 21, 2018 Posted July 21, 2018 The same thing was happening to me. When I tried to start a game it went back to the wheel. 1. Try starting the game in mame itself to see if there is any bios missing for said games. If so, get them. 2. where you set the emulator and rom paths in HQ there is an option that says "extensions" and you have to put zip, 7z in that window. Those were my two problems. After I fixed that, it stopped. I have the rom/emu path set in both RL and HQ and mine works fine. Not sure if it would help but like I said, same problems for me until I did what I did.
