I have the same problem as gwjrabbit in post #275. When I exit VP with FPLaunch v1.295, my DMD and UltraVP don't exit properly when mapping exitEmulatorKey to Joy8 or E in the Settings.ini file. This worked properly in v1.20. I have bring up a task bar, and kill the processes off. I get the same behavior in either HyperPin or directly in VP.
I'm running VP v9.1.2, UltraVP 6.0.8, and FPLaunch v1.295 with a nanotech controller/plunger.
Any ideas?
When you run VP without HP, how does exit key on pinball wizard work -
a) you have to press it for 3 seconds and then table exits
or
B) table exits as soon as you press exit key?
And when you exit do you go to vp editor or you exit all the way out to windows (by the way is it win7 or xp)?
And when you do this without hp, uvp stays running, right?
So if it is a) you exit only after 3 seconds then it means you can exit clean with short press on exit and then 1 or enter, and you get uvp crash only when you hold esc for exit321 screen? Then you could tune exit process so it is quicker with parameter fadespeed. Fadespeed is sleep time in miliseconds, after 100 fadespeed sleeps you exit the table, default is 25, x100 = ~2500 miliseconds, together with time spent on calculations it could be more then 3 seconds so vp exits before i have a chance to kill it my self.
So if you put fadesleep to ~5 - ~10 you will exit in ~half a second before vp gets exit signal, so i will be able to close it my way (which is by closing editor window which is more clean way).
If it is B) you are exiting right away as soon as you press exit key then you have to change it in PBW configuration or in VP configuration. There should be some util to config this for pbw. So your configuration has to be such that when you play in VP without hyperpin in the background you CAN'T EXIT with exit key. When you do that you can configure exitemulatorkey and start testing with HP and fplaunch, and it should work with "joy8" or "e", both is ok.
Same thing is with fp, you must not configure fp so that joy8 exits. You must remove joy8 as exit key from fp configuration.
All this problems come from two major limitations of ahk, ahk can't stop joystick buttons and it can't send joystick buttons. And pinball wizard actually sends joy8 button and some software like joy2key translates it to esc, and no ahk script can stop it, so you have to config it different in pbw and vp and fp first.
Posted (edited)
i tried today on a cab with full hd lcd
i did not see any drop during the game (after pressing esc), but there is a drop regarding running vp without hp
first fp is on start, second is after starting game an keepin the ball in the plunger
Without hp:
afm 1100 900
panthera 1400 800
with hp and new fplaunch:
afm 600 630
panthera 700 650
hp, new fplaunch, all false:
afm 600 850
panthera 700 730
only hp running in back, no any fplaunch running, vp is started manualy
afm 700 870
panthera 1000 800
so it looks like fplaunch takes some fps, and hp takes only few fps
will have to try 1.0 version also to see what can be done to minimize fps loss
Hey blur. I had a little play with the fps that are lost once a graphic has been displayed and managed to fix it. *It was quite a lot of experimenting but this is what worked in the end:
(1) in the method that creates the loading graphic do a destroy
at the end. No fps is lost after loading a table.
(2) changed the create loading screen sub-routine to only create one image for the one requested by the caller. *Before doing so it destroys the previous graphic.
(3) in the loop that displays the 3 loading images I replaced each of the 'GUI n show' statements to instead call the sub-routine to create the loading image for the given parameter.
With these changes no FPS is lost despite how many time the Pause/Editing window is launched for one table. The whole thing is quite odd as it only affects some tables.
I do get some flicker with the 321 countdown but it is ok. The whole thing seems to relate to garbage collection but where you garbage collect appears to be important. You mat find a cleaner solution but just wanted to share my findings with you. I am not at home now, but if you want my sample script them please pm me and i will send it over to you experiment with. Cheers
Excuse the typos - typed on a iPod touch :)
Edited by settingsons
Tidied up and corrections
or
A - VP exits after about 3 seconds of holding the Joy8 button.
When it exits, VP completely exits (dies?), and all I'm left with is the UVP and DMD.
I'm running Vista (ick) Home Premium SP2. I was too cheap to upgrade it to 7, and too lazy to pull out my old XP Pro CD and reimage the box. Now I've got too many tables configured to want to start all over again.
From HP, if I tap the exit button, then press 1 or Enter, the game does exit cleanly. However, all I have is the "joystick" keys, so that doesn't help much, but maybe helps explain what's happening to you.
I tried messing with the fadesleep values. I tried 1, 5, 10, 25, 35, 100, and didn't see any difference.
I've seen many others say they're happy with the ipac controller. Should I just bite the bullet and drop the $40 and get a controller and map my buttons with it? With as many hours as I've spent on this, maybe dropping $40 is the easy way out. I'd still use the nanotech controller for tilting and plunger control, but would I avoid these issues by using the ipac for my buttons?
MikeN
you must have same resolution in vp, fp and in windows.
if they are not loading screen goes to the side.
Turns out it's not the resolution of the monitors - that was set correctly.
It's just that the Windows 7 taskbar on the main screen clip region somehow also through the load screen window, even though it's not actually drawn. It just masks it.
I moved the taskbar to the second monitor and now the entire load graphic is shown.
great, glad you solved it!
Posted (edited)
Many people work happily with PBW so i see no reason to buy ipac.
For fadespeed value you should see slower or quicker change of exit 321 screens - you don't see it? maybe sleep doesn't work on vista? You did change fadespeed line in settings.ini?
You can find this part of code:
            if (loopVal = [b]10[/b]) {
               if (Paused = 1) {
                   if (systemName = "Future Pinball")
                       GoSub PauseFP
                   else
                       GoSub PauseVP
               Gosub CreateExitScreen
                   GoSub CreateBlackScreen
               Gui, 3:Show
           } else if loopVal = [b]40[/b]
               Gui, 2:Show
           else if loopVal = [b]70[/b]
               Gui, 1:Show
           Sleep,  %fadespeed%
           if (loopVal = [b]100[/b]) {
               if (systemName = "Visual Pinball")
                   GoSub, CloseVP
               else if (systemName = "Future Pinball")
                   GoSub, CloseFP
               break
and change bolded numbers (number of loops before exit) to 5, 10 15, 20 or 10, 20 30 40, and recompile ahk. Then you should be able to exit before VP gets exit key.
For "esc" "1" and "enter" keys - they are all configurable with lines:
exitEmulatorKey= Esc
exitEmulatorKey2= 1
exitEmulatorKey3= Enter
in settings.ini.
Just change them to any button like:
exitEmulatorKey= Joy8
exitEmulatorKey2= Joy7
exitEmulatorKey3= Joy6
The idea is to use start (1) and plunger (enter) buttons from your cab ie from your PBW so check what is button number for start and plunger and set them.
Edited by blur
Posted (edited)
Ok, I think I may have found a possible bug. I'm only running HP on a single screen, so I have the playfield and DMD showing. Running the original 1.1 FPLaunch my DMD shows on top of the table. Tried 1.13 since that is the first MOD and it shows up on the table. I then upgraded to 1.294, and now my DMD blinks for a second, and then disappears behind the table when the table loads. Alt-Tabbing brings it back to the front. But, once I click to focus the playfield again it disappears. I then upgraded to 1.295wip2, and it still has the same issue.
So I put my original FPLaunch and settings.ini file back in and it shows correctly. I've been trying to figure out what it was for almost a week now. But, I'm pretty sure it's FPLaunch MOD doing it. I'm thinking it has to do with the new graphics files showing on screen, since the 1.294 is when the issue arose. I tried setting the useLoadScreen to false, but it still happens.
Recap:
1.1 - DMD shown on playfield.
1.13 - DMD shown on playfield.
1.294 - DMD blinks then disappears behind table.
1.295 wip2 - DMD blinks then disappears behind table.
Edited by HyphyCus
Posted (edited)
you're welcome :)
hyphy i know for this problem - it works on two screens but not on one
problem is that i added:
winactivate backglass (uvp backglass),
winactivate dmd,
winactivate playfield
after start of every table
this is done to make dmd appear in front of backglass, and it works fine if dmd is on backglass window
if it is on playfield it stays under the playfield
probably it's better not to touch anything and leave to vp and uvp to open windows in order they like
you can remove all this commands and recompile, here is how it should look after commenting these lines:
    WinWaitActive, ahk_class VPPlayer ;Wait for vp to be Ready before killing Gui blackScreen
   ;WinActivate, ahk_class TBackglass
   ;WinActivate, ahk_class MAME
   ;WinActivate, ahk_class VPPlayer
   Gui, Destroy
   Process, WaitClose, %executable%
i also find it better this way cause often some table puts dmd on playfield and then you don't see it, and you have to do alt-tab
i don't know how it will work for people that get backglass cover dmd, but for me it's better without these commands, maybe i will remove them in next release
proper way as you all know from your own experience with vp would be to activate dmd (alt-tab) and then click on dmd and then click on playfield, that makes dmd stay over the table, but i did not find a way to click in a window, only in coordinate and i don't know the coordinates where dmd would be
maybe it is doable with some ahk scripting
usually setting vpinball.exe to nt 4.0 sp5 compatibility mode solves this problem with dmd - but those commands still have to be removed cause they are not needed then.
Edited by blur
   Gui, Destroy
I commented those out as shown above (hopefully it's correct), and recompiled and it still does it. I had my VPinball.exe already at NT4 compatibility so I didn't need to change that. Just for reference I'm on VP912 and Win7x64.
Do you still have one blink of dmd and then it disappears?
Do you have dmd hidden when you run VP outside of HP?
I don't do win 7, but this should work the same in win 7 and xp.
Correct. It blinks once, and then disappears. My DMD is shown when I run it in VP. It's weird because Ill bring it back to the front by alt-tabbing, but when I click back to the playfield to play the table it pushes it back again.
If it blinks you did not removed winactivate from the right place.
What version did you edit?
It's easier with 295 wip 2, you just search for this comment
and comment lines after that
in 294 you have to comment win activate on several places
to solve the problem in game - you alt-tab to dmd, then click on dmd, then click on playfield - try it, it should bring dmd in front and give focus to vp
Posted (edited)
I edited 1.295wip2. And I did the correct lines as I listed in the code 2 posts above. That was copied from my ahk. I did compile too. Doing the quick solve as you suggest always brings the focus back to the playfield and hides the DMD.
EDIT: Ok, I deleted the nvram of a few tables, then reran the games and now they show up. I don't know what happened there, but they seem to show up now. I had a clean install of VPinball and HP I was testing this on, so something saved weird. But, the new code seems to work now. Thanks for the help! I couldn't use HP without the load screens, they are awesome!
Edited by HyphyCus
Posted (edited)
here is the new version 1.295 wip 3
download from megaupload:
http://www.megaupload.com/?d=HR79NG2H
or if mega is too busy:
http://uploading.com/files/e1294955/FPLaunch1.295wip3.zip/
new features are:
slamit support
winactivates removed
reduced time for exit screens (so pinball wizard should not exit)
about fps drop - i have one new gui destroy in loadscreen, but gui destroy was executed before also right after exit from loadscreen
i tested fps drop on pause window a little and main reason for fps drop is change of focus, i get same fps drop when i just go from vp to explorer many times, so this is probably due to vp, not due to fplaunch
* FPLaunch MOD Version 1.295 WIP 3
TO DO:
Fixes
+ fix runtime error on close (set exe to comp mode)
+ fix dmd not visible behind playfield (set exe to comp mode)
+ fps drop - same drop comes from loose of focus
+ shorter time for esc screens
- fix slow down after close (vp still closing)
- fix late printscreen in fp
New features
+ win activate of secondary fp window - doesn't help
+ put version in usage
+ bigboss additions (more exe files, sound mods ...)
+ support for slamit pinball
- while loading esc should be quick kill and exit
- save printscreen-a under name taken from description
- fp auto positioning
- new images with new text
* Modified by dumpster.monkey (samwyze) & blur
* Based on original FPLaunch 1.2 by BadBoyBill
* Includes modified pause code from ManoWars Nuevo FPLaunch 1.2
* Includes exit png's based on jpg's from BBB's 'exit feature' thread
* Includes support for Pause on Exit by blur
*   Esc and then 1 or Enter exits, Esc and then Esc again takes you back to the game
* Includes support for Pause in FP by blur
*   For pause to work in FP you have to assign right mouse button to pause in FP
* Includes support for saving FP table position (scrolllock) on exit by blur
* VP nag screen removal by blur
* All images are to be placed in %HyperPinDir%\Media\HyperPin\Images
* These settings are automatically added to your settings.ini
* file in the %HyperPinDir%\Settings folder on first start:
*   [FPLaunch]
*   exitScriptKey    = q & s
*   exitEmulatorKey  = Esc
*   toggleCursorKey  = t
*   pauseVPinball       = p
*   hideCursor       = true
*   hideDesktop      = true
*   hideTaskbar      = true
*   useExitScreen    = true
*   usePauseKey      = true
*   useLoadScreen    = true
*   fadespeed        = 25
*   useExitAsPause   = true
*   exitEmulatorKey2 = 1
*   exitEmulatorKey3 = Enter
*   pauseFPKey       = RButton
*   saveFPTables     = true
* NOTE: This is a wip and is by no means complete or optimized
* Feel free to disect, mod, clean, optimize, distribute or delete!
* Autohotkey script by BadBoyBill  [email protected]
* CursorHide by Lazlo
* If you are reading this and do not have autohotkey you can get it
* @ http://www.autohotkey.com/download/
* If you would like to modify this script and share it thats OK, but
* see if your modification is something that we would like to add
* to the official version.
* Refer to the autohotkey documentation for the keyoboard keylist
* If this script does not support your favorite emulator
* then please request support @ http://www.hyperspin-fe.com/forum
* Supports Future Pinball and Visual Pinball
#SingleInstance force      ;Prevent multiple instances
#InstallKeybdHook
#InstallMouseHook
#UseHook
#KeyHistory 500
#MaxThreadsPerHotkey 1
SetTitleMatchMode 2        ;Use relaxed title matching
#NoEnv  ; Recommended for performance and compatibility with future AutoHotkey releases.
SendMode Input  ; Recommended for new scripts due to its superior speed and reliability.
SetWorkingDir %A_ScriptDir%  ; Ensures a consistent starting directory.
DetectHiddenWindows on
;*                  EDIT BELOW THIS POINT AT YOUR OWN RISK                     *
;                       GET PARAMATERS AND SET HOTKEYS                         ;
;CHECKING FOR 2 PARAMS, IF NOT THEN EXIT
if 0 < 2
   MsgBox FPLaunch v. 1.295 WIP 3`nUsage: FPLaunch.ahk/exe "System Name" "Rom Name"
   ExitApp
systemName = %1%
tableName = %2%
hyperini = %A_ScriptDir%\Settings\Settings.ini
picDir = %A_ScriptDir%\Media\HyperPin\Images\
;                              GET AND CHECK PATHS                             ;
GoSub, CheckINI
IniRead, iniEmuPath, %hyperini%, %systemName%, Path
emuPath := GetFullName(iniEmuPath)
IniRead, iniTablePath, %hyperini%, %systemName%, Table_Path
tablePath := GetFullName(iniTablePath)
IniRead, executable, %hyperini%, %systemName%, Exe
iniKeys = exitScriptKey,exitEmulatorKey,hideCursor,toggleCursorKey,hideDesktop,hideTaskbar
,useExitScreen,usePauseKey,pauseVPinball,useLoadScreen,fadespeed
,useExitAsPause,exitEmulatorKey2,exitEmulatorKey3,pauseFPKey,saveFPTables
Loop, parse, iniKeys, `,
     IniRead, %A_LoopField%, %hyperini%, FPLaunch, %A_LoopField%
romExtension =
GoSub, CheckPaths
loadspeed := fadespeed * 10
Hotkey, %exitScriptKey%, ExitScript
; we use loading screeen dimentions for all screens
;If  (useLoadScreen = "true") {
   ProgBar = 0
   gui, 99:add,picture,hwndloadpic, %A_ScriptDir%\Media\HyperPin\Images\Loading.png
   controlgetpos,,,wLoad,hLoad,,ahk_id %loadpic%
   gui, 99:destroy
   wLoad := Round(wLoad*A_ScreenWidth/1280)
   xLoad := Round(A_ScreenWidth/2-(wLoad/2))
   hLoad := Round(hLoad*A_ScreenHeight/800)
   yLoad := Round(A_ScreenHeight/2-(hLoad/2))
   wLoadProgress := Round(20*A_ScreenWidth/1280)
   xLoadProgress := Round(145*A_ScreenWidth/1280)
   hLoadProgress := Round(194*A_ScreenHeight/800)
   yLoadProgress := Round(288*A_ScreenHeight/800)
;If  (usePauseKey = "true") {
   Paused = 0
;    PausePic =
;    gui, 98:add,picture,hwndpausepic, %picDir%\Media\HyperPin\Images\Pause.png
;    controlgetpos,,,wPause,hPause,,ahk_id %pausepic%
;    gui, 98:destroy
;    wPause := Round(wPause*A_ScreenWidth/1280)
;    xPause := Round(A_ScreenWidth/2-(wPause/2))
;    hPause := Round(hPause*A_ScreenHeight/800)
;    yPause := Round(A_ScreenHeight/2-(hPause/2))
;If  (useExitScreen = "true") {
   Exiting = 0
;    Exit =
;    gui, 97:add,picture,hwndexitpic, %A_ScriptDir%\Media\HyperPin\Images\Exit_1.png
;    controlgetpos,,,wExit,hExit,,ahk_id %exitpic%
;    gui, 97:destroy
;    wExit := Round(wExit*A_ScreenWidth/1280)
;    xExit := Round(A_ScreenWidth/2-(wExit/2))
;    hExit := Round(hExit*A_ScreenHeight/800)
;    yExit := Round(A_ScreenHeight/2-(hExit/2))
if (hideCursor = "true")
 MouseMove %A_ScreenWidth%,%A_ScreenHeight%
 Hotkey, %toggleCursorKey%, ToggleCursor
 SystemCursor("Off")
if (hideTaskbar = "true")
 WinHide, ahk_class Shell_TrayWnd
 WinHide, Start ahk_class Button
if (hideDesktop = "true")
 Gui, Color, 000000
 Gui +AlwaysOnTop -Caption +ToolWindow
 Gui, Show, x0 y0 W%A_ScreenWidth% H%A_ScreenHeight%, BlackScreen
WinClose, cmd.exe
;                                  RUN SYSTEM                                  ;
;**********************************FUTURE PINBALL***********************************
if (systemName = "Future Pinball") {
 ; big boss bigscore
 if(tableName = "BigScore") {
   Hotkey, $%exitEmulatorKey%, CloseSlam
   ;Remap some keys (enter to down arrow for plunger, 1 to s for start, 2 to 1 for insert coin, both ctrl to enter.
   ;setworkingdir, "..\SlamIt\BigScore.exe"
   Run, "..\slamit\go.bat", "..\SlamIt"
   WinWait, ahk_class SlamIt Pinball - Big Score
   Gui, destroy
   #IfWinActive ahk_class SlamIt Pinball - Big Score
   RControl::Enter
   LControl::Enter
   Enter::down
   5::1
   1::s
   #IfWinActive ; This puts subsequent remappings and hotkeys in effect for all windows.
   Process, WaitClose, BigScore.exe
 } else {
   if (useExitScreen = "true")
       Hotkey, $*%exitEmulatorKey%, ExitScreen
   else if (useExitAsPause = "true")
       Hotkey, $*%exitEmulatorKey%, PauseFP
   else
       Hotkey, $*%exitEmulatorKey%, CloseFP
   if  (usePauseKey = "true") {
       Hotkey, $*%pauseVPinball%, PauseFP
       ;Hotkey, $*Pause, PauseFP
   Hotkey, $!F4, ShowFP
   if (saveFPTables = "true") {
       Hotkey, $ScrollLock, SetSaveFPNeeded
       Run, "%emuPath%\%executable%" /open "%tablePath%\%tableName%.fpt" /play /arcaderender,,Min UseErrorLevel
   } else
       Run, "%emuPath%\%executable%" /open "%tablePath%\%tableName%.fpt" /play /Exit /arcaderender,,Min UseErrorLevel
   If (useLoadScreen   = "true") ;Draw the loading Gui with wrapped Progress bar
       Gosub CreateLoadScreen
   Else {
       WinWait, ahk_class FuturePinball
       WinHide, ahk_class FuturePinball
   WinWait, ahk_class FuturePinballOpenGL
   WinActivate, ahk_class FuturePinballOpenGL
   WinWaitActive, ahk_class FuturePinballOpenGL
   Gui, destroy
   WinWait, ahk_class FuturePinballOpenGLSecondary,,1
   WinActivate, ahk_class FuturePinballOpenGLSecondary
   WinWaitActive, ahk_class FuturePinballOpenGLSecondary,,1
;**********************************VISUAL PINBALL***********************************
else if (systemName = "Visual Pinball")
   ; bigboss
   ; Array examples: http://www.autohotkey.com/docs/misc/Arrays.htm
   ; Read config file for vp9.08 tables
   vp908count = 0
   ; This loop retrieves each line from the file, one at a time.
   Loop, Read, %A_ScriptDir%\Settings\vp908tables.txt
       vp908count += 1  ; Keep track of how many items are in the array.
       vp908array%vp908count% := A_LoopReadLine  ; Store this line in the next array element.
   ; Check if table is in the vp908tables array.
   Loop %vp908count%
       ; The following line uses the := operator to retrieve an array element:
       element := vp908array%A_Index%  ; A_Index is a built-in variable.
       if(tableName = element)
           TableIndex = %A_Index%
           vpExeIndex = %TableIndex%
           vpExeIndex += 1
           executable := vp908array%vpExeIndex%
           break
   ; Read config file for disable HD rendering tables since this is a global setting now.
   HDRenderOffCount = 0
   HDRenderOffChanged = 0
   ; This loop retrieves each line from the file, 1 at a time.
   Loop, Read, %A_ScriptDir%\Settings\hdrenderofftables.txt
       HDRenderOffCount += 1  ; Keep track of how many items are in the array.
       HDRenderOffArray%HDRenderOffCount% := A_LoopReadLine  ; Store this line in the next array element.
   ; Check if table is in the no hdrender array and write the VP hardwarerender key to off.
   Loop %HDRenderOffCount%
       element := HDRenderOffArray%A_Index%  ; A_Index is a built-in variable.
           HDRenderOffChanged = 1
           RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\Visual Pinball\Player, HardwareRender, 0
           break
   ; Read config for sound volume hard codes
   SoundModCount = 0
   SoundChangeAmount = 0
   Loop, Read, %A_ScriptDir%\Settings\soundmodtables.txt
       SoundModCount += 1
       SoundModCountArray%SoundModCount% := A_LoopReadLine
   Loop %SoundModCount%
       SoundIndex = %TableIndex%
       SoundIndex += 1
       TheTable := SoundModCountArray%TableIndex%
       TheSoundAmount := SoundModCountArray%SoundIndex%
       if(tableName = TheTable)
           ; Set the new sound change amount. Should be a + or - number otherwise it needs a , SoundSet, absoluteamt
           ; SoundSet: http://www.autohotkey.com/docs/commands/SoundSet.htm
           ; SoundGet: http://www.autohotkey.com/docs/commands/SoundGet.htm
           ;SoundSet, %TheSoundAmount%
           Send {Volume_Down %TheSoundAmount%}
           break
  ; rosve
  ;------     check if an active backglass shall be started -----
   StringRight, ending, tableName, 3
   if (ending = "B2S")
       Run, %tablePath%%tableName%.exe, %tablePath%
       sleep 200
   Run, "%emuPath%\%executable%" /play -"%tablePath%%tableName%.vpt",, Min UseErrorLevel ;Run Minimized
   ;was the best way I could hide the vp editor and play loading screens as WinHide didn't seem to find them
       Hotkey, *%exitEmulatorKey%, ExitScreen
   Else If (useExitAsPause = "true")
       Hotkey, *%exitEmulatorKey%, PauseVP
   Else
       Hotkey, *%exitEmulatorKey%, CloseVP
       Hotkey, $*%pauseVPinball%, PauseVP
       ;Hotkey, $*Pause, PauseVP
   Hotkey, $!F4, ShowVP
   Else {
       WinWait, ahk_class VPinball
       WinHide, ahk_class VPinball
   Gui, Destroy
else
   MsgBox,48,Error,%systemName% is an invalid System Name or %executable% isnt supported yet,6
;                WHEN EMULATOR FINISHES OR IF LAUNCH EXE FAILS                 ;
;************PROBABLY DO NOT NEED TO EDIT THIS AREA*************
if (ErrorLevel = "ERROR")
 MsgBox,48,Error,Failed to run executable check your paths,6
Goto ExitScript ; Exits script and returns to frontend
;                                KILL COMMANDS                                 ;
CloseProcess:
Hotkey, %exitScriptKey%, Off
Process, Close, %executable%
return
; big boss bigscore
CloseSlam:
WinClose, ahk_class SlamIt Pinball - Big Score
goto ExitScript
return
PauseFP:
if (Paused = 0) {
   Paused = 1
   Send {%pauseFPKey%}
   Gosub CreateBlackScreen
   Gosub CreatePauseScreen
   Hotkey, $%exitEmulatorKey2%, CloseFP
   Hotkey, $%exitEmulatorKey2%, On
   Hotkey, $%exitEmulatorKey3%, CloseFP
   Hotkey, $%exitEmulatorKey3%, On
} else {
   Paused = 0
   Gui 1: Destroy
   Gui 5: Destroy
   Send {%pauseFPKey%}
   Hotkey, $%exitEmulatorKey2%, Off
   Hotkey, $%exitEmulatorKey3%, Off
return
pauseVP:
If (Paused = 0) {
   Paused = 1
   Hotkey, $%exitEmulatorKey2%, CloseVP
   Hotkey, $%exitEmulatorKey3%, CloseVP
} Else {
   Paused = 0
   Gui, Destroy
return
ShowFP:
if (Paused = 1)
   Gosub PauseFP
Send {Esc}
WinWaitClose, ahk_class FuturePinballOpenGL
WinShow, ahk_class FuturePinball
WinRestore, ahk_class FuturePinball
SystemCursor("On")
WinShow, ahk_class Shell_TrayWnd
WinShow, Start ahk_class Button
Suspend, On
Suspend, Off
SystemCursor("Off")
WinMinimize, ahk_class FuturePinball
return
ShowVP:
if (Paused = 1)
   Gosub PauseVP
WinClose, ahk_class VPPlayer
WinWaitClose, ahk_class VPPlayer
WinShow, ahk_class VPinball
WinRestore, ahk_class VPinball
WinActivate, ahk_class VPinball
WinWaitActive, ahk_class VPinball
SystemCursor("On")
WinShow ahk_class Shell_TrayWnd
WinShow Start ahk_class Button
Suspend, On
WinWait, ahk_class VPPlayer
Suspend, Off
SystemCursor("Off")
WinMinimize, ahk_class VPinball
return
SetSaveFPNeeded:
saveFPNeeded = true
Send {ScrollLock}
return
CloseFP:
;close all gui's except black screen (gui 5)
Loop, 4
   Gui, %A_Index%: Destroy
;hide and minimize fp editor
;Future Pinball must be closed this way instead of killing process
;or it wil not save your last game information.i.e score/credtis
Send {Esc}
;saving fp table position, black screen hides fp window
if (saveFPTables = "true") and (saveFPNeeded = "true") {
   ;WinRestore, ahk_class FuturePinball
   WinMenuSelectItem, ahk_class FuturePinball,,File,Save
   Sleep, 1000
WinClose, ahk_class FuturePinball
GoSub, ExitScript
return
CloseVP:
; rosve
; --- Close the animated backglass -----------------------
if (ending = "B2S")
WinKill, Form1
;Visual Pinball must be closed this way instead of killing process
;DetectHiddenWindows, on ;Or next line will not work
Loop, 4
;This line fixes where the VP Window flashes real quick
;when closing the window for a cleaner exit
WinClose, ahk_class VPinball
; bigboss
; Restore hdrender original value
if (HDRenderOffChanged)
   RegWrite, REG_DWORD, HKEY_CURRENT_USER, Software\Visual Pinball\Player, HardwareRender, 1
; Restore master volume original value
if (TheSoundAmount)
   Send {Volume_Up %TheSoundAmount%}
GoSub, ExitScript
return
CreateLoadScreen:
   Gui, Destroy ; kill Gui blackScreen
   Gui, Color, EEAA99
   Gui, Margin, 0, 0
   Gui, Add, Progress, x%xLoadProgress% y%yLoadProgress% w%wLoadProgress% h%hLoadProgress% -smooth 0x8 c0C32A5 vLoading vertical BackgroundFFFFFF
   Gui +AlwaysOnTop -Caption +Lastfound
   Gui, Show, AutoSize Center, loadScreen
   WinSet, TransColor, EEAA99
   Loop {
       Sleep %loadspeed%
       ;ProgBar += 1
       ;If ProgBar = %loadspeed%
           GuiControl,, Loading, 1
       ;    ProgBar = 0
       ; get rid of nag screens
       ifWinExist, Please
           WinActivate, Please
           IfWinActive, Please
               Send {Tab}
               Send {Space}
               Send {Enter}
       } else ifWinExist, Game Info
           WinActivate, Game Info
           IfWinActive, Game Info
               Send {Enter}
               Send {Enter}
       } else ifWinExist, Notice
           WinActivate, Notice
           IfWinActive, Notice
               Send {Enter}
               Send {Enter}
       } else ifWinExist, VBScript
           WinActivate, VBScript
           IfWinActive, VBScript
               Send {Enter}
       } else ifWinExist, Error
           ;IfWinActive, Error
               ;Send {Enter}
               Gui, Destroy
               WinActivate, Error
               SystemCursor("On")
               ExitApp
       if (systemName = "Visual Pinball") {
           IfWinExist, Visual Pinball Player,, DMD ;Check if visual pinball is Ready
               IfWinActive, Visual Pinball Player,, DMD ;Check if visual pinball is Ready
                   Break
       } else {
           IfWinExist, ahk_class FuturePinballOpenGL ;Check if visual pinball is Ready
               IfWinActive, ahk_class FuturePinballOpenGL ;Check if visual pinball is Ready
                   Break
Gui, Destroy  ; Vic
Return
CreateBlackScreen:
   CaptureScreen(3)
   ;Sleep 100
   WinWaitActive, ahk_class FuturePinballOpenGL,,2
   Gui 5: Destroy
   Gui 5: Color, 000000
   Gui 5: Margin, 0, 0
   Gui 5: Add, Picture, W%A_ScreenWidth% H%A_ScreenHeight% vScreenPic, screen.bmp
   Gui 5: +AlwaysOnTop -Caption +ToolWindow
   Gui 5: Show, x0 y0 W%A_ScreenWidth% H%A_ScreenHeight%, BlackScreen
Return
CreatePauseScreen:
   Gui, Color, EEAA99
   Gui, Margin, 0, 0
   ;Gui, Add, Progress, x%xLoadProgress% y%yLoadProgress% w%wLoadProgress% h%hLoadProgress% -smooth 0x8 c0C32A5 vLoading vertical BackgroundFFFFFF
   Gui, Show, AutoSize Center, pauseScreen
   Gui, Destroy
   Gui, Color, EEAA99
   Gui, Margin, 0, 0
   ;Gui, Show
Return
CreateExitScreen:
    Gui, Destroy
   Loop, 4
       Gui %A_Index%: Destroy
       Gui %A_Index%: Color, EEAA99
       Gui %A_Index%: Margin, 0, 0
       Gui %A_Index%: Add, Picture, w%wLoad% h%hLoad%, %picDir%%ExitPic%
       Gui %A_Index%: +AlwaysOnTop -Caption +Lastfound
       Gui %A_Index%: Show, AutoSize Center Hide
Return
ExitScreen:
   if (Exiting = 1)
       return
   else
       Exiting = 1
   LoopVal = 0
   Loop {
       state = 0
       GetKeyState, statep, %exitEmulatorKey%, P
       if statep = D
           state = 1
       GetKeyState, statel, %exitEmulatorKey%
       if statel = D
           state = 1
       if (state) {
           if (loopVal = 10) {
               if (Paused = 1) {
                       GoSub PauseFP
                   else
                       GoSub PauseVP
               Gui, 3:Show
           } else if loopVal = 30
               Gui, 2:Show
           else if loopVal = 50
               Gui, 1:Show
           Sleep,  %fadespeed%
           if (loopVal = 70) {
                   GoSub, CloseVP
                   GoSub, CloseFP
               break
       } else {
           Exiting = 0
           if (LoopVal < 10 && useExitAsPause = "true") {
                   GoSub, PauseVP
                   GoSub, PauseFP
           } else {
               Loop, 5
               WinActivate, Visual Pinball Player,, DMD
            Transvalue = 0
           LoopVal = 0
            break
       LoopVal += 1
Return
ExitScript:
Loop, 5
Process, Exist, HyperPin.exe
PID := errorLevel
;no need to show taskbar on exit, it can only cause problems
;it was already commented in 1.10
;if (hideTaskbar = "true") {
 ;WinShow ahk_class Shell_TrayWnd
 ;WinShow Start ahk_class Button
if (PID) {
 WinActivate, ahk_pid %PID%
 ;WinWaitActive, ahk_pid %PID%
 SystemCursor("On")
;to debug script uncomment the pause
;Pause
ExitApp
OnExit, ExitScript
return
;                                 REST OF SCRIPT                               ;
SystemCursor(OnOff=1)   ; INIT = "I","Init"; OFF = 0,"Off"; TOGGLE = -1,"T","Toggle"; ON = others
   static AndMask, XorMask, $, h_cursor
       ,c0,c1,c2,c3,c4,c5,c6,c7,c8,c9,c10,c11,c12,c13 ; system cursors
       , b1,b2,b3,b4,b5,b6,b7,b8,b9,b10,b11,b12,b13   ; blank cursors
       , h1,h2,h3,h4,h5,h6,h7,h8,h9,h10,h11,h12,h13   ; handles of default cursors
   if (OnOff = "Init" or OnOff = "I" or $ = "")       ; init when requested or at first call
       $ = h                                          ; active default cursors
       VarSetCapacity( h_cursor,4444, 1 )
       VarSetCapacity( AndMask, 32*4, 0xFF )
       VarSetCapacity( XorMask, 32*4, 0 )
       system_cursors = 32512,32513,32514,32515,32516,32642,32643,32644,32645,32646,32648,32649,32650
       StringSplit c, system_cursors, `,
       Loop %c0%
           h_cursor   := DllCall( "LoadCursor", "uint",0, "uint",c%A_Index% )
           h%A_Index% := DllCall( "CopyImage",  "uint",h_cursor, "uint",2, "int",0, "int",0, "uint",0 )
           b%A_Index% := DllCall("CreateCursor","uint",0, "int",0, "int",0
               , "int",32, "int",32, "uint",&AndMask, "uint",&XorMask )
   if (OnOff = 0 or OnOff = "Off" or $ = "h" and (OnOff < 0 or OnOff = "Toggle" or OnOff = "T"))
       $ = b  ; use blank cursors
   else
       $ = h  ; use the saved cursors
   Loop %c0%
       h_cursor := DllCall( "CopyImage", "uint",%$%%A_Index%, "uint",2, "int",0, "int",0, "uint",0 )
       DllCall( "SetSystemCursor", "uint",h_cursor, "uint",c%A_Index% )
ToggleCursor:
 SystemCursor("Toggle")
return
IniRead(Filename, Section, Key, Default = "") {
  FileRead, text, *t %Filename%
  text = `n%text%`n
  StringTrimLeft, text, text, InStr(text, "`n[" . Section . "]`n")
  Loop, 8 {
     sp := sp . " "
     StringReplace, text, text, %Key%%sp%=, %Key%=
     If ErrorLevel
        Break
  start := InStr(text, "`n" . Key . "=")
  If !start
     Return, Default
  start += StrLen(Key) + 2
  StringMid, Value, text, start, InStr(text, "`n", false, start) - start
  Return, Value
;Get Full Path from Relative Path
GetFullName( fn ) {
  static buf, i
  if !i
     i := VarSetCapacity(buf, 512)
  DllCall("GetFullPathNameA", "str", fn, "uint", 512, "str", buf, "str*", 0)
  return buf
CheckINI:
 IfNotExist, %A_ScriptDir%\HyperPin.exe
   MsgBox,48,Error, Must be in same directory as HyperPin.exe,6
   Goto ExitScript
 IfNotExist, %A_ScriptDir%\Settings\Settings.ini
   MsgBox,48,Error,Cannot Find %A_ScriptDir%\Settings\Settings.ini,6
   Goto ExitScript
return
CheckPaths:
 romFound =
 StringRight, emuPathBackSlash, EmuPath, 1
 StringRight, tablePathBackSlash, TablePath, 1
 If (emuPathBackSlash != "\" || tablePathBackSlash != "\")
     MsgBox,48,Error, Make sure your paths contains a backslash on the end ,6
     Goto ExitScript
 If (executable = "")
     MsgBox,48,Error, Missing executable in Settings.ini ,6
     Goto ExitScript
 If (tablePath = "")
     MsgBox,48,Error, Missing rom path in Settings.ini ,6
     Goto ExitScript
 If (emuPath = "")
     MsgBox,48,Error, Missing emulator path in Settings.ini ,6
     Goto ExitScript
 If (exitScriptKey = "ERROR") or (useExitAsPause = "ERROR") or (exitEmulatorKey3 = "ERROR")
   Gosub addIni
 IfNotExist, %EmuPath%%Executable%
   MsgBox,48,Error,Cannot Find %EmuPath%%Executable%,6
   Goto ExitScript
return
addIni:
 IniWrite, q & s, %hyperini%, FPLaunch, exitScriptKey
 IniWrite, Esc, %hyperini%, FPLaunch, exitEmulatorKey
 IniWrite, t, %hyperini%, FPLaunch, toggleCursorKey
 IniWrite, p, %hyperini%, FPLaunch, pauseVPinball
 IniWrite, true, %hyperini%, FPLaunch, hideCursor
 IniWrite, true, %hyperini%, FPLaunch, hideDesktop
 IniWrite, true, %hyperini%, FPLaunch, hideTaskbar
 IniWrite, false, %hyperini%, FPLaunch, useExitScreen
 IniWrite, true, %hyperini%, FPLaunch, usePauseKey
 IniWrite, true, %hyperini%, FPLaunch, useLoadScreen
 IniWrite, 25, %hyperini%, FPLaunch, fadespeed
 IniWrite, true, %hyperini%, FPLaunch, UseExitAsPause
 IniWrite, 1, %hyperini%, FPLaunch, exitEmulatorKey2
 IniWrite, Enter, %hyperini%, FPLaunch, exitEmulatorKey3
 IniWrite, RButton, %hyperini%, FPLaunch, pauseFPKey
 IniWrite, true, %hyperini%, FPLaunch, saveFPTables
toggleCursorKey  = t
pauseVPinball      = p
hideCursor       = true
hideDesktop      = true
hideTaskbar      = true
usePauseKey      = true
fadespeed        = 25
saveFPTables     = true
return
/* CaptureScreen(aRect, bCursor, sFileTo, nQuality)
 By Sean - Taken from Forum page:    http://www.autohotkey.com/forum/topic18146.html
1) If the optional parameter bCursor is True, captures the cursor too.
2) If the optional parameter sFileTo is 0, set the image to Clipboard.
  If it is omitted or "", saves to screen.bmp in the script folder,
  otherwise to sFileTo which can be BMP/JPG/PNG/GIF/TIF.
3) The optional parameter nQuality is applicable only when sFileTo is JPG. Set it to the desired quality level of the resulting JPG, an integer between 0 - 100.
4) If aRect is 0/1/2/3, captures the entire desktop/active window/active client area/active monitor.
5) aRect can be comma delimited sequence of coordinates, e.g., "Left, Top, Right, Bottom" or "Left, Top, Right, Bottom, Width_Zoomed, Height_Zoomed".
  In this case, only that portion of the rectangle will be captured. Additionally, in the latter case, zoomed to the new width/height, Width_Zoomed/Height_Zoomed.
Example:
CaptureScreen(0)
CaptureScreen(1)
CaptureScreen(2)
CaptureScreen(3)
CaptureScreen("100, 100, 200, 200")
CaptureScreen("100, 100, 200, 200, 400, 400")   ; Zoomed
/* Convert(sFileFr, sFileTo, nQuality)
Convert("C:\image.bmp", "C:\image.jpg")
Convert("C:\image.bmp", "C:\image.jpg", 95)
Convert(0, "C:\clip.png")   ; Save the bitmap in the clipboard to sFileTo if sFileFr is "" or 0.
CaptureScreen(aRect = 0, bCursor = False, sFile = "", nQuality = "")
   If    !aRect
       SysGet, nL, 76
       SysGet, nT, 77
       SysGet, nW, 78
       SysGet, nH, 79
   Else If    aRect = 1
       WinGetPos, nL, nT, nW, nH, A
   Else If    aRect = 2
       WinGet, hWnd, ID, A
       VarSetCapacity(rt, 16, 0)
       DllCall("GetClientRect" , "Uint", hWnd, "Uint", &rt)
       DllCall("ClientToScreen", "Uint", hWnd, "Uint", &rt)
       nL := NumGet(rt, 0, "int")
       nT := NumGet(rt, 4, "int")
       nW := NumGet(rt, 8)
       nH := NumGet(rt,12)
   Else If    aRect = 3
       VarSetCapacity(mi, 40, 0)
       DllCall("GetCursorPos", "int64P", pt)
       DllCall("GetMonitorInfo", "Uint", DllCall("MonitorFromPoint", "int64", pt, "Uint", 2), "Uint", NumPut(40,mi)-4)
       nL := NumGet(mi, 4, "int")
       nT := NumGet(mi, 8, "int")
       nW := NumGet(mi,12, "int") - nL
       nH := NumGet(mi,16, "int") - nT
   Else
       StringSplit, rt, aRect, `,, %A_Space%%A_Tab%
       nL := rt1
       nT := rt2
       nW := rt3 - rt1
       nH := rt4 - rt2
       znW := rt5
       znH := rt6
   mDC := DllCall("CreateCompatibleDC", "Uint", 0)
   hBM := CreateDIBSection(mDC, nW, nH)
   oBM := DllCall("SelectObject", "Uint", mDC, "Uint", hBM)
   hDC := DllCall("GetDC", "Uint", 0)
   DllCall("BitBlt", "Uint", mDC, "int", 0, "int", 0, "int", nW, "int", nH, "Uint", hDC, "int", nL, "int", nT, "Uint", 0x40000000 | 0x00CC0020)
   DllCall("ReleaseDC", "Uint", 0, "Uint", hDC)
   If    bCursor
       CaptureCursor(mDC, nL, nT)
   DllCall("SelectObject", "Uint", mDC, "Uint", oBM)
   DllCall("DeleteDC", "Uint", mDC)
   If    znW && znH
       hBM := Zoomer(hBM, nW, nH, znW, znH)
   If    sFile = 0
       SetClipboardData(hBM)
   Else    Convert(hBM, sFile, nQuality), DllCall("DeleteObject", "Uint", hBM)
CaptureCursor(hDC, nL, nT)
   VarSetCapacity(mi, 20, 0), mi := Chr(20)
   DllCall("GetCursorInfo", "Uint", &mi)
   bShow   := NumGet(mi, 4)
   hCursor := NumGet(mi, 8)
   xCursor := NumGet(mi,12)
   yCursor := NumGet(mi,16)
   If    bShow && hCursor:=DllCall("CopyIcon", "Uint", hCursor)
   VarSetCapacity(ni, 20, 0)
   DllCall("GetIconInfo", "Uint", hCursor, "Uint", ∋)
   bIcon    := NumGet(ni, 0)
   xHotspot := NumGet(ni, 4)
   yHotspot := NumGet(ni, 8)
   hBMMask  := NumGet(ni,12)
   hBMColor := NumGet(ni,16)
   DllCall("DrawIcon", "Uint", hDC, "int", xCursor - xHotspot - nL, "int", yCursor - yHotspot - nT, "Uint", hCursor)
   DllCall("DestroyIcon", "Uint", hCursor)
   If    hBMMask
   DllCall("DeleteObject", "Uint", hBMMask)
   If    hBMColor
   DllCall("DeleteObject", "Uint", hBMColor)
   mDC1 := DllCall("CreateCompatibleDC", "Uint", 0)
   mDC2 := DllCall("CreateCompatibleDC", "Uint", 0)
   zhBM := CreateDIBSection(mDC2, znW, znH)
   oBM1 := DllCall("SelectObject", "Uint", mDC1, "Uint",  hBM)
   oBM2 := DllCall("SelectObject", "Uint", mDC2, "Uint", zhBM)
   DllCall("SetStretchBltMode", "Uint", mDC2, "int", 4)
   DllCall("StretchBlt", "Uint", mDC2, "int", 0, "int", 0, "int", znW, "int", znH, "Uint", mDC1, "int", 0, "int", 0, "int", nW, "int", nH, "Uint", 0x00CC0020)
   DllCall("SelectObject", "Uint", mDC1, "Uint", oBM1)
   DllCall("SelectObject", "Uint", mDC2, "Uint", oBM2)
   DllCall("DeleteDC", "Uint", mDC1)
   DllCall("DeleteDC", "Uint", mDC2)
   Return    zhBM
Convert(sFileFr = "", sFileTo = "", nQuality = "")
   If    sFileTo  =
       sFileTo := A_ScriptDir . "\screen.bmp"
   SplitPath, sFileTo, , sDirTo, sExtTo, sNameTo
   If Not    hGdiPlus := DllCall("LoadLibrary", "str", "gdiplus.dll")
       Return    sFileFr+0 ? SaveHBITMAPToFile(sFileFr, sDirTo . "\" . sNameTo . ".bmp") : ""
   VarSetCapacity(si, 16, 0), si := Chr(1)
   DllCall("gdiplus\GdiplusStartup", "UintP", pToken, "Uint", &si, "Uint", 0)
   If    !sFileFr
       DllCall("OpenClipboard", "Uint", 0)
       If     DllCall("IsClipboardFormatAvailable", "Uint", 2) && (hBM:=DllCall("GetClipboardData", "Uint", 2))
       DllCall("gdiplus\GdipCreateBitmapFromHBITMAP", "Uint", hBM, "Uint", 0, "UintP", pImage)
       DllCall("CloseClipboard")
   Else If    sFileFr Is Integer
       DllCall("gdiplus\GdipCreateBitmapFromHBITMAP", "Uint", sFileFr, "Uint", 0, "UintP", pImage)
   Else    DllCall("gdiplus\GdipLoadImageFromFile", "Uint", Unicode4Ansi(wFileFr,sFileFr), "UintP", pImage)
   DllCall("gdiplus\GdipGetImageEncodersSize", "UintP", nCount, "UintP", nSize)
   VarSetCapacity(ci,nSize,0)
   DllCall("gdiplus\GdipGetImageEncoders", "Uint", nCount, "Uint", nSize, "Uint", &ci)
   Loop, %    nCount
       If    InStr(Ansi4Unicode(NumGet(ci,76*(A_Index-1)+44)), "." . sExtTo)
           pCodec := &ci+76*(A_Index-1)
           Break
   If    InStr(".JPG.JPEG.JPE.JFIF", "." . sExtTo) && nQuality<>"" && pImage && pCodec
   DllCall("gdiplus\GdipGetEncoderParameterListSize", "Uint", pImage, "Uint", pCodec, "UintP", nSize)
   VarSetCapacity(pi,nSize,0)
   DllCall("gdiplus\GdipGetEncoderParameterList", "Uint", pImage, "Uint", pCodec, "Uint", nSize, "Uint", π)
   Loop, %    NumGet(pi)
       If    NumGet(pi,28*(A_Index-1)+20)=1 && NumGet(pi,28*(A_Index-1)+24)=6
           pParam := π+28*(A_Index-1)
           NumPut(nQuality,NumGet(NumPut(4,NumPut(1,pParam+0)+20)))
           Break
   If    pImage
       pCodec    ? DllCall("gdiplus\GdipSaveImageToFile", "Uint", pImage, "Uint", Unicode4Ansi(wFileTo,sFileTo), "Uint", pCodec, "Uint", pParam) : DllCall("gdiplus\GdipCreateHBITMAPFromBitmap", "Uint", pImage, "UintP", hBitmap, "Uint", 0) . SetClipboardData(hBitmap), DllCall("gdiplus\GdipDisposeImage", "Uint", pImage)
   DllCall("gdiplus\GdiplusShutdown" , "Uint", pToken)
   DllCall("FreeLibrary", "Uint", hGdiPlus)
CreateDIBSection(hDC, nW, nH, bpp = 32, ByRef pBits = "")
   NumPut(VarSetCapacity(bi, 40, 0), bi)
   NumPut(nW, bi, 4)
   NumPut(nH, bi, 8)
   NumPut(bpp, NumPut(1, bi, 12, "UShort"), 0, "Ushort")
   NumPut(0,  bi,16)
   Return    DllCall("gdi32\CreateDIBSection", "Uint", hDC, "Uint", &bi, "Uint", 0, "UintP", pBits, "Uint", 0, "Uint", 0)
SaveHBITMAPToFile(hBitmap, sFile)
   DllCall("GetObject", "Uint", hBitmap, "int", VarSetCapacity(oi,84,0), "Uint", &oi)
   hFile:=    DllCall("CreateFile", "Uint", &sFile, "Uint", 0x40000000, "Uint", 0, "Uint", 0, "Uint", 2, "Uint", 0, "Uint", 0)
   DllCall("WriteFile", "Uint", hFile, "int64P", 0x4D42|14+40+NumGet(oi,44)<<16, "Uint", 6, "UintP", 0, "Uint", 0)
   DllCall("WriteFile", "Uint", hFile, "int64P", 54<<32, "Uint", 8, "UintP", 0, "Uint", 0)
   DllCall("WriteFile", "Uint", hFile, "Uint", &oi+24, "Uint", 40, "UintP", 0, "Uint", 0)
   DllCall("WriteFile", "Uint", hFile, "Uint", NumGet(oi,20), "Uint", NumGet(oi,44), "UintP", 0, "Uint", 0)
   DllCall("CloseHandle", "Uint", hFile)
   hDIB :=    DllCall("GlobalAlloc", "Uint", 2, "Uint", 40+NumGet(oi,44))
   pDIB :=    DllCall("GlobalLock", "Uint", hDIB)
   DllCall("RtlMoveMemory", "Uint", pDIB, "Uint", &oi+24, "Uint", 40)
   DllCall("RtlMoveMemory", "Uint", pDIB+40, "Uint", NumGet(oi,20), "Uint", NumGet(oi,44))
   DllCall("GlobalUnlock", "Uint", hDIB)
   DllCall("DeleteObject", "Uint", hBitmap)
   DllCall("EmptyClipboard")
   DllCall("SetClipboardData", "Uint", 8, "Uint", hDIB)
Unicode4Ansi(ByRef wString, sString)
   nSize := DllCall("MultiByteToWideChar", "Uint", 0, "Uint", 0, "Uint", &sString, "int", -1, "Uint", 0, "int", 0)
   VarSetCapacity(wString, nSize * 2)
   DllCall("MultiByteToWideChar", "Uint", 0, "Uint", 0, "Uint", &sString, "int", -1, "Uint", &wString, "int", nSize)
   Return    &wString
Ansi4Unicode(pString)
   nSize := DllCall("WideCharToMultiByte", "Uint", 0, "Uint", 0, "Uint", pString, "int", -1, "Uint", 0, "int",  0, "Uint", 0, "Uint", 0)
   VarSetCapacity(sString, nSize)
   DllCall("WideCharToMultiByte", "Uint", 0, "Uint", 0, "Uint", pString, "int", -1, "str", sString, "int", nSize, "Uint", 0, "Uint", 0)
   Return    sString
Edited by blur
Oh, duh. Okay, that works well. I'm now able to pause my cabinet for VP hitting Joy8, then exit it hitting my start button when the screen is paused. That works fine now.
Thanks for not giving up on me Blur! :)
Now I'm seeing that if I exit a FP game and then try to spin the HP wheel too soon after, that it freezes. If I wait a couple of seconds, everything is fine. I believe I read that through here, so I'll go back and find it.
Thanks for the help. I really appreciate it!
test it a little before i upload exe
new features are:
slamit support
So this is not available to download anywhere yet blur? I am using an older version of fplaunch and I am getting hangs, popup text box windows popping open when exiting a game, etc. I think I should probably just go to the latest and greatest version and give it a go.
'It's Saturday night; I have no date, a two liter bottle of Shasta, and my all-Rush mix tape... let's rock!' — Philip J. Fry
there is a source in a post - you just copy it to fplaunch.ahk and compile
i just wrote it and was going away so didn't have time to upload exe to megaupload
here is exe and ahk:
When I try to download I get this:
The file you are trying to access is temporarily unavailable. Please try again later.
I will try and figure out how to compile.
Create an account
Register a new account
Sign in
Sign In Now
