tgenerotzke Posted June 3, 2021 Posted June 3, 2021 My machine was in storage for over a year due to a recent move and when I powered it back on, Windows did its critical updates. On 5/15/21 it installed Win 10 Pro patch 20H2. Since that time, I cannot get HyperSpin to run no matter what I do. This happened to me before. The last time there was a patch that a user shared with me. I am hoping for the same. Thanks
dark13 Posted June 3, 2021 Posted June 3, 2021 Some users reported that old sxs.dll into HS folder works also on 20H2, please try it and check windows defender exception, with version change it may tends to reset rules. Â Â 1 Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin Â
pacifikballa Posted June 4, 2021 Posted June 4, 2021 The sxs file works with the latest version of Windows 10 21H1.  Trust me, I’m always updating Windows and running HS right after to make sure  1
tgenerotzke Posted June 4, 2021 Author Posted June 4, 2021 Thank you both for the advice I will give those ideas a shot. I have my machine set to download updates but not install them but this must have been a critical update that overrides that. Every time I see an update install its pucker time! 1
dark13 Posted June 4, 2021 Posted June 4, 2021 Windows updates has become a plague, everytime the thing is updated something stopped working. I install new windows versions only when the support cease, infact I updated to 2004 this week. I was asked to uninstall virtualbox and the system uninstalled cpu-z. No problem at all, after the update I installed the new versions of virtualbox and cpu-z but just think to a place where virtualbox is used ro run old software and there are no people who knows how to fix the thing... On the HTPC I just installed W10 LTSC, 10 years of security updates without version change Automatizing infopanels creation from .csv files for HTPCs themes (look at infopanel tutorial.zip on the ftp in dark13 folder) PNGs to SWFs automatized flash scripts Hyperspin Wheelset automatized template (photoshop's variables + batch) Aeon nox 4.13 W.I.P. hyperspin skin Â
jonescc01 Posted June 19, 2021 Posted June 19, 2021 i updated to windows 10 21H1, added the dll file and made sure hyperspin is allowed in windows defender and i still cant get it to work. any more suggestions? if i cant get this to work im rolling back to windows 7
ktcoady12 Posted June 21, 2021 Posted June 21, 2021 same problem here- I even uninstalled the windows update - still no luck- man oh man -Â
AllIKnow Posted August 8, 2021 Posted August 8, 2021 I have never had a problem with that. I've been using Windows 10 for years (although I preferred Windows XP)
cfssilva Posted July 20, 2022 Posted July 20, 2022 Dark13, you're a genius! Thanks a lot! This file works on Windows 11 too.
ervinjason Posted September 2, 2022 Posted September 2, 2022 The sxs file works with the latest version of Windows 10 21H1. I’m always updating Windows and running HS right after to make sure Alight Motion APK is a free motion graphic design editor for mobile devices. It makes the editing process for videos easy, despite the chaotic home screen.
superbike2 Posted September 10, 2022 Posted September 10, 2022 So, I had set H/S up for a friend of mine on a win 7 system pouring hours and hours into making it look nice. Then the HDD failed. I only have access to win 10 and now h/s won't even open. I've tried uninstall/reinstall, moving things around, I've pasted the .DLL into the root I've even tried using 1.3 again but nothing works. HyperHq does open but it looks pretty messed up. I've looked at launchbox but I don't really like it. Any advice? .... Edit..... I'm currently trying the 32bit version of Windows 10.. will update.Â
ralphyboy Posted September 16, 2022 Posted September 16, 2022 You guys are lifesavers! I purposefully have my arcade computer offline to avoid Windows updates because I figured "If it ain't broke, don't fix it." Everything had worked fine, so I let it be. Last week Windows crashed on me (stupid blue screen of death), I had no choice but to re-install Windows and any new updates that came with it. Sure enough, Hyperspin would not open. If it wasn't for this thread, I would have never figured it out. THANK YOU x1,000,000 1
Szehang Posted October 1, 2022 Posted October 1, 2022 I just installed Hyperspin for the first time and it didn't work, with this fix it works now. Thank you so much
dany651 Posted December 7, 2022 Posted December 7, 2022  The solution describe by Dark13 work just fine  thanks
Metalzoic Posted January 13, 2023 Posted January 13, 2023 I'm running Windows 10 Home version 1709 on my cab. So HS 1.51 wiin 10 fix was the last time I updated mine and I've kept it offline since. Came here to see if it was safe to reconnect online as all my Steam games no longer load, but looks like forced Windows updates will possibly destroy it again eh? Probably safer to disable my PC game wheels instead and leave it that way forever. Ha!
kneetzstopz Posted July 25, 2023 Posted July 25, 2023 i updated to windows 10 21H1, added the dll file and made sure hyperspin is allowed in windows defender and i still cant get it to work. any more suggestions? whatsapp mod watch tv series Â
Aorin Posted July 25, 2023 Posted July 25, 2023 On 7/25/2023 at 8:03 AM, kneetzstopz said: i updated to windows 10 21H1, added the dll file and made sure hyperspin is allowed in windows defender and i still cant get it to work. any more suggestions? These fixes have been rolling for years, mostly when Windows 10 was released with its subsequent updates. The .dll fix doesn't seem to work for everyone and there's the Defender issue, which is probably the main reason why most users have been facing issues starting the frontend. Since HS also relies on flash, which has been discontinued for years, it could be one of the reasons why it's flagged as a potential risk, but I'm not a developer, thus, I'm not sure. As for suggestions, depending on how you use your PC, if it's dedicated to gaming, you can either install a Windows version that won't update, and will only receive important security updates, or make it offline entirely, deactivating or making sure the anti-virus won't block its functionality. Is Hyperspin your only option? Have you tried another frontend, which is currently supported? I know there are many free options that have modern features, making it much easier to setup your systems. Hyperspin's and its community's heyday ended in 2018 at best, many talented people came and went their ways, it's a legacy and in my view, many other frontends owe a great deal to it, thousands of logos, box arts, databases, and Emumovies is a branch of Hyperspin and vice-versa, which feeds even more other frontends media overall. If, for some reason, you decide to stick to Hyperspin, make sure you understand that its development ceased for many years and these fixes may or may not work forever. Let's face it, it's old, it runs at 1024x768, closed source and it's not like there aren't modern options. RocketLauncher development also ceased, few users are keeping modules working. I see how keeping Hyperspin working makes sense for very old users which has a working HS setup and put a lot of effort on it, however, any newer users are advised that your mileage will be way easier and more comfortable with a current, more modern option, that won't alarm your anti-virus and won't need fixes to work on current OSes. 1 Aorin
jesfknkrys Posted July 26, 2023 Posted July 26, 2023 @kneetzstopz I had to run a Windows system scan to fix my issue when Hyperspin would not load.  It has been working great since.  I’m running the latest Windows update.  Try running a sfc / scannow.  Let us know if you need additional assistance. 1
Topgun68 Posted July 27, 2023 Posted July 27, 2023 Just to keep this thread going. I am a new Hyperspin user and have all the latest updates to Windows 10 and HyperSpin would not run with the SXS.DLL Thanks!!
jesfknkrys Posted July 27, 2023 Posted July 27, 2023 Update: 8/2/23 I installed Hyperspin 1.51 on a Surface Pro with Windows 11 with latest updates up to 8/2/2023 and worked as well.   I just downloaded and installed a fresh copy of Hyperspin 1.5.1 on Windows 10 Pro 22H2 and worked without any issues. See picture below.  Things to try: 1. Right click on  "Hyperspin.exe" and select "Run as Administrator". 2. DIsable your antivirus temporarily. 3. Download a fresh copy of Hyperspin ad install it on a separate drive to test. That way we rule out Hyperspin as the issue. Don't forget to copy the sxs.dll file inside the Hyperspin folder.   Let us know if you need additional assistance.  1
cindrela80 Posted October 9, 2023 Posted October 9, 2023 Â I was asked to uninstall virtualbox and the system uninstalled cpu-z. No problem at all, after the update I installed the new versions of virtualbox and cpu-z but just think to a place where virtualbox is used ro run old software and there are no people who knows how to fix the thing. pikashow download
Aloy Posted October 12, 2023 Posted October 12, 2023 Is there anyway to get the 1.5.1 update files? How long has the download page been down? Â
