wfelldin1 Posted July 12, 2014 Posted July 12, 2014 I am new to this and I have a quad core machine running Windows 7 64 bit. I downloaded Hyperpin but when Cannot get the file to launch and install after it is downloaded. Is there another program that needs to be used to install this?
Polemicist Posted July 12, 2014 Posted July 12, 2014 What is the file type of the file you have? I assume it should be a ZIP file?
wfelldin1 Posted July 12, 2014 Author Posted July 12, 2014 Yes it came through as a zipped file. HyperPin_v1.0. I then extracted the file I could not find the exe setup file to start the installation. In the extracted file there are 3 folders (databases, media, settings) The other files are fplaunch, fp launch.ahk, fplaunch4-7.ahx, fplaunch4-7, hglass, hyperpin, and hyperpin-help-file
32assassin Posted July 13, 2014 Posted July 13, 2014 their is no installation file for HyperSpin or Hyperpin. simply unzipp HyperPin_v1.0 (as you did) place all the contents in C:\Hyperpin\ Downloaed an update to FPLauhnch here --> http://www.hyperspin-fe.com/forum/showthread.php?10935-FPLaunch-MOD-Pause-and-Loading-screens ^^ this is a MOD version but you will love the load, pause and exit screens. Open this file C:\Hyperpin\Settings\Settings.ini UPDATE WHAT I HAVE IN RED!!! Quote Version = 0.5.0.0 Starting_Genre = All Games [Video] Playfield_Monitor = Primary Playfield_Rotation = 270 Backglass_Monitor = Secondary Quality = BESTTable_Video_Enabled = true Table_Video_Offset = 50 Use_Backglass = true Backglass_Image_x = 0 Backglass_Image_y = 0Backglass_Image_w = 1280 MATCH YOUR MONITOR SETTINGS Backglass_Image_h = 800 MATCH YOUR MONITOR SETTINGS Backglass_Image_r = 0 Backglass_Delay = .1 [Future Pinball]Show_Games = false false = Disable True = Enable Exe = Future Pinball.exePath = C:\Games\Future Pinball\ MATCH YOUR SETTINGSTable_Path = C:\Games\Future Pinball\Tables\MATCH YOUR SETTINGS Table_Video_Path = C:\HyperPin\Media\Future Pinball\Table Videos\ Table_Image_Path = C:\HyperPin\Media\Future Pinball\Table Images\ Backglass_Image_Path= C:\HyperPin\Media\Future Pinball\Backglass Images\ [Visual Pinball]Show_Games = true false = Disable True = Enable Path =C:\HyperSpin\emulators\Visual Pinball\vp\MATCH YOUR SETTINGSTable_Path = J:\Emulators\Pinball\MATCH YOUR SETTINGS Table_Video_Path = J:\Emulators\Pinball\Cabinet Front End files\Table Videos\ Table_Image_Path = J:\Emulators\Pinball\Cabinet Front End files\Table Images\ Backglass_Image_Path= C:\Hyperpin\Media\Visual Pinball\Backglass Images\Exe = VPinball.exe RENAME YOUR VISUAL PINBALL EXE TO MATCH THIS DO NOT RENAME THIS TO VPinballXXX.exe you will get errors!! and THE MOST IMPORTANT PART!!!!!!!!!! go here -- > C:\Hyperpin\Databases you will find two sub folders Future Pinball Visual Pinball in this folders you will find Future Pinball.XML, Visual Pinball.XML this XML files contain all the games that will be displayed as you scroll through Hyperpin. THE XMLS ARE OLD AS HELL!!!!, they need to be updated. More importantly they need to be updated to match the tables YOU HAVE!!!. if the names don't match then Hyperpin will not load the table NO MATTER WHAT YOU DO. XML format Quote </game> <game name="GAME TITTLE"> (NAME OF YOUR TABLE) <description>Game tittle (Mannuacture Year)</description> (NAME OF YOUR MEDIA wheel, videos, flyers ect) <manufacturer>Manufacture</manufacturer> <year>Year</year> <type>Type of Pinball</type> (type of Pinball Electrical Mechanical = EM Solid State = SS) </game> this is an example of one of my games. The Table and media tittles do not need to match. I named my table the same as the media to avoid confusion. Quote </game> <game name="300 (Gottlieb 1975)"> <description>300 (Gottlieb 1975)</description> <manufacturer>Gottlieb</manufacturer> <year>1975</year> <type>EM</type> </game> when all that is done run Hyperpin by launching C:\Hyperpin\HyperPin.exe
Fender Posted December 10, 2016 Posted December 10, 2016 someone has a solution for hyperpin can not find vpinball.exe. Have just installed vpx all in one.exe but no vpinball.exe found in vp. [Visual Pinball] Show_Games = true Path = C:\Visual Pinball\ Table_Path = C:\Visual Pinball\Tables\ Table_Video_Path = C:\HyperPin\Media\Visual Pinball\Table Videos\ Table_Image_Path = C:\HyperPin\Media\Visual Pinball\Table Images\ Backglass_Image_Path= C:\HyperPin\Media\Visual Pinball\Backglass Images\ Exe = VPinball.exe
32assassin Posted December 12, 2016 Posted December 12, 2016 Quote Exe = VPinball.exe you have Vpinball921.exe Vpinball992.exe Vpinball99_PhysMod5.exe VpinballX.exe
Fender Posted December 13, 2016 Posted December 13, 2016 Have done it few days ago no luck The same error. Cant find Vpinball.exe Outside of HP all works fine, only in HP is the problem
mikekim Posted December 30, 2016 Posted December 30, 2016 make a copy the vpinball992.exe file in the same folder and rename it to vpinball.exe
