gigapig Posted July 22, 2014 Posted July 22, 2014 Just to clarify, I don't know what the PD set contains, but I'll check it out and maybe download that aswell.
gigapig Posted July 22, 2014 Posted July 22, 2014 Blatant promotion. I know Zerojay likes a challenge and hell, it's why we are here right. So why not join in with LSDGuys Hiscore Challenge. May the best man win. www.hyperspin-fe.com/forum/showthread.php?35770-HyperScore-Challenge-1-Donky-Kong-(-Don-t-Just-Lurk-Compete!)&p=330135#post330135
zerojay Posted July 22, 2014 Posted July 22, 2014 Demobase is around 11gb and is a real mess, there is also a TOSEC set on PD at 13gb. I think SIC put together a smaller package of the best demos, which he or I could happily share. If I can clean up my Dropbox I could share the Demobase as well. Yeah, I'd love to get my hands on the package of demos if possible.
zerojay Posted July 23, 2014 Posted July 23, 2014 I just end up sitting at an Amiga prompt when I run any of these demos. Any idea what I could be doing wrong? I've already properly set the path to the demos in the module config.
gigapig Posted July 23, 2014 Posted July 23, 2014 I just end up sitting at an Amiga prompt when I run any of these demos. Any idea what I could be doing wrong? I've already properly set the path to the demos in the module config. Have you setup your Amiga games to use WinUAE using Rons Guide? And they are working. You then need to use the modified module and isd which is in my ftp folder, and point to the WHD folder. Remove the bezel offsets if not using bezels. System name needs to be Commodore Amiga Demos, or I'm sure you know how to change that.
gigapig Posted July 23, 2014 Posted July 23, 2014 And 7z must be set to false. At least at my end it is.
gigapig Posted July 23, 2014 Posted July 23, 2014 Nice but i dont have the ftp You should be able to use the same dropbox link, I put it there and also the video.
gigapig Posted July 23, 2014 Posted July 23, 2014 What link is that? You don't need it because you can get on the ftp for the files. For Mastermark I sent him a DB link.
zerojay Posted July 23, 2014 Posted July 23, 2014 Have you setup your Amiga games to use WinUAE using Rons Guide? And they are working.You then need to use the modified module and isd which is in my ftp folder, and point to the WHD folder. Remove the bezel offsets if not using bezels. System name needs to be Commodore Amiga Demos, or I'm sure you know how to change that. Yeah, I've done all that as well as the 7z disable and I'm still just getting the prompt.
mastermark Posted July 23, 2014 Author Posted July 23, 2014 Got the site download sorted mate but the video is not playing for me ive added it to Media/Main menu/video Is that correct
gigapig Posted July 23, 2014 Posted July 23, 2014 Got the site download sorted mate but the video is not playing for me ive added it to Media/Main menu/video Is that correct Yes that's right. I was going to pm you about that, have you renamed the theme to match the system name and put it in Media/Main menu/themes? I originally named it Default, which is wrong for a main menu, but it can be used on the sub wheel as well.
mastermark Posted July 23, 2014 Author Posted July 23, 2014 The zip is called Commodore Amiga Demos.zip i moved that to HS/Media/commodore amiga demos/themes .......... Im not getting anything Also when i go onto the demo wheel it stays blank until i select it ?
gigapig Posted July 23, 2014 Posted July 23, 2014 Just noticed mine is the same, so you must only be able to use it on the main menu not the sub wheel. unless someone knows of a way to get a default video to play on the sub wheel.
gigapig Posted July 23, 2014 Posted July 23, 2014 Yeah, I've done all that as well as the 7z disable and I'm still just getting the prompt. Would you mind posting your Hyperlaunch log, maybe that will shed some light.
mastermark Posted July 23, 2014 Author Posted July 23, 2014 I dont have a Main Menu for my demo screen ? Where is the log file located is it in HS folder as i got a file called log.txt 06:21:11 PM | HyperSpin Started 06:21:11 PM | Going FullScreen 06:21:12 PM | Checking for updates 06:21:12 PM | Update Check Complete 06:21:12 PM | Startup program unavailable 06:21:12 PM | Playing intro video 06:21:13 PM | Error intializing joysticks 06:21:13 PM | Menu Mode is multi 06:21:13 PM | Loading Main Menu.xml 06:21:13 PM | Main Menu.xml successfully loaded 06:21:14 PM | Main Menu wheel loaded successfully 06:21:25 PM | Loading Commodore Amiga Demos.xml 06:21:25 PM | Main Menu.xml successfully loaded 06:21:26 PM | Commodore Amiga Demos wheel loaded successfully 06:21:30 PM | Loading Main Menu.xml 06:21:30 PM | Main Menu.xml successfully loaded 06:21:30 PM | Main Menu wheel loaded successfully 06:22:17 PM | Loading Commodore Amiga Demos.xml 06:22:17 PM | Main Menu.xml successfully loaded 06:22:18 PM | Commodore Amiga Demos wheel loaded successfully 06:23:35 PM | Loading Main Menu.xml 06:23:35 PM | Main Menu.xml successfully loaded 06:23:36 PM | Main Menu wheel loaded successfully 06:23:38 PM | Exit program unavailable 06:23:38 PM | Quiting Hyperspin 06:23:38 PM | Bye! Now i cant post nomore as ive used my 5 a day limit ????
sic Posted July 23, 2014 Posted July 23, 2014 Demobase is around 11gb and is a real mess, there is also a TOSEC set on PD at 13gb. I think SIC put together a smaller package of the best demos, which he or I could happily share. If I can clean up my Dropbox I could share the Demobase as well. The Demo package I use is the one that can be downloaded at http://kg.whdownload.com/kgwhd/
gigapig Posted July 23, 2014 Posted July 23, 2014 I dont have a Main Menu for my demo screen ? Where is the log file located is it in HS folder as i got a file called log.txt Now i cant post nomore as ive used my 5 a day limit ???? I was responding to zerojay about the log, you shouldn't need to post one unless your still having problems running the demos. The theme I knocked up can be used for the main menu, so name it "Commodore Amiga Demos" and drop it in Media>Main Menu>Themes. Same for the video, named the same, goes to Media>Main Menu>video. You have the theme working in the sub wheel, but maybe just a background image would be better without the video.
rfancella Posted July 23, 2014 Posted July 23, 2014 I just end up sitting at an Amiga prompt when I run any of these demos. Any idea what I could be doing wrong? I've already properly set the path to the demos in the module config. ZeroJay, If you are getting the "Insert Workbench" screen, that means you do not have your "PathtoWHDFolder" set in the System Module Settings in HLHQ. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
mastermark Posted July 24, 2014 Author Posted July 24, 2014 Not sure how to remove the video off the wheel menu ?
gigapig Posted July 24, 2014 Posted July 24, 2014 I not entirely sure what you mean Master, but if you want the video removed from the sub wheel theme, then try the attached file. You can change the background just extract the Default.zip archive, delete the Background.png and add another, then zip up. Default.zip
