Darkfall Posted September 11, 2011 Posted September 11, 2011 sidewinder freestyle pro i think has only two axis which are from nudge detector.so nudging should work out of the box. just stick the gamepad firmly to your cab. for plunger I'm not sure what is in the code. You can check the code before you buy it. there is some wheel that rascal tried to use for plunger but i'm not sure if this worked. Nudging is what I'm after more than anything, so that would work for me. I'll see what else is in the code and see if I can find a pad that'll do all of it - but really, I'll ignore the plunger stuff for now anyway, since I have a Launch Ball button only on my cabinet and it requires fiddling with the table code to make work. Thanks again, Blur. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
legtod2 Posted September 13, 2011 Posted September 13, 2011 Nudging and iPac... I am going to pick up the Microsoft sidewinder and have some questions for you gurus. What key stroke(s) do I need to map to my iPac for nudging to work. For example I think the keys are a, z, x for the various nudging directions. Or does it work via USB connect to xpadder? I will be using a simple button for the plunger so nothing special to consider there.
northvibe Posted September 13, 2011 Author Posted September 13, 2011 I just got my MS sidewinder pro freestyle in the mail Windows 7 x64 i5 2500k OC 4.4ghz nvidia GTX 470 Intel onboard video 8gb ram Crucial M4 64gb SSD
pinballlooking Posted September 13, 2011 Posted September 13, 2011 I just got my MS sidewinder pro freestyle in the mail Good deal. You will have to let us know how it works you you. My Pinball Cabinet:http://www.hyperspin-fe.com/forum/showthread.php?t=15290
wierdo Posted September 13, 2011 Posted September 13, 2011 Nudging and iPac...I am going to pick up the Microsoft sidewinder and have some questions for you gurus. What key stroke(s) do I need to map to my iPac for nudging to work. For example I think the keys are a, z, x for the various nudging directions. Or does it work via USB connect to xpadder? I will be using a simple button for the plunger so nothing special to consider there. The ipac has nothing to do with nudging unless you have nudge buttons. The Sidewinder works by configuring XPadder to send keypress events whenever the accelerometer shows movement beyond whatever threshold you set in Xpadder. The game pad is connected to the PC using USB.
Darkfall Posted September 14, 2011 Posted September 14, 2011 Nudging and iPac...I am going to pick up the Microsoft sidewinder and have some questions for you gurus. What key stroke(s) do I need to map to my iPac for nudging to work. For example I think the keys are a, z, x for the various nudging directions. Or does it work via USB connect to xpadder? I will be using a simple button for the plunger so nothing special to consider there. Default nudging with the keyboard is Z for left, / for right, and space for up. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
Darkfall Posted September 15, 2011 Posted September 15, 2011 Good news - I was able to build Visual Pinball 9.13 successfully, so that means I'm going to get myself a game pad, make the modifications Blur/Rascal mentioned, and fiddle with analog nudging. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
chriz99 Posted September 15, 2011 Posted September 15, 2011 awesome! I want it, too cheers chris [sIGPIC][/sIGPIC] * taito egret 29 candy cabs * indy & star wars pachinkos 17" bartop with ledwiz rgbleds * 10" bubble bobble & galaga bartop * arm champs 2 check out hi-res backglasses * best vpin performance * ledwiz config and software
Darkfall Posted September 15, 2011 Posted September 15, 2011 Are you able to do the compile on VP, or would you like me to make an executable available to you? You probably already have your pad. I'm going to pick one up tomorrow. They're cheap. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
Guest gstav Posted September 15, 2011 Posted September 15, 2011 hit me too mr. Darkfall! My gamepad is allready mounted and hungry! But it's mounted upsidedown, so left and right is reversed. Maybe a special version for me then! wee!
wierdo Posted September 17, 2011 Posted September 17, 2011 So it turns out that the Sidewinder Freestyle Pro support is already in 9.12. Just make sure the PBW Accelerometer box is checked in the table options and you'll be good to go. (possibly after some tweaking of the various settings) It would be nice if there were a global setting as well as a per-table setting, but oh well. I'm too dumb with Win32 to even make a checkbox.
kronic24601 Posted September 17, 2011 Posted September 17, 2011 Has anyone ever done a comparison of the Nanotech product vs the sidewinder game-pad? I know people have given good reviews of both, I'm just curious which one is better (I have an order of the Nanotech on the way). My Evil Arcade Monkey shakes when ever I'm having arcade problems ... notice how he is always shaking
legtod2 Posted September 18, 2011 Posted September 18, 2011 Let me know what you think of nano tech when you get it set up and installed.
blur Posted September 18, 2011 Posted September 18, 2011 legtod you have thousnads of posts on pbw here and on vpf gustav you have three main settings for pbw: enable accelerator normal position rotation so you can always set any position to work for you combining flipping (normal position) and rotation My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Darkfall Posted September 19, 2011 Posted September 19, 2011 I just returned from Ottawa today and picked up a Logitech F310 gamepad on the way home from the airport. I fired up the custom build of Visual Pinball and played with the analog nudge. It works amazingly well! I'm psyched about putting it in the cabinet with some weight on the stick to better pick up on the nudging motion, so I can see how well it works in a live situation. Looks very promising, though! ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
blur Posted September 19, 2011 Posted September 19, 2011 great job man good luck with testing just be sure to set accelerometer checkbox on in every table you use if you don't set accelerometer then nudge will work like digital nudge - only three directions - left, right and front with fixed strength if you set accelerometer check box you can have any direction and strength how to test it - for people that don't know what to expect from nudge: when you do front nudge - ball should go toward you ie down - not up - this is little secret that nobody of vp/fp programmers knows about - even black has done front nudge wrong in fp when you bump table from the right corner - diagonally at 45 degrees - ball should go toward your hand - which is again down - not up when you bump from right to left - horizontally - ball should go from left to right direction can also be anything in between strength should be small or big - it should depend on strength of your nudge My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
wierdo Posted September 19, 2011 Posted September 19, 2011 just be sure to set accelerometer checkbox on in every table you use If you're already compiling your own, it's much easier to comment out two lines and force PBW support on for all tables. Not that it makes a terribly large amount of sense for the setting to be per-table anyway. (I can understand wanting different parameters per-table, but the overall setting?)
blur Posted September 19, 2011 Posted September 19, 2011 I agree. I plan to put three main settings on key config window and into the registry: enable acceler. normal mount rotation maybe even gain and other values since they all depend more on your device then on exact table that's why i don't go so much in detail with code fixes. My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
Darkfall Posted September 27, 2011 Posted September 27, 2011 If you're asking about my tests with the game pad and the modified VP, it appears to work great - but I haven't had time to install the game pad in my cabinet and try it in a real-world situation. It does, indeed, behave in an analog way, though - small joystick movements result in small nudges, and the nudges occur in whatever direction the stick is moved. It looks very promising. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
legtod2 Posted October 3, 2011 Posted October 3, 2011 Here is a link of the u hid g device test http://ramvikpinball.wordpress.com/#!/page/1
Darkfall Posted October 4, 2011 Posted October 4, 2011 I ordered a U-HID G for testing next to the gamepad idea. I'm marginally skeptical of accelerometers, but if it works as promised, then it'll be way easier to implement and calibrate. If nothing else, it'll be fun to play with, even if it doesn't end up in the cabinet. I'm sure I can stick this thing in something else and have fun with it, if it doesn't do what I want for the cabinet. The board also allows you to assign the Z axis to a pin (instead of the accelerometer - at least, I think that it does, anyway), so you can grab a potentiometer from your favorite electronics store, fire 5 volts through it to the U-HID board, and connect that potentiometer to your plunger via an arm (like Rawd did in his test video), and you have an analog plunger, too. I will be messing with that idea to see how well it works. If it does work as planned, then this would be easier to set up than trying to get one of the analog sticks on a gamepad relocated near the plunger (or sticking the whole gamepad near the plunger). I imagine it'll be a few days getting here, so I'll continue to screw around with the gamepad in the meantime, as time permits. Thanks for reminding me about the U-HID G, legtod2. I remember seeing it and thinking, "Hmmmm - cool", then forgot about it and got pretty into the gamepad thing. Might as well test both *grin*. ...Paul Check out Wildfire Pinball's build details here: Project Wildfire
legtod2 Posted October 4, 2011 Posted October 4, 2011 Darkfall, I've had good luck with the products ordered from ultrimarc, I expect nothing less from the accelerometer. There is a sdk kit for it and third party software. I expect mine to arrive today or tomorrow. I need to figure out where to mount it, direction to mount, how to config and calibrate, integrate to vp . Yup, like you said fun.
blur Posted October 4, 2011 Posted October 4, 2011 For gamepad - you can put it under the plunger so that your z axis is inline with plunger (gamepad rotated for 90 degrees clockwise). Then for nudge you just set flip and rotation so that you can nudge correctly. Gamepad will not be upside down - but i think it could work for nudge if you don't add to much weight on it. Cause gamepad sticks have some strong springs that should be able to return weight to center after nudge. Of course putting gamepad upside down with large ball like weight and very soft springs would be better for nudging but then you need to relocate z axis for plunger. What gamepad did you used? All my gamepads are ps2 like gamepads which need press on analog button to activate analog sticks. It would be better if you have some gamepad that is automatically in analog mode (xbox 360 maybe?). About uhid - I'm not sure if it is analog or not? Last time I checked vp source only analog devices supported were pbw and ultracade. For uhid people used xpadder to convert movement to nudge keys - which is digital not analog nudge (always same strength and angle). My paper cab core.vbs with better nudge FPLaunch with exit menu, instructions, flyer VP with support for analog nudge and plunger with any gamepad www.submania.hr www.phoenixmarine.hr rent-a-boat-rab.com bootsvermietung-rab.com
