Help with demul057
Emu54
Doing it that way I'm guessing d/lb those files and replace the ones I'm currently using?
Git has always been a pain in the arse
Please Please backup before over writing anything and only move what is suggested in the GIT instructions. If you have not setup anything yet then it would be OK, but just overwriting everything if you have lots of systems setup is asking for trouble.
Most module folders have ini files with stored settings, so be very careful.
If you do it don't forget the module extensions folder and Libs folder as well as the Hyperlaunch exe.
Awww man I'm just going to avoid it I guess. Sucks it was the last system I wanted on my machine, I dig the games. Maybe if I can get this git thing working then it'll work no problem, I'll put my focus on that, cheers
  • 1 month later...
I am getting .zip is not a supported file type for this module. I have it listed in the rom extensions though, is there any other reason for this? I have most of my games zipped for other systems but this one is causing issues.
It appears zip is supported
zip|gdi|cue|cdi|chd|mds|ccd|nrg
mine is at the start of the list, maybe that would help?
Perhaps upgrade to Demul 0.58.2 and make sure your Hyperlaunch setup is up to date via GIT.
Failing that, post your Hyperlaunch log set to troubleshooting.
  • 7 months later...
Demul 0.58.2 says it hasn't been updated since 2013, is that really the latest version?
This is the best emulator for Atomiswave games correct?
