Creezz67
    1,307
    23
Everything posted by Creezz67
  1. Version 1.0.0
    9 downloads
    The 1983 classic multi-room platformer Montezuma's Revenge returns in 2.5D glory, and now Pedro's adventure is bigger than ever with 100 tricky rooms to explore! For its 40th anniversary, what was once an unfinished game is now resurrected to match the full vision of creator Robert Jaeger.
  2. PC Games/Windows also work perfectly using shortcuts, but you need to use RocketLauncher as the emulator. I know that's not what they are wanting us to use, but at least it works for now until they get around to it
  3. Version 1.0.0
    5 downloads
    X Games Snowboarder Arcade Game is Raw Thrills' 8-way linkable deluxe racing Snowboard simulator Arcade Game that sends players hurtling down Iceland's icy .
  4. I just had this. Delete the MainMenu media folder & _cache folders completely, close down HyperHQ and then go back into HyperHQ It should just re-build them all again and work in Hyperspin, that's what I did.
  5. Since the last update to .35 all the themes are suddenly looking grainy when previously they were not (see below) It looks like there is a fine shader covering the screen for every system.
  6. The only reason I mentioned this was I told the Launchbox admin the same thing about 2 years ago and they said they knew it was a BIG problem, but the only way they could rectify it, was to start coding Launchbox again ..... from scratch !! Now, 2 years later (7 years since it's release) it's like a Ferrari with a lawn mower's engine and completely useless.
  7. HyperHQ is still not installing in the correct place when updating from v2.0.33 to v2.0.34 My setup is located in D:\Arcade\HyperHQ and it installed automatically to C:\Program Files\HyperHQ Why not have an option box to ask where you want it to be installed ?
  8. The new _cache folder in the media folder takes up so much space it's unbelievable. It literally copies EVERY item of media again and put it into the _cache folder I only have 10 systems setup and it's already 13.5gb I predict it will be 100-200gb+ when I am finished. Launchbox has this same setup and it grinds the entire setup to a snail pace the more you add. I suggest before you get too far into this, you take a look to see if it can be eliminated in any way ?
  9. No, now all videos are being sent to the correct location
  10. Great news ... MAME Rom Mapping is working in Hyperspin 2.0 using RocketLauncher as the emulator.
  11. I updated from 31 to 33 and it installed into C:\ instead of D\ once I moved the new HyperHQ folder onto my D:\ and then added a new system all the media it downloaded was added to the correct location (D:\ drive) for the first time
  12. Just updated from 2.0.31 to 2.0.33 and it still updated to the wrong drive C:\ Copied it to my D:\ drive location, installed a new system and now it is finally putting ALL the media and videos in the correct location, rather than sending it all to C:\ as it was before
  13. Forget about them ever fixing this, now Hyperspin 2.0 is out this is redundant as far as they are concerned. Go back to 23H2 (look for download for Windows 11 23H2) iso , it all works fine on that.
  14. Has anyone got this to work using Rocketlauncher as the emulator ? the Rom mapping screens all load fine , but then it just has a black screen and exits when trying to load. if this works Hyperspin could literally be as it was before , all running through Rocketlauncher , because every system I have tried running through RL seems to work fine so far and best of all the exit works on the controller.
  15. Current command line only load to main menu. Thanks
  16. Now I know why it keeps asking me to update over and over, even though I am using HyperHQ on D:\ when it updated it kept updating and copying to C:\ So it seems to think it's not updated and then asks over and over to update, all the while sending it to C:\ Once I copied the C:\ files back to D:\ it then stops asking me to update. Update: Once I did this, HyperHQ works fine but now Hyperspin will not load at all.
  17. No, as soon as I reload it asks me again. Also HyperHQ will not exit correctly and can only be rebooted if I close it down in Task Manager Same with Hyperspin.exe (won't exit correctly)
  18. HyperHQ keeps asking me to update, now it has been 10 times in a row and still it keeps asking ? I am assuming this is a bug ?
  19. High Quality Why only have 1 option when many systems don't have High Quality, yet some do ? Just deleted everything and tried again setting it to Medium and it still goes to C:\Hyperspin while the other media like boxart etc all go to correct place.
  20. Also, how are we supposed to exit from the emulator without RocketLauncher modules doing it for us ? There needs to be an default exit key to get back to Hyperspin, not all emulators allow Escape key to be used.
  21. EmuMovies videos are all defaulting to C:\Hyperspin, regardless of the location you setup in HyperHQ (In my case D:\Arcade) When I then copy them from this location back to where all the other media is, they don't show up. Also boxart is not showing in Hyperspin either, even though it's all showing up in HyerHQ Is this a bug or can we only use C:\ to install Hyperspin ?
  22. Look on the Facebook link … it’s real this time
  23. Finally !!!!!!! Hyperspin 2 is coming I know one person that won't be happy about it ..... Jason Carr !! And if you don't go and read the announcement on FB, remember this site will be down for a few days from tomorrow to get it all sorted. 1 thing i read .... the 24H2 problem will be no more !!!! From Andyman https://www.facebook.com/therealhyperspin/posts/pfbid02oaam4b6xjJ9pwQsQNVCeK88kLMLw2yaUaS9oQEUThRV8VD84EexVX9gkKipbda5Jl ... that's all I'm at liberty to say right now. See? I told you things only seemed quiet around here!
  24. Finally !!!!!!! Hyperspin 2 is coming I know one person that won't be happy about it ..... Jason Carr !! And if you don't go and read the announcement on FB, remember this site will be down for a few days from tomorrow to get it all sorted. 1 thing i read .... the 24H2 problem will be no more !!!! From Andyman https://www.facebook.com/therealhyperspin/posts/pfbid02oaam4b6xjJ9pwQsQNVCeK88kLMLw2yaUaS9oQEUThRV8VD84EexVX9gkKipbda5Jl ... that's all I'm at liberty to say right now. See? I told you things only seemed quiet around here!
