11
Everything posted by dark13
In case I can help with Italian
I installed w11 24h2 iso downloaded from microsoft website on virtualbox and HyperSpin is working. 24h2 anyway is a trainwreck, it breaks also other games and apps, not only HyperSpin
Again, it seems to work on virtualbox. I dont' have a spare hard disk to do the test on a real machine, can someone try a thing? Install windows 11 home 24h2, switch to pro with an activator or a cheap serial, try if the thing works.
As far as I know BBB said HS uses some commercial flash libraries so it can't actually go open source
Ok, upgraded to PRO, it still seems to work. Can you try it on a virtual machine? This is weird, maybe virtualbox preventing some 24h2 protection? Fresh 24h2 install, updates done.
Trying on a VM, on 24h2 Home version it seems to works. Now I have to understand how to install Pro on virtualbox... Anyway 24h2 breaks lots of stuff and games, not only Hyperspin.
Wrong roms folder in settings?
I don't have them in my mame xml, try copy/paste gtfore04.chd and name it gtfore04a.chd, copy/paste another .zip file and rename it rebound.zip
Extract the archive in a folder and add the folder to RL roms folder. No copyright infringment, they are only empty .txt with a different extension Breakout is not the only game needing a dummy rom Dummy roms.zip
The white screeen with exclamation point means Flash run out of memory, Flash has some serious memory leaking problems and can't use all the ram of the system (can't remember if it is limited to 2gb or the classic 32bit 3.8gb). Basically even if the Flash garbage collector runs properly some stuff still hangs in memory. You can trigger the problem using huge .swf or .swf that are not huge but have lots of frames (it is better to stay in the 160-180 frame max range for a fullscreen .swf).
To me joy2key and xpadder adds a bit of lag even with empty configurations. I use xpadder in HS (joystick input is bugged) but the AHKs close it when I launch an emulator (it seems to restart automatically once I close the emulator and return to HS). It is better to set keys directly in emulators, also because in MAME or RetroArch you can have per-game input settings.
Do you have problems with control mapping in HS or in games? To set up control mapping for HS just open HyperHQ.exe and set up the buttons. For mame and other emulators you must set up inputs in the emulator.
Because the sxs.dll in Windows 10's system32/syswow64 is not compatible with Hyperspin. There is no patch on HS exe, you only need to download the posted dll and put it in the same folder of hyperspin.exe. It's the dll used in windows7, if a dll is included in the same folder of the exe, the exe will use that dll instead of using the one in system32/syswow64. It's an old school trick
Ok, now I need to see forza7 running on a 480p CRT Just curious, how did you connected the PC to the CRT? HDMI to something? What about input lag?
Version 2.0.0
41 downloads
***WARNING*** THIS SET SUPPORTS ADULT GAMES AND I FIRMLY BELIEVE CENSORSHIP IS THE SEED OF ALL EVIL SO YEAH, IT CONTAINS FLYERS WITH NUDE GIRLS 3.716 Arcade flyers at 400*563 (4:3), 300*563 (16:9), 203*477 (Aeon Nox) Compatible with: Included MAME.xml (no clones, no hanafuda, no casino, no bet, no playchoice, no mahjong), AAE, Atari Classics, Capcom Classic, Capcom Play System, Capcom Play System II, Capcom Play System III, Cave, Data East Classics, Gaelco, Irem Classics, Konami Classics, Midway Classics, Namco classics, Namco System 22, Nintendo Classics, Sega ST-v, SNK Classics, Taito Classics, Sega Model 2, Sega Model 3, Sega Naomi, Gaelco (inside MAME folder), Taito Type X, Sega Hikaru . Ok, this is not the holy grail of MAME flyers as it is not a complete set but what you get is a fixed resolution MAME flyers with a decent database. Hundres of flyers have been restored, remade, rethinked or built from scratches. Some flyers for games with no artwork are a bit generic and/or boring but I think I did a good job on most of them. Lots of well known games with bad looking flyers now have a custom flyer with fanart, like it or not . Sources: Amyfever Flyerset, Arcade Flyers Archive, HyperSpin official Wheelart, HyperSpin official Themes, LaunchBox database, Goggle search images. Williams Classic is not supported as the .xml on hyperlist is a real mess, it contains pinball roms. If there are new and more complete .xmls please post it, I will release an "addendum" to support them. This is a flyers set but it is designed to work as wheel art set -
Version 2.0.0
86 downloads
Version 2.0.0
72 downloads
Version 20120927
423 downloads
This archive contains 3 folders: 1- In "SWF" folder you'll find .SWF renamed as .png. Hyperpsin will read it as .sfw so you will have animated cartridges as wheel's images. If you change the extension back to .swf hyperspin won't read it as wheel images but you can use it as artwork. 2- In "Real PNG's" you will find proper png's. 3- In "Real PNG's 16-9" you will find png's to use while running hyperspin on 16:9 monitor. The quality suffers a bit due to sampling but in most cases it will look better than the normal set does in 16:9. Png and swf file's names are compatible with HYPERLIST's "NEC Supergrafx.XML" You can redistribute/modify this set, just give credit to "dark13"- 1 review
- 2
Version 20121129
684 downloads
Neo Geo ShoXbox 1080p set by dark13 Feel free to report your feedback or bugs in english or italian to: @[email protected] Feel free to use it in your projects, just give credit to me. Uses of this material is not viable in commercial products. Share the thing, don't sell the sharing This set is based on the neo geo mvs shockbox insert you can dowload at http://southtown-homebrew.com/ and the official hyperspin mame wheel you can dowload at http://www.hyperspin-fe.com/ . A great thank to every artist who contributes to these projects, without them this set would not exists. If you made an insert or a wheel image used in this set and you want credit just email me, i will add your name in this .readme. Dark13- 1 review
- 1
Version 20121218
308 downloads
Neo Geo ShoXbox 1080p no reflex set by dark13 Feel free to report your feedback or bugs in english or italian to: @[email protected] Feel free to use it in your projects, just give credit to me. Uses of this material is not viable in commercial products. Share the thing, don't sell the sharing This set is based on the neo geo mvs shockbox insert you can dowload at http://southtown-homebrew.com/ and the official hyperspin mame wheel you can dowload at http://www.hyperspin-fe.com/ . A great thank to every artist who contributes to these projects, without them this set would not exists. If you made an insert or a wheel image used in this set and you want credit just email me, i will add your name in this .readme. Dark13- 1 review
- 1
Version 20121216
277 downloads
Neo Geo ShoXbox 720p set by dark13 Feel free to report your feedback or bugs in english or italian to: @[email protected] Feel free to use it in your projects, just give credit to me. Uses of this material is not viable in commercial products. Share the thing, don't sell the sharing This set is based on the neo geo mvs shockbox insert you can dowload at http://southtown-homebrew.com/ and the official hyperspin mame wheel you can dowload at http://www.hyperspin-fe.com/ . A great thank to every artist who contributes to these projects, without them this set would not exists. If you made an insert or a wheel image used in this set and you want credit just email me, i will add your name in this .readme. Dark13 -
Version 20121216
337 downloads
Version 20121217
194 downloads
Neo Geo ShoXbox 720p 16:9 set by dark13 Feel free to report your feedback or bugs in english or italian to: @[email protected] Feel free to use it in your projects, just give credit to me. Uses of this material is not viable in commercial products. Share the thing, don't sell the sharing This set is based on the neo geo mvs shockbox insert you can dowload at http://southtown-homebrew.com/ and the official hyperspin mame wheel you can dowload at http://www.hyperspin-fe.com/ . A great thank to every artist who contributes to these projects, without them this set would not exists. If you made an insert or a wheel image used in this set and you want credit just email me, i will add your name in this .readme. Dark13 -
Version 20121218
484 downloads
Neo Geo ShoXbox 2D set by dark13 Feel free to report your feedback or bugs in english or italian to: @[email protected] Feel free to use it in your projects, just give credit to me. Uses of this material is not viable in commercial products. Share the thing, don't sell the sharing This set is based on the neo geo mvs shockbox insert you can dowload at http://southtown-homebrew.com/ and the official hyperspin mame wheel you can dowload at http://www.hyperspin-fe.com/ . A great thank to every artist who contributes to these projects, without them this set would not exists. If you made an insert or a wheel image used in this set and you want credit just email me, i will add your name in this .readme. Dark13- 1 review
- 1
