rfancella Posted November 24, 2013 Posted November 24, 2013 Arcadia, I was having the same issue when I first set it up. I was trying to run the wrapper exe. You should be using the FixitFelixJr.exe. Hope this helps. Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
Arcadia Posted November 24, 2013 Posted November 24, 2013 Arcadia,I was having the same issue when I first set it up. I was trying to run the wrapper exe. You should be using the FixitFelixJr.exe. Hope this helps. Thanks, Ron Unfortunately not. Here that just starts the windowed default version. I am doing something wrong I think.
rfancella Posted November 24, 2013 Posted November 24, 2013 Arcadia, That is correct. The HL script should do the rest for you. Are you using the Fix-It Felix Jr Launcher.ahk script to launch it? Below are the paths setup in mine. GamePath=C:\Emulation\roms\PC Games\Fix-It Felix Jr\Fixitfelixjr.exe ; the full path and exe of FixitFelixJr.exe BezelPath=C:\Emulation\roms\PC Games\Fix-It Felix Jr\bezel.png ; the full path and extension to bezel file Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
guyverjay Posted November 27, 2013 Posted November 27, 2013 This may seem like a stupid question, but where do I get the game??
ghutch92 Posted November 27, 2013 Posted November 27, 2013 Back of a truck somewhere. Thanks I found Felix, he had a hammer and everything. He didn't like bricks falling on him either. How to Install HyperSpin and more RocketLauncher HyperSpin Startup Script
mrxtreme Posted November 27, 2013 Posted November 27, 2013 Everything is working fine but when I exit the game it doesnt go back to hyperspin, I have to click on hyperspin instead of it automatically doing it. I have chosen [ restore ] on the option of Restore Frontend on exit in RL but still no go, any idea?
mrxtreme Posted December 4, 2013 Posted December 4, 2013 tried a couple of different things but still no luck im thinking it could be in the code but not sure... has anyone else run into this?
Arcadia Posted December 6, 2013 Posted December 6, 2013 Arcadia,That is correct. The HL script should do the rest for you. Are you using the Fix-It Felix Jr Launcher.ahk script to launch it? Below are the paths setup in mine. GamePath=C:\Emulation\roms\PC Games\Fix-It Felix Jr\Fixitfelixjr.exe ; the full path and exe of FixitFelixJr.exe BezelPath=C:\Emulation\roms\PC Games\Fix-It Felix Jr\bezel.png ; the full path and extension to bezel file Thanks, Ron Ow, use HyperLaunch to run it. I'll try that.
RetroBorg Posted December 17, 2013 Posted December 17, 2013 I've done some (pretty terrible) editing and I've got some more sound effectshttp://www.filedropper.com/sound4 - a coin going into the machine, from the movie introduction http://www.filedropper.com/sound18 - Ralph splatting into the mud http://www.filedropper.com/sound19 - Ralph falling off the building, part two http://www.filedropper.com/sound23 - Ralph falling off the building, part one http://www.filedropper.com/sound28 - Gene screaming yeah, this is my first time editing audio, but I hope I did well enough also, does anyone have Felix's death sound that I could use please? The links don't seem to be working or do you need a file dropper account? Would really like to try these sounds.
gigapig Posted December 17, 2013 Posted December 17, 2013 tried a couple of different things but still no luck im thinking it could be in the code but not sure... has anyone else run into this? I did have that issue, but no more. Did you resolve it? If not try this thread. www.hyperspin-fe.com/forum/showthread.php?30313-Fix-it-Felix-Junior-has-been-uh-FIXEDG No need to use the script anymore. I think the original Disney leaked version doesn't have the sound samples, but I had another version which the above works fine with.
mrxtreme Posted December 17, 2013 Posted December 17, 2013 I did have that issue, but no more. Did you resolve it? If not try this thread. www.hyperspin-fe.com/forum/showthread.php?30313-Fix-it-Felix-Junior-has-been-uh-FIXEDGNo need to use the script anymore. I think the original Disney leaked version doesn't have the sound samples, but I had another version which the above works fine with. oh nice! i'll give it a shot, i was still having the same issues but hopefully with the new link i can get it running smooth.
Mrmikey73 Posted December 17, 2013 Posted December 17, 2013 Does anyone have the new sound files for this game? I used to have them but when I couldn't get the game to run on my horizontal monitor I just gave up and must have deleted them. This works perfect on my arcade monitor using xp64!! Thanks gigapig
gigapig Posted December 17, 2013 Posted December 17, 2013 Does anyone have the new sound files for this game? No problem. Which new sound files? If you mean the voices, eg. "You Moved my Stump", "I'm gonna wreck it" then yes I have a version of the game which has those. You can find it in my ftp folder. There is a zip file up there as well, which i think is the original leaked version, but those sound samples are missing; so grab the rest instead.
Mrmikey73 Posted December 17, 2013 Posted December 17, 2013 Thanks giga! I had the game from your link above and just copied over your data folder for the sounds works perfect. Is there no video for this? I searched emu movies downloads but didn't go into their FTP.
gigapig Posted December 17, 2013 Posted December 17, 2013 Thanks giga! I had the game from your link above and just copied over your data folder for the sounds works perfect. Is there no video for this? I searched emu movies downloads but didn't go into their FTP. I search for it now and again, but nothing. I also tried grabbing something from youtube but everything on there is poor. So might need to make my own, hang on, I think I tried that as well but at the time couldn't get the sound recorded; might try again.
gigapig Posted December 19, 2013 Posted December 19, 2013 Hi,Check my ftp Can't see a video snap for FFJ in your ftp, if that is what you meant.
Polemicist Posted December 19, 2013 Posted December 19, 2013 Can't see a video snap for FFJ in your ftp, if that is what you meant. He is still using the old folder. Nice one shinobi will download now. Thanks.
gigapig Posted December 19, 2013 Posted December 19, 2013 He is still using the old folder. Nice one shinobi will download now. Thanks. What old folder? The old ft doesn't exist anymore, so if you enlighten me Mr Polemicist I would be grateful.
Polemicist Posted December 20, 2013 Posted December 20, 2013 The old FTP does exist. You can login to both. Jeepguy is still using the old one as well. LOL yes even the old guys are making that mistake.
gigapig Posted December 20, 2013 Posted December 20, 2013 The old FTP does exist. You can login to both. Jeepguy is still using the old one as well. LOL yes even the old guys are making that mistake. Sorry Sir, I was under the impression that it had been removed, going by this statement from Rain. PLEASE NOTEThe old FTP will be dissolved on 12/2/2013, under no circumstance is anyone to upload new media to this server as it will not be carried over to the new server. Please use the information above to connect to the new FTP system. Thank you. Strange how that video snap got uploaded or not transferred. Perhaps Rain has been busy. Thanks for the Snap.
Polemicist Posted December 20, 2013 Posted December 20, 2013 Yeah Rain was not aware that it was still up and running, They are looking into it now. Hope everyone grabbed their stuff before it gets really turned off. I'd put money on people making posts saying "The FTP server isn't working" for a week after it gets deleted.
