mameuifx64 No Nag 0.166
oldhag270
  • Replies 55
any chance of doin one without direct input cus my light gun not working with this one for mameuifx. had to go back to .163
If I'm not mistaken you can turn Direct Input off in mameuifx by yourself(I could be wrong).
Not sure where in the current version you disable this, I thought mame stopped using direct input many versions ago, hence the option to disbale is gone.
People with two light guns (myself included) need a compile with no direct input.
I'll be the first to put my hand up and say I've tried to compile many time with no success.
If anyone could compile one would be much appreciated.
File Name: mameuifx64 0.166
File Submitter: oldhag270
File Submitted: 02 Oct 2015
File Category: OtherCredits: oldhag270 & MAME Developers &mameuifx Developers
Here is mameuifx64 0.166 with Hi Score+No Nag+Direct input
not sure if you are aware that directinput enable/disable + hiscore is already built-in into mameuifx, so the the patch is not required; just need to check it in the misc menu of mameuifx.
when the directinput is patch in, it cannot be disable, its hard-coded enable.
only the no nag and white box msg need to be patch. just throwing out some info thats all, keep up the work.
Sent from my SM-N900V using Tapatalk
That's really interesting to know. Is it possible to do one with only no nag patch to try please?
The no nag is working but I seem to have no mouse support even though they appear to be turned on. If I go back to my previous version it's working. How do I turn it on?
Where is this in misc tab? Got the "no nag only version " but no mouse support with last updated version.
I av no mouse either so u cant use ur light gun. I found another compile over at insertmorecoins and that worked with mouse support and light gun works also.
