R0CK632 Posted October 15, 2015 Posted October 15, 2015 Hey Guys I am a severe nube here and have watched countless youtube videos and read threads but still cant get anything on hyperspin to work. To test out I download approx 700 genesis roms and the Gens Emulator. When I open the emulator and test out the games everything works. I goto Rocketlauncher Changed the Global Gens Emulator path to the path where my Exe file is. Went to the the Sega Genesis Emulators and Set Rom path to the tolder I have all my roms in. Set the default emulator to Gens. Set 7z value to true because the roms are still zipped files. Goto the Games section and do an audit of system games and None are found. I cant figure out what on earth iam doing wrong? Please help; I also tried using Dons Generator Tool and downloaded the XML file from the hyperlist file on the hyperspin site and that doesnt find any games either.
drewjbx1 Posted October 15, 2015 Posted October 15, 2015 Did you place the xml file In the rocketlauncher/database folder? In database folder should be the exact same name as your system ie: Sega Genesis/Sega genesis.xml Also rom names need to be exact in the xml Sent from my iPhone using Tapatalk
gigapig Posted October 15, 2015 Posted October 15, 2015 Firstly welcome to the forum R0ck. When you added the emu path under Global did you check the extension was correct? Are your Roms named exactly the same as the XML? Have you named the system correctly? Everything needs to exact where naming is concerned. That's all I can think of at the moment as you seem to be doing pretty well so far.
R0CK632 Posted October 15, 2015 Author Posted October 15, 2015 Ok Thanks so Far, I had to change the names to the exact way the XML file was so now it turns green and says found when i do an audit but when I select a file and hit the red launch arrow i get the following error...Could not find "3 Ninjas Kick Back (USA) Inside the archive with any defined rom extensions. Check if you are missing the correct Rom Extension for this rom for Gens's Extensions, enable Rom_match_Extension, or correct the file name inside the archive.. Damn this stuff is frustrating. Thanks for the help again guys EDIT- FIGURED IT OUT THE GLOBAL SECTION WAS MISSING THE GEN FILE EXTENSION. THANKS AGAIN FOR NOW LOL
gigapig Posted October 15, 2015 Posted October 15, 2015 Did you place the xml file In the rocketlauncher/database folder? I'm curious drew, why do you have a RocketLauncher database folder? Rock, glad you go it sorted.
R0CK632 Posted October 15, 2015 Author Posted October 15, 2015 New Problem... Using ZSnesw Emulator. When in Rocketlauncherand Adding Roms and checking them in the audit. When I launch through the audit the file loads fine. If I go into Hyperspin and try to load it says missing rom extension in .ini. any thoughts? thanks in advance. It's doing in genesis too..everything loads fine in rocket launcher but not in hyperspin..all say missing or extension in .ini.
Metalzoic Posted October 15, 2015 Posted October 15, 2015 New Problem... Using ZSnesw Emulator. When in Rocketlauncherand Adding Roms and checking them in the audit. When I launch through the audit the file loads fine. If I go into Hyperspin and try to load it says missing rom extension in .ini. any thoughts? thanks in advance. It's doing in genesis too..everything loads fine in rocket launcher but not in hyperspin..all say missing or extension in .ini. Sounds like you might need to set your extensions, rom paths etc... in Hyperspin. You do that in HyperHQ That is seperate from RLauncher and needs to be done if you use any special options/rom filters in Hyperspin.
R0CK632 Posted October 15, 2015 Author Posted October 15, 2015 how might one do that I cannot seem to figure it out. Also in HyperHQ and when i setlect the Genesis. Under emulator, the executable path is that suppose to goto my Gens.Exe? or the Rocketlauncher.exe? And I set the rom path to the Rom Folder correct?
gigapig Posted October 15, 2015 Posted October 15, 2015 There is no need to add anything to HypeHQ unless you are using Wheel filters. Please post your HyperSpin and RocketLauncher logs.
R0CK632 Posted October 15, 2015 Author Posted October 15, 2015 heres my hyperspin log 05:39:16 AM | HyperSpin Started05:39:16 AM | Going windowed mode05:39:16 AM | Checking for updates05:39:16 AM | Update Check Complete05:39:16 AM | Startup program unavailable05:39:16 AM | Playing intro video05:39:17 AM | Error intializing joysticks05:39:17 AM | Menu Mode is multi05:39:17 AM | Loading Main Menu.xml05:39:17 AM | Main Menu.xml successfully loaded05:39:18 AM | Main Menu wheel loaded successfully05:39:18 AM | Loading Sega Genesis.xml05:39:18 AM | Main Menu.xml successfully loaded05:39:19 AM | Sega Genesis wheel loaded successfully05:39:19 AM | Launching Game05:39:19 AM | Using HyperLaunch05:39:19 AM | Getting Launcher path05:39:19 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:19 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:19 AM | Running Launcher05:39:19 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "3 Ninjas Kick Back (USA)"05:39:20 AM | Launching Game05:39:20 AM | Using HyperLaunch05:39:20 AM | Getting Launcher path05:39:20 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:20 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:20 AM | Running Launcher05:39:20 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "3 Ninjas Kick Back (USA)"05:39:21 AM | Launching Game05:39:21 AM | Using HyperLaunch05:39:21 AM | Getting Launcher path05:39:21 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:21 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:21 AM | Running Launcher05:39:21 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "3 Ninjas Kick Back (USA)"05:39:21 AM | Launching Game05:39:21 AM | Using HyperLaunch05:39:21 AM | Getting Launcher path05:39:21 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:21 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:21 AM | Running Launcher05:39:21 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "3 Ninjas Kick Back (USA)"05:39:21 AM | Launching Game05:39:21 AM | Using HyperLaunch05:39:21 AM | Getting Launcher path05:39:21 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:21 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:21 AM | Running Launcher05:39:21 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "3 Ninjas Kick Back (USA)"05:39:22 AM | Launching Game05:39:22 AM | Using HyperLaunch05:39:22 AM | Getting Launcher path05:39:22 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:22 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:22 AM | Running Launcher05:39:22 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "3 Ninjas Kick Back (USA)"05:39:23 AM | Launching Game05:39:23 AM | Using HyperLaunch05:39:23 AM | Getting Launcher path05:39:23 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:23 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:23 AM | Running Launcher05:39:23 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "6-Pak (USA)"05:39:23 AM | Launching Game05:39:23 AM | Using HyperLaunch05:39:24 AM | Getting Launcher path05:39:24 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:24 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:24 AM | Running Launcher05:39:24 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "6-Pak (USA)"05:39:24 AM | Launching Game05:39:24 AM | Using HyperLaunch05:39:24 AM | Getting Launcher path05:39:24 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:24 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:24 AM | Running Launcher05:39:24 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "6-Pak (USA)"05:39:24 AM | Launching Game05:39:24 AM | Using HyperLaunch05:39:24 AM | Getting Launcher path05:39:24 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:24 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:24 AM | Running Launcher05:39:24 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "6-Pak (USA)"05:39:24 AM | Launching Game05:39:24 AM | Using HyperLaunch05:39:24 AM | Getting Launcher path05:39:24 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:24 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:24 AM | Running Launcher05:39:24 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "6-Pak (USA)"05:39:25 AM | Launching Game05:39:25 AM | Using HyperLaunch05:39:25 AM | Getting Launcher path05:39:25 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:25 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:25 AM | Running Launcher05:39:25 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:26 AM | Launching Game05:39:26 AM | Using HyperLaunch05:39:26 AM | Getting Launcher path05:39:26 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:26 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:26 AM | Running Launcher05:39:26 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:26 AM | Launching Game05:39:26 AM | Using HyperLaunch05:39:26 AM | Getting Launcher path05:39:26 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:26 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:26 AM | Running Launcher05:39:26 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:26 AM | Launching Game05:39:26 AM | Using HyperLaunch05:39:26 AM | Getting Launcher path05:39:26 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:26 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:26 AM | Running Launcher05:39:26 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:26 AM | Launching Game05:39:26 AM | Using HyperLaunch05:39:26 AM | Getting Launcher path05:39:26 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:26 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:26 AM | Running Launcher05:39:26 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:26 AM | Launching Game05:39:26 AM | Using HyperLaunch05:39:27 AM | Getting Launcher path05:39:27 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:27 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:27 AM | Running Launcher05:39:27 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:27 AM | Launching Game05:39:27 AM | Using HyperLaunch05:39:27 AM | Getting Launcher path05:39:27 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:27 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:27 AM | Running Launcher05:39:27 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:27 AM | Launching Game05:39:27 AM | Using HyperLaunch05:39:27 AM | Getting Launcher path05:39:27 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:27 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:27 AM | Running Launcher05:39:27 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:27 AM | Launching Game05:39:27 AM | Using HyperLaunch05:39:27 AM | Getting Launcher path05:39:27 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:27 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:27 AM | Running Launcher05:39:27 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:27 AM | Launching Game05:39:27 AM | Using HyperLaunch05:39:27 AM | Getting Launcher path05:39:27 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:27 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:27 AM | Running Launcher05:39:27 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:27 AM | Launching Game05:39:28 AM | Using HyperLaunch05:39:28 AM | Getting Launcher path05:39:28 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:28 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:28 AM | Running Launcher05:39:28 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:28 AM | Launching Game05:39:28 AM | Using HyperLaunch05:39:28 AM | Getting Launcher path05:39:28 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:28 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:28 AM | Running Launcher05:39:28 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:28 AM | Launching Game05:39:28 AM | Using HyperLaunch05:39:28 AM | Getting Launcher path05:39:28 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:28 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:28 AM | Running Launcher05:39:28 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:28 AM | Launching Game05:39:28 AM | Using HyperLaunch05:39:28 AM | Getting Launcher path05:39:28 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:28 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:28 AM | Running Launcher05:39:28 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:29 AM | Launching Game05:39:29 AM | Using HyperLaunch05:39:29 AM | Getting Launcher path05:39:29 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:29 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:29 AM | Running Launcher05:39:29 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:29 AM | Launching Game05:39:29 AM | Using HyperLaunch05:39:29 AM | Getting Launcher path05:39:29 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:29 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:29 AM | Running Launcher05:39:29 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:29 AM | Launching Game05:39:29 AM | Using HyperLaunch05:39:29 AM | Getting Launcher path05:39:29 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:29 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:29 AM | Running Launcher05:39:29 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:29 AM | Launching Game05:39:29 AM | Using HyperLaunch05:39:29 AM | Getting Launcher path05:39:29 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:29 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:29 AM | Running Launcher05:39:29 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:30 AM | Launching Game05:39:30 AM | Using HyperLaunch05:39:30 AM | Getting Launcher path05:39:30 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:30 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:30 AM | Running Launcher05:39:30 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:30 AM | Launching Game05:39:30 AM | Using HyperLaunch05:39:30 AM | Getting Launcher path05:39:30 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:30 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:30 AM | Running Launcher05:39:30 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:30 AM | Launching Game05:39:30 AM | Using HyperLaunch05:39:30 AM | Getting Launcher path05:39:30 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:30 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:30 AM | Running Launcher05:39:30 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:30 AM | Launching Game05:39:30 AM | Using HyperLaunch05:39:30 AM | Getting Launcher path05:39:30 AM | Can't find HyperLaunch, defaulting to root HyperLaunch.exe05:39:30 AM | Launcher located at C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe05:39:30 AM | Running Launcher05:39:30 AM | Launcher Command Line is: C:\Users\DiPasquales\Desktop\HyperSpin\HyperLaunch.exe "Sega Genesis" "Action 52 (USA) (Unl)"05:39:35 AM | Sega Genesis wheel loaded successfully05:39:35 AM | Sega Genesis wheel loaded successfully05:39:36 AM | Sega Genesis wheel loaded successfully05:39:36 AM | Sega Genesis wheel loaded successfully05:39:38 AM | Sega Genesis wheel loaded successfully05:39:38 AM | Sega Genesis wheel loaded successfully05:39:39 AM | Sega Genesis wheel loaded successfully05:39:39 AM | Sega Genesis wheel loaded successfully05:39:41 AM | Cannot find Genre.xml05:39:43 AM | Cannot find Genre.xml05:39:44 AM | Cannot find Genre.xml05:39:46 AM | Sega Genesis wheel loaded successfully05:39:46 AM | Sega Genesis wheel loaded successfully05:39:52 AM | Sega Genesis wheel loaded successfully05:39:52 AM | Sega Genesis wheel loaded successfully05:39:55 AM | Sega Genesis wheel loaded successfully05:39:55 AM | Sega Genesis wheel loaded successfully05:39:59 AM | Loading Main Menu.xml05:39:59 AM | Main Menu.xml successfully loaded05:40:00 AM | Main Menu wheel loaded successfully05:40:06 AM | Exit program unavailable05:40:06 AM | Quiting Hyperspin05:40:06 AM | Bye! Rocket launcher log 05:11:56:295 | RL | INFO | +N/A | Main - RocketLauncher v1.0.1.3 (www.rlauncher.com) 05:11:56:415 | RL | INFO | +109 | Main - System Specs: RocketLauncher Dir: C:\Rocket Launcher\RocketLauncher RocketLauncher is: 32-bit OS: Microsoft Windows 7 Home Premium SKU: Home Premium Total Memory: 4058.96 MB Free Memory: 2612.52 MB Used Memory: 1446.441 MB SystemType: 64-bit Physical Processors: 1 Logical Processors: 2 GPU 1 Name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1) GPU 1 RAM: 1805.48 MB GPU 1 Driver Version: 8.15.10.1749 GPU 2 Name: Mobile Intel(R) 45 Express Chipset Family (Microsoft Corporation - WDDM 1.1) GPU 2 RAM: 0.00 MB GPU 2 Driver Version: 8.15.10.1749 Sound 1 Device: High Definition Audio Device Sound 1 Status: Enabled Sound 2 Device: High Definition Audio Device Sound 2 Status: Enabled OS Language: English_United_States OS Admin Status: No Latest .Net Version: v4.0.30319 Monitor #1 (\\.\DISPLAY1): 1280x800 (1280x760 work) [Landscape] (Primary) Current AHK Desktop Width: 1280 Current AHK Desktop Height: 800 AutoHotkey Path: AHK Version: 1.1.09.04 Unicode: No 05:11:56:415 | RL | INFO | +0 | CheckFile - Checking if C:\Rocket Launcher\RocketLauncher\RocketLauncher.exe exists 05:11:56:416 | RL | INFO | +0 | Main - Loading Front End Plugin: "HyperSpin" 05:11:56:417 | RL | INFO | +0 | Main - RocketLauncher received "Sega Genesis" and "3 Ninjas Kick Back (USA)" 05:11:56:427 | RL | INFO | +16 | Main - Did not find a "C:\Rocket Launcher\RocketLauncher\Settings\Sega Genesis\Game Options.ini" file, skipping any game-specific options. 05:11:56:428 | RL | INFO | +0 | Main - 3 Ninjas Kick Back (USA) is using the default emulator: Gens 05:11:56:428 | RL | INFO | +0 | Main - Checking for a [Gens] section in C:\Rocket Launcher\RocketLauncher\Settings\Sega Genesis\Emulators.ini 05:11:56:428 | RL | INFO | +0 | Main - Checking for a [Gens] section in C:\Rocket Launcher\RocketLauncher\Settings\Global Emulators.ini 05:11:56:428 | RL | INFO | +0 | Main - Found [Gens] in C:\Rocket Launcher\RocketLauncher\Settings\Global Emulators.ini 05:11:56:429 | RL | INFO | +0 | CheckFile - Checking if C:\Rocket Launcher\RocketLauncher\Modules\Gens\Gens.ahk exists 05:11:56:435 | RL | INFO | +16 | Main - CRC Check - CRC matches, this is an official unedited module. 05:11:56:435 | RL | INFO | +0 | Main - 3 Ninjas Kick Back (USA) will use module: C:\Rocket Launcher\RocketLauncher\Modules\Gens\Gens.ahk 05:11:56:459 | RL | INFO | +15 | Main - Using standard method with "Rom Extension" SkipChecks or without any SkipChecks. 05:11:56:461 | RL | INFO | +0 | CheckFile - Checking if C:\Users\DiPasquales\Desktop\Emulators\GEN_EMULATOR\gens.exe exists 05:11:56:462 | RL | INFO | +0 | Main - INI Keys read 05:11:56:463 | RL | INFO | +0 | CheckFile - Checking if C:\Rocket Launcher\RocketLauncher\Module Extensions\7z.exe exists 05:11:56:464 | RL | INFO | +0 | CheckFile - Checking if C:\Rocket Launcher\RocketLauncher\Module Extensions\7z.dll exists 05:11:56:470 | RL | INFO | +16 | Main - "3 Ninjas Kick Back (USA)" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: (Disc,(Disk,(Cart,(Tape,(Cassette,(Part,(Side 05:11:56:470 | RL | INFO | +0 | CheckPaths - Started 05:11:56:470 | RL | INFO | +0 | CheckPaths - Found rom: C:\Users\DiPasquales\Desktop\ROMS\Correct Genesis\3 Ninjas Kick Back (USA).gen 05:11:56:471 | RL | INFO | +0 | CheckPaths - Ended 05:11:56:498 | RL | INFO | +31 | BuildScript - Loaded XHotkey Init.ahk scripts 05:11:56:498 | RL | INFO | +0 | BuildScript - Loaded Statistics Init.ahk scripts 05:11:56:499 | RL | WARNING | +0 | BuildScript - "C:\Rocket Launcher\RocketLauncher\Lib\User Functions Init.ahk" not found 05:11:56:499 | RL | INFO | +0 | BuildScript - Validating module 05:11:56:499 | RL | INFO | +0 | BuildScript - Validation complete 05:11:56:672 | RL | INFO | +172 | BuildScript - Loaded Multi-Player scripts 05:11:56:673 | RL | INFO | +0 | BuildScript - Loaded Statistics.ahk script 05:11:56:673 | RL | WARNING | +0 | BuildScript - "C:\Rocket Launcher\RocketLauncher\Lib\User Functions.ahk" not found 05:11:56:673 | RL | INFO | +0 | BuildScript - Finished injecting functions into module 05:11:56:675 | RL | INFO | +0 | Main - Module is built 05:11:56:675 | RL | INFO | +0 | CheckFile - Checking if C:\Rocket Launcher\RocketLauncher\AutoHotkey.dll exists 05:11:56:682 | RL | INFO | +0 | Main - Running module 05:11:56:830 | MD | INFO | +N/A | Module initialized 05:11:56:834 | MD | INFO | +0 | StartModule - Started 05:11:56:834 | MD | INFO | +0 | StartModule - MEmu: Gens MEmuV: v2.14 MURL: http://segaretro.org/Gens MAuthor: djvj MVersion: 2.0.1 MCRC: 7B3AF9E0 iCRC: 2805229D MID: MSystem: "Sega CD","Sega Genesis","Sega Mega Drive","Sega Mega-CD" 05:11:56:834 | MD | INFO | +0 | StartModule - You have a supported System Name for this module: "Sega Genesis" 05:11:56:836 | MD | INFO | +0 | PluginInit - Started 05:11:56:836 | MD | INFO | +0 | CheckFile - Checking if C:\Users\DiPasquales\Desktop\HyperSpin\Databases\Sega Genesis\Sega Genesis.xml exists 05:11:56:932 | MD | INFO | +93 | PluginInit - Ended 05:11:56:953 | MD | INFO | +31 | StartModule - Ended 05:11:56:953 | MD | INFO | +0 | Module Setting - [Settings] - Fullscreen: true 05:11:56:953 | MD | INFO | +0 | Module Setting - [Settings] - Stretch: true 05:11:56:953 | MD | INFO | +0 | 7z - Started, received C:\Users\DiPasquales\Desktop\ROMS\Correct Genesis\3 Ninjas Kick Back (USA).gen. If rom is an archive, it will extract to C:\TEMP GAME HS 05:11:56:953 | MD | INFO | +0 | 7z - This rom type does not need 7z: ".gen" 05:11:56:953 | MD | INFO | +0 | 7z - Ended 05:11:56:953 | MD | INFO | +0 | CheckFile - Checking if C:\Users\DiPasquales\Desktop\Emulators\GEN_EMULATOR\Gens.cfg exists 05:11:57:012 | MD | INFO | +63 | Run - Running: C:\Users\DiPasquales\Desktop\Emulators\GEN_EMULATOR\gens.exe "C:\Users\DiPasquales\Desktop\ROMS\Correct Genesis\3 Ninjas Kick Back (USA).gen" 05:11:57:092 | MD | INFO | +78 | WinWait - Waiting for "Gens ahk_class Gens" 05:11:57:296 | MD | INFO | +203 | WinWaitActive - Waiting for "Gens ahk_class Gens" 05:11:58:762 | MD | INFO | +1466 | Process - WaitClose gens.exe 05:12:00:387 | MD | INFO | +1622 | WinClose - Closing: Gens ahk_class Gens 05:12:03:643 | MD | INFO | +3261 | 7zCleanUp - Started 05:12:03:643 | MD | INFO | +0 | 7zCleanUp - Ended 05:12:03:643 | MD | INFO | +0 | ExitModule - Started 05:12:03:643 | MD | INFO | +0 | Starting Updating Statistics: 05:12:04:354 | MD | INFO | +702 | Game section statistics updated. 05:12:04:423 | MD | INFO | +78 | ExitModule - Ended 05:12:04:423 | MD | INFO | +0 | End of Module Logs 05:12:04:459 | RL | INFO | +7784 | Main - Module ended, exiting RocketLauncher normally 05:12:04:459 | RL | INFO | +0 | ExitScript - Started 05:12:04:486 | RL | INFO | +31 | SystemCursor - Restoring mouse cursor 05:12:04:497 | RL | INFO | +0 | ExitScript - Ended
thcdgaf Posted October 15, 2015 Posted October 15, 2015 sounds to me like your rocketlauncher path isnt set so its defaulting to hyperlauncher.exe
gigapig Posted October 15, 2015 Posted October 15, 2015 You need to edit the settings.ini file found in the HyperSpin\settings folder. You need to edit this line to the full path to RL. [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=MAME Hyperlaunch_Path=C:\HyperSpin\RocketLauncher\RocketLauncher.exe
drewjbx1 Posted October 16, 2015 Posted October 16, 2015 I'm curious drew, why do you have a RocketLauncher database folder? Rock, glad you go it sorted. Ahh right.. I Was thinking of modules folder. Database is in my hyperspin root. Thx for the correction [emoji16] Sent from my iPhone using Tapatalk
thegreatiandi Posted October 16, 2015 Posted October 16, 2015 Just want to say, it's so awesome how everyone is always helpful here at hyperspin forums. No one is EVER a jerk...or I did it, you figure it out. We all help... Awesome to be a part of :thefinger:I do my fighting in the real world, In a sanctioned cage or ring, not online tough guys:eviltongue: Gracie Trained. Purple Belt Get some
R0CK632 Posted October 16, 2015 Author Posted October 16, 2015 Thanks for the help guys fixed the issue..In the Settings ini I had the path set to just the location.. I had to add rocket launcher.exe to the end of the path like gigipig suggested. That is why rocket launcher wasn't opening.. everything is going soo smooth now. thanks again for all the help wveryone. The simpliest thing was driving me nuts for days
mccorkled Posted October 16, 2015 Posted October 16, 2015 Thanks for the help guys fixed the issue..In the Settings ini I had the path set to just the location.. I had to add rocket launcher.exe to the end of the path like gigipig suggested. That is why rocket launcher wasn't opening.. everything is going soo smooth now. thanks again for all the help wveryone. The simpliest thing was driving me nuts for days Glad you got it sorted out, even though this is what we were trying to get you to do in the chat last night Aeon Nox XIII Themes Minted Cases w/ Reflection : Minted Cases : Minted XMLs
jcm9800 Posted October 16, 2015 Posted October 16, 2015 you should turn off 7z in rocketlauncher settings because its not needed for sega genesis if you launch with fusion is green why your zipped roms are correct named but inside the Zips not [sIGPIC][/sIGPIC]
mikeclark22 Posted December 23, 2015 Posted December 23, 2015 GigaPig Thank you so much, i was literally beaten my head against the wall for the last 45 mins trying to find this. Thank you again! Happy Holidays!
TheWolfslinker Posted May 26, 2016 Posted May 26, 2016 the saved files have to be the same name as the ones it says in HL or RL and such, make sure they all say the same thing
DJQuad Posted August 28, 2016 Posted August 28, 2016 You need to edit the settings.ini file found in the HyperSpin\settings folder. You need to edit this line to the full path to RL. [Main] Menu_Mode=multi Single_Mode_Name=MAME Enable_Exit_Menu=true Enable_Exit=true Exit_Default=yes Exit_Action=exit Version=1.0.0.0 Last_System=MAME Hyperlaunch_Path=C:\HyperSpin\RocketLauncher\RocketLauncher.exe Old thread I know but does the Hyperlaunch_Path have to be an absolute path? I have mine set to Hyperlaunch_Path=..\..\RocketLauncher\RocketLauncher.exe I believe that's causing an error when launching a game in HyperSpin, but it runs fine launching from RocketLauncherUI. http://imgur.com/a/JKlNd
maddies1985 Posted December 9, 2016 Posted December 9, 2016 I am the same problem with Rocket Launcher 1.4 Aduting any roms for any system it all comes back pink. I did what all the youtube videos said so like the guy of the original post. everything is in the ROOT dir for me that is C Global is set to false and each system is set to true under 7z . I read this post and not sure if I am understanding the answers to the original owners post. I am using windows 10, I made all the exe to have admin rights thinking that was the issue , even i gave admin rights to 7z.exe my rom path is C:\Hyperspin\Roms Rocket Launder is C:\RocketLauncher Hyperspin path is C:\Hyperspin I am not sure which ini you need to change under settings and I am not sure what you mean by XML file beacuse there is lots of those, and do i change these in both hyperspin and in rocket launcher?? thanks if there is a youtube video showing me the answer to the original owners post so I can actually see the solution I am using RetroArch as the emulator for each system, if that matters or not Thanks in advance.
KRIS85 Posted March 3, 2017 Posted March 3, 2017 Hello plis tell me whether the HS can turn on the counter meter display how many games in the wheels, because in each of wheels missing games ??
chickenwingmm Posted September 11, 2017 Posted September 11, 2017 I know the names have to be exactly the same as in the xml but what if i dont have an xml file for the large folder of roms i have? all the roms are named slightly differently is there a place to generate this? i dont think fixing every single file is the only way, please no. im also new to the emulator game
chickenwingmm Posted September 11, 2017 Posted September 11, 2017 On 10/16/2015 at 1:45 AM, R0CK632 said: Thanks for the help guys fixed the issue..In the Settings ini I had the path set to just the location.. I had to add rocket launcher.exe to the end of the path like gigipig suggested. That is why rocket launcher wasn't opening.. everything is going soo smooth now. thanks again for all the help wveryone. The simpliest thing was driving me nuts for days So did you end up just renaming each file? theres thousands lol
