HyperSearch Open Source
pietie
HyperSearch.exe -search
So under HyperHQ your executable will be HyperSearch.exe and params will be -search
I just grabbed the version in beta 2. Hq has the exe file path, parameter is -search. When I try opening the wheel is just get a blank command prompt
Tapatalk signature
  • Replies 186
I just tested the beta and so far no crash with HyperMarquee! :D
EDIT: Damn, tried some more and scrolled up and down in the result list, same behaviour as before, many instances of Hyper Marquee is spawned and it crashes.
Maybe you and the Hyper Marquee author could look at it together?
Please download and try again. Antos pointed out a couple of issues that I believe are now fixed. He is looking at something on EDS' side as well but maybe this prevents the crash.
My tools
Steam wheel creator - Generate xml list from Steam profile with artwork and videos
HyperSearch - Integrates search functionality with HyperSpin
I can sent you my settings XML as well as my HyperSearch.ahk
That's how I've been calling HyperSearch from my main wheel.
Can you post this AHK? I would like to test it to see if the ahk fixes my focus issue. If it doe, I think it should be included in pieties package
CPU usage is pretty crazy, 25% used by Hypersearch.exe basically it eats up a core.
I believe the CPU usage should be much better in the latest upload
My tools
The OSK layouts are not currently exposed. I've been meaning to do that so I've added it to my todo list.
On a side note. Would you (or anyone else really) be interested in assisting me with designing a couple of different themes? If you can supply me with mockups with color values/design elements I can attempt to translate them to xaml. I'd like to offer users a choice between a couple of themes...
Would try to do that ... will post as soon as I have them ready :)
#thisismydesign by ryuuji is licensed under a Creative Commons Attribution-NonCommercial-NoDerivatives 4.0 International License.
Permissions beyond the scope of this license may be available at
http://www.hyperspin-fe.com/user/34679-ryuuji/.
I ve made something in Photoshop
*note: this is just a idea, the letters/numbers look distorted because I used a screenshot of my current hypersearch theme... all letters and numbers are supposed to use Calibri(light) font.
* adding FULL SEARCH button if possible (ignoring anything you typed)
*also the bottom can be cropped
That looks pretty good but I dont like how the keyboard is fully extended on the left side. The A is never under the Q like and Z is never under A. The right side is good because of the "search" button
YES! This time it seems to be really fixed! :D
NICE JOB!
i would like to report that Hypersearch is working much better, not displaying issue with eds nor hypermarquee.
still remains is the focus issue and keyboard input is not detectable at the moment.
good job pietie overall
How do you mean? Just normal typing? Make sure that CabMode is turned off.
My tools
The design of aeon nox 5 keyboard is really plain
In aeon nox 4 it was a bit better but anyway quite "boring" (in older xbmc versions it was a bit more interesting :P)
Is it posssible to link .png in the program for keyboard and GUI graphics instead of defining them by code? I think it can make skinning easier and more accessible :P The current gui does match decently Aeon Nox XIII, if png can't be used I guess a darker blue for GUI and a blue select bar on list/keyboard would do the trick.
Is it possible to stretch the font and the GUI in the .xaml or source code for 16:9 ratio correction? Fonts should be bebas neue
Is it now possible to select an alternative folder for system and wheel images?
The new build seems OK with cpu usage, it uses 100% of one core while starting and reading the database then quickly sits near 0% (tested also on a p4 3ghz). Moreover, the annoying input bug I had with older version on my HTPC seems to have been addressed, thank you very much :D
thanks will test tonight
Tapatalk signature
I may be mental but how do I test this?
Tapatalk signature
Please grab the latest upload and try again, thanks.
just to notify you that the keyboard input is working again, thank you.
let me know any way that i can help you further, glad to help anyway that i can
the input from kb is working now
but videos still not playing (most of them)
it looks like in some systems (MAME in this case) the hypersearch is looking into Frontend video instead of MAME video ... or maybe the way are encoded ?
Video failed: file:///E:/Inochi/Media/Frontend/Video/No Video.flv, with error: System.IO.FileNotFoundException: Media file download failed. ---> System.Runtime.InteropServices.COMException (0xC00D0FEA): Exception from HRESULT: 0xC00D0FEA
Do you perhaps have custom video paths setup? Please turn on verbose logging and post the full log...
My tools
