Hyperspin 1.3.2 very laggy
epac90
Title pretty much says it. I was running Hyperspin 1.2, and it ran great. However, when I upgraded to 1.3.2, I get alot more lag (wheels, animations, everything). I have a phenom II 965 at 3.6ghz (200mhz overclock) and 4Gb's of RAM, that should be well more than enough to run it. I also have flash player 11 installed and updated. I've seen several other people in some other threads that have the same problem, is this currently being worked on? I have not updated my vids to .mp4's, still using .flv's, though I don't think this would cause this issue. Is anybody else still having this problem? If so, what did you do to fix it? Thanks.
Also, my main reason for upgrading is that I'm really wanting to try out the new Hyperlaunch. Is it possible to use RocketLauncher with Hyperspin 1.2?
change the optimizer settings in HQ and drop them down to low (app quality) if u have too also CPU priority should be high, should solve ur problem :)
goodluck
i will the say the same like epac i run on a high end system core i7 3770k overclocked 16 gb ram gtx 680 and i also see that the old hyperspin build runs better
[sIGPIC][/sIGPIC]
I have the app quality on HIGH at the moment, also I'm at work so I can't change it right now. Is there a very noticable difference from say LOW to HIGH? I'm mainly just wondering why 1.3.2 would run worse than 1.2, especially since I believe it added better multi-core support. Like I said, 1.2 runs great on HIGH, 1.3.2 is much worse.
Apart from proving a point, why would you want to turn all the good stuff off? Especially on your system.
Sometimes I have more than 1 instance of Hyperspin running, not sure why. It may slow things down.
Press cntl alt del, go to processes and see if Hyperspin appears more than once.
Exactly. I shouldn't have to turn anything down. All of my graphics settings have stayed the same, yet run worse with the newest .exe. I have not looked to see if multiple instances of Hyperspin is running, I'll be sure to check that when I get home. Is it possible to use RocketLauncher with Hyperspin 1.2? I know that 1.3.2 has a definable path for Hyperlaunch's location, is there anyway to do this with 1.2?
I think I get multiple instances because I'm in and out of HS, testing. I don't think it closes properly.
You cannot use RL with older versions of HS. Sorry not entirely true.
There is some talk about this issue (may be related) here.
http://www.hyperspin-fe.com/forum/showthread.php?26829-Mortal-Kombat-9-PC-THEME
You can use RL with an older hs but you need a dummy hyperlaunch exe to forward the launch command to the real one
Only BBB can answer why there is a performance difference.
Sent from my SCH-I535 using Tapatalk 4 Beta
If you appreciate my work:
My Apps:
Window Logger
Idle Volume Adjuster
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
I guess I'll try turning the settings down and dealing with it for now, maybe there will be a 1.3.3 addressing some of the performance issues. Djvj, I'm a complete noob at Hyperlaunch so I really don't know how to set that up, and it seems like it may just be easier to deal with a little lag on the frontend.
I have also noticed multiple Hyperspin.exe processes running. I do not think it is closing properly sometimes.
HyperPin Manager | HyperSpin Manager | HyperSpin Checker | HyperSpin Renamer
ASRock Z77 Extreme4 MB | Core i5 3570K | Coolermaster Hyper212 EVO CPU cooler | 16GB RAM | OCZ Vertex 4 128Gb SSD (Windows 8) | OCZ Vertex 4 256Gb SSD (HS and all emulators and media) | Gigabyte GTX670 2Gb video card | 27" ASUS LED monitor | 650W Corsair PSU
Turn it down. You won't notice any difference whatsoever except smoothness.
Just turned it all off in the optimizer. It's ok, but not as cool, you loose a lot of animations, so I turned it all on again. I suppose you can be selective.
It lagged anyway when it started up.
Anyone running off an SSD and getting lag?
I didn't say anything about turning off animations. I said turn down the quality from HIGH. You lose no animations and far less lag.
djvj can you make such an application that its possible to take the old one hyperspin i think there are many people here the would go back to the much smoother old exe or you knowing if bbb working on an update?
[sIGPIC][/sIGPIC]
I think high is just higher than it used to be. Like zero jay said I think three times now YOU WON'T NOTICE THE DIFFERENCE
HyperSpin Website Admin Team
Also Visit EmuMovies.com
Hyperspin does indeed not close properly. Sometimes it will not even start. If I look at the processes, it is being run multiple times. I haven't figured out yet what triggers this behaviour.
i have now tried to set it down on medium but the stutters dont go away i dont think this problem has something to do with the quality there are more bugs in the new hyperspin build hope this will be fixed or possible to go back to the old one with the new hyperlaunch because i dont wont to chance back and lose the great step forward with the new hyperlauch
[sIGPIC][/sIGPIC]
Dear Mr DJVJ
From your underground bunker, could you make me a intelligent, sexy woman from a plastic doll and magazine clippings, while wearing a bra on your head?
You can do anything.:)
May I suggest for testing purposes take Hyperspin out of full screen mode, if you notice a marginal improvement in performance it might be you PC is struggling running Hyperspin at your full desktop resolution.
This might not be ideal but try lowering you desktop resolution then test Hyperspin in full screen mode, this inproved preformance for me.
Sent from my GT-N7105 using Tapatalk 2
I made a HyperLaunch Forwarder for older HS versions. You can find it on dropbox under the "HyperLaunch Forwarder" folder.
Read the included readme.txt for instructions on how to use.
My Apps:
Window Logger
ExplorerRestorer
Rom Folder Cleaner
Module Updater
My Guides:
Shame as most of the 2000+ mame video updates were never released in flv format :(
But you can use the emumovies one click converter to convert the current mp4s to flv
Sent from my iPad using Tapatalk HD
I did use the Emumovies converter for the new videos, I had the other still on a backup (just in case the update went wrong?) I'm very happy with this solution ver. 1.1 is the stable version and I never had any trouble with it. ( like wheel keep spinning, exit issues, flag and strobe don't work etc) I think I'll just wait for a stable 1.4 or 1.5 version before I let this version go ? By the way I'll be glad to help test different versions if needed...
Sent from my {Nokia Lumia 925} using Board Express
Build your cabinet, conquer the codes, become a King of Chaos!
