gigapig Posted May 31, 2015 Author Posted May 31, 2015 They will be red as these games are Roms and you cannot add a Rom path so there is nothing for RLUI to cross match. Did you add the games and paths in "Edit Global Module Settings" ? Post your log.
DR9 Posted May 31, 2015 Posted May 31, 2015 Found out the problem, disabled FADE and saw it was stuck at the security prompt to run the .exe because of no digital signature. Sometimes, windows itself won't allow some .EXE files running without admin rights, so you can "force admin" in these by doing the following: Right-click in the game main executable (or the .EXE you want to test) and choose "properties". Go to the "compatibility" tab, then check "Run this program as an administrator", and click on OK Tip for disabling prompts in 7 and probably 8 is here: http://twigstechtips.blogspot.com/2009/08/windows-7-disable-file-security-warning.html
jedah Posted June 4, 2015 Posted June 4, 2015 First off, I would like to say thank you to Gigapig and langersld for putting all of this together. I now have a complete set of games launching in Hyperspin with very little effort. I have a couple of questions though. When setting the configs for a 360 pad and copying the config across to all relevant games that use the same bindings I have noticed that none of my games accept diagonal movement. I have had this setup before I had a hard drive crash and I don't think I had this issue last time. So it is something I have done. Does anyone know the cause of this could be? Also a couple of games look very stretched and blocky (Chaos Breaker and KOF'98 for example). I think it is because I am using a wide screen TV and the image is being stretched 16:9 instead of 4:3. Is there a way of changing this so it looks a bit closer to what I believe should be it's correct screen size? Lastly, I cant seem to enable bezels for any game the normal way (rocketlauncher/media). Do they need to be enabled a different way? I figured this may help with the above games. Cheers, J.
gigapig Posted June 5, 2015 Author Posted June 5, 2015 I'm glad you got it up and running so quick. I'm not sure about your control issues unless you need to reconfigure them. You could also check out the ftp folder of urbangangsta101 who did a bunch of different configs based on game type. You can sometimes change the resolution by opening either the gameres.dat or setting.arc But as you'd like bezels working check out the ftp for alexdc22 who did some great bezels and we put together some files as well so the res and window changes.
jedah Posted June 5, 2015 Posted June 5, 2015 Hi Giga, Thanks for the response. I will look into the controller suggestions. I think I know where I am going wrong with the bezels.
jedah Posted June 6, 2015 Posted June 6, 2015 I thought I would post my findings regarding no diagonals on a wireless 360 pad. I ended up using the taito config tool to set the directions as the cursor keys and set the buttons normally, I then made an xpadder profile for each taito game and just mapped cursors to the analog and d-pad. This worked really well and will also allow you to use the analog stick instead of the d-pad if required. The reason I did a config per game is because some other games require other buttons to be configured so this seemed like the best solution. I have no idea why the controller was behaving like this, but this fix works (for me, at least). Just thought I would post it for anyone else having the same issue. I do have a couple of questions. I still can't get bezels to work. Does anyone else use these for type x? If so do you have any tips on how to set them up as I think they are set up differently to other emulators bezels? Also before modifying Street fighter IV Arcade Edition 2012. The single player version ran fine, however after the 2 player mod the resolution is set too high for my p.c. and runs noticeably slower. I can see the graphics settings are different as the boot up sequence writing is tiny compared to the 1 player version. Does anyone know how to change this? Cheers
epayson85 Posted July 16, 2015 Posted July 16, 2015 Hey guys does anyone know what happened to the thread about setting up Taito games while having a dolphin bar? I have seen the link passed around a couple times but it seems the thread is gone? http://www.hyperspin...ETOOTH)-Trouble
epayson85 Posted July 17, 2015 Posted July 17, 2015 FYI for those that come here looking here is the new link for those having trouble with a dolphinbar http://www.hyperspin-fe.com/topic/7465-mayflash-dolphin-bar-and-taito-type-x-bluetooth-trouble/
Yardley Posted August 4, 2015 Posted August 4, 2015 Hey guys, launching some of the TTX games is very "dirty", Arcana Heart for example has a nasty flash for me (see video). Is there anything that can be done about this or is this how it looks for for you guys as well. Can some check and let me know? Thanks
gigapig Posted August 4, 2015 Author Posted August 4, 2015 Have you tried some slightly longer fade times? Yours are a lot shorter than mine. I can't test mine at the moment but I'll try to remember.
emoney Posted August 4, 2015 Posted August 4, 2015 Don't know if this is a Hyperspin or RL problem. I am a noob to hyperspin and rocketlauncher and I am having the hardest time setting up TTX. I am able to get the games running outside the app, as well from the rocket icon in rocketlauncher.But when I go into Hyperspin it does not launch regardless of what buttons I press. No error message, just not launching at all.I followed GIGA's guide on YouTube to set up.I don't know if this is a simple setup issue that is common to PCLauncher and TTX.Any help would be great.I am running the latest RL on Windows 7 box with an AMD 6800 series gpuI have taken some steps noted in the forum such as:- skip rom and emu check.- checked the PCLauncher module is running as virtual emulator with no rom or emu path.Could this be related to controls of the game itself not getting the "start" button to launch the file.Another thing I was wondering if this is related to the .bat file and if Windows will allow that to run as a precaution, I lowered my securty settings to see if that could be preventing it from running. None have been successful. I am at a lost.Thanks in advance.
gigapig Posted August 4, 2015 Author Posted August 4, 2015 So emoney, you've said the games are working when you run them via the bat file outside HS and when you click the Rocket icon in RLUI? If that is true and RocketLauncher isn't running in the task manager then it must be a HS issue. Perhaps it's your version, are you using 1.3 and have not rerun the Transition tool if you just added this system? Post the HS log and maybe the settings INI for TTX.
Yardley Posted August 4, 2015 Posted August 4, 2015 Have you tried some slightly longer fade times? Yours are a lot shorter than mine. I can't test mine at the moment but I'll try to remember. I'll play with the fade times. If you can try yours and report back that would be great. Thanks.
emoney Posted August 4, 2015 Posted August 4, 2015 So emoney, you've said the games are working when you run them via the bat file outside HS and when you click the Rocket icon in RLUI? If that is true and RocketLauncher isn't running in the task manager then it must be a HS issue. Perhaps it's your version, are you using 1.3 and have not rerun the Transition tool if you just added this system? Post the HS log and maybe the settings INI for TTX. That is correct. I can launch the bat outside. I should have the latest HS as I just got into HS and I did not have a previous version. In another forum I read that the "execution" set to normal instead of hyperlaunch but the results the same. Here is my HS log which basically says that it cannot find the file. 06:29:53 PM | HyperSpin Started 06:29:53 PM | Going windowed mode 06:29:53 PM | Checking for updates 06:29:53 PM | Update Check Complete 06:29:53 PM | Startup program unavailable 06:29:53 PM | Error intializing joysticks 06:29:53 PM | Menu Mode is multi 06:29:53 PM | Loading Main Menu.xml 06:29:53 PM | Main Menu.xml successfully loaded 06:29:54 PM | Main Menu wheel loaded successfully 06:30:13 PM | Loading Taito Type X.xml 06:30:13 PM | Main Menu.xml successfully loaded 06:30:14 PM | Taito Type X wheel loaded successfully 06:30:39 PM | Launching Game 06:30:39 PM | Not using HyperLaunch 06:30:39 PM | Running as PC Game from Sub Menu 06:30:39 PM | Error Cannot Find File: Street Fighter IV. 06:30:40 PM | Launching Game 06:30:40 PM | Not using HyperLaunch 06:30:40 PM | Running as PC Game from Sub Menu 06:30:40 PM | Error Cannot Find File: Street Fighter IV. 06:30:41 PM | Launching Game 06:30:41 PM | Not using HyperLaunch 06:30:41 PM | Running as PC Game from Sub Menu 06:30:41 PM | Error Cannot Find File: Street Fighter IV. 06:30:41 PM | Launching Game 06:30:41 PM | Not using HyperLaunch 06:30:41 PM | Running as PC Game from Sub Menu 06:30:41 PM | Error Cannot Find File: Street Fighter IV. 06:30:42 PM | Launching Game 06:30:42 PM | Not using HyperLaunch 06:30:42 PM | Running as PC Game from Sub Menu 06:30:42 PM | Error Cannot Find File: Street Fighter IV. 06:30:43 PM | Launching Game 06:30:43 PM | Not using HyperLaunch 06:30:43 PM | Running as PC Game from Sub Menu 06:30:43 PM | Error Cannot Find File: Street Fighter IV. 06:30:49 PM | Launching Game 06:30:49 PM | Not using HyperLaunch 06:30:49 PM | Running as PC Game from Sub Menu 06:30:49 PM | Error Cannot Find File: Street Fighter IV. 06:30:51 PM | Loading Main Menu.xml 06:30:51 PM | Main Menu.xml successfully loaded 06:30:52 PM | Main Menu wheel loaded successfully 06:30:54 PM | Loading Taito Type X.xml 06:30:54 PM | Main Menu.xml successfully loaded 06:30:55 PM | Taito Type X wheel loaded successfully 06:31:09 PM | Taito Type X wheel loaded successfully 06:31:12 PM | Taito Type X wheel loaded successfully 06:31:12 PM | Taito Type X wheel loaded successfully 06:31:13 PM | Taito Type X wheel loaded successfully 06:31:15 PM | Taito Type X wheel loaded successfully 06:31:15 PM | Taito Type X wheel loaded successfully 06:31:17 PM | Taito Type X wheel loaded successfully 06:31:17 PM | Taito Type X wheel loaded successfully 06:31:19 PM | Taito Type X wheel loaded successfully 06:31:20 PM | Taito Type X wheel loaded successfully 06:31:20 PM | Taito Type X wheel loaded successfully 06:31:22 PM | Taito Type X wheel loaded successfully 06:31:23 PM | Taito Type X wheel loaded successfully 06:31:23 PM | Taito Type X wheel loaded successfully 06:31:25 PM | Taito Type X wheel loaded successfully 06:31:27 PM | Taito Type X wheel loaded successfully 06:31:27 PM | Taito Type X wheel loaded successfully 06:32:52 PM | Launching Game 06:32:52 PM | Not using HyperLaunch 06:32:52 PM | Running as PC Game from Sub Menu 06:32:52 PM | Error Cannot Find File: Street Fighter IV. 06:32:53 PM | Launching Game 06:32:53 PM | Not using HyperLaunch 06:32:53 PM | Running as PC Game from Sub Menu 06:32:53 PM | Error Cannot Find File: Street Fighter IV. 06:32:54 PM | Launching Game 06:32:54 PM | Not using HyperLaunch 06:32:54 PM | Running as PC Game from Sub Menu 06:32:54 PM | Error Cannot Find File: Street Fighter IV. 06:33:00 PM | Taito Type X wheel loaded successfully 06:33:00 PM | Cannot find Genre.xml 06:33:11 PM | Launching Game 06:33:11 PM | Not using HyperLaunch 06:33:11 PM | Running as PC Game from Sub Menu 06:33:11 PM | Error Cannot Find File: Trouble Witches AC. 06:33:11 PM | Launching Game 06:33:11 PM | Not using HyperLaunch 06:33:11 PM | Running as PC Game from Sub Menu 06:33:11 PM | Error Cannot Find File: Trouble Witches AC. 06:33:12 PM | Launching Game 06:33:12 PM | Not using HyperLaunch 06:33:12 PM | Running as PC Game from Sub Menu 06:33:12 PM | Error Cannot Find File: Trouble Witches AC. 06:33:13 PM | Launching Game 06:33:13 PM | Not using HyperLaunch 06:33:13 PM | Running as PC Game from Sub Menu 06:33:13 PM | Error Cannot Find File: Trouble Witches AC. 06:33:14 PM | Launching Game 06:33:14 PM | Not using HyperLaunch 06:33:14 PM | Running as PC Game from Sub Menu 06:33:14 PM | Error Cannot Find File: Trouble Witches AC. 06:33:14 PM | Launching Game 06:33:14 PM | Not using HyperLaunch 06:33:14 PM | Running as PC Game from Sub Menu 06:33:14 PM | Error Cannot Find File: Trouble Witches AC. 06:33:14 PM | Launching Game 06:33:14 PM | Not using HyperLaunch 06:33:14 PM | Running as PC Game from Sub Menu 06:33:14 PM | Error Cannot Find File: Trouble Witches AC. 06:33:15 PM | Launching Game 06:33:15 PM | Not using HyperLaunch 06:33:15 PM | Running as PC Game from Sub Menu 06:33:15 PM | Error Cannot Find File: Trouble Witches AC. 06:33:23 PM | Launching Game 06:33:23 PM | Not using HyperLaunch 06:33:23 PM | Running as PC Game from Sub Menu 06:33:23 PM | Error Cannot Find File: BlazBlue Calamity Trigger. 06:33:49 PM | Launching Game 06:33:49 PM | Not using HyperLaunch 06:33:49 PM | Running as PC Game from Sub Menu 06:33:49 PM | Error Cannot Find File: Street Fighter IV. 06:33:51 PM | Launching Game 06:33:51 PM | Not using HyperLaunch 06:33:51 PM | Running as PC Game from Sub Menu 06:33:51 PM | Error Cannot Find File: Street Fighter IV. 06:34:55 PM | Launching Game 06:34:55 PM | Not using HyperLaunch 06:34:55 PM | Running as PC Game from Sub Menu 06:34:55 PM | Error Cannot Find File: Street Fighter IV. 06:34:55 PM | Launching Game 06:34:55 PM | Not using HyperLaunch 06:34:55 PM | Running as PC Game from Sub Menu 06:34:55 PM | Error Cannot Find File: Street Fighter IV. 06:34:57 PM | Launching Game 06:34:57 PM | Not using HyperLaunch 06:34:57 PM | Running as PC Game from Sub Menu 06:34:57 PM | Error Cannot Find File: Street Fighter IV. 06:34:57 PM | Launching Game 06:34:57 PM | Not using HyperLaunch 06:34:57 PM | Running as PC Game from Sub Menu 06:34:57 PM | Error Cannot Find File: Street Fighter IV. 07:13:12 PM | Launching Game 07:13:12 PM | Not using HyperLaunch 07:13:12 PM | Running as PC Game from Sub Menu 07:13:12 PM | Error Cannot Find File: Homura. 07:13:12 PM | Launching Game 07:13:12 PM | Not using HyperLaunch 07:13:12 PM | Running as PC Game from Sub Menu 07:13:12 PM | Error Cannot Find File: Homura. 07:13:12 PM | Launching Game 07:13:12 PM | Not using HyperLaunch 07:13:12 PM | Running as PC Game from Sub Menu 07:13:12 PM | Error Cannot Find File: Homura. 07:13:12 PM | Launching Game 07:13:12 PM | Not using HyperLaunch 07:13:12 PM | Running as PC Game from Sub Menu 07:13:12 PM | Error Cannot Find File: Homura. 07:13:13 PM | Launching Game 07:13:13 PM | Not using HyperLaunch 07:13:13 PM | Running as PC Game from Sub Menu 07:13:13 PM | Error Cannot Find File: Homura. 07:13:13 PM | Launching Game 07:13:13 PM | Not using HyperLaunch 07:13:13 PM | Running as PC Game from Sub Menu 07:13:13 PM | Error Cannot Find File: Homura. 07:13:13 PM | Launching Game 07:13:13 PM | Not using HyperLaunch 07:13:13 PM | Running as PC Game from Sub Menu 07:13:13 PM | Error Cannot Find File: Homura. 07:13:13 PM | Launching Game 07:13:13 PM | Not using HyperLaunch 07:13:14 PM | Running as PC Game from Sub Menu 07:13:14 PM | Error Cannot Find File: Homura. 07:13:14 PM | Launching Game 07:13:14 PM | Not using HyperLaunch 07:13:14 PM | Running as PC Game from Sub Menu 07:13:14 PM | Error Cannot Find File: Homura. 07:13:14 PM | Launching Game 07:13:14 PM | Not using HyperLaunch 07:13:14 PM | Running as PC Game from Sub Menu 07:13:14 PM | Error Cannot Find File: Homura. 07:13:14 PM | Launching Game 07:13:14 PM | Not using HyperLaunch 07:13:14 PM | Running as PC Game from Sub Menu 07:13:14 PM | Error Cannot Find File: Homura. 07:13:14 PM | Launching Game 07:13:14 PM | Not using HyperLaunch 07:13:14 PM | Running as PC Game from Sub Menu 07:13:14 PM | Error Cannot Find File: Homura. 07:13:24 PM | Quiting Hyperspin 07:13:24 PM | Bye! Taito Type X ini: [exe info] path= rompath= userompath= exe= romextension= parameters= searchsubfolders= pcgame=true winstate=HIDDEN hyperlaunch=false Per_Game_Modules=false Skipchecks=false Hide_Cursor=use_global Hide_Desktop=use_global Hide_Taskbar=use_global CPWizard_Enabled=use_global CPWizard_Delay=use_global CPWizard_Params=use_global Fade_In=use_global Fade_Out=use_global Fade_Color=use_global Fade_In_Duration=use_global Fade_Out_Duration=use_global Fade_In_Delay=use_global 7z_Enabled=use_global 7z_Extract_Dir=use_global 7z_Delete_Temp=use_global Keymapper_Enabled=use_global Keymapper=use_global MultiGame_Enabled=use_global MultiGame_Background_Color=use_global MultiGame_Side_Padding=use_global MultiGame_Y_Offset=use_global MultiGame_Image_Adjust=use_global MultiGame_Font=use_global MultiGame_Text_1_Options=use_global MultiGame_Text_1_Text=use_global MultiGame_Text_2_Options=use_global MultiGame_Text_2_Offset=use_global MultiGame_Use_Sound=use_global MultiGame_Sound_Frequency=use_global MultiGame_Exit_Effect=use_global MultiGame_Selected_Effect=use_global MultiGame_Use_Game_Art=use_global MultiGame_Art_Folder=use_global [filters] parents_only=false themes_only=false wheels_only=false roms_only=false [themes] use_parent_vids=false use_parent_themes=false animate_out_default=false reload_backgrounds=false [wheel] alpha=.15 small_alpha=1 style=normal speed=high pin_center_width=500 horz_wheel_y=512 vert_wheel_position=right y_rotation=center norm_large=360 norm_small=230 vert_large=400 vert_small=240 pin_large=500 pin_small=200 horz_large=240 horz_small=150 letter_wheel_x=800 letter_wheel_y=384 text_width=700 text_font=Style4 small_text_width=260 large_text_width=400 text_stroke_size=6 text_stroke_color=0x000000 text_color1=0x00BFFD text_color2=0xFFFFFF text_color3=0x00BFFD color_ratio=139 shadow_distance=0 shadow_angle=45 shadow_color=0x000000 shadow_alpha=1 shadow_blur=0 [pointer] animated=true x=975 y=384 [video defaults] path=D:\Hyperspin\Media\Taito Type X\Video\ [sounds] game_sounds=true wheel_click=true [navigation] game_jump=50 use_indexes=true jump_timer=400 remove_info_wheel=false remove_info_text=false use_last_game=false last_game=Street Fighter IV random_game=false start_on_favorites=false [special Art A] default=false active=true x=512 y=720 in=0.4 out=0.4 length=3 delay=0 type=normal start=bottom [special Art B] default=true active=true x=512 y=740 in=0.4 out=0.4 length=3 delay=0 type=fade start=none [special Art C] active=true x=512 y=384 in=0 out=0 length=3 delay=10 type=fade start=none [Game Text] game_text_active=true show_year=true show_manf=true show_description=true text_color1=0xffffff text_color2=0x0099cc stroke_color=0x000000 text_font=Style1 text1_textsize=26 text1_strokesize=7 text1_x=32 text1_y=610 text2_textsize=36 text2_strokesize=8 text2_x=30 text2_y=640 Thanks for your help!
gigapig Posted August 5, 2015 Author Posted August 5, 2015 OK, so your log shows that you are using "Normal" execution so you'll need to changecit to Hyperlaunch. The next question is which version of HyperSpin are you using? Are you using RocketLauncher or HyperLaunch? As you say you've just installed it I'll assume it's the former. If you're using HyperSpin 1.3 and RocketLauncher you'll need to rerun the Transition tool if you have just added the TTX wheel.
emoney Posted August 5, 2015 Posted August 5, 2015 I have HS ver. 1.3.3. Set back to Hyperlaunch. Do I need to run the transition tool? i never had hyperlaunch.
gigapig Posted August 5, 2015 Author Posted August 5, 2015 Yes I think you need to every time you add a new system.
emoney Posted August 5, 2015 Posted August 5, 2015 I have the transition tool and it is looking for the Hyperlaunch folder. I never had hyperlaunch. I started with rocketlauncher.
ninja2bceen Posted August 5, 2015 Posted August 5, 2015 Yes I think you need to every time you add a new system. If you are running1.4 do you have to ru. The transition tool every time u add a new wheel too? Tapatalk signature Looking for letter makers. Volunteer http://www.hyperspin-fe.com/topic/10813-project-assignments/ To see what hyperspin still needs... http://hyperbase.hyperspin-fe.com/ Advance the cause to 100%. http://hyperbase.hyperspin-fe.com/ Planet Geekdom, Subscribe for Tutorials! https://www.youtube.com/channel/UCdcby-s2GwriaOHGmVC2vGA?sub_confirmation=1&app=desktop
emoney Posted August 6, 2015 Posted August 6, 2015 Yes I think you need to every time you add a new system. OK. I see so HS is trying to run HL, which I don't have. I run the update tool to to have HS use the RL.exe which has all my settings. Will give it a go and see you on the other side..I hope. Update: Updating the Hyperspin inis did it. Using the Hyperspin 1.3 selection and Update only worked out. Thanks again gigapig
glstar Posted August 10, 2015 Posted August 10, 2015 I can't remeber if Street Fighter IV could be run in two players mode and can works without the need of networks too. someone could help me please?
gigapig Posted August 11, 2015 Author Posted August 11, 2015 I can't remeber if Street Fighter IV could be run in two players mode and can works without the need of networks too. someone could help me please? I'm pretty sure that version is single player only and you may be able to disable network in the service mode. My advice would be to just use SSFIVAE 2012 and patch it for 2 players.
SIMPLYAUSTIN Posted August 11, 2015 Posted August 11, 2015 I can't remeber if Street Fighter IV could be run in two players mode and can works without the need of networks too. someone could help me please? Here you go mate Simply Austin's YouTube
glstar Posted August 11, 2015 Posted August 11, 2015 Thank you. Just what i thought... I'll go with super street fighter 4 then....
zillion23 Posted August 13, 2015 Posted August 13, 2015 I am having a problem with Arcana Heart 2 and 3 since I upgraded to windows 10 with my wireless xbox controller. If I have the controller turned on, the games will not launch but if I turn the controller off they launch just fine. Anybody else having these issues? I think they might have changed something with the xbox controllers.
