JFlash3785 Posted January 5, 2014 Posted January 5, 2014 I'm all set with design and dimensions. Which should I use and why MDF or plywood. 1. They are about the same price 2. Plywood is a bit lighter and will last longer 3. Plywood is more durable. Why use MDF over plywood?
djvj Posted January 5, 2014 Posted January 5, 2014 It's smoother and easier to cut/shape and doesn't splinter off, cabs have been made since forever using mdf for those reasons. You can get lightweight mdf also which can help bring down the weight issue a little. "Computer games don't affect kids; I mean if Pac-Man affected us as kids, we'd all be running around in darkened rooms, munching magic pills and listening to repetitive electronic music."RocketLauncher's Official Home If you appreciate my work:My Apps:Window LoggerIdle Volume AdjusterExplorerRestorerRom Folder CleanerModule UpdaterMy Guides:How To Mod Guncons with Aimtrak
connorsdad Posted January 5, 2014 Posted January 5, 2014 Don't forget to check what thickness of material you need to use if applying tmoulding. Sent from my SM-N9005 using Tapatalk
somail Posted January 6, 2014 Posted January 6, 2014 MDF is exponentially easier to work with. For the cabinet itself I highly recommend 3/4 MDF. For the control panel you are okay with 1/2 MDF or comparable strength plywood. I just built a small cab out of plywood as my friend requested one as light as possible. It can be a pain to say the least. Routing and doweling plywood is an exercise in patience, but very doable once you know what you are doing. If you use plywood I highly suggest using laminate for the outside (order it at lowes or Home Depot). Paint and decals (unless you sand) are not able to hide big mistakes.
Polemicist Posted January 6, 2014 Posted January 6, 2014 MDF is my vote. The lightweight stuff is great (I prefer heavy weight) but remember that MDF is basically sawdust and glue compressed so lightweight just means the pressure is lower which makes it a little more susceptible to water ingress so make sure you seal it very well all over especially on edges. They make compounds you can use to seal the edges which if you have to money is a great way to improve how long the MDF lasts. Word vomit. Enough of my guff.
Fursphere Posted January 6, 2014 Posted January 6, 2014 djvj said: It's smoother and easier to cut/shape and doesn't splinter off, cabs have been made since forever using mdf for those reasons. You can get lightweight mdf also which can help bring down the weight issue a little. I just sledgehammered a Area 51 cabinet that had a minor amount of water damage to the lower area. The moister caused the entire cabinet to become brittle. I don't like "MDF" for that reason. But you have to be careful when you talk about "MDF" - because what we get today is not what those old cabinets were made out of. That Area 51 looked more like particle board. My Turbo Outrun mini cabinet is also made with similar materials... closer to "particle board" than what I would consider (today's) MDF board. I suggest some simple googling to get a better idea of "MDF" vs "particle board" vs "chip board" vs "plywood" - so when you buy, you know what you are looking for, and are not at the mercy of bad labeling. The reason I posted this is my local Home Depot AND Lowes label particle board "MDF" WRONG all the time, and its NOT the same thing. Like the melamine covered "MDF" board (white melamine on one side). Thats particle / chip board. Very brittle when compared to what this forum (generally) considers "MDF"
jeepguy81 Posted January 6, 2014 Posted January 6, 2014 +1 on the MDF comments, especially if there's going to be some structural weight bearing. Built allot of audio crap over the years out of just about any and all type of paneled wood, and MDF is by far easier to work with, you end up with a much better finish. Granted it can have a bit more weight, but when you're filling and sanding and filling and sanding for the X number of times, you stop caring about weight lol. Definitely keep what Fursphere said in mind, my local HD has crap labeled all of the place. One day they had 1/2 in MDF as chip board...?? - Vertical-Cocktail Cab Theme Project
