Launching Pinabll FX2 without Steam?
Attack_theTITANS
I'm having a hard time getting Pinball FX2 and Pinball Arcade to load without steam.
They play by themselves without steam, but through RocketLauncher and Hyperspin, it says cannot find Steam etc...
Any suggestions on what to do?
I downloaded mine as a stand alone pc game so I really don't know about the steam version I just renamed my pinball fx2 rocketlauncher module example to pinball fx2 and it was already set up.
Here is what the notes say if that helps any
 Notes:
; If launching as a Steam game:
; When setting this up in RocketLauncherUI under the global emulators tab, make sure to select it as a Virtual Emulator. Also no rom extensions, executable, or rom paths need to be defined. You can put an extension of pxp if you want RLUI audit to work however. It will not affect launching.
; Set Skip Checks to "Rom and Emu" when using this module as roms do not exist.
Sorry I can't help you out more I don't have steam.
Mine is also a stand alone game. I didn't get it through steam, hell it isn't even istalled on my computer.
But when I try to launch a table it says "Steam cannot be found"
I followed the module notes too so I really don't get why this is happening
Did you rename your pinball fx2 module ini example to pinball fx2?
It's been awhile when I set this one up so I may not be the best one to answer this quetion.
Here is a old gigapig tutorial if that helps
Yeah I did. I even tried using an older module I downloaded and a different version of Pinball FX2 to see if it would make a difference but none.
I had it working a couple weeks ago and decided to start my Hyperspin project over from scratch,
so this is really bugging me because I truly don't get what is going wrong
What program is asking for Steam? If it's the game then perhaps the crack isn't working. If it's Rocketlauncher then you will need the latest version of the game which should have cab launching.
You also need the correct xml if launching via the new launch method not the old grid launch.
It's also possible you have set it up incorrectly as the standalone version is set slightly differently.
  • 2 months later...
I have the same issue.
I have the latest version of FX2 with Alien & Predator (71 tables) and it's a non steam version, but I do have Steam installed. It's working outside RL/HS.
So when I try to start a game via RL, it looks like it's starting (Loading Game) but then it stops after a while and when the Fade is away I see a window to install FX2 in Steam.
Then I exit and close Steam and tried again but then it comes up with:
Can I set some option somewhere to not open it in Steam mode?
I followed all instructions from the module (set the .exe and virtual emu etc.)
same here, happened after I updated rocketlauncher a few months back, tried asking on the rl forums with no joy so just left it not working
Then I exit and close Steam and tried again but then it comes up with:tapatalk_1469691409082.jpg
What happens if you are logged into steam or not logged in, same results?
Did you post your logs?
When I'm logged into Steam I get the following:
https://s31.postimg.org/kkwyg088r/with_steam_logged_in.png
[code]
14:58:44:412 | RL |      INFO  | +N/A   | Main - RocketLauncher v1.1.1.1 (www.rlauncher.com)
14:58:44:412 | RL |   WARNING  | +0     | Main - Logging level is debug or higher and will cause slowdowns to RocketLauncher's performance. When troubleshooting is finished, please lower logging level to restore proper performance.
14:58:44:702 | RL |     DEBUG  | +281   | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
14:58:44:702 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
14:58:44:703 | RL |      INFO  | +0     | Main - System Specs:
					RocketLauncher Dir: G:\RocketLauncher
					RocketLauncher is: 32-bit
					OS: Microsoft Windows 10 Pro
					SKU: Professional
					Total Memory: 16303.05 MB
					Free Memory: 10812.23 MB
					Used Memory: 5490.824 MB
					SystemType: 64-bit
					Physical Processors: 1
					Logical Processors: 8
					GPU 1 Name: NVIDIA GeForce GTX 580
					GPU 1 RAM: 1536.00 MB
					GPU 1 Driver Version: 10.18.13.6881
					Sound 1 Device: HD Webcam C270
					Sound 1 Status: Enabled
					Sound 2 Device: NVIDIA High Definition Audio
					Sound 2 Status: Enabled
					Sound 3 Device: NVIDIA High Definition Audio
					Sound 3 Status: Enabled
					Sound 4 Device: NVIDIA High Definition Audio
					Sound 4 Status: Enabled
					Sound 5 Device: NVIDIA High Definition Audio
					Sound 5 Status: Enabled
					Sound 6 Device: High Definition Audio-apparaat
					Sound 6 Status: Enabled
					Sound 7 Device: NVIDIA Virtual Audio Device (Wave Extensible) (WDM)
					Sound 7 Status: Enabled
					OS Language: Dutch_Standard
					System Locale: nl-NL
					Formats Locale: en-US
					Windows UI Language: nl-NL
					Text Encoding: Windows-1252
					OS Admin Status: Yes
					RL Compatibility Flags: ~ RUNASADMIN
					Latest .Net Version: v4.0.30319
					Monitor #1 (\\.\DISPLAY1): 1920x1080 (1920x1040 work) [32bit] [60hz] [Landscape]  (Primary)
					Current AHK Desktop Width: 1920
					Current AHK Desktop Height: 1080
					Monitor #1 DPI: 100
					ErrorMode: 0
					AutoHotkey Path:
					AHK Version: 1.1.13.00
					Unicode: No
14:58:44:703 | RL |      INFO  | +0     | CheckFile - Checking if G:\RocketLauncher\RocketLauncher.exe exists
14:58:44:704 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					FileDescription         	RocketLauncher
					FileVersion             	1.1.1.1
					LegalCopyright          	�2016 RocketLauncher
					ProductVersion          	1.1.1.1
					CompanyName             	Your favorite Front End companion! Visit us @ www.rlauncher.com
					File Size:			2179584 bytes
					Created:			1/3/2016 - 6:53:22 PM
					Modified:			7/21/2016 - 9:24:09 AM
14:58:44:705 | RL |      INFO  | +16    | Main - Raw CLI received: "-s Pinball FX2 -r AmericanDad -f G:\HyperSpin\HyperSpin.exe -p HyperSpin -c 1 -o 1"
14:58:44:706 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "G:\RocketLauncher\Module Extensions\RocketLauncher.dll"
14:58:44:707 | RL |      INFO  | +0     | File.CheckFile - Checking if "G:\RocketLauncher\Module Extensions\RocketLauncher.dll" exists
14:58:44:707 | RL |     TRACE  | +0     | File.Exist - This file exists: G:\RocketLauncher\Module Extensions\RocketLauncher.dll
14:58:44:708 | RL |     DEBUG  | +0     | File.CheckFile - Attributes:
					FileDescription         	RocketLauncher Utils
					FileVersion             	1.0.0.9
					InternalName            	RocketLauncher.dll
					LegalCopyright          	Copyright � RocketLauncher 2013-2016
					OriginalFilename        	RocketLauncher.dll
					ProductName             	RocketLauncher
					ProductVersion          	1.0.0.9
					File Size:			68608 bytes
					Created:			1/3/2016 - 6:55:51 PM
					Modified:			7/21/2016 - 9:24:13 AM
14:58:44:726 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\Array.ahk
14:58:44:727 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			4781 bytes
					Created:			1/3/2016 - 6:55:48 PM
					Modified:			5/13/2016 - 9:01:05 PM
14:58:44:753 | RL |      INFO  | +32    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Module Extensions\BinHexRW.ahk | v1.0.2
14:58:44:754 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			5077 bytes
					Modified:			5/13/2016 - 9:00:37 PM
14:58:44:754 | RL |      INFO  | +0     | CheckFile - Checking if G:\RocketLauncher\Module Extensions\BlockInput.exe exists
14:58:44:756 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					FileDescription
					InternalName
					OriginalFilename
					ProductName
					File Size:			657920 bytes
					Modified:			1/3/2014 - 4:27:34 AM
14:58:44:782 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\CLR_L.ahk | vInterop
14:58:44:782 | RL |     DEBUG  | +16    | CheckFile - Attributes:
					File Size:			5323 bytes
					Modified:			5/13/2016 - 9:00:18 PM
14:58:44:804 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\Control_AniGif.ahk | vAniGif.ahk
14:58:44:805 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			5716 bytes
					Created:			1/3/2016 - 6:55:49 PM
					Modified:			4/29/2013 - 7:56:02 PM
14:58:44:817 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\gdip.ahk
14:58:44:818 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			88789 bytes
					Modified:			1/13/2013 - 11:07:30 PM
14:58:44:828 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Module Extensions\gdip_alt.ahk | v1.0.3
14:58:44:829 | RL |     DEBUG  | +16    | CheckFile - Attributes:
					File Size:			5891 bytes
					Modified:			1/20/2016 - 11:38:47 PM
14:58:44:829 | RL |      INFO  | +0     | CheckFile - Checking if G:\RocketLauncher\Module Extensions\gsdll32.dll exists
14:58:44:845 | RL |     DEBUG  | +15    | CheckFile - Attributes:
					File Size:			13090816 bytes
					Modified:			1/7/2015 - 3:20:42 AM
14:58:44:845 | RL |      INFO  | +0     | CheckFile - Checking if G:\RocketLauncher\Module Extensions\itextsharp.dll exists
14:58:44:869 | RL |     DEBUG  | +16    | CheckFile - Attributes:
					FileDescription         	iTextSharp
					FileVersion             	5.4.2.0
					InternalName            	itextsharp.dll
					LegalCopyright          	Copyright (C) 1999-2013 by Bruno Lowagie and Paulo Soares. All Rights Reserved.
					OriginalFilename        	itextsharp.dll
					ProductName             	iTextSharp
					ProductVersion          	5.4.2.0
					CompanyName             	1T3XT BVBA
					File Size:			3743744 bytes
					Created:			1/3/2016 - 6:55:50 PM
					Modified:			6/14/2013 - 8:06:21 PM
14:58:44:876 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Module Extensions\Java.ahk | v1.0.0
14:58:44:877 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			7841 bytes
					Modified:			12/24/2014 - 5:02:37 AM
14:58:44:890 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\JSON.ahk
14:58:44:890 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			9227 bytes
					Modified:			5/13/2016 - 9:00:30 PM
14:58:44:906 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Module Extensions\Origin.ahk | v1.0.2
14:58:44:907 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			4904 bytes
					Modified:			3/22/2015 - 8:51:41 PM
14:58:44:912 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\RegRW64.ahk
14:58:44:913 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			6915 bytes
					Modified:			5/8/2014 - 9:06:39 AM
14:58:44:926 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\RIni.ahk | v1.7
14:58:44:927 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			67562 bytes
					Modified:			7/4/2016 - 3:12:47 PM
14:58:44:927 | RL |      INFO  | +0     | CheckFile - Checking if G:\RocketLauncher\Module Extensions\SevenZipSharp.dll exists
14:58:44:929 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					FileDescription         	SevenZipSharp
					FileVersion             	0.64.5717.6837
					InternalName            	SevenZipSharp.dll
					LegalCopyright          	Copyright (C) Markovtsev Vadim 2009, 2010, licenced under LGPLv3
					OriginalFilename        	SevenZipSharp.dll
					ProductName             	SevenZipSharp
					ProductVersion          	0.64.5717.6837
					CompanyName             	Markovtsev Vadim
					File Size:			167424 bytes
					Modified:			10/7/2015 - 10:51:42 PM
14:58:44:944 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Module Extensions\Steam.ahk | v1.0.3
14:58:44:945 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			5504 bytes
					Modified:			5/18/2016 - 3:28:20 PM
14:58:44:956 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Extension: G:\RocketLauncher\Module Extensions\VA.ahk
14:58:44:957 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			34688 bytes
					Modified:			3/2/2013 - 3:05:47 AM
14:58:44:962 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Module Extensions\VA_Extension.ahk | v1.0.1
14:58:44:963 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			3833 bytes
					Modified:			1/14/2015 - 2:16:56 AM
14:58:44:974 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\7z.ahk | v1.1.0
14:58:44:975 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			31579 bytes
					Created:			1/3/2016 - 6:53:26 PM
14:58:44:989 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Bezel.ahk | v1.2.5
14:58:44:990 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			119247 bytes
					Modified:			7/4/2016 - 3:12:38 PM
14:58:44:003 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Fade.ahk | v1.1.9
14:58:45:004 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			39542 bytes
					Created:			1/3/2016 - 6:53:27 PM
					Modified:			7/4/2016 - 3:12:54 PM
14:58:45:005 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Fade Init.ahk | v1.0.3
14:58:45:006 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			1130 bytes
					Modified:			5/13/2016 - 9:00:24 PM
14:58:45:008 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Fade Animations.ahk | v1.2.4
14:58:45:009 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			77966 bytes
					Modified:			7/21/2016 - 9:24:07 AM
14:58:45:026 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Keymapper.ahk | v1.1.5
14:58:45:027 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			33668 bytes
					Modified:			5/13/2016 - 9:00:50 PM
14:58:45:029 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Keymapper Init.ahk | v1.0.6
14:58:45:030 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			3956 bytes
					Modified:			1/20/2016 - 11:38:23 PM
14:58:45:040 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\MultiGame.ahk | v1.1.0
14:58:45:041 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			41541 bytes
					Modified:			5/13/2016 - 9:00:55 PM
14:58:45:043 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\MultiGame Init.ahk | v1.0.0
14:58:45:044 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			161 bytes
					Modified:			4/14/2013 - 7:33:19 PM
14:58:45:059 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\MultiPlayer.ahk | v1.0.8
14:58:45:060 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			66776 bytes
					Modified:			1/20/2016 - 11:38:50 PM
14:58:45:075 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Pause.ahk | v1.2.4
14:58:45:076 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			397144 bytes
					Modified:			7/4/2016 - 3:12:56 PM
14:58:45:078 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Pause Init.ahk | v1.0.3
14:58:45:078 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			553 bytes
					Modified:			8/26/2015 - 5:00:07 PM
14:58:45:097 | RL |      INFO  | +31    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Password.ahk | v1.0.4
14:58:45:098 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			10121 bytes
					Modified:			5/13/2016 - 9:00:23 PM
14:58:45:111 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\DLL\RocketLauncher.ahk | v1.7.1
14:58:45:112 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			26345 bytes
					Created:			5/13/2016 - 9:01:03 PM
					Modified:			7/21/2016 - 9:24:11 AM
14:58:45:114 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Log\Logger.ahk | v1.1.0
14:58:45:115 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			3098 bytes
					Created:			5/13/2016 - 9:00:27 PM
					Modified:			7/4/2016 - 3:12:40 PM
14:58:45:123 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\MiscUtils.ahk | v1.1.1
14:58:45:124 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			6725 bytes
					Created:			5/13/2016 - 9:00:28 PM
					Modified:			7/4/2016 - 3:12:49 PM
14:58:45:126 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\Environment\Registry.ahk | v1.0.0
14:58:45:126 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			1549 bytes
					Created:			5/13/2016 - 9:00:20 PM
14:58:45:136 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\Environment\StringUtils.ahk | v1.5.1
14:58:45:136 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			7797 bytes
					Created:			5/13/2016 - 9:00:46 PM
					Modified:			7/21/2016 - 9:24:12 AM
14:58:45:138 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\Environment\TimerUtils.ahk | v1.0.0
14:58:45:139 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			2963 bytes
					Created:			5/13/2016 - 9:00:26 PM
					Modified:			7/4/2016 - 3:12:39 PM
14:58:45:145 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\File\File.ahk | v1.6.0
14:58:45:146 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			9146 bytes
					Created:			5/13/2016 - 9:00:59 PM
14:58:45:148 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\File\Folder.ahk | v1.0.0
14:58:45:148 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			648 bytes
					Modified:			7/4/2016 - 3:12:41 PM
14:58:45:160 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\File\IniFile.ahk | v1.0.0
14:58:45:161 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			4412 bytes
					Created:			5/13/2016 - 9:00:56 PM
					Modified:			7/4/2016 - 3:12:55 PM
14:58:45:162 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\File\RIniFile.ahk | v1.1.1
14:58:45:163 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			3741 bytes
					Created:			5/18/2016 - 3:28:20 PM
					Modified:			7/4/2016 - 3:12:37 PM
14:58:45:172 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\File\Process.ahk | v1.5.0
14:58:45:172 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			9584 bytes
					Created:			5/13/2016 - 9:00:14 PM
					Modified:			7/4/2016 - 3:12:50 PM
14:58:45:174 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\File\Emulator.ahk | v1.1.0
14:58:45:175 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			1220 bytes
					Created:			5/18/2016 - 3:28:19 PM
					Modified:			7/4/2016 - 3:12:46 PM
14:58:45:184 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\Input\KeyUtils.ahk | v1.0.1
14:58:45:184 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			5520 bytes
					Created:			5/13/2016 - 9:01:06 PM
14:58:45:186 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\UI\Control.ahk | v1.2.0
14:58:45:187 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			4561 bytes
					Created:			5/13/2016 - 9:00:34 PM
					Modified:			7/4/2016 - 3:12:52 PM
14:58:45:190 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\UI\Window.ahk | v1.2.0
14:58:45:191 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			22846 bytes
					Created:			5/13/2016 - 9:00:11 PM
					Modified:			7/4/2016 - 3:12:51 PM
14:58:45:193 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Classes\Util\UI\WindowTitle.ahk | v1.0.0
14:58:45:194 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			1156 bytes
					Created:			5/13/2016 - 9:00:53 PM
					Modified:			7/4/2016 - 3:12:42 PM
14:58:45:207 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Rom Mapping Launch Menu.ahk | v1.0.7
14:58:45:207 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			72261 bytes
					Modified:			1/20/2016 - 11:38:27 PM
14:58:45:209 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Shader.ahk | v1.0.1
14:58:45:210 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			3943 bytes
					Created:			5/13/2016 - 9:00:05 PM
					Modified:			5/13/2016 - 9:00:05 PM
14:58:45:211 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Shader Init.ahk | v1.0.0
14:58:45:212 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			397 bytes
					Created:			5/13/2016 - 9:01:07 PM
					Modified:			5/13/2016 - 9:01:07 PM
14:58:45:226 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Shared.ahk | v1.4.7
14:58:45:227 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			175721 bytes
14:58:45:242 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Statistics.ahk | v1.0.4
14:58:45:243 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			26810 bytes
14:58:45:245 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Statistics Init.ahk | v1.0.1
14:58:45:246 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			33 bytes
					Modified:			12/24/2014 - 5:23:48 AM
14:58:45:259 | RL |      INFO  | +16    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\Virtual Drive.ahk | v1.0.5
14:58:45:260 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			19148 bytes
					Modified:			5/13/2016 - 9:00:16 PM
14:58:45:274 | RL |      INFO  | +15    | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\XHotkey.ahk | v1.0.4
14:58:45:275 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			26540 bytes
					Modified:			8/26/2015 - 4:59:44 PM
14:58:45:276 | RL |      INFO  | +0     | CRC Check - CRC matches, this is an official unedited Library: G:\RocketLauncher\Lib\XHotkey Init.ahk | v1.0.2
14:58:45:277 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			1063 bytes
					Modified:			8/26/2015 - 5:00:10 PM
14:58:45:277 | RL |     DEBUG  | +0     | Main - Received this dbName with no path via CLI: "AmericanDad"
14:58:45:277 | RL |     DEBUG  | +0     | Main - dbName: AmericanDad
14:58:45:278 | RL |      INFO  | +0     | Main - Loading Front End Plugin: "HyperSpin"
14:58:45:278 | RL |     TRACE  | +0     | Process.__New - Creating new process object for: "G:\HyperSpin\HyperSpin.exe"
14:58:45:278 | RL |     TRACE  | +0     | File.__New - Creating new file object of: "G:\HyperSpin\HyperSpin.exe"
14:58:45:279 | RL |      INFO  | +0     | Main - RocketLauncher received "Pinball FX2" and "AmericanDad"
14:58:45:284 | RL |      INFO  | +16    | Main - Did not find a "G:\RocketLauncher\Settings\Pinball FX2\Game Options.ini" file, skipping any game-specific options.
14:58:45:284 | RL |      INFO  | +0     | Main - AmericanDad is using the default emulator: Pinball FX2
14:58:45:284 | RL |      INFO  | +0     | Main - Checking for a [Pinball FX2] section in G:\RocketLauncher\Settings\Pinball FX2\Emulators.ini
14:58:45:284 | RL |      INFO  | +0     | Main - Checking for a [Pinball FX2] section in G:\RocketLauncher\Settings\Global Emulators.ini
14:58:45:285 | RL |      INFO  | +0     | Main - Found [Pinball FX2] in G:\RocketLauncher\Settings\Global Emulators.ini
14:58:45:287 | RL |      INFO  | +0     | CheckFile - Checking if G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ahk exists
14:58:45:289 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			5510 bytes
					Created:			1/3/2016 - 6:56:04 PM
					Modified:			5/18/2016 - 3:28:26 PM
14:58:45:290 | RL |      INFO  | +0     | Main - CRC Check - CRC matches, this is an official unedited module.
14:58:45:290 | RL |      INFO  | +0     | Main - AmericanDad will use module: G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ahk
14:58:45:300 | RL |   WARNING  | +15    | RIniLoadVar - Created missing Global ini key: "Fade_Click_Through " in section: "Fade" in "G:\RocketLauncher\Settings\Global RocketLauncher.ini"
14:58:45:300 | RL |   WARNING  | +0     | RIniLoadVar - Created missing System ini key: "Fade_Click_Through " in section: "Fade" in "G:\RocketLauncher\Settings\Pinball FX2\RocketLauncher.ini"
14:58:45:327 | RL |      INFO  | +16    | Main - Using SkipChecks method "Rom and Emu" or emuName = "PCLauncher".
14:58:45:328 | RL |      INFO  | +0     | Main - INI Keys read
14:58:45:330 | RL |      INFO  | +16    | CheckFile - Checking if C:\Program Files\7-Zip\7z.exe exists
14:58:45:332 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					FileVersion             	15.14
					InternalName            	7z
					LegalCopyright          	Copyright (c) 1999-2015 Igor Pavlov
					ProductVersion          	15.14
					File Size:			447488 bytes
					Created:			1/3/2016 - 12:33:05 AM
					Modified:			12/31/2015 - 4:15:28 PM
14:58:45:332 | RL |      INFO  | +0     | CheckFile - Checking if C:\Program Files\7-Zip\7z.dll exists
14:58:45:334 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					FileDescription         	7z Plugin
					FileVersion             	15.14
					InternalName            	7z
					OriginalFilename        	7z.dll
					File Size:			1592320 bytes
					Modified:			12/31/2015 - 4:22:03 PM
14:58:45:340 | RL |      INFO  | +0     | Main - "AmericanDad" does not qualify for MultiGame. Only roms with any of these strings in their name are acceptable: \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
14:58:45:341 | RL |   WARNING  | +N/A   | Main - SkipChecks is enabled and set to: Rom and Emu
14:58:45:341 | RL |      INFO  | +0     | CheckPaths - Started
14:58:45:341 | RL |      INFO  | +0     | CheckPaths - Looking for rom: G:\Emulators\Pinball FX2\data_steam\AmericanDad.pxp
14:58:45:342 | RL |      INFO  | +0     | CheckPaths - Found rom: G:\Emulators\Pinball FX2\data_steam\AmericanDad.pxp
14:58:45:342 | RL |     DEBUG  | +0     | CheckPaths - Current romName: AmericanDad
14:58:45:342 | RL |     DEBUG  | +0     | CheckPaths - Current romPath: G:\Emulators\Pinball FX2\data_steam
14:58:45:343 | RL |     DEBUG  | +0     | CheckPaths - Current romExtension: .pxp
14:58:45:343 | RL |      INFO  | +0     | CheckPaths - Ended
14:58:45:344 | RL |      INFO  | +0     | BuildScript - User Variables:
					; INJECTED VARIABLES
					#NoTrayIcon
					#InstallKeybdHook
					MiscUtils.DetectHiddenWindows("On")
					SetTitleMatchMode, 2
					SendMode, Event
					0 = 12
					rlPath = G:\RocketLauncher
					pluginPath = G:\RocketLauncher\Plugins
					pluginName = HyperSpin
					pluginExt = .plugin
					contextOnExit = 1
					rlMode =
					rlTitle = RocketLauncher
					rlVersion = 1.1.1.1
					rlAuthor = djvj
					rlURL = www.rlauncher.com
					langFile = G:\RocketLauncher\Data\Language\Localization.ini
					primMonitor = 1
					frontendPID =
					frontendPath = G:\HyperSpin
					frontendExe = HyperSpin.exe
					frontendExt = exe
					frontendName = HyperSpin
					frontendDrive = G
					exitEmulatorKey = ~Esc
					restoreFE = false
					exitScriptKey = ~PGUP & ~PGDN
					toggleCursorKey = ~e & ~t
					emuFullPath = G:\Emulators\Pinball FX2\Pinball FX2.exe
					emuPath =
					emuName = Pinball FX2
					emuExt =
					baseRomPath =
					romPath = G:\Emulators\Pinball FX2\data_steam
					romPathFromIni = G:\Emulators\Pinball FX2\data_steam
					romExtension = .pxp
					romExtensionOrig = .pxp
					romExtensions = pxp
					executable =
					systemDbName = Pinball FX2
					systemName = Pinball FX2
					dbPath =
					dbName = AmericanDad
					dbExt =
					romName = AmericanDad
					romMapPath =
					romMappingEnabled = false
					romMappingHideParent = false
					romMappingMenuWidth = 400
					romMappingMenuMargin = 65
					romMappingTextMargin = 15
					romMappingGameNameTextFont = Bebas Neue
					romMappingGameNameTextOptions = cFFFFFFFF r4 s40 Regular
					romMappingMenuFlagWidth = 55
					altArchiveNameOnly =
					altRomNameOnly =
					altArchiveAndRomName =
					altArchiveAndManyRomNames =
					altRomNamesOnly =
					romMapScenario =
					skipchecks = Rom and Emu
					romMatchExt = false
					blockInputTime = 0
					blockInputFile = G:\RocketLauncher\Module Extensions\BlockInput.exe
					errorLevelReporting = false
					lockLaunch = false
					lockLaunchGame =
					screenRotationAngle = 0
					screenRotationAngleGame =
					setResolution = 1|2560|1980|32|60
					logFile =
					logLabel := ["    INFO"," WARNING","   ERROR","   DEBUG","   TRACE"]
					logLevel = 10
					logShowDebugConsole = false
					logShowCommandWindow = false
					logCommandWindow = false
					logIncludeModule = true
					logIncludeDLLLogs = false
					errorSounds = true
					rlDebugConsoleStdout =
					sysLang = Dutch_Standard
					sysType = 64-bit
					broadcastWindowTitle =
					navUpKey = Up
					navDownKey = Down
					navLeftKey = Left
					navRightKey = Right
					navSelectKey = Enter|Z|3joy1
					navP2UpKey = Numpad8
					navP2DownKey = Numpad2
					navP2LeftKey = Numpad4
					navP2RightKey = Numpad6
					navP2SelectKey = NumpadEnter
					originalWidth = 1920
					originalHeight = 1080
					vdEnabled = false
					vdFullPath = C:\Program Files\DAEMON Tools Lite\DTAgent.exe
					vdUseSCSI = true
					vdDriveLetter = D
					vdDriveLetterScsi = H
					vdAddDrive = true
					demulShooterPath =
					servoStikEnabled = false
					servoStikExitMode = false
					ledblinkyEnabled = false
					ledblinkySystemName =
					ledblinkyFullPath =
					ledblinkyProfilePath = G:\RocketLauncher\Profiles\LEDBlinky
					ledblinkyRLProfile = G:\RocketLauncher\Profiles\LEDBlinky\RocketLauncher
					winIPACFullPath =
					ultraMapEnabled = false
					ultraMapFullPath =
					emuIdleShutdown = 0
					hideCursor = true
					hideEmu = false
					hideFE = false
					suspendFE = false
					fadeIn = true
					fadeInDuration = 500
					fadeInDelay = 0
					fadeInExitDelay = 0
					fadeOutExitDelay = 0
					fadeOut = false
					fadeOutExtraScreen = false
					fadeOutDuration = 500
					fadeOutDelay = 0
					fadeLyrInterpolation = 7
					fadeMuteEmulator = false
					fadeUseBackgrounds = false
					fadeClickThrough = false
					fadeSounds = true
					fade7zProgressMode = extraction
					fadeWidthBaseRes = 1920
					fadeHeightBaseRes = 1080
					fadeLyr1Color = FF000000
					fadeLyr2X = 0
					fadeLyr2Y = 0
					fadeLyr2W =
					fadeLyr2H =
					fadeLyr2Adjust = 1
					fadeLyr2PicPad = 0
					fadeLyr3Pos = Center
					fadeLyr3X = 450
					fadeLyr3Y = 450
					fadeLyr3W =
					fadeLyr3H =
					fadeLyr3Adjust = 1
					fadeLyr3PicPad = 0
					fadeLyr3Speed = 750
					fadeLyr3Type = imageandbar
					fadeLyr3Repeat = 1
					fadeLyr3StaticX = 0
					fadeLyr3StaticY = 870|1575
					fadeLyr3StaticW =
					fadeLyr3StaticH =
					fadeLyr3StaticAdjust = 1
					fadeLyr3StaticPicPad = 0
					fadeLyr4Adjust = 1
					fadeLyr4X = 1792|952
					fadeLyr4Y = 891|1596
					fadeLyr4W = 128
					fadeLyr4H =
					fadeLyr4Pos = No Alignment
					fadeLyr4FPS = 50
					fadeLyr4PicPad = 0
					fadeTranspGifColor = FFFFFF
					fadeBarWindow = Image
					fadeBarWindowX =
					fadeBarWindowY =
					fadeBarWindowW = 900
					fadeBarWindowH =
					fadeBarWindowR = 30
					fadeBarWindowM = 30
					fadeBarWindowHatchStyle = 8
					fadeBar = 7zOnly
					fadeProgressDuration = 0
					fadeBarBack = true
					fadeBarBackColor = FF555555
					fadeBarH = 30
					fadeBarR = 10
					fadeBarColor = DD00BFFF
					fadeBarHatchStyle = 8
					fadeBarPercentageText = true
					fadeBarInfoText = true
					fadeBarXOffset = 0
					fadeBarYOffset = 150
					fadeRomInfoSystemName = image
					fadeRomInfoDeveloper = text with label
					fadeRomInfoPublisher = text with label
					fadeRomInfoGenre = disabled
					fadeRomInfoRating = image
					fadeRomInfoTextMargin = 7
					fadeRomInfoText7Options = h135 x15 y885|1590 cFFCFCFCA r4 s120 Regular
					fadeStatsInfoTextMargin = 7
					fadeText1X = 0
					fadeText1Y = 0
					fadeText1 = Loading Game
					fadeText2X = 0
					fadeText2Y = 0
					fadeText3 = Loading Game
					fadeText4 = Loading Complete
					fadeFont = Bebas Neue
					fadeExtractionTime = disabled
					fadeExtractionTimeTextX = 0
					fadeExtractionTimeTextY = 0
					fadeInterruptKey =
					detectFadeErrorEnabled = true
					fadeImgPath = G:\RocketLauncher\Media\Fade
					RLDataPath = G:\RocketLauncher\Data
					RLMediaPath = G:\RocketLauncher\Media
					RLErrSoundPath = G:\RocketLauncher\Media\Sounds\Error
					modulesPath = G:\RocketLauncher\Modules
					moduleFullName = G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ahk
					moduleName = Pinball FX2
					modulePath = G:\RocketLauncher\Modules\Pinball FX2
					moduleExtension = ahk
					moduleExtensionsPath = G:\RocketLauncher\Module Extensions
					libPath = G:\RocketLauncher\Lib
					sevenZEnabled = true
					sevenZPath = C:\Program Files\7-Zip\7z.exe
					sevenZDllPath = C:\Program Files\7-Zip\7z.dll
					sevenZExtractPath = C:\Users\visse\My Games
					sevenZExtractPathOrig =
					sevenZAttachSystemName = false
					sevenZDelTemp = true
					sevenZFormats = .zip|.rar|.7z|.lzh|.gzip|.tar
					sevenZFormatsNoP = zip|rar|7z|lzh|gzip|tar
					sevenZFormatsRegEx = \.zip|\.rar|\.7z|\.lzh|\.gzip|\.tar
					7zExtractPath = C:\Users\visse\My Games
					mgEnabled = false
					mgKey = ~NumpadSub
					mgBackgroundColor = FF000000
					mgSidePadding = 0.2
					mgWidthBaseRes = 1920
					mgHeightBaseRes = 1080
					mgYOffset = 500|800
					mgFont = Arial
					mgText2Offset = 100
					mgUseSound = true
					mgSoundfreq = 300
					mgExitEffect = none
					mgSelectedEffect = rotate
					mgUseGameArt = false
					mgCandidate =
					mgValidTypes = \(Disc|\(Disk|\(Cart|\(Tape|\(Cassette|\(Part|\(Side
					mgOnLaunch = false
					pauseEnabled = true
					pauseKey = ~NumpadAdd
					pauseBackToMenuBarKey = X
					pauseZoomInKey = C
					pauseZoomOutKey = V
					pauseHiToTextPath = G:\RocketLauncher\Module Extensions\HiToText.exe
					pauseSaveStateKeyCodes =
					pauseLoadStateKeyCodes =
					keyboardEncoder =
					keyboardEncoderEnabled = false
					keymapperEnabled = false
					keymapperAHKMethod = false
					keymapper = xpadder
					xpadderFullPath = G:\3rd party software\XPADDER\Xpadder.exe
					joyToKeyFullPath = G:\3rd party software\JoyToKey_en\JoyToKey.exe
					profilePath = G:\RocketLauncher\Profiles
					keymapperProfilePath = G:\RocketLauncher\Profiles\xpadder
					keymapperFrontEndProfile = xpadder
					joyIDsEnabled = false
					joyIDsPreferredControllersGlobal =
					joyIDsPreferredControllersSystem = use_global
					joyIDsPreferredControllersOnExit =
					CustomJoyNamesEnabled = false
					CustomJoyNames =
					rotateMethod = false
					FEProfile = G:\RocketLauncher\Profiles\xpadder\HyperSpin
					defaultProfile = G:\RocketLauncher\Profiles\xpadder\_Default
					systemProfile = G:\RocketLauncher\Profiles\xpadder\Pinball FX2
					xPadderSystemProfile = G:\RocketLauncher\Profiles\xpadder\Pinball FX2\_Default
					emuProfile = G:\RocketLauncher\Profiles\xpadder\Pinball FX2\Pinball FX2
					romProfile = G:\RocketLauncher\Profiles\xpadder\Pinball FX2\AmericanDad
					RocketLauncherProfile = G:\RocketLauncher\Profiles\xpadder\RocketLauncher
					blankProfile = G:\RocketLauncher\Profiles\xpadder\_Default\blank
					ahkFEProfile = G:\RocketLauncher\Profiles\AHK\HyperSpin
					ahkDefaultProfile = G:\RocketLauncher\Profiles\AHK\_Default
					ahkSystemProfile = G:\RocketLauncher\Profiles\AHK\Pinball FX2
					ahkEmuProfile = G:\RocketLauncher\Profiles\AHK\Pinball FX2\Pinball FX2
					ahkRomProfile = G:\RocketLauncher\Profiles\AHK\Pinball FX2\AmericanDad
					ahkRocketLauncherProfile = G:\RocketLauncher\Profiles\AHK\RocketLauncher
					bezelEnabled = false
					bezelICEnabled = false
					shaderName = false
					shaderColor =
					shaderTransparency =
					statisticsEnabled = true
					pressDuration = -1
					emuVolume = 1
					dxwndIni = G:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
					dxwndFullPath = G:\RocketLauncher\Module Extensions\dxwnd\dxwnd.exe
					qResFullPath = G:\RocketLauncher\Module Extensions\QRes.exe
					mon1O =
					pacDrivedllFile = G:\RocketLauncher\Module Extensions\PacDrive32.dll
					userFadeAnimIniFile = G:\RocketLauncher\Lib\User Fade Animations.ini
					testFile =
					testDuration =
					initialErrorMode = 0
14:58:45:345 | RL |      INFO  | +15    | BuildScript - Loaded XHotkey Init.ahk scripts
14:58:45:345 | RL |      INFO  | +0     | BuildScript - Loaded Fade Init.ahk scripts
14:58:45:345 | RL |      INFO  | +0     | BuildScript - Loaded Pause Init.ahk scripts
14:58:45:346 | RL |      INFO  | +0     | BuildScript - Loaded Statistics Init.ahk scripts
14:58:45:346 | RL |   WARNING  | +0     | BuildScript - "G:\RocketLauncher\Lib\User Functions Init.ahk" not found
14:58:45:347 | RL |     DEBUG  | +0     | BuildScript - Module starts on line: 2
14:58:45:347 | RL |      INFO  | +0     | BuildScript - Validating module
14:58:45:348 | RL |      INFO  | +0     | BuildScript - Validation complete
14:58:45:348 | RL |      INFO  | +0     | BuildScript - Module:
					MEmu = Pinball FX2
					MEmuV = N/A
					MURL = http://www.pinballfx.com/
					MAuthor = djvj,bleasby
					MVersion = 2.1.3
					MCRC = B1C30353
					iCRC = 489E4B10
					mId = 635244873683327779
					MSystem = "Pinball FX2","Pinball"
					; Notes:
					; If not launching through Steam:
					; Add this as any other standard emulator and define the PInball FX2.exe as your executable, but still select Virtual Emulator as you do not need rom extensions or rom paths
					; When setting this up in RocketLauncherUI under the global emulators tab, make sure to set rom extensions to pxp
					; Also make your rom path the Pinball FX2\data_steam folder if you want audit to show green
					; DMD (Dot Matrix Display)
					; The module will support and hide the window components of detached DMD
					; To see it, you must have a 2nd monitor connected as an extension of your desktop, and placement will be on that monitor
					; To Detach:
					; Run Pinball FX2 manually, and goto Help & Options -> Settings -> Video
					; Set Dot Matrix Size to Off, and close Pinball FX2
					; The module will automatically create the dotmatrix.cfg file in the same folder of the "Pinball FX2.exe" (your installation folder) for you
					; Edit the module's settings in RLUI to customize the DMD size and placement of this window
					StartModule()
					BezelGUI()
					FadeInStart()
					; primaryExe := new Emulator(emuPath . "\" . executable)					; instantiate emulator executable object
					primaryExe := new Emulator(If executable ? emuPath . "\" . executable : "Pinball FX2.exe")	; instantiate emulator executable object
					emuPrimaryWindow := new Window(new WindowTitle("Pinball FX2","PxWindowClass"))				; instantiate primary emulator window object
					emuDMDWindow := new Window(new WindowTitle("Pinball FX2 DotMatrix","PxWindowClass"))
					fullscreen := moduleIni.Read("Settings", "Fullscreen","true","",1)
					fullscreenWidth := moduleIni.Read("Settings", "Fullscreen_Width",A_ScreenWidth,"",1)
					fullscreenHeight := moduleIni.Read("Settings", "Fullscreen_Height",A_ScreenHeight,"",1)
					externalDMD := moduleIni.Read("Settings", "External_DMD","false","",1)
					dmdX := moduleIni.Read("Settings", "DMD_X",A_ScreenWidth,"",1)
					dmdY := moduleIni.Read("Settings", "DMD_Y",0,"",1)
					dmdW := moduleIni.Read("Settings", "DMD_Width",0,"",1)
					dmdH := moduleIni.Read("Settings", "DMD_Height",0,"",1)
					BezelStart()
					fullscreen := fullscreen = "true" ? " -fullscreen" : " -borderless"	; -window is also supported but not used in this module
					resolution := " -resolution" . fullscreenWidth . "x" . fullscreenHeight
					If (externalDMD = "true") {
						RLLog.Info("Module - Updating external DMD window placement values")
						If (!executable && !steamPath)
							GetSteamPath()
						dotmatrixCFGFile := new File(If executable ? emuPath . "\dotmatrix.cfg" : steamPath . "\SteamApps\common\Pinball FX2\dotmatrix.cfg")
						If !dotmatrixCFGFile.Exist()
							dotmatrixCFGFile.Append()	; create a new blank file if one does not exist
						RLLog.Info("Module - Using this dotmatrix.cfg: " . dotmatrixCFGFile.FileFullPath)
						dotmatrixCFG := LoadProperties(dotmatrixCFGFile.FileFullPath)
						WriteProperty(dotmatrixCFG, "x", dmdX, 1)
						WriteProperty(dotmatrixCFG, "y", dmdY, 1)
						WriteProperty(dotmatrixCFG, "width", dmdW, 1)
						WriteProperty(dotmatrixCFG, "height", dmdH, 1)
						SaveProperties(dotmatrixCFGFile.FileFullPath, dotmatrixCFG)
					hideEmuObj := Object(pinballTitleClass,1)	; Hide_Emu will hide these windows. 0 = will never unhide, 1 = will unhide later
					HideAppStart(hideEmuObj,hideEmu)
					If executable {
						RLLog.Info("Module - Running Pinball FX2 as a stand alone game and not through Steam as an executable was defined.")
						primaryExe.Run(" " . romName . fullscreen . resolution)
					} Else {
						RLLog.Info("Module - Running Pinball FX2 through Steam.")
						Steam(226980,,romName . fullscreen . resolution)
					emuPrimaryWindow.Wait()
					emuPrimaryWindow.WaitActive()
					; Attempt to hide window components of the detached DMD
						Gui +LastFound
						hWnd := WinExist()
						DllCall("RegisterShellHookWindow", UInt,hWnd)
						MsgNum := DllCall("RegisterWindowMessage", Str,"SHELLHOOK")
						OnMessage(MsgNum, "ShellMessage")
					BezelDraw()
					HideAppEnd(hideEmuObj,hideEmu)
					FadeInExit()
					primaryExe.Process("WaitClose")
					; Process("WaitClose", "Pinball FX2.exe")
					BezelExit()
					FadeOutExit()
					ExitModule()
					ShellMessage(wParam, lParam) {
						RLLog.Debug("Module - DMD external window - " . wParam)
						If (wParam = 1)
							If emuDMDWindow.Exist()
								emuDMDWindow.RemoveBorder()				; hide title bar
								emuDMDWindow.Set("Style", "-0x800000")	; hide thin-line border
								emuDMDWindow.Set("Style", "-0x400000")	; hide dialog frame
								; emuDMDWindow.Set("Style", "-0xC00000")	; hide title bar
								; emuDMDWindow.Set("Style", "-0x40000")	; hide thickframe/sizebox
								; emuDMDWindow.Move(0,0,1920,1080)
					CloseProcess:
						FadeOutStart()
						emuPrimaryWindow.Close()
					Return
14:58:45:370 | RL |      INFO  | +16    | BuildScript - Loaded Pause scripts
14:58:45:372 | RL |      INFO  | +0     | BuildScript - Loaded Multi-Player scripts
14:58:45:373 | RL |      INFO  | +0     | BuildScript - Loaded Statistics.ahk script
14:58:45:373 | RL |   WARNING  | +0     | BuildScript - "G:\RocketLauncher\Lib\User Functions.ahk" not found
14:58:45:374 | RL |      INFO  | +0     | BuildScript - Finished injecting functions into module
14:58:45:375 | RL |      INFO  | +0     | Main - Module is built
14:58:45:376 | RL |      INFO  | +16    | CheckFile - Checking if G:\RocketLauncher\AutoHotkey.dll exists
14:58:45:391 | RL |     DEBUG  | +0     | CheckFile - Attributes:
					FileVersion             	1.1.13.00
					LegalCopyright          	Copyright (C) 2003-2013
					ProductVersion          	1.1.13.00
					File Size:			802304 bytes
14:58:45:400 | RL |      INFO  | +15    | Main - Hiding taskbar
14:58:45:400 | RL |     TRACE  | +0     | Window.__New - Created: "ahk_class Shell_TrayWnd"
14:58:45:400 | RL |     TRACE  | +0     | Window.__New - Created: "Start ahk_class Button"
14:58:45:401 | RL |     TRACE  | +0     | Window.Hide - Hiding window "ahk_class Shell_TrayWnd"
14:58:45:505 | RL |     TRACE  | +110   | Window.Hide - Hiding window "Start ahk_class Button"
14:58:45:505 | RL |      INFO  | +0     | Main - Starting timer to watch if Front End gets displaced and restore it if it does.
14:58:45:506 | RL |      INFO  | +0     | Main - Running module
14:58:45:682 | MD |      INFO  | +N/A   | Module initialized
14:58:45:682 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:58:45:682 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc not in TableKeyGroups
14:58:45:682 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:45:683 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
14:58:45:683 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:58:45:683 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:58:45:684 | MD |     DEBUG  | +0     | fadeInTransitionAnimation: DefaultAnimateFadeIn
14:58:45:684 | MD |     DEBUG  | +0     | fadeOutTransitionAnimation: DefaultAnimateFadeOut
14:58:45:685 | MD |     DEBUG  | +0     | fadeLyr3Animation: DefaultFadeAnimation
14:58:45:685 | MD |     DEBUG  | +0     | fadeLyr37zAnimation: DefaultFadeAnimation
14:58:45:685 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:58:45:685 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd not in TableKeyGroups ~Esc,
14:58:45:685 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:45:686 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
14:58:45:686 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~NumpadAdd" to call label: "TogglePauseMenuStatus"
14:58:45:686 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:58:45:687 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:58:45:687 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup PrintScreen not in TableKeyGroups ~Esc,~NumpadAdd,
14:58:45:687 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:45:687 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
14:58:45:688 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "PrintScreen" to call label: "SaveScreenshot"
14:58:45:688 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:58:45:688 | MD |      INFO  | +0     | StartModule - Started
14:58:45:688 | MD |      INFO  | +0     | StartModule - MEmu: Pinball FX2
					MEmuV: N/A
					MURL: http://www.pinballfx.com/
					MAuthor: djvj,bleasby
					MVersion: 2.1.3
					MCRC: B1C30353
					iCRC: 489E4B10
					MID:
					MSystem: "Pinball FX2","Pinball"
14:58:45:710 | MD |      INFO  | +32    | StartModule - You have a supported System Name for this module: "Pinball FX2"
14:58:45:711 | MD |      INFO  | +0     | PluginInit - Started
14:58:45:711 | MD |     DEBUG  | +0     | BuildDatabaseTable - Started - Building Table for: Name|Cloneof|Publisher|Year|Genre|Rating
14:58:45:711 | MD |      INFO  | +0     | CheckFile - Checking if G:\HyperSpin\Databases\Pinball FX2\Pinball FX2.xml exists
14:58:45:712 | MD |     DEBUG  | +0     | CheckFile - Attributes:
					File Size:			22939 bytes
					Created:			5/28/2016 - 1:07:58 PM
					Modified:			5/28/2016 - 1:07:58 PM
14:58:45:713 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching for a "Game Name" in the database
14:58:45:713 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Game Name" in the database!
14:58:45:713 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Name
14:58:45:713 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Name" with a value: "American Dad!"
14:58:45:714 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Cloneof
14:58:45:714 | MD |     DEBUG  | +0     | BuildDatabaseTable - Could not find: Cloneof
14:58:45:714 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Publisher
14:58:45:714 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Publisher" with a value: "Zen Studios"
14:58:45:715 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Year
14:58:45:715 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Year" with a value: "2015"
14:58:45:715 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Genre
14:58:45:715 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Genre" with a value: "Pinball"
14:58:45:716 | MD |     DEBUG  | +0     | BuildDatabaseTable - Searching database for: Rating
14:58:45:716 | MD |     DEBUG  | +0     | BuildDatabaseTable - Found "Rating" with a value: "ESRB - E (Everyone)"
14:58:45:716 | MD |     TRACE  | +0     | PluginInit - GameInfo:
					GameInfo Label: Genre | GameInfo Value: Pinball
					GameInfo Label: Name | GameInfo Value: American Dad!
					GameInfo Label: Publisher | GameInfo Value: Zen Studios
					GameInfo Label: Rating | GameInfo Value: ESRB - E (Everyone)
					GameInfo Label: Year | GameInfo Value: 2015
14:58:45:716 | MD |     DEBUG  | +0     | BuildDatabaseTable - Ended
14:58:45:717 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Game Logo|System Logo
14:58:45:717 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: G:\HyperSpin\Media\Pinball FX2\Images\Wheel\AmericanDad.png
14:58:45:770 | MD |     DEBUG  | +62    | BuildAssetsTable - Searching for a System Logo: G:\HyperSpin\Media\Main Menu\Images\Wheel\Pinball FX2.png
14:58:45:770 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Game Logo | Asset Path1:  G:\HyperSpin\Media\Pinball FX2\Images\Wheel\AmericanDad.png | Asset Extension1:  png | Asset Type1:  game
					Asset Label: System Logo | Asset Path1:  G:\HyperSpin\Media\Main Menu\Images\Wheel\Pinball FX2.png | Asset Extension1:  png | Asset Type1:  system
14:58:45:771 | MD |      INFO  | +0     | BuildAssetsTable - Ended
14:58:45:771 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: Artwork1|Box Art|Cartridge|Flyers|Letters|Other
14:58:45:771 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Artwork1: G:\HyperSpin\Media\Pinball FX2\Images\Artwork1\AmericanDad.png
14:58:45:771 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Box Art: G:\HyperSpin\Media\Pinball FX2\Images\Artwork2\AmericanDad.png
14:58:45:772 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Cartridge: G:\HyperSpin\Media\Pinball FX2\Images\Artwork3\AmericanDad.png
14:58:45:800 | MD |     DEBUG  | +31    | BuildAssetsTable - Searching for a Flyers: G:\HyperSpin\Media\Pinball FX2\Images\Artwork4\AmericanDad.png
14:58:45:800 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Letters: G:\HyperSpin\Media\Pinball FX2\Images\Letters
14:58:45:865 | MD |     DEBUG  | +63    | BuildAssetsTable - Searching for a Other: G:\HyperSpin\Media\Pinball FX2\Images\Other
14:58:45:866 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Letters | Asset Path1:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\!.png | Asset Extension1:  png | Asset Type1:  system
					Asset Label: Letters | Asset Path2:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\'.png | Asset Extension2:  png | Asset Type2:  system
					Asset Label: Letters | Asset Path3:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\(.png | Asset Extension3:  png | Asset Type3:  system
					Asset Label: Letters | Asset Path4:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\0.png | Asset Extension4:  png | Asset Type4:  system
					Asset Label: Letters | Asset Path5:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\1.png | Asset Extension5:  png | Asset Type5:  system
					Asset Label: Letters | Asset Path6:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\2.png | Asset Extension6:  png | Asset Type6:  system
					Asset Label: Letters | Asset Path7:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\3.png | Asset Extension7:  png | Asset Type7:  system
					Asset Label: Letters | Asset Path8:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\4.png | Asset Extension8:  png | Asset Type8:  system
					Asset Label: Letters | Asset Path9:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\5.png | Asset Extension9:  png | Asset Type9:  system
					Asset Label: Letters | Asset Path10:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\6.png | Asset Extension10:  png | Asset Type10:  system
					Asset Label: Letters | Asset Path11:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\7.png | Asset Extension11:  png | Asset Type11:  system
					Asset Label: Letters | Asset Path12:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\8.png | Asset Extension12:  png | Asset Type12:  system
					Asset Label: Letters | Asset Path13:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\9.png | Asset Extension13:  png | Asset Type13:  system
					Asset Label: Letters | Asset Path14:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\a.png | Asset Extension14:  png | Asset Type14:  system
					Asset Label: Letters | Asset Path15:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\b.png | Asset Extension15:  png | Asset Type15:  system
					Asset Label: Letters | Asset Path16:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\c.png | Asset Extension16:  png | Asset Type16:  system
					Asset Label: Letters | Asset Path17:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\d.png | Asset Extension17:  png | Asset Type17:  system
					Asset Label: Letters | Asset Path18:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\e.png | Asset Extension18:  png | Asset Type18:  system
					Asset Label: Letters | Asset Path19:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\f.png | Asset Extension19:  png | Asset Type19:  system
					Asset Label: Letters | Asset Path20:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\g.png | Asset Extension20:  png | Asset Type20:  system
					Asset Label: Letters | Asset Path21:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\h.png | Asset Extension21:  png | Asset Type21:  system
					Asset Label: Letters | Asset Path22:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\i.png | Asset Extension22:  png | Asset Type22:  system
					Asset Label: Letters | Asset Path23:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\j.png | Asset Extension23:  png | Asset Type23:  system
					Asset Label: Letters | Asset Path24:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\k.png | Asset Extension24:  png | Asset Type24:  system
					Asset Label: Letters | Asset Path25:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\l.png | Asset Extension25:  png | Asset Type25:  system
					Asset Label: Letters | Asset Path26:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\m.png | Asset Extension26:  png | Asset Type26:  system
					Asset Label: Letters | Asset Path27:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\n.png | Asset Extension27:  png | Asset Type27:  system
					Asset Label: Letters | Asset Path28:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\o.png | Asset Extension28:  png | Asset Type28:  system
					Asset Label: Letters | Asset Path29:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\p.png | Asset Extension29:  png | Asset Type29:  system
					Asset Label: Letters | Asset Path30:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\q.png | Asset Extension30:  png | Asset Type30:  system
					Asset Label: Letters | Asset Path31:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\r.png | Asset Extension31:  png | Asset Type31:  system
					Asset Label: Letters | Asset Path32:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\s.png | Asset Extension32:  png | Asset Type32:  system
					Asset Label: Letters | Asset Path33:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\t.png | Asset Extension33:  png | Asset Type33:  system
					Asset Label: Letters | Asset Path34:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\u.png | Asset Extension34:  png | Asset Type34:  system
					Asset Label: Letters | Asset Path35:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\v.png | Asset Extension35:  png | Asset Type35:  system
					Asset Label: Letters | Asset Path36:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\w.png | Asset Extension36:  png | Asset Type36:  system
					Asset Label: Letters | Asset Path37:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\x.png | Asset Extension37:  png | Asset Type37:  system
					Asset Label: Letters | Asset Path38:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\y.png | Asset Extension38:  png | Asset Type38:  system
					Asset Label: Letters | Asset Path39:  G:\HyperSpin\Media\Pinball FX2\Images\Letters\z.png | Asset Extension39:  png | Asset Type39:  system
					Asset Label: Other | Asset Path1:  G:\HyperSpin\Media\Pinball FX2\Images\Other\Pointer.png | Asset Extension1:  png | Asset Type1:  system
14:58:45:867 | MD |      INFO  | +0     | BuildAssetsTable - Ended
14:58:45:867 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: MP4 Game Video|FLV Game Video
14:58:45:867 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a MP4 Game Video: G:\HyperSpin\Media\Pinball FX2\Video\AmericanDad.*
14:58:45:908 | MD |     DEBUG  | +47    | BuildAssetsTable - Searching for a FLV Game Video: G:\HyperSpin\Media\Main Menu\Video\Pinball FX2.*
14:58:45:942 | MD |     DEBUG  | +31    | BuildAssetsTable - Media assets found:
					Asset Label: FLV Game Video | Asset Path1:  G:\HyperSpin\Media\Main Menu\Video\Pinball FX2.mp4 | Asset Extension1:  mp4 | Asset Type1:  system
					Asset Label: MP4 Game Video | Asset Path1:  G:\HyperSpin\Media\Pinball FX2\Video\AmericanDad.mp4 | Asset Extension1:  mp4 | Asset Type1:  game
14:58:45:942 | MD |      INFO  | +0     | BuildAssetsTable - Ended
14:58:45:943 | MD |      INFO  | +0     | PluginInit - Ended
14:58:45:943 | MD |     DEBUG  | +0     | StartModule - Setting romName to the dbName sent to RocketLauncher: AmericanDad
14:58:45:943 | MD |      INFO  | +0     | SetDisplaySettings - Started
14:58:45:944 | MD |      INFO  | +0     | SetDisplaySettings - Ended
14:58:45:945 | MD |      INFO  | +0     | SystemCursor - Hiding mouse cursor
14:58:45:977 | MD |     TRACE  | +31    | XHotkeyTableCreation - Started
14:58:45:977 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~e&~t not in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,
14:58:45:978 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 1 check
14:58:45:978 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 2 check
14:58:45:978 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~e & ~t" to call label: "ToggleCursor"
14:58:45:979 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:58:45:979 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "G:\HyperSpin\HyperSpin.exe"
14:58:45:979 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "G:\HyperSpin\HyperSpin.exe"
14:58:45:980 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2\AmericanDad.ini"
14:58:45:981 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ini"
14:58:45:002 | MD |     TRACE  | +32    | File.Exist - This file exists: G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ini
14:58:46:002 | MD |     DEBUG  | +0     | RIniFile.__New - "Module" at index 1, adding "SystemModuleIni" from: "G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ini"
14:58:46:003 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ini"
14:58:46:004 | MD |     TRACE  | +0     | File.Exist - This file exists: G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ini
14:58:46:004 | MD |     DEBUG  | +0     | RIniFile.__New - "Module" at index 2, adding "GlobalModuleIni" from: "G:\RocketLauncher\Modules\Pinball FX2\Pinball FX2.ini"
14:58:46:013 | MD |      INFO  | +0     | StartModule - Ended
14:58:46:013 | MD |     DEBUG  | +0     | FadeInStart - Started
14:58:46:014 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:58:46:014 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~NumpadAdd is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:58:46:014 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
14:58:46:015 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~NumpadAdd"
14:58:46:015 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
14:58:46:015 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabling "TogglePauseMenuStatus" standard Hotkey method for key(s): "~NumpadAdd"
14:58:46:015 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
14:58:46:016 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:58:46:016 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:58:46:016 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:58:46:016 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
14:58:46:034 | MD |     TRACE  | +31    | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:58:46:034 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
14:58:46:035 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:58:46:035 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
14:58:46:035 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:58:46:036 | MD |     DEBUG  | +0     | FadeInStart - No keys were set to interrupt fade so ability to interrupt fade is disabled
14:58:46:036 | MD |     TRACE  | +0     | FadeInStart - Fade screen scale factor: X=1.000000, Y= 1.000000
14:58:46:036 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\AmericanDad\Layer 1*.*
14:58:46:046 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Horizontal\Layer 1*.*
14:58:46:046 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Layer 1*.*
14:58:46:046 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: G:\RocketLauncher\Media\Fade\_Default\Horizontal\Layer 1*.*
14:58:46:067 | MD |     DEBUG  | +31    | GetFadeDirPicFile - Checking if any Fade "Layer 1" media exists in: G:\RocketLauncher\Media\Fade\_Default\Layer 1*.*
14:58:46:067 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": G:\RocketLauncher\Media\Fade\_Default\Layer 1*.png
14:58:46:068 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Layer 1": G:\RocketLauncher\Media\Fade\_Default\Layer 1.png
14:58:46:068 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": G:\RocketLauncher\Media\Fade\_Default\Layer 1*.gif
14:58:46:068 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": G:\RocketLauncher\Media\Fade\_Default\Layer 1*.tif
14:58:46:069 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": G:\RocketLauncher\Media\Fade\_Default\Layer 1*.bmp
14:58:46:069 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 1": G:\RocketLauncher\Media\Fade\_Default\Layer 1*.jpg
14:58:46:069 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use G:\RocketLauncher\Media\Fade\_Default\Layer 1.png
14:58:46:070 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\AmericanDad\Extra Layer 1 - Console*.*
14:58:46:070 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Horizontal\Extra Layer 1 - Console*.*
14:58:46:070 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Extra Layer 1 - Console*.*
14:58:46:071 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: G:\RocketLauncher\Media\Fade\_Default\Horizontal\Extra Layer 1 - Console*.*
14:58:46:071 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Extra Layer 1 - Console" media exists in: G:\RocketLauncher\Media\Fade\_Default\Extra Layer 1 - Console*.*
14:58:46:189 | MD |      INFO  | +125   | DefaultAnimateFadeIn - Started, direction is: in
14:58:46:189 | MD |      INFO  | +0     | DefaultAnimateFadeIn - Drawing First FadeIn Image.
14:58:46:692 | MD |      INFO  | +500   | DefaultAnimateFadeIn - Ended
14:58:46:853 | MD |      INFO  | +156   | DefaultFadeAnimation - Started
14:58:46:853 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\AmericanDad\Info Bar*.*
14:58:46:853 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Horizontal\Info Bar*.*
14:58:46:854 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Info Bar*.*
14:58:46:854 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: G:\RocketLauncher\Media\Fade\_Default\Horizontal\Info Bar*.*
14:58:46:854 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Info Bar" media exists in: G:\RocketLauncher\Media\Fade\_Default\Info Bar*.*
14:58:46:855 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": G:\RocketLauncher\Media\Fade\_Default\Info Bar*.png
14:58:46:855 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Info Bar": G:\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:58:46:855 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": G:\RocketLauncher\Media\Fade\_Default\Info Bar*.gif
14:58:46:856 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": G:\RocketLauncher\Media\Fade\_Default\Info Bar*.tif
14:58:46:856 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": G:\RocketLauncher\Media\Fade\_Default\Info Bar*.bmp
14:58:46:856 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Info Bar": G:\RocketLauncher\Media\Fade\_Default\Info Bar*.jpg
14:58:46:857 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use G:\RocketLauncher\Media\Fade\_Default\Info Bar.png
14:58:46:881 | MD |     DEBUG  | +32    | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\AmericanDad\Layer 3*.*
14:58:46:881 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Horizontal\Layer 3*.*
14:58:46:882 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Layer 3*.*
14:58:46:882 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: G:\RocketLauncher\Media\Fade\_Default\Horizontal\Layer 3*.*
14:58:46:882 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Layer 3" media exists in: G:\RocketLauncher\Media\Fade\_Default\Layer 3*.*
14:58:46:883 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": G:\RocketLauncher\Media\Fade\_Default\Layer 3*.png
14:58:46:883 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "Layer 3": G:\RocketLauncher\Media\Fade\_Default\Layer 3.png
14:58:46:883 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": G:\RocketLauncher\Media\Fade\_Default\Layer 3*.gif
14:58:46:884 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": G:\RocketLauncher\Media\Fade\_Default\Layer 3*.tif
14:58:46:884 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": G:\RocketLauncher\Media\Fade\_Default\Layer 3*.bmp
14:58:46:884 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "Layer 3": G:\RocketLauncher\Media\Fade\_Default\Layer 3*.jpg
14:58:46:885 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use G:\RocketLauncher\Media\Fade\_Default\Layer 3.png
14:58:46:972 | MD |      INFO  | +93    | BuildAssetsTable - Started - Building Table for: Genre Logo|Rating Logo|Developer Logo|Publisher Logo|Year Logo
14:58:46:972 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Genre Logo: G:\RocketLauncher\Media\Genre\_Default\Pinball.*
14:58:46:972 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Rating Logo: G:\RocketLauncher\Media\Rating\_Default\ESRB - E (Everyone).*
14:58:46:982 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Developer Logo:
14:58:46:983 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Publisher Logo: G:\RocketLauncher\Media\Publisher\_Default\Zen Studios.*
14:58:46:983 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Year Logo: G:\RocketLauncher\Media\Year\_Default\2015.*
14:58:46:984 | MD |     DEBUG  | +0     | BuildAssetsTable - Media assets found:
					Asset Label: Rating Logo | Asset Path1:  G:\RocketLauncher\Media\Rating\_Default\ESRB - E (Everyone).png | Asset Extension1:  png | Asset Type1:  rating
14:58:46:984 | MD |      INFO  | +0     | BuildAssetsTable - Ended
14:58:46:984 | MD |      INFO  | +0     | BuildAssetsTable - Started - Building Table for: System Logo|Game Logo|Game Logo
14:58:46:984 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a System Logo: G:\RocketLauncher\Media\Logos\Pinball FX2\_Default\
14:58:46:985 | MD |     DEBUG  | +0     | BuildAssetsTable - Searching for a Game Logo: G:\RocketLauncher\Media\Logos\Pinball FX2\AmericanDad\
14:58:46:004 | MD |     DEBUG  | +32    | BuildAssetsTable - Media assets found:
14:58:47:005 | MD |      INFO  | +0     | BuildAssetsTable - Ended
14:58:47:146 | MD |     DEBUG  | +140   | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\AmericanDad\Loading start*.*
14:58:47:147 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Horizontal\Loading start*.*
14:58:47:147 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Loading start*.*
14:58:47:147 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: G:\RocketLauncher\Media\Fade\_Default\Horizontal\Loading start*.*
14:58:47:148 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "Loading start" media exists in: G:\RocketLauncher\Media\Fade\_Default\Loading start*.*
14:58:47:148 | MD |     DEBUG  | +0     | FadeInDelay - Started
14:58:47:148 | MD |     DEBUG  | +0     | FadeInDelay - Ended
14:58:47:149 | MD |      INFO  | +0     | DefaultFadeAnimation - Ended
14:58:47:149 | MD |     DEBUG  | +0     | FadeInStart - Ended
14:58:47:149 | MD |      INFO  | +0     | DxwndUpdateIniPath - DxwndIni set to G:\RocketLauncher\Module Extensions\dxwnd\dxwnd.ini
14:58:47:150 | MD |     DEBUG  | +0     | CoverFE - Started
14:58:47:173 | MD |     DEBUG  | +31    | CoverFE - Ended
14:58:47:174 | MD |     TRACE  | +0     | Emulator.__New - Creating new emulator object for: "Pinball FX2.exe"
14:58:47:174 | MD |     TRACE  | +0     | Process.__New - Creating new process object for: "Pinball FX2.exe"
14:58:47:174 | MD |     TRACE  | +0     | File.__New - Creating new file object of: "Pinball FX2.exe"
14:58:47:175 | MD |     TRACE  | +0     | Window.__New - Created: "Pinball FX2 ahk_class PxWindowClass"
14:58:47:176 | MD |     TRACE  | +0     | Window.__New - Created: "Pinball FX2 DotMatrix ahk_class PxWindowClass"
14:58:47:176 | MD |      INFO  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - Fullscreen: true
14:58:47:176 | MD |      INFO  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - Fullscreen_Width: 1920
14:58:47:177 | MD |      INFO  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - Fullscreen_Height: 1080
14:58:47:177 | MD |      INFO  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - External_DMD: false
14:58:47:177 | MD |     TRACE  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - DMD_X: Key does not exist
14:58:47:178 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - DMD_X: Key does not exist
14:58:47:178 | MD |      INFO  | +0     | RIniFile.Read - Module - DMD_X: 1920 (DEFAULT)
14:58:47:178 | MD |     TRACE  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - DMD_Y: Key does not exist
14:58:47:179 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - DMD_Y: Key does not exist
14:58:47:179 | MD |      INFO  | +0     | RIniFile.Read - Module - DMD_Y: 0 (DEFAULT)
14:58:47:179 | MD |     TRACE  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - DMD_Width: Key does not exist
14:58:47:180 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - DMD_Width: Key does not exist
14:58:47:180 | MD |      INFO  | +0     | RIniFile.Read - Module - DMD_Width: 0 (DEFAULT)
14:58:47:180 | MD |     TRACE  | +0     | RIniFile.Read - Module {SystemModuleIni} - [Settings] - DMD_Height: Key does not exist
14:58:47:181 | MD |     TRACE  | +0     | RIniFile.Read - Module {GlobalModuleIni} - [Settings] - DMD_Height: Key does not exist
14:58:47:181 | MD |      INFO  | +0     | RIniFile.Read - Module - DMD_Height: 0 (DEFAULT)
14:58:47:181 | MD |      INFO  | +0     | Module - Running Pinball FX2 through Steam.
14:58:47:182 | MD |      INFO  | +0     | Steam - Started
14:58:47:182 | MD |      INFO  | +0     | Steam - Received SteamID: "226980" | SteamProtocol: "" | Parameters: "AmericanDad -fullscreen -resolution1920x1080"
14:58:47:182 | MD |      INFO  | +0     | GetSteamPath - Started
14:58:47:182 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=SteamExe,RegistryVersion=auto
14:58:47:183 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=SteamExe,RegistryVersion=64
14:58:47:183 | MD |      INFO  | +0     | RegRead - Registry Read finished, returning c:/program files (x86)/steam/steam.exe
14:58:47:183 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=SteamExe,RegistryVersion=32
14:58:47:184 | MD |      INFO  | +0     | RegRead - Registry Read finished, returning c:/program files (x86)/steam/steam.exe
14:58:47:184 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=StartupMode,RegistryVersion=auto
14:58:47:185 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=StartupMode,RegistryVersion=64
14:58:47:185 | MD |      INFO  | +0     | RegRead - Registry Read finished, returning 0
14:58:47:185 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=StartupMode,RegistryVersion=32
14:58:47:186 | MD |      INFO  | +0     | RegRead - Registry Read finished, returning 0
14:58:47:186 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=Offline,RegistryVersion=auto
14:58:47:186 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=Offline,RegistryVersion=64
14:58:47:187 | MD |      INFO  | +0     | RegRead - Registry Read finished, returning
14:58:47:187 | MD |      INFO  | +0     | RegRead - Reading from Registry : RootKey=HKCU, SubKey=Software\Valve\Steam, ValueName=Offline,RegistryVersion=32
14:58:47:188 | MD |     DEBUG  | +0     | GetSteamPath - Steam is running in Online Mode
14:58:47:188 | MD |      INFO  | +0     | GetSteamPath - Ended - Steam install path: c:\program files (x86)\steam\steam.exe
14:58:47:188 | MD |      INFO  | +0     | Process - Exist steam.exe
14:58:47:211 | MD |      INFO  | +32    | DefaultFadeAnimationLoop - percentage
14:58:47:237 | MD |      INFO  | +31    | Steam - Steam is set to start in Standard Mode.
14:58:47:238 | MD |      INFO  | +0     | Steam - Steam is already running, using Steam Browser Protocol to launch game.
14:58:47:238 | MD |      INFO  | +0     | Run - Running: c:\program files (x86)\steam\steam.exe -applaunch 226980 AmericanDad -fullscreen -resolution1920x1080
14:58:47:285 | MD |      INFO  | +47    | DefaultFadeAnimationLoop - percentage8
14:58:47:286 | MD |     DEBUG  | +0     | Run - "steam.exe -applaunch 226980 AmericanDad -fullscreen -resolution1920x1080" Process ID: 56900
14:58:47:288 | MD |      INFO  | +0     | Steam - Ended
14:58:47:288 | MD |     TRACE  | +0     | Window.__New - Created: "ahk_id 198472"
14:58:47:289 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
14:58:47:289 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 1920 h: 1080 from "ahk_id 198472"
14:58:47:289 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
14:58:47:290 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x30748 | Process ID: 39416 | Process Path: G:\RocketLauncher\RocketLauncher.exe
14:58:47:290 | MD |      INFO  | +0     | Window.Wait - Waiting for window "Pinball FX2 ahk_class PxWindowClass"
14:58:47:348 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage19
14:58:47:419 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage27
14:58:47:472 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage35
14:58:47:535 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage44
14:58:47:598 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage52
14:58:47:659 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage60
14:58:47:721 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage69
14:58:47:785 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage77
14:58:47:846 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage85
14:58:47:912 | MD |      INFO  | +63    | DefaultFadeAnimationLoop - percentage94
14:58:47:975 | MD |      INFO  | +62    | DefaultFadeAnimationLoop - percentage100
14:58:47:976 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\AmericanDad\7z complete*.*
14:58:47:977 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\Horizontal\7z complete*.*
14:58:47:977 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: G:\RocketLauncher\Media\Fade\Pinball FX2\_Default\7z complete*.*
14:58:47:977 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: G:\RocketLauncher\Media\Fade\_Default\Horizontal\7z complete*.*
14:58:47:977 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Checking if any Fade "7z complete" media exists in: G:\RocketLauncher\Media\Fade\_Default\7z complete*.*
14:58:47:978 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Looking for Fade "7z complete": G:\RocketLauncher\Media\Fade\_Default\7z complete*.mp3
14:58:47:978 | MD |     DEBUG  | +0     | GetFadeDirPicFile - Found Fade "7z complete": G:\RocketLauncher\Media\Fade\_Default\7z complete.mp3
14:58:47:978 | MD |      INFO  | +0     | GetFadePicFile - Randomized images and Fade  will use G:\RocketLauncher\Media\Fade\_Default\7z complete.mp3
14:58:47:979 | MD |      INFO  | +0     | DefaultFadeAnimationLoop - Playing 7z fade complete sound: G:\RocketLauncher\Media\Fade\_Default\7z complete.mp3
14:58:48:509 | MD |     DEBUG  | +532   | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:58:48:511 | MD |      INFO  | +0     | DefaultFadeAnimationLoop - percentage100
14:58:48:511 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - AnimationLoop has finished
14:58:48:511 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - Ended
14:58:48:514 | MD |     DEBUG  | +0     | DefaultFadeAnimationLoop - Fade Layer 3 is drawn so animation loop is finished.
14:59:17:290 | MD |     TRACE  | +28781 | Window.__New - Created: "ahk_id 198472"
14:59:17:291 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "Off"
14:59:17:291 | MD |     TRACE  | +0     | Window.GetPos - Retrieved x:0 y:0 w: 1920 h: 1080 from "ahk_id 198472"
14:59:17:291 | MD |     TRACE  | +0     | MiscUtils.DetectHiddenWindows - Mode changed to "On"
14:59:17:292 | MD |     DEBUG  | +0     | MiscUtils.GetActiveWindowStatus - Title: CoverFE | Class: AutoHotkeyGUI | State: 0 | X: 0 | Y: 0 | Width: 1920 | Height: 1080 | Window HWND: 0x30748 | Process ID: 39416 | Process Path: G:\RocketLauncher\RocketLauncher.exe
14:59:17:292 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:59:17:292 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:59:17:292 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
14:59:17:293 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:59:17:293 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
14:59:17:293 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabling "CloseProcess" standard Hotkey method for key(s): "~Esc"
14:59:17:294 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
14:59:17:294 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:59:17:294 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:59:17:294 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:59:17:295 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
14:59:17:295 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:59:17:295 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
14:59:17:296 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseError"
14:59:17:296 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
14:59:17:296 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:59:17:750 | MD |     DEBUG  | +453   | ScriptError - Playing error sound: error5.mp3
14:59:19:366 | MD |      INFO  | +1625  | 7zCleanUp - Started
14:59:19:367 | MD |      INFO  | +0     | 7zCleanUp - Deleted
14:59:19:367 | MD |      INFO  | +0     | 7zCleanUp - Ended
14:59:28:713 | MD |     TRACE  | +9344  | XHotkeyTableCreation - Started
14:59:28:713 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:59:28:714 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
14:59:28:714 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:59:28:715 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
14:59:28:715 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabling "CloseError" standard Hotkey method for key(s): "~Esc"
14:59:28:715 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
14:59:28:715 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:59:28:716 | MD |     TRACE  | +0     | XHotkeyTableCreation - Started
14:59:28:716 | MD |     TRACE  | +0     | XHotkeyTableCreation - KeyGroup ~Esc is in TableKeyGroups ~Esc,~NumpadAdd,PrintScreen,~e&~t,
14:59:28:716 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 10 check
14:59:28:717 | MD |     TRACE  | +0     | XHotkeyTableCreation - Disabled Hotkey for: "~Esc"
14:59:28:717 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 11 check
14:59:28:717 | MD |     TRACE  | +0     | XHotkeyTableCreation - Using standard Hotkey method for key(s): "~Esc" to call label: "CloseProcess"
14:59:28:718 | MD |     TRACE  | +0     | XHotkeyTableCreation - Post loop 12 check
14:59:28:718 | MD |     TRACE  | +0     | XHotkeyTableCreation - Ended
14:59:28:719 | MD |     ERROR  | +0     | ScriptError - There was an error waiting for the window "Pinball FX2 ahk_class PxWindowClass". Please check you have the correct version emulator installed for this module, followed any notes in the module, and have this emulator working outside your Frontend first. Also turn off Fade to see if you are hiding your problem.
14:59:28:719 | MD |      INFO  | +0     | ExitModule - Started
14:59:28:738 | MD |      INFO  | +31    | Starting Updating Statistics:
14:59:28:738 | MD |     TRACE  | +0     | Total Elapsed Time in Pause in seconds: 0
14:59:28:739 | MD |     TRACE  | +0     | gameSectionStartTime:221730375
14:59:28:739 | MD |     TRACE  | +0     | ElapsedTime:42
14:59:28:739 | MD |     TRACE  | +0     | Statistics cleared game name: AmericanDad
14:59:28:770 | MD |     TRACE  | +31    | Loaded game statistics from ini files:
					Number_of_Times_Played: 0
					Last_Time_Played: 0
					Average_Time_Played: 0
					Total_Time_Played: 0
					System_Total_Played_Time: 3591
					Total_Global_Played_Time: 2460
14:59:28:770 | MD |     TRACE  | +0     | Updated Statistics: Number_of_Times_Played: 1
					Last_Time_Played: Thursday July 28, 2016 02:58:46 PM
					Average_Time_Played: 42
					Total_Time_Played: 42
					System_Total_Played_Time: 3633
					Total_Global_Played_Time: 2502
14:59:28:802 | MD |      INFO  | +31    | Game section statistics updated.
14:59:28:803 | MD |     TRACE  | +0     | CustomFunction.PostExit - Starting
14:59:28:803 | MD |     TRACE  | +0     | CustomFunction.PostExit - Ending
14:59:28:803 | MD |      INFO  | +0     | ExitModule - Ended
End of Module Logs
14:59:28:970 | RL |      INFO  | +43468 | Main - Module ended, exiting RocketLauncher normally
14:59:28:970 | RL |      INFO  | +0     | ExitScript - Started
14:59:28:974 | RL |     DEBUG  | +0     | Registry.Read - Reading from Registry : RootKey=HKEY_LOCAL_MACHINE, SubKey=System\CurrentControlSet\Control\Windows, ValueName=ErrorMode,RegistryVersion=32
14:59:28:974 | RL |     DEBUG  | +0     | Registry.Read - Registry Read finished, returning 0
14:59:28:975 | RL |     TRACE  | +0     | StringUtils.Contains - "true" contains "true|kill" at position 1
14:59:28:975 | RL |      INFO  | +0     | ExitScript - Restoring taskbar
14:59:28:975 | RL |     TRACE  | +0     | Window.Show - Unhiding window "ahk_class Shell_TrayWnd"
14:59:29:098 | RL |     TRACE  | +125   | Window.Show - Unhiding window "Start ahk_class Button"
14:59:29:127 | RL |      INFO  | +32    | SystemCursor - Restoring mouse cursor
14:59:29:136 | RL |      INFO  | +0     | ExitScript - Restored cursor
[/code]
and without Steam the RL error from the post above
but I don't want to uninstall Steam, I want the module to see if I have a .exe filled in at Edit Pinball FX2 Emulator, and if so, then skip the Steam part and use the .exe
Nor do I but what I'm saying is even if you eliminate the steam issue, the exe doesn't launch anyway
I run the game with Steam but I have a few copies of the standalone version for testing. The ones I tested both throw up the errors you guys are experiencing.
I'm not sure it will help in this situation but have you activated cabinet mode? This can be done here.
OMG My pinball FX2 stopped working and I get the same script error. I uninstall steam but now it says that I don't have the correct version of the emulator...
Has anyone fixed this?
I even set skip checks to false like the guy above, but nothing
