HazzardActual Posted February 11, 2014 Posted February 11, 2014 Hey Fellas So I finally got my new aimtrak board in. It works off of the cab just fine.. But when I tried to hook it up to the arcade I couldnt get the app to run. Well task manager thinks its running but i cant pull it up to do anything with it. i tried uninstall/reinstall and still nothing. The app opens up in task manager and continually eats ram till it crashes or i end its process. Any ideas? hopefully its something simple im over looking.. Thanks in advance for the help dudes.
HazzardActual Posted February 11, 2014 Author Posted February 11, 2014 If anyone has had any issues with 2 aimtrak guns please chime in. I'm looking for hopefully a simple solution
dougan78 Posted February 11, 2014 Posted February 11, 2014 Only issue I have had is the ability to actually order them! Ha ha! Will let you know how I do if I ever get to order 1 let alone 2!
HazzardActual Posted February 11, 2014 Author Posted February 11, 2014 lets hope you have less issues than i have
rfancella Posted February 11, 2014 Posted February 11, 2014 So, to be more specific in your question. It really doesn't have anything to do with 2 guns. The issue is that the AimTrak utility won't open in your version of windows (Win7 64bit). It did before you updated your Anti-Virus? And now it won't. When the utility is run, it churns for a sec but won't open the GUI. The AimTrak.exe shows up in the process list of Task Manager, but the program won't open. Hazzard, is this correct? Thanks, Ron Code Monkey and all around Command Line geek!If you like what someone has said or done for you, be sure and 'Thank' them. And if they changed your life, send them a Beer!
HazzardActual Posted February 11, 2014 Author Posted February 11, 2014 True, However It had been about a week prior to installing antivirus that I had ran the app. Thanks for clearing up my shite post Ron
Polemicist Posted February 11, 2014 Posted February 11, 2014 AV software is a pain. What are you using?
HazzardActual Posted February 11, 2014 Author Posted February 11, 2014 I WAS using Symantec endpoint. got that deleted. no change. Updated/repaired .net framework. nothing. Anything else yous guys can thinks ofs?
dougan78 Posted February 11, 2014 Posted February 11, 2014 Test logging in to your computer with a different user account that is also a local admin to make sure it is not something with the user profile. If it works with a new user account that is a local admin of your computer I would create a new user profile for yourself on your computer. Worth a shot...
HazzardActual Posted February 11, 2014 Author Posted February 11, 2014 tried that too. forgot to mention. also tried uninstall/re install of app on my windows drive and my hyperspin drive. no change
Drakin Posted February 12, 2014 Posted February 12, 2014 It's been awhile sense I've had a problem like this...and it was with the old Aimtrak boards.... The problem I had was that something on the board had gone corrupt. Have you tried to re-flash the firmware on the Aimtrak? I ended up returning the board to Andy and he swapped me a new one. Can you try on another computer? 1. Make sure your leds are pointing at the gun. 2. Make sure your aimtrak pcb eye can see your leds and clear the upper lip of the gun barrel. Then you just shoot each arrow when it stops in the left corner right corner and center bottom. 3. If it does not register still try standing closer/further 4. Still no go make sure your lighting around you is not too bright 5. Also some may need to be manually calibrated through the F2 service menu.
Polemicist Posted February 12, 2014 Posted February 12, 2014 Are you using the correct firmware on your Aimtrack? Check the Ultimarc website.
HazzardActual Posted February 12, 2014 Author Posted February 12, 2014 OK so i pulled the guns from the cab and brought em to my desk to test. weird looks from loads of people who have no idea what im doing..lol. gun 1 is running firm 8.15 and gun 2 is running 9.15. when i tried to update the firm on the 8.15 the app asks me to find the firmware file.... i simply dont have it. its not in the install folder like the directions say CHANGE DEVICE ID Tab On this window you can change the ID of the device to one, two, three or four. This is required to be done if you have more than one device connected. After the device is re-assigned, it will "disappear" from the PC for a few seconds and re-appear as a new device with its new ID. This tab is also used to upgrade firmware. Upgrading Firmware NOTE: There is not at present any later version for the retail guns. Click "Upgrade Firmware" then "OK". The PC will detect a new USB device and a driver will be automatically installed. The upgrade program will start. Click on "Select Firmware File" and navigate to the UFW file. This will normally be contained in the install folder of the program. i dont have a ufw file
joe35car Posted February 12, 2014 Posted February 12, 2014 I have 2 aimtrak guns and they work fine. Just follow the instructions that came with them.
HazzardActual Posted February 12, 2014 Author Posted February 12, 2014 I have 2 aimtrak guns and they work fine. Just follow the instructions that came with them. i wish they would work like yours sir. i really do
joe35car Posted February 12, 2014 Posted February 12, 2014 Did you do everything in the Aim Trak setup guide? Make sure you also go in MAME and configure that also. http://www.arcadeguns.com/download/AimTrakSetupGuide.pdf http://www.ultimarc.com/aimtrak.html
Polemicist Posted February 12, 2014 Posted February 12, 2014 The guy who makes these guns is Andy at Ultimarc. Everyone else is a supplier. He is awesome for customer service. Think it may be that time.
HazzardActual Posted February 12, 2014 Author Posted February 12, 2014 It has unfortunately been that time for a few weeks. been corresponding with him for a while about the bad board/app issues caused by board.. I really would like to try all other options before bothering him about MORE shit. Hes a busy dude.
alcoatjez Posted February 12, 2014 Posted February 12, 2014 Only issue I have had is the ability to actually order them! Ha ha! Will let you know how I do if I ever get to order 1 let alone 2! I pre-ordered 2 of them today
HazzardActual Posted February 13, 2014 Author Posted February 13, 2014 ok so i made a little headway.. when I do either gun by themselves the guns work fine, app works fine. when I plug in both only the most recently plugged in gun works. and the app either wont open like before or if its open just freezes and requires task manager to close it. Is this a problem with the different firmware types? Does anyone know where i can get that specific firmware file? The install for the app is supposed to include a specific firmware file thats not in my install.
Polemicist Posted February 13, 2014 Posted February 13, 2014 Perhaps you need to phone a friend that has a couple of guns and get them to bring them around. Check the firmware on his and then try some testing between them. I did wonder if a mixed firmware issue would cause that.
HazzardActual Posted February 13, 2014 Author Posted February 13, 2014 Perhaps you need to phone a friend that has a couple of guns and get them to bring them around. Check the firmware on his and then try some testing between them. I did wonder if a mixed firmware issue would cause that. ring ring mo fo. I am the only mame arcade enthusiast i know besides you dudes. Everyone i know is strictly old school.
dougan78 Posted April 15, 2014 Posted April 15, 2014 I just got a second gun and found this to fix my issue and this may help others: 1. Plug only 1 gun in. 2. Set the gun id to gun 2 if it is your second gun. (it will disappear and come back as device 2). 3. Plug in second gun. This gun will be gun id 1 or device 1 now. I had an issue where second gun would not be detected to the fix for that was: Plug both guns in, then go to USB devices in device manager and delete all of your USB composite devices out. Unplug both guns and plug them in again. Then only plug 1 gun in and follow the above 3 steps. If you run into calibration issues reset calibration to defaults on the main page and click apply for each device then test again. Hope this helps others with aimtraks. I have it working now and now for some Duck Hunting Love the Sammy arcade hunting games.
