New Bezel Art Location And Approval
rfancella
What aspect ratio are you using? (Your screen width devided by your screen height)
278 members have voted
  1. 1. What aspect ratio are you using? (Your screen width devided by your screen height)
    • 4x3 (Your Aspect = 1.33333)
    • 16x9 (Your Aspect = 1.77777)
    • 16x10 (Your Aspect = 1.6)
  • Replies 988
Would it be ok if I took this bezel and added it to the _HyperLaunch Media folder on the FTP?
I do like it as well!!
Thanks,
Ron
Glad you like it.
I was going to post it for approval once I got a little feedback on it. I didn't assume it would be good enough first pass to just go into the approval queue. :)
I just posted a revised version above so if someone with scoring enabled could test it.. we can call this one done and I'll submit it.
Then onto Space Ace which I think will run into the same issues because of the arches on top left and right (which i kind of like) but I can do 2 versions of that. One to accommodate scores and one for me. ;)
* I posted 2 DL versions to FTP for approval
i did one like this...but for a theme..
and it used the actual arch walkway for the video :}
cool my man!
thanks!
snapshot attached :}
I don't run scoring in daphne but I can adjust this bezel to remove the brick that's obscuring the PP1 score. give me a minute...
Meanwhile here's the Space Ace one I just did but haven't tried yet.
[ATTACH=CONFIG]46695[/ATTACH]
Nice! I don't see the png file in your folder or in the HyperLaunch Media folder either. Can you upload it so I can test??
Thanks,
Ron
You might have beat me to it but they're all there now including this one I just did.. Not much to work with in terms of DLII artwork but the Garden of Eden art felt like it would work well.
I'm trying to keep any actual characters out of these because there's so many different scenes, unlike raster games.
Hopefully some of the video will show through the clouds on the bottom which I thought might be cool. Again, haven't tested it and might need to pull off the arches on top corners for people who run scoring.
[ATTACH=CONFIG]46697[/ATTACH]
All I see in there is the ini and the background file. I do now see the lair2 stuff. ;)
[EDIT]
Maybe I was not clear at all. I was looking for the ace png file.
There is no special configuration. You can use the module defaults just fine. But you must use the module with bezel support. You must have Bezels enabled in HLHQ also.
Can you post a screen shot of it messed up? Also, you could post your HyperLaunch.log with your Logging Level set to Troubleshooting.
Thanks,
Ron
Here is what i got when launching daphne bezelpost-1651-142870654594_thumb.jpg
Tried to change options on module but no success
https://www.dropbox.com/s/c31rhnpsx41fttc/HyperLaunch.log?dl=0
Hyperalaunch log above
[EDIT]
wooops.. i forgot to upload that one. it's there now.
and while you're in there... feel free to grab the DL2 alternate one I just did. Needs an .ini though since I moved the screen a little.
Here is what i got when launching daphne bezel[ATTACH=CONFIG]46699[/ATTACH][ATTACH=CONFIG]46700[/ATTACH]
Are those the whole screen? So you are only seeing a quarter of the screen?
Or is it that the emulator window is cutting off part of the bezel?
Thanks,
Ron
[ATTACH=CONFIG]46701[/ATTACH]
Got it. I will upload all these to /HyperLaunch Media/Bezels/Submissions Open/kcorcoran
for others to test.
Thank you for your submissions!!!
Thanks,
Ron
Thanks,
Ron
Yes...... this image shows in the center of the screen (1/4 of the game in the center of the display); the surronding is black
Can you post your Daphne.akh?? i think mine is wrong.......got it from noshgar........ but i saw that you made de dapnhe singe
Yepper, both my Daphne and Daphne Singe modules are in my signature. Along with all the other modules I have edited. ;)
Thanks,
Ron
Thanks,
Ron
Ohh man.......it was the module........ even your moduler from your ftp directory didnt work right.
But the module from your signature worked!! thanks man.......now i can use this new bezels!!
good job bsymon!
Made a new Bezel. Put in submission open.
Sweet! Thank you!
So, this irem? Wonder if they bought the rights to resell the games, or are they all in the public domain now?
Thanks,
Ron
Guys,
Grizz is a mad-man on a mission. Here is another submission in all three aspect ratios.
Acorn BBC Micro:
Thanks for you hard work Grizz!
Thanks,
Ron
This one is on behalf of bsymon from this thread, I've uploaded it to submissions open.
All moved and checked. Now in Submissions Final and ready for review!
Thanks guys for your submissions!!
Thanks,
Ron
Gents,
Here is an Amstrad GX4000 bezel in all three aspect ratios! Thanks again Grizz!!
Amstrad GX4000:
Thanks,
Ron
Hello,
A final installment from Grizz.
Atari 8-Bit:
Thank you Grizz for your contributions!
Thanks,
Ron
Hello,
Atari 8-Bit:
[ATTACH=CONFIG]47703[/ATTACH]
Thanks,
Ron
Atari 800... wich emulator? Mess??... i use atari800 and dont have bezel support..
Alex,
MESS will work, but I like to use Atari800. ;)
Thanks,
Ron
Alex,
Thanks,
Ron
Ok... using atari 800 because mess dont run all games.. i tried to add bezel support to atari800.. no luck!
LOL... Had this modified module setting around. Made a couple tweaks to it and posted over on HyperLaunch.net. ;)
You can also find a link here: http://www.hyperspin-fe.com/forum/showthread.php?31302-Adding-bezel-support-A-step-by-step-Walkthrough&p=353607&viewfull=1#post353607
It needs some more people to test it for me... ;)
Thanks,
Ron
